Mike's RSM 500 Code
modulok
Re: Mike's RSM 500 Code
Post by modulok »
OK, when I unplug the RF module the red light turns off. And I can control ports.
Try this update.
You need to open the enclosure and connect the USB-TTL cable with the black wire on the GND pin.
Then, you need to edit the file update.bat to use whatever com port you are using.
Double-click the update.bat file to start updating.
update.zip
(427.13 KiB) Downloaded 506 times
modulok
Post by modulok »
Which is the ground pin?
Sorry, I forgot to say to remove the RF module too.
modulok
Post by modulok »
libusb0.dll is missing error when I run the bat file (avrdude.exe)
EDIT:Got the fix...Had to copy that file to c:\Windows\syswow64
RF firmware should be updated now. Going to plug it back in and see what happens.
modulok
Post by modulok »
Same issue....after a bit red light comes on and relays don't toggle on/off. When I unplug RF module the relays toggle (even when I manually toggle when red light is blinking).
Is my RF module a dud?
Ok, are you sure you got it updated?
Did it go through the % from 0 to 100?
modulok
Post by modulok »
OK, I didn't see any percentage...the command window closed when it was finished. I just re-ran the update by running it manually so the window didn't auto exit.
EDIT: My RA just had two power outage scenarios (code that was working fine), when power was fine (relay exp never lost power). Could the root cause be the new Expansion Hub?
avrdude -Cavrdude.conf -v -patmega328p
-carduino -P\\.\COM6 -b115200 -D -Uflash:w:RF_Update_WDT_modified.hex:i
avrdude: Version 6.0, compiled on Apr  6 2012 at 19:29:19
         System wide configuration file is "avrdude.conf"
         Using Port                    : \\.\COM6
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude done.  Thank you.
No, it didn't upload.
It needs to upload just like in RA.
It will flash the red led for a few seconds and there will be a % bar.
Did you remove the Ecotech RF module?
It won't work with the RF module plugged into the board.
modulok
Post by modulok »
I don't think I understand...here is what I did.
I unplugged the RF Exp Module and removed the board from the plastic case. Hooked up the USB TTL to the RF board (pic I posted above) black wire to ground pin. Connect USB end to computer and run the command.
Sent from my Nexus 7 using Tapatalk 4
You must also remove the Ecotech RF module before you can upload or it will thing the serial data is supposed to be sent to the vortech drivers.
modulok
Post by modulok »
It's been awhile since I have needed to update code, but the power outage function wasn't working.
Not sure why but the power outage was below "// This should always be the last line" When I moved it up I couldn't compile. What did I do wrong here?
Getting the following compile error at: void CheckPower() {
updated_code.cpp: In function 'void loop()':
updated_code:165: error: a function-definition is not allowed here before '{' token
updated_code:257: error: expected `}' at end of input
// Define Named Relay Ports
#define Flow1           1
#define Flow2           2
#define Flow3           3
#define Return          4
#define Skimmer         5
#define VortechL        6
#define VortechR        7
#define HeaterDisp      8
#define CenterT5        Box1_Port1
#define FrontT5         Box1_Port2
#define BackT5          Box1_Port3
#define MoonLED         Box1_Port4
