Sacohen's Current code
PostPosted: Fri Sep 27, 2013 9:22 am
This is a copy of my current code basically as a backup, but feel free to look over it and use what you may feel fits your needs.
The system includes...
RA +
Relay(original included)'
PH Probe
Standard ATO High and Low
Expansion Hub
Dimming Expansion
RANet and Relay
Water Level Expansion
Multi Water Level Expansion
Salinity Expansion
ATO Pump
WiFi module
Bluetooth module
3 Jebao Cables (WP-25, WP-40, DC-12000pump)
3 Temp Sensors
Dimmable Lunar Hub & 2 Moonlights
Basic control of the following.
Daylight
Actinic
Moonlight
Pumps
2 Jebao pumps (WP40 & WP25)
Control of my NatuReef DeNitrification chamber.
(Thanks to lnevo for help with this coding)
Random Jebao modes that lnevo did for PaulTurner911.
12/21/13
Changed the Speed for the Jebao pumps from 30% to 0% during feeding.
3/22/14
Added AutoFeeder triggered by Reef Angel.
How to modify the Eheim 3581 are here. http://wamas.org/forums/blog/13/entry-4 ... ontroller/
Added Dimmable Lunar Hub. Right now I'm just using the MoonPhase with an on and off time that coincide with my lighting. I added a slope to it so it seems like a moonrise and set
4/8/14 Added some code to turn a pump on every 8 hours for 15 min to stir my Kalkwasser.
5/26/14 Removed code to mix Kalkwasser.
8/1/14 Modified the Denitrification code to use variables instead of hard times. (Thanks to lnevo again for this)
8/4/14 Added Kalk Mixing Code. When the ATO reservoir is at 100% or above the pump in the reservoir turns on for 1 hr to mix the Kalkwasser in the reservoir and then turns off to let the unsaturated Kalk settle to bottom before use as ATO water.
9/11 Updated code for 1.1.1 Libraries. Added DNS server name and Server Authentication. Removed the Else Mode wave function code since it is now incorporated in to the libraries and added the Gyre Wave mode to the choice of Random Waves. Made some slight changes to the ATO code that had to be done because of the new libraries.
1/26/15 Added RA Net and Relay.
2/27/15 Added code to auto flush my RO/DI unit Monday, Wednesday and Friday using a 12V DC 1/2" Normally Closed Pneumatic Plastic Air Water Electric Solenoid Valve.
7/05/15 Added 2 Evergreen D120 LED lights. Modded for RA Dimming control and set up and East to West Sunrise/Sunet code.
#include <SoftwareSerial.h>
// Define Relay Ports by Name
#define Actinic_Lights     1
#define Day_Lights         2
#define Kalkwasser         3
#define Pumps              4
#define Unused             5
#define DeNit_Doser        6
#define DeNit_Pump         7
#define ATO_Pump           8
#define Unused             Box1_Port1
#define Feeder             Box1_Port2
#define Unused             Box1_Port3
#define Unused             Box1_Port4
#define Unused             Box1_Port5
#define Flush_Bypass       Box1_Port6
#define Main_RODI          Box1_Port7
#define Dummy              Box1_Port8
// Does not need to be global.
// unsigned long ATOUpdate=0;
static time_t LastATO=millis();    // For de-bounced ATO
//Set Standard Menu
ReefAngel.AddStandardMenu();
//Water Level
ReefAngel.AddMultiChannelWaterLevelExpansion();
//Webserver Authentication
ReefAngel.Network.WifiAuthentication("Sacohen:xxxxxxxx");
//DDNS Server
ReefAngel.DDNS("myreeftank");
ReefAngel.AddRANet();
//ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
//ReefAngel.DCPump.AntiSyncOffset=85;
ReefAngel.Relay.On( Pumps );
ReefAngel.Relay.On( Dummy );
  ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
  ReefAngel.StandardLights( Day_Lights,12,30,21,0 );
  //East to West Sunrise/Sunset Dimming
    ReefAngel.PWM.SetChannel( 0, PWMSlope(12,30,20,30,0,100,60,0) );
    ReefAngel.PWM.SetChannel( 1, PWMSlope(12,0,21,30,0,100,60,0) );
    ReefAngel.PWM.SetChannel( 2, PWMSlope(13,0,21,0,0,100,60,0) );
    ReefAngel.PWM.SetChannel( 3, PWMSlope(12,30,22,0,0,100,60,0) );
  // *******************  Debounced ATO code. Activate ATO no more than every 30 seconds.  *******************
//if (ReefAngel.WaterLevel.GetLevel(0) < 34) LastATO=millis();    // Start a timer
//if (millis()-LastATO<30000 && millis()-LastATO>10)     // Has it been less than 30,000 ms? (30 secs)
//  ReefAngel.Relay.Off(ATO_Pump);                         // If so, make sure the topoff pump is off
//  else
    ReefAngel.WaterLevelATO(0,ATO_Pump,720,34,36);                     // Otherwise, use the normal topoff routine.
