Mike's RSM 500 Code
Re: Mike's RSM 500 Code
You must also remove the Ecotech RF module before you can upload or it will thing the serial data is supposed to be sent to the vortech drivers.
It's been awhile since I have needed to update code, but the power outage function wasn't working.
Not sure why but the power outage was below "// This should always be the last line" When I moved it up I couldn't compile. What did I do wrong here?
Getting the following compile error at: void CheckPower() {
updated_code.cpp: In function 'void loop()':
updated_code:165: error: a function-definition is not allowed here before '{' token
updated_code:257: error: expected `}' at end of input
// Define Named Relay Ports
#define Flow1 1
#define Flow2 2
#define Flow3 3
#define Return 4
#define Skimmer 5
#define VortechL 6
#define VortechR 7
#define HeaterDisp 8
#define CenterT5 Box1_Port1
#define FrontT5 Box1_Port2
#define BackT5 Box1_Port3
#define MoonLED Box1_Port4
#define Unused Box1_Port5
#define Reactor Box1_Port6
#define Fan Box1_Port7
#define HeaterSump Box1_Port8
// Custom Main
byte x,y;
////// Setup Begin
// Controlled Modes Toggled Ports
ReefAngel.FeedingModePortsE[0] = Port7Bit | Port8Bit; //Fan,HeaterSump
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit; // Flow1-3,Return,Skimmer,HeaterDisp
ReefAngel.WaterChangePortsE[0] = Port2Bit | Port3Bit | Port6Bit | Port7Bit | Port8Bit; //Front+BackT5,Reactor,Fan,HeaterSump
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port3Bit; //Center+Front+BackT5
// Water Temperature Settings & Overheat
ReefAngel.OverheatShutoffPorts = Port8Bit; //HeaterDisp
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit | Port3Bit | Port8Bit; //Front+BackT5,HeaterSump
ReefAngel.Relay.On( Flow1 );
ReefAngel.Relay.On( Flow2 );
ReefAngel.Relay.On( Flow3 );
ReefAngel.Relay.On( Return );
ReefAngel.Relay.On( VortechL );
ReefAngel.Relay.On( VortechR );
ReefAngel.Relay.On( Reactor );
// Ports that are always off
ReefAngel.Relay.Off(Unused);
//5 second timer for power outage detection
ReefAngel.Timer[1].SetInterval(5);
////// Setup End
////// Loop Begin
// Ports that are Delayed
ReefAngel.Relay.DelayedOn( Skimmer,2 );
// Temperature Control
ReefAngel.StandardHeater( HeaterSump,770,773 );
ReefAngel.StandardHeater( HeaterDisp,767,770 );
ReefAngel.StandardFan( Fan,810,814 );
// T5 Light Schedule
ReefAngel.StandardLights( CenterT5,9,0,20,0 );
if (hour()==14 && minute()>=0 && minute()<=59) ReefAngel.Relay.Off(CenterT5);
ReefAngel.StandardLights( FrontT5,10,0,18,0 );
if (hour()==15 && minute()>=0 && minute()<=29) ReefAngel.Relay.Off(FrontT5);
ReefAngel.StandardLights( BackT5,11,0,19,0 );
if (hour()==16 && minute()>=0 && minute()<=29) ReefAngel.Relay.Off(BackT5);
// RSM MoonLED Schedule
if (hour()>=6 && hour()<=8) ReefAngel.StandardLights( MoonLED,6,0,8,59 ); //Morning
else if(hour()>=20 && hour()<=23) ReefAngel.StandardLights( MoonLED,20,0,23,45 ); //Evening
else if(hour()>=23 || hour()<=4) if (MoonPhase()>=90) ReefAngel.StandardLights( MoonLED,23,46,4,0 ); //Full Moon
// Moonphase LED Schedule
if (hour()>=20 || hour()<4)
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
//T5 Light Off Variable
//if (hour()==12 && minute()>=30 && minute()<=44) ReefAngel.Relay.Off(CenterT5);
