PaulTurner911 Code
PostPosted: Thu Jul 25, 2013 6:06 am
lnevo wrote:
lnevo wrote:
Changed extension of feeding mode to 15 minutes so total duration is 30. Feel free to make the 900 back to 1800.
Fixed the timer issue you had as well...sorry bout that one.
Force night mode to Constant instead of whatever is default mode (NTM was today's mode.)
Ok, so we changed to 1800 to 900 but never changed the comment line?
PostPosted: Thu Jul 25, 2013 7:51 am
Correct. Was trying to match up with what you were trying to do. I didn't change the comments.
PostPosted: Thu Jul 25, 2013 7:55 am
Thanks Bud!!!!
PostPosted: Tue Jul 30, 2013 6:42 pm
Any chance you had time to revise the code and implement the boolean?
PostPosted: Tue Jul 30, 2013 7:28 pm
Sorry i haven't yet, it fell off my radar. Give me a bit still, been super busy and tomorrow I am picking up my new mandarin! Nice and fat and trained to eat frozen! So I'll be busy holding the fish bag on the train home :)
PostPosted: Wed Jul 31, 2013 7:09 am
Thanks! No rush by any means.
I guess Ive been lucky, my mandrin eats ANYTHING!!
TRAIN?!? Where do you live?
PostPosted: Wed Jul 31, 2013 9:36 am
Long Island Rail Road to manhattan every day. Fun. Not.
PostPosted: Thu Aug 01, 2013 3:04 pm
Ok, so this should do...
0:00 Feeding Mode Start (all pumps off)
0:15 Smart_NTM
0:30 Feeding Mode End (return pump on)
1:15 Smart_NTM end / Resume previous mode
Good Luck, keep me posted.
static boolean feedingStarted;
static unsigned long feeding;
if (ReefAngel.DisplayedMenu==FEEDING_MODE && !feedingStarted) {
    feedingStarted=true;
    feeding = now();
  feedingStarted=false;
// Feeding Mode is 30 minutes
if (now()-feeding<=900) {
  // First 15 minutes after feeding mode. Pump is off
  ReefAngel.DCPump.Speed=0;
} else if (now()-feeding<=(900+3600)) {
  // NTM after 15 minutes for the next 60 minutes
  ReefAngel.DCPump.Speed=InternalMemory.DCPumpSpeed_read(); // Resume previous speed
PostPosted: Thu Aug 01, 2013 3:19 pm
Im getting an error 'redeclaration of long unsinged in feeding.
Here is my complete code
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.DayLights( Port1 ); // Return Pump
ReefAngel.StandardFan( Port2 ); // Canopy Fans
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
//Port 6 NOT USED (Possibly Skimmer)
ReefAngel.DayLights( Port7 ); // MH 1
ReefAngel.DayLights( Port8 ); //MH 2
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 60sec @ 11pm-12pm (every 15min)
if (hour() >=23 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<60);
//Kalk Stir 12pm-1pm
if (hour() >=12 & hour() < 13)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port5);
///// Place your custom code below here
static int rmode;
byte modes[] = { ReefCrest, TidalSwell, ShortPulse, NutrientTransport };
changeMode=false;
if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
feeding = now();
    feeding = now();
  // Night mode (go to 30%)
  ReefAngel.DCPump.Speed=30;
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
PostPosted: Thu Aug 01, 2013 3:21 pm
You didn't delete this part...
feeding=now();
Return to My PDE/INO file