  if ( hour()>=13 && hour()<21 )
  ReefAngel.PWM.SetChannel( 5, 0 );
  ReefAngel.PWM.SetChannel( 5, PWMSlope(21,0,13,0,0,MoonPhase() ,60,0) );
  //Flush RO/DI Membrane Monday, Wednseday and Friday times a week @ 9pm.
ReefAngel.Relay.Off(Main_RODI);
if (weekday()==dowMonday && hour()==21 && minute()<5)
  ReefAngel.Relay.On(Main_RODI);
if (weekday()==dowWednesday && hour()==21 && minute()<5)
if (weekday()==dowFriday && hour()==21 && minute()<10)
ReefAngel.Relay.Off(Flush_Bypass);
if (weekday()==dowFriday && hour()==21 && minute()>=05 && minute()<10)
  ReefAngel.Relay.On(Flush_Bypass);
  //Mix Kalkwasser
static unsigned long Kalk_Mixing = 0;
static unsigned long stopTime = 0;
static byte prevWL=0;
if (ReefAngel.WaterLevel.GetLevel(1)==100 && prevWL<100) {
  stopTime=now()+7200; // Get time one hour from now.
prevWL = ReefAngel.WaterLevel.GetLevel(1); // Store the water level
if (now() < stopTime) { ReefAngel.Relay.On(Kalkwasser); } else { ReefAngel.Relay.Off(Kalkwasser); }
  //AutoFeeder
static unsigned long autofeeding = 0;
if ((now()%SECS_PER_DAY==64800)) //if it is 6 pm
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-autofeeding>=60) && (now()-autofeeding<=61)) //if between 60 and 61 seconds has past
if ( autofeeding > 0 ) {
autofeeding = 0;
  // DeNitrate Routine
int DeNit_Offset=3600;
int DeNit_Repeat=21600;
int DeNit_Doser_Offset=1200;
int DeNit_Doser_Runtime=600;
int DeNit_Pump_Runtime=1200;
int DeNit_ATO_Offtime=1500;
// Pump comes on first
ReefAngel.Relay.Set(DeNit_Pump,(now()-DeNit_Offset)%DeNit_Repeat<DeNit_Pump_Runtime);  // Runs denitrator pump
// Doser comes on second
ReefAngel.Relay.Set(DeNit_Doser,((now()-DeNit_Offset)-DeNit_Doser_Offset)%DeNit_Repeat<DeNit_Doser_Runtime); // Runs denitrator doser
  // Disable ATO
if ( (now()-3600)%21600<DeNit_ATO_Offtime) ReefAngel.WaterLevelATO(0,ATO_Pump,720,0,1);
  // Delay WL ATO after water change and DeNit_Dosing
  static time_t wcTimer=0;
  // First 10 minutes after WC disable ATO
  if (now()-wcTimer >= 0 && now()-wcTimer < 600)
    // Track Salinity low duration
    static unsigned long lastGoodSal;
    static boolean lowSalFlag;
    // Salinity is good, update counter
    if (ReefAngel.Params.Salinity>=335) lastGoodSal=now();
    // Counter hasn't been updating in 300 seconds..
