Re: Mike's RSM 500 Code
Posted: Wed Jun 22, 2016 6:13 pm
You aren't turning anything back on when the power comes up. You can either explicitly add it, or move all your on statements from setup() into loop()
http://forum.reefangel.com/
void CheckPower() {
static time_t powerOutage=false;
static WiFiAlert powerAlert;
// Power Outage - turn off everything
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY) && !powerOutage) // Expansion Relay NOT present
byte rfPowerOutageSpeed=InternalMemory.read(Mem_B_PowerOutageSpeed);
powerOutage=now();
if (now()-powerOutage > 300) {
ReefAngel.Relay.Set(Return, now()%3600<300);
ReefAngel.Relay.Off(FlowPumps);
ReefAngel.Relay.Off(Lights);
ReefAngel.Relay.Off(Skimmer);
ReefAngel.Relay.Off(FanSump);
ReefAngel.Relay.Off(HeaterSump);
ReefAngel.RF.SetMode(Constant,rfPowerOutageSpeed,0);
if (now()-powerOutage > 10) { // Wait 10 seconds before sending to avoid false alarms
powerAlert.Send("Power+outage!");
// Power Restored - Turn things back on
if (powerOutage && ReefAngel.Relay.IsRelayPresent(EXP1_RELAY))
powerOutage=0;
LastStart=now();
ReefAngel.RF.SetMode(vtMode,vtSpeed,vtDuration);
powerAlert.Send("Power+restored.",true);
sketch_rsms500:64: error: expected ',' or '...' before numeric constant
sketch_rsms500.cpp: In function 'void loop()':
sketch_rsms500:64: error: too few arguments to function 'void WaterchangeHeater(byte, int)'
sketch_rsms500:144: error: at this point in file
sketch_rsms500.cpp: At global scope:
sketch_rsms500:256: error: expected ',' or '...' before numeric constant
#include <WiFiAlert.h>
// Define Custom Memory Locations
#define Mem_B_SwabbieRepeat 100
#define Mem_B_SwabbieTime 101
#define Mem_B_PowerOutageSpeed 102
#define Mem_I_WCHeaterLowTemp 103
#define Mem_I_WCHeaterHighTemp 105
// Define Named Relay Ports
#define FlowPumps 1
#define Lights 2
#define Return 3
#define VortechL 4
#define VortechR 5
#define Skimmer 6
#define FanSump 7
#define HeaterSump 8
#define Reactor Box1_Port1
#define Swabbie Box1_Port2
#define FugeLight Box1_Port3
#define Unused Box1_Port4
#define WCMix Box1_Port5
#define WCFlow Box1_Port6
#define WCHeater Box1_Port7
#define Bad Box1_Port8
// Place global variable code below here
// Vortech Variables for PowerOutage
// byte vtMode, vtSpeed, vtDuration;
// Place global variable code above here
// #################### Setup (controller starting) ####################
ReefAngel.FeedingModePortsE[0] = Port8Bit; //Unused port for testing random feeding
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit; // Flowpumps,Return
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit; // Reactor,FugeLight
ReefAngel.LightsOnPorts = Port2Bit; //Lights
ReefAngel.OverheatShutoffPorts = Port2Bit | Port8Bit; //Lights,HeaterSump
// ON by default
ReefAngel.Relay.On(FlowPumps);
ReefAngel.Relay.On(Return);
ReefAngel.Relay.On(VortechL);
ReefAngel.Relay.On(VortechR);
// OFF by default
ReefAngel.Relay.Off(Swabbie);
ReefAngel.Relay.Off(WCMix);
ReefAngel.Relay.Off(WCFlow);
ReefAngel.Relay.Off(WCHeater);
ReefAngel.Relay.Off(Unused);
ReefAngel.Relay.Off(Bad);
// ##### Place additional initialization code below here #####
// Define labels for LCD screen
ReefAngel.CustomLabels[0]="Flow Pumps";
ReefAngel.CustomLabels[1]="Lights";
ReefAngel.CustomLabels[2]="Return";
ReefAngel.CustomLabels[3]="Vortech L";
ReefAngel.CustomLabels[4]="Vortech R";
ReefAngel.CustomLabels[5]="Skimmer";
ReefAngel.CustomLabels[6]="Fan";
ReefAngel.CustomLabels[7]="Heater";
ReefAngel.CustomLabels[Box1_Port1Label] = "Reactor";
ReefAngel.CustomLabels[Box1_Port2Label] = "Swabbie";
ReefAngel.CustomLabels[Box1_Port3Label] = "Fuge Light";