//if (hour()==12 && minute()>=15 && minute()<=29) ReefAngel.Relay.Off(FrontT5);
//if (hour()==16 && minute()>=15 && minute()<=29) ReefAngel.Relay.Off(FrontT5);
//if (hour()==13 && minute()>=45 && minute()<=59) ReefAngel.Relay.Off(BackT5);
//if (hour()==16 && minute()>=45 && minute()<=59) ReefAngel.Relay.Off(BackT5);
// Vortech MP40 | Constant | Lagoon | ReefCrest | ShortWave 1=10ms | LongWave 1=1s | NutrientTransport 1=10ms | TidalSwell
if (ReefAngel.DisplayedMenu!=FEEDING_MODE || ReefAngel.DisplayedMenu!=WATERCHANGE_MODE)
if (hour()>=16 && hour()<=19)
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(LongWave,50,30);
else if (hour()>=20 || hour()<7)
ReefAngel.RF.SetMode(Lagoon,25,0);
ReefAngel.RF.UseMemory=true;
// When Return pump is off so is Skimmer
if (!ReefAngel.Relay.Status(Return)) {
ReefAngel.Relay.Override(Skimmer,0);
void CheckPower() {
static boolean PowerOutage=false;
static boolean DelayedPowerOutage=false;
// Power Outage - Leave Single Flow Pump Powered
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY)) PowerOutage=true; //Expansion Relay 1 has lost power
if (!PowerOutage)
ReefAngel.Timer[1].Start();
if (ReefAngel.Timer[1].IsTriggered())
DelayedPowerOutage=true;
if (DelayedPowerOutage)
ReefAngel.Relay.Off (Flow1);
ReefAngel.Relay.Off (Flow2);
ReefAngel.Relay.Off (Flow3);
ReefAngel.Relay.Off (Return);
ReefAngel.Relay.Off (Skimmer);
ReefAngel.Relay.Off (HeaterDisp);
//set vortechs to low power
// Power Restored
if (PowerOutage && ReefAngel.Relay.IsRelayPresent(EXP1_RELAY))
PowerOutage=false;
LastStart=now();
ReefAngel.Portal( "*****","*****" );
////// Loop End
////// Custom Main Begin
// Display Date & Time
ReefAngel.LCD.DrawDate(5, 2);
// Display Water Temp Value
ReefAngel.LCD.DrawHugeNumbers(COLOR_CRIMSON, 255, 5, 14, text);
// Display pH Text
ReefAngel.LCD.DrawText(COLOR_INDIGO,255,80,14,"pH");
// Display pH Value
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 95, 14, text, Num8x16);
// Display Room Temp Text
ReefAngel.LCD.DrawText(COLOR_ROYALBLUE,255,80,24,"Rm");
// Display Room Temp Value
ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_ROYALBLUE, 255, 95, 24, text, Num8x16);
// Vortech Info
//Moon Phase
ReefAngel.LCD.Clear(DefaultBGColor,5,88,95,95);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,5,88,MoonPhaseLabel());
//Dimmable Moon LEDs
ReefAngel.LCD.DrawText(COLOR_NAVY,255,5,98, "MoonLEDs:");
ReefAngel.LCD.Clear(DefaultBGColor,59,98,75,106);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,59,98, ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,75,98, "%");
// Display Main Relay Box
ReefAngel.LCD.DrawOutletBox( 2, 107, TempRelay );
// Display Expansion Relay Box 1
ReefAngel.LCD.DrawOutletBox( 2, 119, TempRelay );
////// Custom Main End
////// Custom Graph Begin
///// Custom Graph End
you cannot define a function within another function. your checkpower function is being defined inside the loop function code.
move it out and that should help.
Sent from my Nexus 7
I went ahead and updated your code and moved everything around how it should be. I test compiled and everything compiles just fine. I did not upload the code to a controller though.
The formatting is updated too. You will also need to put your portal information back in since you removed it before.
Hope this helps.
Hope this helps.