#define Unused          Box1_Port5
#define Reactor         Box1_Port6
#define Fan             Box1_Port7
#define HeaterSump      Box1_Port8
// Custom Main
byte x,y;
////// Setup Begin
    // Controlled Modes Toggled Ports
    ReefAngel.FeedingModePortsE[0] = Port7Bit | Port8Bit; //Fan,HeaterSump
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit; // Flow1-3,Return,Skimmer,HeaterDisp
    ReefAngel.WaterChangePortsE[0] = Port2Bit | Port3Bit | Port6Bit | Port7Bit | Port8Bit; //Front+BackT5,Reactor,Fan,HeaterSump
    ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port3Bit; //Center+Front+BackT5
    // Water Temperature Settings & Overheat
    ReefAngel.OverheatShutoffPorts = Port8Bit; //HeaterDisp
    ReefAngel.OverheatShutoffPortsE[0] = Port2Bit | Port3Bit | Port8Bit; //Front+BackT5,HeaterSump
    ReefAngel.Relay.On( Flow1 );
    ReefAngel.Relay.On( Flow2 );
    ReefAngel.Relay.On( Flow3 );
    ReefAngel.Relay.On( Return );
    ReefAngel.Relay.On( VortechL );
    ReefAngel.Relay.On( VortechR );
    ReefAngel.Relay.On( Reactor );
    // Ports that are always off
    ReefAngel.Relay.Off(Unused);
    //5 second timer for power outage detection
    ReefAngel.Timer[1].SetInterval(5);
////// Setup End
////// Loop Begin
    // Ports that are Delayed
    ReefAngel.Relay.DelayedOn( Skimmer,2 );
    // Temperature Control
    ReefAngel.StandardHeater( HeaterSump,770,773 );
    ReefAngel.StandardHeater( HeaterDisp,767,770 );
    ReefAngel.StandardFan( Fan,810,814 );
    // T5 Light Schedule
    ReefAngel.StandardLights( CenterT5,9,0,20,0 );
        if (hour()==14 && minute()>=0 && minute()<=59) ReefAngel.Relay.Off(CenterT5);
    ReefAngel.StandardLights( FrontT5,10,0,18,0 );
	if (hour()==15 && minute()>=0 && minute()<=29) ReefAngel.Relay.Off(FrontT5);
    ReefAngel.StandardLights( BackT5,11,0,19,0 );
        if (hour()==16 && minute()>=0 && minute()<=29) ReefAngel.Relay.Off(BackT5);
    // RSM MoonLED Schedule
    if (hour()>=6 && hour()<=8) ReefAngel.StandardLights( MoonLED,6,0,8,59 ); //Morning
    else if(hour()>=20 && hour()<=23) ReefAngel.StandardLights( MoonLED,20,0,23,45 ); //Evening
    else if(hour()>=23 || hour()<=4) if (MoonPhase()>=90) ReefAngel.StandardLights( MoonLED,23,46,4,0 ); //Full Moon
    // Moonphase LED Schedule
    if (hour()>=20 || hour()<4)
      ReefAngel.PWM.SetActinic(0);
      ReefAngel.PWM.SetDaylight(0);
    //T5 Light Off Variable
    //if (hour()==12 && minute()>=30 && minute()<=44) ReefAngel.Relay.Off(CenterT5);
    //if (hour()==12 && minute()>=15 && minute()<=29) ReefAngel.Relay.Off(FrontT5);
    //if (hour()==16 && minute()>=15 && minute()<=29) ReefAngel.Relay.Off(FrontT5);
    //if (hour()==13 && minute()>=45 && minute()<=59) ReefAngel.Relay.Off(BackT5);
    //if (hour()==16 && minute()>=45 && minute()<=59) ReefAngel.Relay.Off(BackT5);
    // Vortech MP40 | Constant | Lagoon | ReefCrest | ShortWave 1=10ms | LongWave 1=1s | NutrientTransport 1=10ms | TidalSwell
    if (ReefAngel.DisplayedMenu!=FEEDING_MODE || ReefAngel.DisplayedMenu!=WATERCHANGE_MODE)
      if (hour()>=16 && hour()<=19)
        ReefAngel.RF.UseMemory=false;
        ReefAngel.RF.SetMode(LongWave,50,30);
        else if (hour()>=20 || hour()<7)
          ReefAngel.RF.SetMode(Lagoon,25,0);
          ReefAngel.RF.UseMemory=true;
    // When Return pump is off so is Skimmer
    if (!ReefAngel.Relay.Status(Return)) {