ReefAngel.CustomLabels[Box1_Port4Label] = "Unused";
ReefAngel.CustomLabels[Box1_Port5Label] = "WCMix";
ReefAngel.CustomLabels[Box1_Port6Label] = "WCFlow";
ReefAngel.CustomLabels[Box1_Port7Label] = "WCHeater";
ReefAngel.CustomLabels[Box1_Port8Label] = "Bad";
// 5 second timer for power outage detection
ReefAngel.Timer[1].SetInterval( 5 );
// #################### Loop ####################
ReefAngel.Relay.On(Reactor);
ReefAngel.StandardHeater(HeaterSump);
ReefAngel.StandardFan(FanSump);
ReefAngel.StandardLights(Lights);
ReefAngel.StandardLights(FugeLight,22,0,6,0);
ReefAngel.Relay.DelayedOn(Skimmer);
// ##### Place your custom code below here #####
RunSwabbie(); // Skimmer neck cleaner
SetRF(); // Set Vortech modes
CheckPower(); // Monitor for power loss
CheckSwitches(); // Monitor float switches
WaterchangeHeater(); // Heater control for Waterchange Heater
// ##### Place your custom code above here #####
ReefAngel.Portal("modulok");
// #################### Custom Function ####################
void CheckPower()
static boolean powerOutage = false;
static boolean delayedPowerOutage = false;
// Power Outage - Leave Only Vortech Pumps active
if ( !ReefAngel.Relay.IsRelayPresent( EXP1_RELAY ) ) {
powerOutage = true; //Expansion Relay 1 has lost power
if ( !powerOutage ) {
ReefAngel.Timer[1].Start();
if ( ReefAngel.Timer[1].IsTriggered() ) {
delayedPowerOutage = true;
if (delayedPowerOutage) {
ReefAngel.Relay.Off(Return);
ReefAngel.RF.SetMode(Constant,70,0);
powerAlert.Send("Power+lost!");
// Power Restored - return equipment back to normal power state
if ( powerOutage && ReefAngel.Relay.IsRelayPresent( EXP1_RELAY ) ) {
LastStart = now();
void CheckSwitches() {
static boolean returnOverride=true;
static WiFiAlert skimmerAlert, atoAlert;
skimmerAlert.SetDelay(3600);
atoAlert.SetDelay(3600);
if (ReefAngel.DisplayedMenu==FEEDING_MODE || ReefAngel.DisplayedMenu==WATERCHANGE_MODE)
// HighATO=off, Skimmer shuts off
if (!ReefAngel.HighATO.IsActive()) {
skimmerAlert.Send("Skimmate+container+is+full!+Skimmer+has+been+shutoff.");
ReefAngel.Relay.Override(Skimmer,0);
// If Return pump is off, kill power to Skimmer
if (!ReefAngel.Relay.Status(Return)) {
// Alert if ATO timeout flag
if (bitRead(ReefAngel.AlertFlags,ATOTimeOutFlag))
atoAlert.Send("ATO+timeout!+ATO+disabled.");
void SetRF() {
// Vortech MP40 | Constant | Lagoon | ReefCrest | ShortWave 1=10ms | LongWave 1=1s | NutrientTransport 1=10ms | TidalSwell
if ( ReefAngel.DisplayedMenu != FEEDING_MODE || ReefAngel.DisplayedMenu != WATERCHANGE_MODE ) {
if ( hour() >= 16 && hour() <= 20 ) {
ReefAngel.RF.SetMode( LongWave, 70, 30 );
else if ( hour() >= 20 || hour() < 7 ) {
ReefAngel.RF.SetMode( ReefCrest, 40, 0 );
else {
ReefAngel.RF.UseMemory = true;
void RunSwabbie() {
int repeat=InternalMemory.read(Mem_B_SwabbieRepeat)*60;
int runtime=InternalMemory.read(Mem_B_SwabbieTime)*60;
static time_t t;
// Manual mode
if (ReefAngel.Relay.isMaskOn(Swabbie)) {
ReefAngel.Relay.Auto(Swabbie);
t=now();
if (now()-t < runtime) {
ReefAngel.Relay.On(Swabbie);
else {
ReefAngel.DosingPumpRepeat(Swabbie,0,repeat,runtime);
void WaterchangeHeater(byte WCHeaterRelay, int Mem_I_WCHeaterLowTemp, int Mem_I_WCHeaterHighTemp)
if (ReefAngel.Params.Temp[T3_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T3_PROBE] <= Mem_I_WCHeaterLowTemp && ReefAngel.Params.Temp[T3_PROBE] > 0) ReefAngel.Relay.On(WCHeater); // If sensor temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T3_PROBE] >= Mem_I_WCHeaterHighTemp) ReefAngel.Relay.Off(WCHeater); // If sensor temperature >= HighTemp - turn off heater
// #################### Custom Function End ####################
