Johniii's Code
PostPosted: Sun Oct 13, 2013 6:20 am
finally putting a backup of my code up.
#include <avr/pgmspace.h>
//Custom Main, Graph & Menu
// Create the menu entries
prog_char menu1_label[] PROGMEM = "ReefCrest";
prog_char menu2_label[] PROGMEM = "TidalSwell";
prog_char menu3_label[] PROGMEM = "Short Pulse";
prog_char menu7_label[] PROGMEM = "ATO Clear";
menu7_label
 void MenuEntry1()
 ReefAngel.DCPump.SetMode(ReefCrest,50,10);
 ReefAngel.DisplayMenuEntry("Reef Crest");
void MenuEntry2()
 ReefAngel.DCPump.SetMode(TidalSwell,50,10);
 ReefAngel.DisplayMenuEntry("tidal Swell");
void MenuEntry3()
ReefAngel.DCPump.SetMode(ShortPulse,50,1000);
ReefAngel.DisplayMenuEntry("Short Pulse");
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
{///// Place global variable code above here
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.ATOClear();
     ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items));// Add Standard Menu
    ReefAngel.LightsOnPorts = Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.SingleATO( true,Port1,60,0 );
    ReefAngel.DosingPumpRepeat( Port2,0,240,10 );
    ReefAngel.DosingPumpRepeat( Port3,0,60,10 );
    ReefAngel.DosingPumpRepeat( Port5,30,60,10 );
    ReefAngel.StandardLights( Port6,14,0,22,0 );
    ReefAngel.StandardHeater( Port7,760,770 );
    ReefAngel.StandardHeater( Port8,760,770 );
    ReefAngel.Portal("johniii");
Return to My PDE/INO file