      ReefAngel.Relay.Override(Skimmer,0);
void CheckPower() {
  static boolean PowerOutage=false;
  static boolean DelayedPowerOutage=false;
    // Power Outage - Leave Single Flow Pump Powered
    if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY)) PowerOutage=true; //Expansion Relay 1 has lost power
    if (!PowerOutage)
      ReefAngel.Timer[1].Start();
    if (ReefAngel.Timer[1].IsTriggered())
      DelayedPowerOutage=true;
    if (DelayedPowerOutage)
    ReefAngel.Relay.Off (Flow1);
    ReefAngel.Relay.Off (Flow2);
    ReefAngel.Relay.Off (Flow3);
    ReefAngel.Relay.Off (Return);
    ReefAngel.Relay.Off (Skimmer);
    ReefAngel.Relay.Off (HeaterDisp);
    //set vortechs to low power
    // Power Restored
    if (PowerOutage && ReefAngel.Relay.IsRelayPresent(EXP1_RELAY))
      PowerOutage=false;
      LastStart=now();
    ReefAngel.Portal( "*****","*****" );
////// Loop End
////// Custom Main Begin
// Display Date & Time
    ReefAngel.LCD.DrawDate(5, 2);
// Display Water Temp Value
    ReefAngel.LCD.DrawHugeNumbers(COLOR_CRIMSON, 255, 5, 14, text);
// Display pH Text
    ReefAngel.LCD.DrawText(COLOR_INDIGO,255,80,14,"pH");
// Display pH Value
    ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 95, 14, text, Num8x16);
// Display Room Temp Text
    ReefAngel.LCD.DrawText(COLOR_ROYALBLUE,255,80,24,"Rm");
// Display Room Temp Value
    ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
    ReefAngel.LCD.DrawLargeText(COLOR_ROYALBLUE, 255, 95, 24, text, Num8x16);
// Vortech Info
//Moon Phase
    ReefAngel.LCD.Clear(DefaultBGColor,5,88,95,95);
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,5,88,MoonPhaseLabel());
//Dimmable Moon LEDs
    ReefAngel.LCD.DrawText(COLOR_NAVY,255,5,98, "MoonLEDs:");
    ReefAngel.LCD.Clear(DefaultBGColor,59,98,75,106);
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,59,98, ReefAngel.PWM.GetActinicValue());
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,75,98, "%");
  // Display Main Relay Box
    ReefAngel.LCD.DrawOutletBox( 2, 107, TempRelay );
// Display Expansion Relay Box 1
    ReefAngel.LCD.DrawOutletBox( 2, 119, TempRelay );
////// Custom Main End
////// Custom Graph Begin
///// Custom Graph End
you cannot define a function within another function. your checkpower function is being defined inside the loop function code.
move it out and that should help.
I went ahead and updated your code and moved everything around how it should be. I test compiled and everything compiles just fine. I did not upload the code to a controller though.
The formatting is updated too. You will also need to put your portal information back in since you removed it before.
Hope this helps.
#define Flow1           1
#define Flow2           2
#define Flow3           3
#define Return          4
#define Skimmer         5
#define VortechL        6
#define VortechR        7
// Custom Main
byte x, y;
////// Setup Begin
    ReefAngel.Relay.Off( Unused );
    ReefAngel.Timer[1].SetInterval( 5 );
////// Setup End
////// Loop Begin
    ReefAngel.Relay.DelayedOn( Skimmer, 2 );
    ReefAngel.StandardHeater( HeaterSump, 770, 773 );
    ReefAngel.StandardHeater( HeaterDisp, 767, 770 );
    ReefAngel.StandardFan( Fan, 810, 814 );
    ReefAngel.StandardLights( CenterT5, 9, 0, 20, 0 );
    if ( hour() == 14 && minute() >= 0 && minute() <= 59 ) {
        ReefAngel.Relay.Off( CenterT5 );
