PaulTurner911 Code
PostPosted: Sun Jun 23, 2013 4:33 pm
Paul I had an error in the feeding mode section that I fixed in my post above. Can you try it and let me know. If it doesn't work, I'll have to relook at the logic, but the error I had could have caused it to f up :)
PostPosted: Wed Jun 26, 2013 6:06 pm
I'm having the same results with the newer code. The night mode doesn't activate and once feedmode has been activated the wp never resumes, it in theory should activate NTM at 1800s on the feedmode countdown. I'd appreciate any help, no rush!!!
PostPosted: Wed Jun 26, 2013 6:57 pm
Hmmm
PostPosted: Thu Jun 27, 2013 5:41 am
I see where I went wrong. When we get to NTM mode we never reset the speed. Lots of other issues. I'm fairly confident in this rework. Please give it a try.
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.DayLights( Port1 ); // Return Pump
ReefAngel.StandardFan( Port2 ); // Canopy Fans
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
//Port 6 NOT USED (Possibly Skimmer)
ReefAngel.DayLights( Port7 ); // MH 1
ReefAngel.DayLights( Port8 ); //MH 2
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 50sec @ 8pm-12pm (every 15min)
if (hour() >=20 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<50);
//Kalk Stir 12pm-1pm
if (hour() >=12 & hour() < 13)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port5);
///// Place your custom code below here
static int rmode;
byte modes[] = { ReefCrest, TidalSwell, ShortPulse, NutrientTransport };
changeMode=false;
if (now()-feeding<=1800) {
  // 30 minutes after feeding mode. Pump is off
  ReefAngel.DCPump.Speed=ReefAngel.DCPump.FeedingSpeed;
} else if (now()-feeding<=(1800+3600)) {
  // First 30 minutes pump is off, Next 60 is NTM
  ReefAngel.DCPump.Speed=InternalMemory.DCPumpSpeed_read(); // Resume previous speed
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Speed=30;
  ReefAngel.DCPump.Mode=modes[rmode];  // Set the mode to the random mode
static unsigned long feeding;
if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
feeding = now();
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
PostPosted: Fri Jun 28, 2013 8:23 am
Awesome! Ill try tonight and let you know! I really appreciate the help Lee.
Thank You
PostPosted: Sat Jun 29, 2013 4:53 pm
I had to move
feeding = now();
ABOVE
b/c I was getting an error for feeding being undefined, when I switched them it worked.
However I am in the same boat, or even worse with the NTP/Feedmode. It still does not activate at the 1800s mark nor after feedmode has timed out. The only difference is before I could go in the portal and activate any mode, now it is unresponsive. Meaning the WP will not run in any mode right now.....Please help :)
PostPosted: Sat Jun 29, 2013 7:39 pm
Well go back to your older code..gonna take me a while to figure it out.
PostPosted: Sat Jun 29, 2013 8:08 pm
It eventually turned back on, just not in or right after feedmode. I looked in the portal after feedmode timed out and it read NTM instead of custom, BUT it read a speed of ZERO at that time. Now its seems to be running "night mode, in NTM" at 30 in stead of nightmode constant 30....its pulsing. Keep me posted, Thanks
PostPosted: Sat Jun 29, 2013 9:08 pm
Oh ok thats cool..we can figure some of that out...
Also just an fyi can you confirm your feeding mode time...how long your return pump is off for..
Right now it goes:
Feeding mode start 00:00
Feeding mode finish 15:00???
Wavemaker at 0 till 45:00
Ntm at usual speed till 1:45
The extended wavemaker off used to be 30 minutes total but now its 45 minutes.. I can fix that but just making sure you are expecting the right thing.
PostPosted: Sat Jun 29, 2013 10:17 pm
So it looks like you reset your controller at around 3:30..mode was in NTM from that point on..which is part of your random rotation... At about 7:05 you went into feeding mode. Your speed was at 0 and mode still at NTM... until 8:14 when it went back to 60. You were still in NTM mode...now forced (ignoring custom mode) until 10:30 when night mode kicked in staying in NTM at 30%.
This is based on the charts below. Keep in mind 0 values do not show on the graph...but note the gap between 7:04 and 8:14.
Speed
status/chart.aspx?id=Paulturner911&filter=DCS
Mode
status/chart.aspx?id=Paulturner911&filter=DCM
So it looks like everything is working except the following which I've fixed below:
Change extension of feeding mode to 15 minutes so total duration is 30. Feel free to make the 900 back to 1800.
Fixed the timer issue you had as well...sorry bout that one.
Force night mode to Constant instead of whatever is default mode (NTM was today's mode.)
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
changeMode=false;
feeding = now();
if (now()-feeding<=900) {
  ReefAngel.DCPump.Speed=0;
} else if (now()-feeding<=(900+3600)) {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Return to My PDE/INO file
Users browsing this forum: Google [Bot] and 2 guests