    if (now()-lastGoodSal>300) {
      lowSalFlag=true; // Salinity is definitely below 33.5
      lowSalFlag=false; // Salinity back to normal
    // Disable ATO if lowSalFlag is true
   //if (lowSalFlag) ReefAngel.WaterLevelATO(0,ATO_Pump,720,0,1);
  // Disable ATO if ATO High IsActive()
static int rmode;
byte modes[] = { ReefCrest, Gyre, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else, };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<3600) {
} else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Speed=30;
  ReefAngel.Portal( "Sacohen","xxxxxxxx" );
int x,y;
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,57, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,57, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,66,66, "WL 1:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel(1) );
//Salinity
  strcat(text,"  ");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,39,75,"Salinity:");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,99,75,text);
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
PostPosted: Fri Mar 07, 2014 5:46 pm
Hey Steve,
If i paste your entire code in the arduino and connect my RA and upload. WIll it just effect my jebaos? or will it make all my outlets the same as yours? sorry, very new here and haven't figured much out yet but want to get pumps going.
Nick
PostPosted: Fri Mar 07, 2014 5:53 pm
It will make all your outlets the same as mine. Not only the outlets, but the WiFi, portal, everyting
PostPosted: Sat Mar 08, 2014 6:06 pm
Nick;
If you want to use the random code you will need the following parts in red.
#define Unused 3
#define Pumps 4
#define Sump_Fan 5
#define Unused 8
#define ATO_Pump Box1_Port1
#define Moon_Lights Box1_Port2
#define Unused Box1_Port6
#define Unused Box1_Port7
//Set Standard Menu
ReefAngel.StandardLights( Day_Lights,13,0,21,0 );
ReefAngel.StandardLights( Sump_Fan,13,0,21,0 );
ReefAngel.WaterLevelATO(ATO_Pump,720,31,34);
ReefAngel.Relay.Set( Moon_Lights, !ReefAngel.Relay.Status( Actinic_Lights ) );
int DeNit_Doser_Runtime=1200;
ReefAngel.Relay.Set(DeNit_Pump,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
ReefAngel.Relay.Set(DeNit_Doser,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
// Disable ATO
if ( (now()-3600)%21600<1500) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
if (lowSalFlag) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else };
changeMode=false;
if (rmode==Else) {
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),20,true ); // ElseMode on sync mode, Portal Speed Setting +/- 20%
ReefAngel.Portal( "Sacohen","********" );
int x,y;
// Water Level
strcat(text," ");
if (WaveSync)
return NewSpeed;
return AntiSpeed;
PostPosted: Mon Dec 01, 2014 1:03 pm
How do I use the code you have provided for the jaebo pumps but only for 1 pump?
so it would alternate and be random through out the day, but go to min setting for feeding, and off for water changes,
Adam
58 Gal
PostPosted: Mon Dec 01, 2014 1:06 pm
Actually that code is for the old libraries that do not have Else mode built into them.
I'll need a little time to go through my current code and highlight what you need and what to remove for a single pump.
I'll try to get it put up today.
PostPosted: Mon Dec 01, 2014 1:09 pm
That be awesome!!! Thanks
do you want me to pm you my current code?
Adam
58 Gal
PostPosted: Mon Dec 01, 2014 1:12 pm
#include <Wire.h>fF
#include <RA_NokiaLCD.h>f
#define Pumps 4
#define Sump_Fan 5
#define ATO_Pump 8
//Set Standard Menu
//Water Level
//ReefAngel.Network.WifiAuthentication("Sacohen:S3tho31o");
//DDNS Server
//Remove this part for single pump
ReefAngel.DCPump.AntiSyncOffset=100;
ReefAngel.WaterLevelATO(0,ATO_Pump,720,28,31);
//Mix Kalkwasser
if (ReefAngel.WaterLevel.GetLevel(1)>=100 && prevWL<100) {
stopTime=now()+3600; // Get time one hour from now.
//AutoFeeder
autofeeding = 0;
// Disable ATO
static int rmode;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else, Gyre };
changeMode=false;
ReefAngel.Portal( "Sacohen","xxxxxxx" );
int x,y;
// Water Level
//Salinity
strcat(text," ");
PostPosted: Mon Dec 01, 2014 2:54 pm
thanks, I will test it later today
Adam
58 Gal
PostPosted: Mon Dec 01, 2014 3:31 pm
tried it, but it comes up with an error.
_58test.cpp: In function 'void loop()':
_58test:98: error: 'Else' was not declared in this scope
_58test:98: error: 'Gyre' was not declared in this scope
Adam
58 Gal
Next
Return to My PDE/INO file
