ATO port stuck on! Flooded my sump =(
PostPosted: Sun Jun 30, 2013 7:15 pm
by neuro
I updated my libraries to the latest, but my subsequent code wouldn't fit, so I downgraded the libraries to 1.03... which I assume was the original version I had.
So after I downgrade the libraries and uploaded my minor change in code, My top off port came on and flooded my sump. I didn't change any of my ATO code. I'm not sure why it's always ON now. I'm using a single ATO (low) and using the ATO high as backup. Both show as red dots in my portal page, but my ATO port is green (on).
Can anyone tell me what I'm doing wrong?
// ports by name
#define halide 1
#define actinics 2
#define mainPump 3
#define skimmer 4
#define pump1 5
#define pump2 6
#define doser1 7
#define doser2 8
#define ato Box1_Port1
#define gfo Box1_Port2
#define unused3 Box1_Port3
#define unused4 Box1_Port4
#define pump3 Box1_Port5
#define pump4 Box1_Port6
#define heater1 Box1_Port7
#define heater2 Box1_Port8
#define halide 1
#define actinics 2
#define unused3 3
#define unused4 4
#define pump1 5 // off
#define pump4 6 // off
#define doser1 7
#define doser2 8
#define heater1 Box1_Port2
#define skimmer Box1_Port3
#define heater2 Box1_Port4
#define pump2 Box1_Port5
#define pump3 Box1_Port6
#define gfo Box1_Port7
#define mainPump Box1_Port8
// mainPump, skimmer, pump2, pump3, ato, gfo
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port3Bit | Port7Bit | Port8Bit;
// mainPump, Skimmer, all 4 pumps, all 2 dosers, ato, gfo
ReefAngel.WaterChangePorts = Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit;
// ReefAngel.Relay.On( mainPump );
ReefAngel.Relay.On( skimmer );
ReefAngel.Relay.Off( pump1 );
ReefAngel.Relay.On( pump2 );
ReefAngel.Relay.On( pump3 );
ReefAngel.Relay.Off( pump4 );
ReefAngel.Relay.On( gfo );
ReefAngel.Relay.Off( unused3 );
ReefAngel.Relay.Off( unused4 );
ReefAngel.DayLights( halide );
ReefAngel.ActinicLights( actinics );
ReefAngel.DosingPumpRepeat1( doser1 );
ReefAngel.DosingPumpRepeat2( doser2 );
// ReefAngel.StandardATO( ato );
ReefAngel.StandardHeater( heater1 );
ReefAngel.StandardHeater( heater2 );
// set single ato
ReefAngel.SingleATO(true,ato,60,0);
if (ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(ato);
ReefAngel.Relay.DelayedOn( skimmer );
ReefAngel.Relay.DelayedOn( ato );
ReefAngel.Relay.DelayedOn( gfo );
ReefAngel.Portal( "neuro" );
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 62, ReefAngel.Params,
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 107, TempRelay );
Re: ATO port stuck on! Flooded my sump =(
PostPosted: Sun Jun 30, 2013 7:25 pm
You should remove this:
This line will turn on your ato port after the delay and it will never turn off.
PostPosted: Sun Jun 30, 2013 7:32 pm
by neuro
rimai wrote:You should remove this:
ahh jeez ok. thanks robert.
is there a way for me to delay the ATO high/low for maybe about 5 minutes until it can check itself after a water change? i just want to be sure the level is OK right after a change
PostPosted: Sun Jun 30, 2013 7:39 pm
Latest version would make this simpler for you if you can fit your code with it.
This is what you would need:
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) bitClear(ReefAngel.Relay.RelayMaskOffE[0],0);
This would apply mask off on the ato port and you can clear the override when you are done with the visual check.
PostPosted: Sun Jun 30, 2013 7:42 pm
by neuro
thanks roberto!!!
