new reef angel board code not uploading
PostPosted: Fri Aug 09, 2013 12:36 pm
by simplefound
Hi all i got a new board today as old one had died im trying to upload this code (pasted under) and i keep getting error uploading
any help will be appreciated
thanks
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port2Bit;
InternalMemory.OverheatTemp_write( 950 );
ReefAngel.StandardATO( Port1,60 );
ReefAngel.StandardLights( Port2,10,45,23,40 );
ReefAngel.StandardLights( Port3,23,0,11,0 );
ReefAngel.StandardFan( Port4,793,797 );
ReefAngel.WavemakerRandom( Port6,60,100 );
ReefAngel.StandardHeater( Port7,788,792 );
ReefAngel.PWM.SetDaylight( PWMSlope(12,0,22,30,0,100,60,0) );
ReefAngel.PWM.SetActinic( PWMSlope(11,0,23,30,0,100,60,0) );
Re: new reef angel board code not uploading
PostPosted: Fri Aug 09, 2013 1:00 pm
What is the error you are getting?
Did you check if you have the correct board and serial port?
Sent from my SPH-L710 using Tapatalk 4
PostPosted: Fri Aug 09, 2013 1:19 pm
by simplefound
thought it might be something simple, i had the wrong board selected
What do i add to the code to be able to edit the time on the controller menu
Simon
PostPosted: Fri Aug 09, 2013 3:44 pm
Add this to your setup():
ReefAngel.AddDateTimeMenu();
