Mike's RSM 500 Code
You aren't turning anything back on when the power comes up. You can either explicitly add it, or move all your on statements from setup() into loop()
Hmm ok, I will have to look into it later. Not sure I need my return pump running. I will need to do a test and see how much it uses up battery life.
On another note I woke up this am to find my tank in a power lost state...Temps dropped a few degrees. I also have a ton of power restored emails. I uploaded my previous code for now, since I have to leave for work. |
It sounds like your either having bus lock issues or you have some bad connections based on this and previous issue
OK? What would cause that and how do I fix?
It's been two months since I've updated the code, but I really need to figure out the power restored email thing. I have gotten so many over the last 18hrs (after water change). I will post my updated code tonight (going back to power outage delay timer) to see if the emails stop.
No change, still getting power restored emails every few minutes. Did a full controller reboot for good measure and no change.
Put Lee's check power code back in and did a power failure test. No power failure email. Relays did go off, but then came back on, while still on the ups battery! Now the flowpumps are in an off state (even after a full power reset on the UPS). I am not sure what's going on here. Help!
Can anyone help me figure out why the power restore code is emailing me when there isn't any power change occurring?
So I was trying to get a second heater code in place that uses T3 probe, but I am getting this compile error below. I am stuck. Any suggestions?