    ReefAngel.StandardLights( FrontT5, 10, 0, 18, 0 );
    if ( hour() == 15 && minute() >= 0 && minute() <= 29 ) {
        ReefAngel.Relay.Off( FrontT5 );
    ReefAngel.StandardLights( BackT5, 11, 0, 19, 0 );
    if ( hour() == 16 && minute() >= 0 && minute() <= 29 ) {
        ReefAngel.Relay.Off( BackT5 );
    if ( hour() >= 6 && hour() <= 8 ) {
        ReefAngel.StandardLights( MoonLED, 6, 0, 8, 59 );    //Morning
    } else if( hour() >= 20 && hour() <= 23 ) {
        ReefAngel.StandardLights( MoonLED, 20, 0, 23, 45 );    //Evening
    } else if( hour() >= 23 || hour() <= 4 ) if ( MoonPhase() >= 90 ) {
            ReefAngel.StandardLights( MoonLED, 23, 46, 4, 0 );    //Full Moon
    if ( hour() >= 20 || hour() < 4 ) {
        ReefAngel.PWM.SetActinic( 0 );
        ReefAngel.PWM.SetDaylight( 0 );
    if ( ReefAngel.DisplayedMenu != FEEDING_MODE || ReefAngel.DisplayedMenu != WATERCHANGE_MODE ) {
        if ( hour() >= 16 && hour() <= 19 ) {
            ReefAngel.RF.SetMode( LongWave, 50, 30 );
        } else if ( hour() >= 20 || hour() < 7 ) {
            ReefAngel.RF.SetMode( Lagoon, 25, 0 );
            ReefAngel.RF.UseMemory = true;
    if ( !ReefAngel.Relay.Status( Return ) ) {
        ReefAngel.Relay.Override( Skimmer, 0 );
    // Check the power here, the function is defined below
    CheckPower();
    ReefAngel.Portal( "*****", "*****" );
////// Loop End
////// Custom Function
void CheckPower()
    static boolean PowerOutage = false;
    static boolean DelayedPowerOutage = false;
    if ( !ReefAngel.Relay.IsRelayPresent( EXP1_RELAY ) ) {
        PowerOutage = true;    //Expansion Relay 1 has lost power
    if ( !PowerOutage ) {
    if ( ReefAngel.Timer[1].IsTriggered() ) {
        DelayedPowerOutage = true;
    if ( DelayedPowerOutage ) {
        ReefAngel.Relay.Off ( Flow1 );
        ReefAngel.Relay.Off ( Flow2 );
        ReefAngel.Relay.Off ( Flow3 );
        ReefAngel.Relay.Off ( Return );
        ReefAngel.Relay.Off ( Skimmer );
        ReefAngel.Relay.Off ( HeaterDisp );
    // Power Restored
    if ( PowerOutage && ReefAngel.Relay.IsRelayPresent( EXP1_RELAY ) ) {
        LastStart = now();
////// Custom Function End
    ReefAngel.LCD.DrawDate( 5, 2 );
    ReefAngel.LCD.Clear( COLOR_BLACK, 1, 11, 132, 11 );
    ConvertNumToString( text, ReefAngel.Params.Temp[T1_PROBE], 10 );
    ReefAngel.LCD.DrawHugeNumbers( COLOR_CRIMSON, 255, 5, 14, text );
// Display pH Text
    ReefAngel.LCD.DrawText( COLOR_INDIGO, 255, 80, 14, "pH" );
// Display pH Value
    ConvertNumToString( text, ReefAngel.Params.PH, 100 );
    ReefAngel.LCD.DrawLargeText( COLOR_INDIGO, 255, 95, 14, text, Num8x16 );
    ReefAngel.LCD.DrawText( COLOR_ROYALBLUE, 255, 80, 24, "Rm" );
    ConvertNumToString( text, ReefAngel.Params.Temp[T3_PROBE], 10 );
    ReefAngel.LCD.DrawLargeText( COLOR_ROYALBLUE, 255, 95, 24, text, Num8x16 );
// Vortech Info
//Moon Phase
    ReefAngel.LCD.Clear( DefaultBGColor, 5, 88, 95, 95 );
    ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE, 255, 5, 88, MoonPhaseLabel() );
    ReefAngel.LCD.DrawText( COLOR_NAVY, 255, 5, 98, "MoonLEDs:" );
    ReefAngel.LCD.Clear( DefaultBGColor, 59, 98, 75, 106 );
    ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE, 255, 59, 98, ReefAngel.PWM.GetActinicValue() );
    ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE, 255, 75, 98, "%" );
modulok
Post by modulok »
Thanks a lot!
