Mike's RSM 500 Code
PostPosted: Mon Jul 06, 2015 11:59 am
It has to go more than 82F and stay there for at least 3 seconds to be considered overheat.
PostPosted: Mon Jul 06, 2015 4:15 pm
Ok it's working, sorry for the false alarm. Just never had it sit right at 82 for awhile.
I moved the ph probe gettin the sump to the DT and the ph reading hasn't changed much.
Sent from my HTC One_M8 using Tapatalk
PostPosted: Fri Jul 10, 2015 6:04 pm
pH was reading under 7 for the past two nights...doing the calibration again. Now its around 7.5, but its still way lower than it was at 8.5. Do I need a new probe?
PostPosted: Wed Jun 08, 2016 9:30 am
So I recently ditched my T5 lights for the RSM S Series LEDs. I also did some wiring cleanup, added a skimmate container using High ATO, and just got an Avast Swabbie retrofit.
During the last few days I have been playing around with the Swabbie code. Not using timing in the memory I could get the port to switch on at 4am, but that was the only time (it wasn't running every 4 hours).
So I tried adding lnevo's code for the Swabbie. Compiles fine, but the relay does not run.
// Define Custom Memory Locations
#define Mem_B_SwabbieRepeat   100
#define Mem_B_SwabbieTime     101
void init_memory() {
  // Initialize Custom Memory Locations
  InternalMemory.write(Mem_B_SwabbieRepeat,6);
  InternalMemory.write(Mem_B_SwabbieTime,1);
// Define Named Relay Ports
#define FlowPumps       1
#define Lights          2
#define Return          3
#define VortechL        4
#define VortechR        5
#define Skimmer         6
#define FanSump         7
#define HeaterSump      8
#define Reactor         Box1_Port1
#define Swabbie         Box1_Port2
#define Unused          Box1_Port3
#define Unused          Box1_Port4
#define Unused          Box1_Port5
#define WCMix           Box1_Port6
#define WCFlow          Box1_Port7
#define WCHeater        Box1_Port8
////// Setup Begin (on controller startup/reset)
    // Define labels for LCD screen
    ReefAngel.CustomLabels[0]="Flow Pumps";
    ReefAngel.CustomLabels[1]="Lights";
    ReefAngel.CustomLabels[2]="Return";
    ReefAngel.CustomLabels[3]="Vortech L";
    ReefAngel.CustomLabels[4]="Vortech R";
    ReefAngel.CustomLabels[5]="Skimmer";
    ReefAngel.CustomLabels[6]="Fan";
    ReefAngel.CustomLabels[7]="Heater";
    ReefAngel.CustomLabels[Box1_Port1Label] = "Reactor";
    ReefAngel.CustomLabels[Box1_Port2Label] = "Swabbie";
    ReefAngel.CustomLabels[Box1_Port3Label] = "";
    ReefAngel.CustomLabels[Box1_Port4Label] = "";
    ReefAngel.CustomLabels[Box1_Port5Label] = "";
    ReefAngel.CustomLabels[Box1_Port6Label] = "WCMix";
    ReefAngel.CustomLabels[Box1_Port7Label] = "WCFlow";
    ReefAngel.CustomLabels[Box1_Port8Label] = "WCHeater";
    ReefAngel.FeedingModePortsE[0] = Port3Bit | Port4Bit | Port5Bit; //Unused ports for testing RF module and random feedmode
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port6Bit | Port7Bit | Port8Bit; // Flowpumps,Return,VortechL,Skimmer,Fan,HeaterSump
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit ; //Reactor,Swabbie
    ReefAngel.LightsOnPorts = Port6Bit; //Lights
    ReefAngel.OverheatShutoffPorts = Port8Bit; //HeaterSump
    // Ports that default on
    ReefAngel.Relay.On( FlowPumps );
    ReefAngel.Relay.On( Return );
    ReefAngel.Relay.On( VortechL );
    ReefAngel.Relay.On( VortechR );
    // Ports that default off
    ReefAngel.Relay.Off( Unused );
    ReefAngel.Relay.Off( Swabbie );
    ReefAngel.Relay.Off( WCMix );
    ReefAngel.Relay.Off( WCFlow );
    ReefAngel.Relay.Off( WCHeater );
    //5 second timer for power outage detection
    ReefAngel.Timer[1].SetInterval( 5 );
////// Setup End
////// Loop Begin
    ReefAngel.Relay.On(Reactor);
    ReefAngel.StandardHeater( HeaterSump );
    ReefAngel.StandardFan( FanSump );
    ReefAngel.StandardLights( Lights );
