code problem after updating from old libraries
PostPosted: Sun Aug 18, 2013 1:47 pm
Hey,
It's been a loooooooong time since I updated my libraries, just went from 1.04 to 1.09. I ran the wizard to get started again, then tried to cut and paste my old custom screen work into the new ino file. In trying to compile, I get the error:
In function "ReefAngelClass::ExitMenu()
Documents\Arduino\libraries\ReefAngel/ReefAngel.ccp:4237;
undefined reference to "DrawCustomGraph()"
ReefAngel\ReefAngel.cpp.o: In function ReefAngelClass:: Showinterface
Documents\Arduion|Libraries|ReefAngel1\Reefangel.cpp:3889;
attached is the code...what am I doing wrong? I assume it is something from having used such old code for a while and not keeping up with how things have been changing...
Rob
//-------------------------------------------------------------------------- Screen set-up ---------------------------------------------------------------------------------
#define NumScreens 4
int ScreenID=0;
  // Refresh is called at start of ShowInterface.
// ShowInterface calls DrawCustomMain
switch (ScreenID)
//---------------------------------------------------------------------------- Screen Code 1--------------------------------------------------------------------------------
case 0://temps and ph
//Top Banner
  ReefAngel.LCD.DrawDate(6, 120);
  ReefAngel.LCD.Clear(COLOR_MAROON, 1,116, 132, 116);
  ReefAngel.LCD.DrawLargeText(COLOR_WHITE, COLOR_OLIVEDRAB,  4, 4 , "ROB'S REEF ANGEL");
  ReefAngel.LCD.Clear(COLOR_MAROON, 1, 13, 132, 13);
  ReefAngel.LCD.Clear(COLOR_MAROON, 10, 42, 119, 42);
  ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, COLOR_WHITE, 6, 17, "Display");
  ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, COLOR_WHITE, 18, 29, "Tank");
  char text[7];
  ReefAngel.LCD.DrawHugeText(COLOR_GOLDENROD, DefaultBGColor, 65, 19, text);
  ReefAngel.LCD.DrawLargeText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 10, 52, "pH:");
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 40, 52, text);
   ReefAngel.LCD.DrawLargeText(COLOR_RED, COLOR_WHITE,59,70,"Frag:");
   ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
   ReefAngel.LCD.DrawLargeText(COLOR_RED, DefaultBGColor, 99, 70, text);
  ReefAngel.LCD.DrawLargeText(COLOR_DARKORCHID, COLOR_WHITE,59,90,"Room:");
  ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, DefaultBGColor, 99, 90, text);
 break;
//---------------------------------------------------------------------------- Screen Code 2---------------------------------------------------------------------------------
case 1:// outlet box
 ReefAngel.LCD.DrawLargeText(COLOR_DARKOLIVEGREEN, COLOR_WHITE, 4, 4 , "ROB'S REEF ANGEL");
   ReefAngel.LCD.Clear(109, 0, 29, 131, 38);
   ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, COLOR_DIMGREY, 28, 30, "OUTLET BOX");
   //ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor, 40, 95, "RED = OFF");
   //ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 35, 105, "BLACK = ON");
     // int t=WMRTimer-now();
      //if (t>=0)
     // ReefAngel.LCD.Clear(255,90,95,110,115);
     // ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 10, 95, "WAVE TIMER:");//display the timer for the wavemaker
    //ReefAngel.LCD.DrawText(APColor, COLOR_WHITE,90,95,t);
  ReefAngel.LCD.DrawText(COLOR_NAVY,DefaultBGColor,80,47,"2");
  ReefAngel.LCD.DrawText(COLOR_NAVY,DefaultBGColor,70,47,"4");
  ReefAngel.LCD.DrawText(COLOR_NAVY,DefaultBGColor,60,47,"6");
  ReefAngel.LCD.DrawText(COLOR_NAVY,DefaultBGColor,50,47,"8");
  ReefAngel.LCD.DrawText(COLOR_NAVY,DefaultBGColor,80,80,"1");
  ReefAngel.LCD.DrawText(COLOR_NAVY,DefaultBGColor,70,80,"3");
  ReefAngel.LCD.DrawText(COLOR_NAVY,DefaultBGColor,60,80,"5");
  ReefAngel.LCD.DrawText(COLOR_NAVY,DefaultBGColor,50,80,"7");
  ReefAngel.LCD.DrawCircleOutletBoxHorizontal(47, 56, TempRelay);
 break;
//----------------------------------------------Screen Code 3-------
case 2://Moon %, phase when code is fixed
ReefAngel.LCD.DrawHugeText(COLOR_TEAL, COLOR_WHITE, 8, 39,"Moon");
ReefAngel.LCD.DrawHugeText(COLOR_TEAL, COLOR_WHITE, 8, 62,"Phase:");
           ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),COLOR_TEAL, 95, 45,1);
             ReefAngel.LCD.DrawHugeText(COLOR_BLACK, COLOR_WHITE, 115, 39, "%");
             ReefAngel.LCD.DrawLargeText(0,255,11,85,MoonPhaseLabel());
break;
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
    ReefAngel.ActinicLights( Port2 );
    ReefAngel.DayLights( Port3 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.Wavemaker1( Port5 );
    ReefAngel.StandardFan( Port8 );
      if (ReefAngel.Joystick.IsLeft())
ScreenID--;
if (ReefAngel.Joystick.IsRight())
ScreenID++;
    ReefAngel.Portal( "psyrob" );
Rob
PostPosted: Sun Aug 18, 2013 10:04 pm
You missed this:
PostPosted: Mon Aug 19, 2013 9:43 am
Doh!!! Thanks Roberto... :)
Return to My PDE/INO file