#define Flow1 1
#define Flow2 2
#define Flow3 3
#define Return 4
#define Skimmer 5
#define VortechL 6
#define VortechR 7
// Custom Main
byte x, y;
////// Setup Begin
ReefAngel.Relay.Off( Unused );
ReefAngel.Timer[1].SetInterval( 5 );
////// Setup End
////// Loop Begin
ReefAngel.Relay.DelayedOn( Skimmer, 2 );
ReefAngel.StandardHeater( HeaterSump, 770, 773 );
ReefAngel.StandardHeater( HeaterDisp, 767, 770 );
ReefAngel.StandardFan( Fan, 810, 814 );
ReefAngel.StandardLights( CenterT5, 9, 0, 20, 0 );
if ( hour() == 14 && minute() >= 0 && minute() <= 59 ) {
ReefAngel.Relay.Off( CenterT5 );
ReefAngel.StandardLights( FrontT5, 10, 0, 18, 0 );
if ( hour() == 15 && minute() >= 0 && minute() <= 29 ) {
ReefAngel.Relay.Off( FrontT5 );
ReefAngel.StandardLights( BackT5, 11, 0, 19, 0 );
if ( hour() == 16 && minute() >= 0 && minute() <= 29 ) {
ReefAngel.Relay.Off( BackT5 );
if ( hour() >= 6 && hour() <= 8 ) {
ReefAngel.StandardLights( MoonLED, 6, 0, 8, 59 ); //Morning
} else if( hour() >= 20 && hour() <= 23 ) {
ReefAngel.StandardLights( MoonLED, 20, 0, 23, 45 ); //Evening
} else if( hour() >= 23 || hour() <= 4 ) if ( MoonPhase() >= 90 ) {
ReefAngel.StandardLights( MoonLED, 23, 46, 4, 0 ); //Full Moon
if ( hour() >= 20 || hour() < 4 ) {
ReefAngel.PWM.SetActinic( 0 );
ReefAngel.PWM.SetDaylight( 0 );
if ( ReefAngel.DisplayedMenu != FEEDING_MODE || ReefAngel.DisplayedMenu != WATERCHANGE_MODE ) {
if ( hour() >= 16 && hour() <= 19 ) {
ReefAngel.RF.SetMode( LongWave, 50, 30 );
} else if ( hour() >= 20 || hour() < 7 ) {
ReefAngel.RF.SetMode( Lagoon, 25, 0 );
ReefAngel.RF.UseMemory = true;
if ( !ReefAngel.Relay.Status( Return ) ) {
ReefAngel.Relay.Override( Skimmer, 0 );
// Check the power here, the function is defined below
CheckPower();
ReefAngel.Portal( "*****", "*****" );
////// Loop End
////// Custom Function
void CheckPower()
static boolean PowerOutage = false;
static boolean DelayedPowerOutage = false;
if ( !ReefAngel.Relay.IsRelayPresent( EXP1_RELAY ) ) {
PowerOutage = true; //Expansion Relay 1 has lost power
if ( !PowerOutage ) {
if ( ReefAngel.Timer[1].IsTriggered() ) {
DelayedPowerOutage = true;
if ( DelayedPowerOutage ) {
ReefAngel.Relay.Off ( Flow1 );
ReefAngel.Relay.Off ( Flow2 );
ReefAngel.Relay.Off ( Flow3 );
ReefAngel.Relay.Off ( Return );
ReefAngel.Relay.Off ( Skimmer );
ReefAngel.Relay.Off ( HeaterDisp );
// Power Restored
if ( PowerOutage && ReefAngel.Relay.IsRelayPresent( EXP1_RELAY ) ) {
LastStart = now();
////// Custom Function End
ReefAngel.LCD.DrawDate( 5, 2 );
ReefAngel.LCD.Clear( COLOR_BLACK, 1, 11, 132, 11 );
ConvertNumToString( text, ReefAngel.Params.Temp[T1_PROBE], 10 );
ReefAngel.LCD.DrawHugeNumbers( COLOR_CRIMSON, 255, 5, 14, text );
// Display pH Text
ReefAngel.LCD.DrawText( COLOR_INDIGO, 255, 80, 14, "pH" );
// Display pH Value
ConvertNumToString( text, ReefAngel.Params.PH, 100 );
ReefAngel.LCD.DrawLargeText( COLOR_INDIGO, 255, 95, 14, text, Num8x16 );
ReefAngel.LCD.DrawText( COLOR_ROYALBLUE, 255, 80, 24, "Rm" );
ConvertNumToString( text, ReefAngel.Params.Temp[T3_PROBE], 10 );
ReefAngel.LCD.DrawLargeText( COLOR_ROYALBLUE, 255, 95, 24, text, Num8x16 );
// Vortech Info
//Moon Phase
ReefAngel.LCD.Clear( DefaultBGColor, 5, 88, 95, 95 );
ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE, 255, 5, 88, MoonPhaseLabel() );
ReefAngel.LCD.DrawText( COLOR_NAVY, 255, 5, 98, "MoonLEDs:" );
ReefAngel.LCD.Clear( DefaultBGColor, 59, 98, 75, 106 );
ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE, 255, 59, 98, ReefAngel.PWM.GetActinicValue() );
ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE, 255, 75, 98, "%" );
Thanks a lot!