    //HighATO=on, delay start Skimmer | HighATO=off, Skimmer shuts off
      ReefAngel.Relay.DelayedOn( Skimmer );
      ReefAngel.Relay.Off( Skimmer );
    // Vortech MP40 | Constant | Lagoon | ReefCrest | ShortWave 1=10ms | LongWave 1=1s | NutrientTransport 1=10ms | TidalSwell
    if ( ReefAngel.DisplayedMenu != FEEDING_MODE || ReefAngel.DisplayedMenu != WATERCHANGE_MODE ) {
        if ( hour() >= 16 && hour() <= 20 ) {
            ReefAngel.RF.SetMode( LongWave, 70, 30 );
        } else if ( hour() >= 20 || hour() < 7 ) {
            ReefAngel.RF.SetMode( ReefCrest, 40, 0 );
            ReefAngel.RF.UseMemory = true;
//    ReefAngel.StandardHeater( HeaterWC, 775, 778 );
    // Turn off Skimmer & FanSump & Reactor if Return Pump is off
    if ( !ReefAngel.Relay.Status( Return ) ) {
        ReefAngel.Relay.Override( Skimmer, 0 );
        ReefAngel.Relay.Override( FanSump, 0 );
        ReefAngel.Relay.Override( Reactor, 0 );
    // Check the power here, the function is defined below
    CheckPower();
    ReefAngel.Portal( "****", "****" );
////// Custom Function
void RunSwabbie() {
  int repeat=InternalMemory.read(Mem_B_SwabbieRepeat)*60;
  int runtime=InternalMemory.read(Mem_B_SwabbieTime)*60;
  static time_t t;
  // Manual mode
  if (ReefAngel.Relay.isMaskOn(Swabbie)) {
    ReefAngel.Relay.Auto(Swabbie);
    t=now();
  if (now()-t < runtime) {
    ReefAngel.Relay.On(Swabbie);
    ReefAngel.DosingPumpRepeat(Swabbie,0,repeat,runtime);
void CheckPower()
    static boolean PowerOutage = false;
    static boolean DelayedPowerOutage = false;
    // Power Outage - Leave Only Vortech Pumps active
    if ( !ReefAngel.Relay.IsRelayPresent( EXP1_RELAY ) ) {
        PowerOutage = true;    //Expansion Relay 1 has lost power
    if ( !PowerOutage ) {
        ReefAngel.Timer[1].Start();
    if ( ReefAngel.Timer[1].IsTriggered() ) {
        DelayedPowerOutage = true;
    if ( DelayedPowerOutage ) {
        ReefAngel.Relay.Off ( FlowPumps );
        ReefAngel.Relay.Off ( Return );
        ReefAngel.Relay.Off ( Skimmer );
        ReefAngel.Relay.Off ( Lights );
        ReefAngel.Relay.Off ( FanSump);
        ReefAngel.Relay.Off ( HeaterSump);
        //set vortechs to long wave? something that ripples surface
    // Power Restored
    if ( PowerOutage && ReefAngel.Relay.IsRelayPresent( EXP1_RELAY ) ) {
        LastStart = now();
////// Custom Function End
When I read the custom memory location of 100 & 101, both result in 255. So I am assuming the memory locations aren't being written. Also when I manually changed the memory from 255 to 6 or 1 the relay has not turned on every six or one hours.
I am guessing maybe it has to do with this line which I do not have. I am not sure how to update it to write the memory for the Swabbie.
InternalMemory.write(Mem_B_ResetMemory,false);
PostPosted: Wed Jun 08, 2016 10:19 am
Ignore the init_memory function, it doesnt always work right. but please manually set both memory locations. One needs the runtime and the other gets the repeat value. Runtime should be 1 for one minute and repeat should be 6 for one hour.
PostPosted: Wed Jun 08, 2016 10:46 am
You mean 6 for six hours, right?
So remove init_memory lines and set manually...do I need to update the controller in order to see the swabbie port activate?
I set 100 to 6, and 101 to 1...
PostPosted: Wed Jun 08, 2016 1:51 pm
You will not see it in the portal if thats what your looking for.
PostPosted: Wed Jun 08, 2016 1:56 pm
The memory values or the relay switching on? I do see the relay switch at 4am.
Sent from my A0001 using Tapatalk
PostPosted: Wed Jun 08, 2016 3:20 pm
You won't reliably see the port in the portal for relay activity.
PostPosted: Wed Jun 08, 2016 3:21 pm
You also need to call RunSwabbie(); in your loop. I don see it there which means its never getting called.
Return to My PDE/INO file