I uploaded the updated code and the power outage is working now.
Strange thing is that the overheat function isn't working now...I did a full power off and it temp is 82.0 and the overheat light isn't coming on and the ports aren't shutting off....any ideas?
hmmm...more checking is needed. nothing is standing out to me at quick glance.
modulok
Post by modulok »
So I recalibrated my pH probe for the first time since I set it up (Nov 2012). Before the calibration I had a pH or 8.34 and now after its at 7.75.
Could the pH be off by that much after about 2.5 years?
modulok
Post by modulok »
Forgot to mention that I moved the pH probe from the back of the display tank to the sump, could that be the difference? I'll move it back tonight and report back.
Any ideas on the overheat function not working?
If you get T1 above 82F, nothing happens?
Not even the status LED?
modulok
Post by modulok »
Correct, last week t1 was at 82 and ports did not shut off and the red light did not come on. I could try and get t1 above 82.
Sent from my HTC One_M8 using Tapatalk
It has to go more than 82F and stay there for at least 3 seconds to be considered overheat.
modulok
Post by modulok »
Ok it's working, sorry for the false alarm. Just never had it sit right at 82 for awhile.
I moved the ph probe gettin the sump to the DT and the ph reading hasn't changed much.
modulok
Post by modulok »
pH was reading under 7 for the past two nights...doing the calibration again. Now its around 7.5, but its still way lower than it was at 8.5. Do I need a new probe?
modulok
Post by modulok »
So I recently ditched my T5 lights for the RSM S Series LEDs. I also did some wiring cleanup, added a skimmate container using High ATO, and just got an Avast Swabbie retrofit.
During the last few days I have been playing around with the Swabbie code. Not using timing in the memory I could get the port to switch on at 4am, but that was the only time (it wasn't running every 4 hours).
So I tried adding lnevo's code for the Swabbie. Compiles fine, but the relay does not run.
// Define Custom Memory Locations
#define Mem_B_SwabbieRepeat   100
#define Mem_B_SwabbieTime     101
void init_memory() {
  // Initialize Custom Memory Locations
  InternalMemory.write(Mem_B_SwabbieRepeat,6);
  InternalMemory.write(Mem_B_SwabbieTime,1);
#define FlowPumps       1
#define Lights          2
#define Return          3
#define VortechL        4
#define VortechR        5
#define Skimmer         6
#define FanSump         7
#define HeaterSump      8
#define Reactor         Box1_Port1
#define Swabbie         Box1_Port2
#define Unused          Box1_Port3
#define Unused          Box1_Port4
#define WCMix           Box1_Port6
#define WCFlow          Box1_Port7
#define WCHeater        Box1_Port8
////// Setup Begin (on controller startup/reset)
    // Define labels for LCD screen
    ReefAngel.CustomLabels[0]="Flow Pumps";
    ReefAngel.CustomLabels[1]="Lights";
    ReefAngel.CustomLabels[2]="Return";
    ReefAngel.CustomLabels[3]="Vortech L";
    ReefAngel.CustomLabels[4]="Vortech R";
    ReefAngel.CustomLabels[5]="Skimmer";
    ReefAngel.CustomLabels[6]="Fan";
    ReefAngel.CustomLabels[7]="Heater";
    ReefAngel.CustomLabels[Box1_Port1Label] = "Reactor";
    ReefAngel.CustomLabels[Box1_Port2Label] = "Swabbie";
    ReefAngel.CustomLabels[Box1_Port3Label] = "";
    ReefAngel.CustomLabels[Box1_Port4Label] = "";
    ReefAngel.CustomLabels[Box1_Port5Label] = "";
    ReefAngel.CustomLabels[Box1_Port6Label] = "WCMix";
    ReefAngel.CustomLabels[Box1_Port7Label] = "WCFlow";