I uploaded the updated code and the power outage is working now.
Strange thing is that the overheat function isn't working now...I did a full power off and it temp is 82.0 and the overheat light isn't coming on and the ports aren't shutting off....any ideas?
hmmm...more checking is needed. nothing is standing out to me at quick glance.
So I recalibrated my pH probe for the first time since I set it up (Nov 2012). Before the calibration I had a pH or 8.34 and now after its at 7.75.
Could the pH be off by that much after about 2.5 years?
Forgot to mention that I moved the pH probe from the back of the display tank to the sump, could that be the difference? I'll move it back tonight and report back.
Any ideas on the overheat function not working?
Correct, last week t1 was at 82 and ports did not shut off and the red light did not come on. I could try and get t1 above 82.
Sent from my HTC One_M8 using Tapatalk
It has to go more than 82F and stay there for at least 3 seconds to be considered overheat.
Ok it's working, sorry for the false alarm. Just never had it sit right at 82 for awhile.
I moved the ph probe gettin the sump to the DT and the ph reading hasn't changed much.
pH was reading under 7 for the past two nights...doing the calibration again. Now its around 7.5, but its still way lower than it was at 8.5. Do I need a new probe?
So I recently ditched my T5 lights for the RSM S Series LEDs. I also did some wiring cleanup, added a skimmate container using High ATO, and just got an Avast Swabbie retrofit.
During the last few days I have been playing around with the Swabbie code. Not using timing in the memory I could get the port to switch on at 4am, but that was the only time (it wasn't running every 4 hours).
So I tried adding lnevo's code for the Swabbie. Compiles fine, but the relay does not run.
When I read the custom memory location of 100 & 101, both result in 255. So I am assuming the memory locations aren't being written. Also when I manually changed the memory from 255 to 6 or 1 the relay has not turned on every six or one hours.
I am guessing maybe it has to do with this line which I do not have. I am not sure how to update it to write the memory for the Swabbie.
// Define Custom Memory Locations
#define Mem_B_SwabbieRepeat 100
#define Mem_B_SwabbieTime 101
void init_memory() {
// Initialize Custom Memory Locations
InternalMemory.write(Mem_B_SwabbieRepeat,6);
InternalMemory.write(Mem_B_SwabbieTime,1);
#define FlowPumps 1
#define Lights 2
#define Return 3
#define VortechL 4
#define VortechR 5
#define Skimmer 6
#define FanSump 7
#define HeaterSump 8
#define Reactor Box1_Port1
#define Swabbie Box1_Port2
#define Unused Box1_Port3
#define Unused Box1_Port4
#define WCMix Box1_Port6
#define WCFlow Box1_Port7
#define WCHeater Box1_Port8
////// Setup Begin (on controller startup/reset)
// Define labels for LCD screen
ReefAngel.CustomLabels[0]="Flow Pumps";
ReefAngel.CustomLabels[1]="Lights";
ReefAngel.CustomLabels[2]="Return";
ReefAngel.CustomLabels[3]="Vortech L";
ReefAngel.CustomLabels[4]="Vortech R";
ReefAngel.CustomLabels[5]="Skimmer";
ReefAngel.CustomLabels[6]="Fan";
ReefAngel.CustomLabels[7]="Heater";
ReefAngel.CustomLabels[Box1_Port1Label] = "Reactor";
