PaulTurner911 Code
PostPosted: Wed Jun 19, 2013 7:35 pm
I went ahead and put the night mode in thinking it may work, but I was wrong....
Looking forward to hearing what you guys have to say :)
PostPosted: Wed Jun 19, 2013 7:51 pm
Paul,
Thats not from the latest code....i know because i streamlined your feeding mode code and its thats not there, plus you didn't post the night mode portion.
And we need roberto to add custom mode to the portal *cough* *cough* otherwise you'll still have to activate the custom mode from memory manually..
I'll see what i can throw together tomorrow...
PostPosted: Wed Jun 19, 2013 8:05 pm
You are right! I grabbed that from my OP in the thread...
Its pretty cool to see the DC Pump on the dashboard, but it doesnt show what percentage it is running at in that section, it does show above in the PWM though.
Last edited by Paulturner911 on Mon Jun 24, 2013 11:42 am, edited 1 time in total.
PostPosted: Wed Jun 19, 2013 8:09 pm
Removed to clean up this thread
Last edited by Paulturner911 on Mon Jun 24, 2013 11:43 am, edited 1 time in total.
PostPosted: Thu Jun 20, 2013 8:01 pm
Try this:
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.DayLights( Port1 ); // Return Pump
ReefAngel.StandardFan( Port2 ); // Canopy Fans
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
//Port 6 NOT USED (Possibly Skimmer)
ReefAngel.DayLights( Port7 ); // MH 1
ReefAngel.DayLights( Port8 ); //MH 2
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 50sec @ 8pm-12pm (every 15min)
if (hour() >=20 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<50);
//Kalk Stir 12pm-1pm
if (hour() >=12 & hour() < 13)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port5);
///// Place your custom code below here
static int rmode;
byte modes[] = { ReefCrest, TidalSwell, ShortPulse, NutrientTransport };
changeMode=false;
// Are we in custom mode
if (ReefAngel.DCPump.Mode==11) {
  ReefAngel.DCPump.UseMemory=false; // We are going to override the memory (which is currently set to 11..)
  ReefAngel.DCPump.UseMemory=true;
static unsigned long feeding;
if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
feeding = now();
// keep wavemakers off for first 30 minutes of feeding mode.
if (now()-feeding<=1800) { // 30 minutes after
ReefAngel.DCPump.Speed=0;
} else if (now()-feeding<=(1800+3600)) { // // First 30 minutes pump is off.. next 60 minutes will be in NTM
// Add night mode (constant 30%)
if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY >=81000) { // Time is before 8:30am and after 10:30pm
  ReefAngel.DCPump.Speed=30;
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
PostPosted: Thu Jun 20, 2013 9:20 pm
Thank YOU SIR!!!
In order to add and remove modes, do I simply type and or remove them in the following section?
byte modes[] = { ReefCrest, TidalSwell, ShortPulse, xxxxxxxx, NutrientTransport };
Could you give a quick explanation of what tidal swell is?
PostPosted: Fri Jun 21, 2013 1:39 am
Its cool. I like it. Look at ecotech manual.
PostPosted: Fri Jun 21, 2013 5:54 pm
I'm having an issue with the feedmode, the wp is not turning to NTM at 1800 on the countdown. It's not turning back on once the 3600s times out either. I'm not sure the night mode is activating either, I uploaded late last night and it didn't run at 30.
PostPosted: Fri Jun 21, 2013 11:35 pm
Let me know what it did. I'll look again at the code...
PostPosted: Sun Jun 23, 2013 11:00 am
Its not activating NTP at 1800 and once the feedmode is complete (3600) the WP pump stays off. Basically once the feed mode is activate it turns the WP pump off until I goto the portal and select a mode other than NTM.
Return to My PDE/INO file