    ReefAngel.CustomLabels[Box1_Port8Label] = "WCHeater";
    ReefAngel.FeedingModePortsE[0] = Port3Bit | Port4Bit | Port5Bit; //Unused ports for testing RF module and random feedmode
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port6Bit | Port7Bit | Port8Bit; // Flowpumps,Return,VortechL,Skimmer,Fan,HeaterSump
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit ; //Reactor,Swabbie
    ReefAngel.LightsOnPorts = Port6Bit; //Lights
    ReefAngel.OverheatShutoffPorts = Port8Bit; //HeaterSump
    // Ports that default on
    ReefAngel.Relay.On( FlowPumps );
    // Ports that default off
    ReefAngel.Relay.Off( Swabbie );
    ReefAngel.Relay.Off( WCMix );
    ReefAngel.Relay.Off( WCFlow );
    ReefAngel.Relay.Off( WCHeater );
////// Setup End
////// Loop Begin
    ReefAngel.Relay.On(Reactor);
    ReefAngel.StandardHeater( HeaterSump );
    ReefAngel.StandardFan( FanSump );
    ReefAngel.StandardLights( Lights );
    //HighATO=on, delay start Skimmer | HighATO=off, Skimmer shuts off
      ReefAngel.Relay.DelayedOn( Skimmer );
      ReefAngel.Relay.Off( Skimmer );
        if ( hour() >= 16 && hour() <= 20 ) {
            ReefAngel.RF.SetMode( LongWave, 70, 30 );
            ReefAngel.RF.SetMode( ReefCrest, 40, 0 );
//    ReefAngel.StandardHeater( HeaterWC, 775, 778 );
    // Turn off Skimmer & FanSump & Reactor if Return Pump is off
        ReefAngel.Relay.Override( FanSump, 0 );
        ReefAngel.Relay.Override( Reactor, 0 );
    CheckPower();
    ReefAngel.Portal( "****", "****" );
void RunSwabbie() {
  int repeat=InternalMemory.read(Mem_B_SwabbieRepeat)*60;
  int runtime=InternalMemory.read(Mem_B_SwabbieTime)*60;
  static time_t t;
  // Manual mode
  if (ReefAngel.Relay.isMaskOn(Swabbie)) {
    ReefAngel.Relay.Auto(Swabbie);
    t=now();
  if (now()-t < runtime) {
    ReefAngel.Relay.On(Swabbie);
    ReefAngel.DosingPumpRepeat(Swabbie,0,repeat,runtime);
void CheckPower()
    // Power Outage - Leave Only Vortech Pumps active
        ReefAngel.Relay.Off ( FlowPumps );
        ReefAngel.Relay.Off ( Lights );
        ReefAngel.Relay.Off ( FanSump);
        ReefAngel.Relay.Off ( HeaterSump);
        //set vortechs to long wave? something that ripples surface
    // Power Restored
        LastStart = now();
When I read the custom memory location of 100 & 101, both result in 255. So I am assuming the memory locations aren't being written. Also when I manually changed the memory from 255 to 6 or 1 the relay has not turned on every six or one hours.
I am guessing maybe it has to do with this line which I do not have. I am not sure how to update it to write the memory for the Swabbie.
InternalMemory.write(Mem_B_ResetMemory,false);
Ignore the init_memory function, it doesnt always work right. but please manually set both memory locations. One needs the runtime and the other gets the repeat value. Runtime should be 1 for one minute and repeat should be 6 for one hour.
modulok
Post by modulok »
You mean 6 for six hours, right?
So remove init_memory lines and set manually...do I need to update the controller in order to see the swabbie port activate?
I set 100 to 6, and 101 to 1...
You will not see it in the portal if thats what your looking for.
modulok
Post by modulok »
The memory values or the relay switching on? I do see the relay switch at 4am.
Sent from my A0001 using Tapatalk
You won't reliably see the port in the portal for relay activity.
You also need to call RunSwabbie(); in your loop. I don see it there which means its never getting called.