ReefAngel.CustomLabels[Box1_Port2Label] = "Swabbie";
ReefAngel.CustomLabels[Box1_Port3Label] = "";
ReefAngel.CustomLabels[Box1_Port4Label] = "";
ReefAngel.CustomLabels[Box1_Port5Label] = "";
ReefAngel.CustomLabels[Box1_Port6Label] = "WCMix";
ReefAngel.CustomLabels[Box1_Port7Label] = "WCFlow";
ReefAngel.CustomLabels[Box1_Port8Label] = "WCHeater";
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port4Bit | Port5Bit; //Unused ports for testing RF module and random feedmode
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port6Bit | Port7Bit | Port8Bit; // Flowpumps,Return,VortechL,Skimmer,Fan,HeaterSump
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit ; //Reactor,Swabbie
ReefAngel.LightsOnPorts = Port6Bit; //Lights
ReefAngel.OverheatShutoffPorts = Port8Bit; //HeaterSump
// Ports that default on
ReefAngel.Relay.On( FlowPumps );
// Ports that default off
ReefAngel.Relay.Off( Swabbie );
ReefAngel.Relay.Off( WCMix );
ReefAngel.Relay.Off( WCFlow );
ReefAngel.Relay.Off( WCHeater );
////// Setup End
////// Loop Begin
ReefAngel.Relay.On(Reactor);
ReefAngel.StandardHeater( HeaterSump );
ReefAngel.StandardFan( FanSump );
ReefAngel.StandardLights( Lights );
//HighATO=on, delay start Skimmer | HighATO=off, Skimmer shuts off
ReefAngel.Relay.DelayedOn( Skimmer );
ReefAngel.Relay.Off( Skimmer );
if ( hour() >= 16 && hour() <= 20 ) {
ReefAngel.RF.SetMode( LongWave, 70, 30 );
ReefAngel.RF.SetMode( ReefCrest, 40, 0 );
// ReefAngel.StandardHeater( HeaterWC, 775, 778 );
// Turn off Skimmer & FanSump & Reactor if Return Pump is off
ReefAngel.Relay.Override( FanSump, 0 );
ReefAngel.Relay.Override( Reactor, 0 );
CheckPower();
ReefAngel.Portal( "****", "****" );
void RunSwabbie() {
int repeat=InternalMemory.read(Mem_B_SwabbieRepeat)*60;
int runtime=InternalMemory.read(Mem_B_SwabbieTime)*60;
static time_t t;
// Manual mode
if (ReefAngel.Relay.isMaskOn(Swabbie)) {
ReefAngel.Relay.Auto(Swabbie);
t=now();
if (now()-t < runtime) {
ReefAngel.Relay.On(Swabbie);
ReefAngel.DosingPumpRepeat(Swabbie,0,repeat,runtime);
void CheckPower()
// Power Outage - Leave Only Vortech Pumps active
ReefAngel.Relay.Off ( FlowPumps );
ReefAngel.Relay.Off ( Lights );
ReefAngel.Relay.Off ( FanSump);
ReefAngel.Relay.Off ( HeaterSump);
//set vortechs to long wave? something that ripples surface
// Power Restored
LastStart = now();
InternalMemory.write(Mem_B_ResetMemory,false);
Ignore the init_memory function, it doesnt always work right. but please manually set both memory locations. One needs the runtime and the other gets the repeat value. Runtime should be 1 for one minute and repeat should be 6 for one hour.
You mean 6 for six hours, right?
So remove init_memory lines and set manually...do I need to update the controller in order to see the swabbie port activate?
I set 100 to 6, and 101 to 1...
You will not see it in the portal if thats what your looking for.
The memory values or the relay switching on? I do see the relay switch at 4am.
Sent from my A0001 using Tapatalk
You won't reliably see the port in the portal for relay activity.
You also need to call RunSwabbie(); in your loop. I don see it there which means its never getting called.
Haha OK..guess I missed it from yours...I'll give it a shot
Yup adding run swabbie worked... Thanks Lee!
So I have my Swabbie installed and working, can't wait to see the skimmer in a few days.
I've updated a few things, curiosity of Lee's code.
I tested the ATO high, when the skimmate container is full, and the skimmer went off and sent me the alert.
Tomorrow I will have to test a few more things.
EDIT: Although my ATO High is set for 'On" now and I am getting emails. I did a controller restart and it's not making a difference.
Maybe I am getting many emails because I do not have this line in?
- Although when I return the float switch down, I got a Power Restored email?!?!
- Also the skimmer does not go back to Auto when the float switch is back down. I got a fewDo I need to clear ATO for it to return to Auto?
- But I also got the Power Restored email.
- And when I manually turned on the ports, I got an email saying Skimmer Container full (maybe just a coincidence from testing ATO High).
skimmerAlert.SetDelay(3600);
#include <WiFiAlert.h>
#define FlowPumps 1
#define Lights 2
#define Return 3
#define VortechL 4
#define VortechR 5
#define Skimmer 6
#define FanSump 7
// Place global variable code below here
// Place global variable code above here
// #################### Setup (controller starting) ####################
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port4Bit | Port5Bit; //Unused ports for testing random feeding
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit; // Flowpumps,Return
ReefAngel.LightsOnPorts = Port2Bit; //Lights
ReefAngel.OverheatShutoffPorts = Port2Bit | Port8Bit; //Lights,HeaterSump
// ON by default
ReefAngel.Relay.On(FlowPumps);
ReefAngel.Relay.On(Return);
ReefAngel.Relay.On(VortechL);
ReefAngel.Relay.On(VortechR);
// OFF by default
ReefAngel.Relay.Off(Swabbie);
ReefAngel.Relay.Off(WCMix);
ReefAngel.Relay.Off(WCFlow);
ReefAngel.Relay.Off(WCHeater);
// ##### Place additional initialization code below here #####
ReefAngel.CustomLabels[Box1_Port3Label] = "Unused";
ReefAngel.CustomLabels[Box1_Port4Label] = "Unused";
ReefAngel.CustomLabels[Box1_Port5Label] = "Unused";
// 5 second timer for power outage detection
// #################### Loop ####################
// ##### Place your custom code below here #####
RunSwabbie(); // Skimmer neck cleaner
SetRF(); // Set Vortech modes
CheckPower(); // Monitor for power loss
CheckSwitches(); // Monitor Float switches
if (ReefAngel.DisplayedMenu = WATERCHANGE_MODE) {
WaterchangeHeater( HeaterWC, 775, 778 );
// ##### Place your custom code above here #####
ReefAngel.Portal("modulok");
// #################### Custom Function ####################
void CheckSwitches() {
static boolean returnOverride=true;
static WiFiAlert skimmerAlert, atoAlert;
if (ReefAngel.DisplayedMenu==FEEDING_MODE || ReefAngel.DisplayedMenu==WATERCHANGE_MODE)
// HighATO=on, delay start Skimmer | HighATO=off, Skimmer shuts off
ReefAngel.Relay.DelayedOn(Skimmer);
skimmerAlert.Send("Skimmate+container+full!+Skimmer+shutoff.");
// If Return pump is off, kill power to others
ReefAngel.Relay.Override(FanSump,0);
ReefAngel.Relay.Override(Reactor,0);
ReefAngel.Relay.Override(HeaterSump,0);
// Alert if ATO timeput flag
if (bitRead(ReefAngel.AlertFlags,ATOTimeOutFlag))
atoAlert.Send("ATO+timeout!+ATO+disabled.");
void SetRF() {
else {
void RunSwabbie() {
static time_t t;
// Manual mode
t=now();
else {
void CheckPower()
static boolean powerOutage = false;
static WiFiAlert powerAlert;
static boolean delayedPowerOutage = false;
powerOutage = true; //Expansion Relay 1 has lost power
if ( !powerOutage ) {
delayedPowerOutage = true;
if (delayedPowerOutage) {
ReefAngel.Relay.Off(FlowPumps);
ReefAngel.Relay.Off(Return);
ReefAngel.Relay.Off(Skimmer);
ReefAngel.Relay.Off(Lights);
ReefAngel.Relay.Off(FanSump);
ReefAngel.Relay.Off(HeaterSump);
ReefAngel.RF.SetMode(Constant,70,0);
powerAlert.Send("Power+lost!");
// Power Restored - return equipment back to normal power state
if ( powerOutage && ReefAngel.Relay.IsRelayPresent( EXP1_RELAY ) ) {
LastStart = now();
powerAlert.Send("Power+restored.",true);
void WaterchangeHeater(byte HeaterRelay, int LowTemp, int HighTemp)
if (ReefAngel.Params.Temp[T3_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T3_PROBE] <= LowTemp && ReefAngel.Params.Temp[T3_PROBE] > 0) ReefAngel.Relay.On(WCHeater);
if (ReefAngel.Params.Temp[T3_PROBE] >= HighTemp) ReefAngel.Relay.Off(WCHeater);
// #################### Custom Function End ####################
I'll take a look at your code later this week. The way my code is written it sets the override when these conditions occur so you just have to reset the ports to auto.
I modified the code a bit and not am not getting skimmate full emails. But for some reason I have power restored emails.
#define FlowPumps 1
#define Lights 2
#define Return 3
#define VortechL 4
#define VortechR 5
#define Skimmer 6
#define FanSump 7
// ON by default
// OFF by default
ReefAngel.StandardHeater(HeaterSump);
ReefAngel.StandardFan(FanSump);
ReefAngel.StandardLights(Lights);
CheckSwitches(); // Monitor float switches
atoAlert.SetDelay(3600);
// HighATO=off, Skimmer shuts off
if (!ReefAngel.HighATO.IsActive()) {
skimmerAlert.Send("Skimmate+container+is+full!+Skimmer+has+been+shutoff.");
// Alert if ATO timeout flag
void SetRF() {
else {
void RunSwabbie() {
static time_t t;
// Manual mode
t=now();
else {
void CheckPower()
LastStart = now();
I updated my code the other day. I'm using a different mechanism to delay the power outage. I dont recommend the way you are doing it with the Timer class. I'm not sire whats happening but clearly you are falsely triggering the power outage and this could cause robertos code to not send you the right alert.
Does the skimmer turn off when your float switch changes? If so the code to send the skimmer full alarm should be fine.
OK, I see you include a delay in the poweroutage code, cool! I will give it a shot and update my code later tonight.
The skimmer does shutoff when the float switch is up, and I got the email. So that seems to be working well. I am waiting for the container to actually fill up for a real test. (It might be two months unless I change to a wetter skimmate)
Not sure why, but the checkpower function isn't working right.
When I kill power to exp relay box only the return shuts off like it should. Lights stay on, skimmer, fan, heater, reactor shut off due to return being off. No email from Power Lost.
After power is returned I get emails every few minutes for Power Restored, and I hear relays but do not see anything switching on or off. The Return does not come back on (waited 5 minutes). Also the ports that shut off when return is off do not reset to auto.
I am curious what this line does. Wait for 300 seconds to signal poweroutage?
if (now()-powerOutage > 300) {
ReefAngel.Relay.Set(Return, now()%3600<300);
#define FlowPumps 1
#define Lights 2
#define Return 3
#define VortechL 4
#define VortechR 5
#define Skimmer 6
#define FanSump 7
// Vortech Variables
byte vtMode, vtSpeed, vtDuration;
// ON by default
// OFF by default
void SetRF() {
else {
void RunSwabbie() {
static time_t t;
// Manual mode
t=now();
else {
void CheckPower() {
static time_t powerOutage=false;
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY) && !powerOutage) //Relay Expansion NOT detected
powerOutage=now();
if (now()-powerOutage > 10) { // Wait 10 seconds before sending to avoid false alarms
if (powerOutage && ReefAngel.Relay.IsRelayPresent( EXP1_RELAY ) )
powerOutage=0;
LastStart=now();
ReefAngel.RF.SetMode(vtMode,vtSpeed,vtDuration);
That line says after the power is out for 5 minutes, run the return pump for 5 minutes each hour. This way my UPS conserves power to run the mp40s
