- Code: Select all
#include <WiFiAlert.h>
// Custom Menu
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Turn Lights On";
prog_char menu1_label[] PROGMEM = "Turn Lights Off";
prog_char menu2_label[] PROGMEM = "Start Feeding";
prog_char menu3_label[] PROGMEM = "Start Water Change";
prog_char menu4_label[] PROGMEM = "Clear Overheat";
prog_char menu5_label[] PROGMEM = "Calibrate pH";
prog_char menu6_label[] PROGMEM = "Calibrate Salinity";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label };
// Define Custom Memory Locations
#define Mem_B_SwabbieRepeat 115
#define Mem_B_SwabbieTime 116
#define Mem_I_CalDP1Vol 128
#define Mem_I_CalDP1Time 130
#define Mem_I_DP1Volume 132
#define Mem_I_CalDP2Vol 134
#define Mem_I_CalDP2Time 136
#define Mem_I_DP2Volume 138
#define Mem_B_MaintSkimmer 151
#define Mem_B_PrintDebug 198
#define Mem_B_ResetMemory 199
void init_memory() {
// Initialize Custom Memory Locations
InternalMemory.write(Mem_B_SwabbieRepeat,6);
InternalMemory.write(Mem_B_SwabbieTime,1);
InternalMemory.write_int(Mem_I_CalDP1Vol,11);
InternalMemory.write_int(Mem_I_CalDP1Time,600);
InternalMemory.write_int(Mem_I_DP1Volume,30);
InternalMemory.write_int(Mem_I_CalDP2Vol,11);
InternalMemory.write_int(Mem_I_CalDP2Time,600);
InternalMemory.write_int(Mem_I_DP2Volume,30);
InternalMemory.write(Mem_B_ResetMemory,false);
// Define Custom Variables for Portal
#define Var_DPump1 4
#define Var_DPump2 5
#define Var_AcclDay 6
// Define Relay Ports by Name
#define DT_LightsOne 1
#define DT_LightsTwo 2
#define Unused3 3
#define Unused4 4
#define DT_LWM 5
#define GT_LWM 6
#define DosePumpOne 7
#define DosePumpTwo 8
#define Unused11 Box1_Port1
#define Swabbie Box1_Port2
#define GT_LightsOne Box1_Port3
#define GT_LightsTwo Box1_Port4
#define DT_RWM Box1_Port5
#define GT_RWM Box1_Port6
#define DT_Heat Box1_Port7
#define DT_Pump Box1_Port8
#define RV_Heat Box2_Port1
#define RV_Pump Box2_Port2
#define GT_Heat Box2_Port3
#define Unused24 Box2_Port4
#define GT_OverFill Box2_Port5
#define GT_Fill Box2_Port6
#define Skimmer Box2_Port7
#define GT_Pump Box2_Port8
// Setup on controller startup/reset
ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize the menu
ReefAngel.FeedingModePortsE[0] = Port8Bit; // Turn off on Box1 when feeding mode is activated is activated
ReefAngel.FeedingModePortsE[1] = Port7Bit | Port8Bit; // Turn off on Box2 when feeding mode is activated is activated
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit; // Turn off when water change mode is activated
ReefAngel.WaterChangePortsE[0] = Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Turn off on Box1 when water change mode is activated
ReefAngel.WaterChangePortsE[1] = Port3Bit | Port8Bit | Port7Bit | Port6Bit | Port1Bit; // Turn off on Box1 when water change mode is activated
// ReefAngel.PHExpMin = 1832;
// ReefAngel.PHExpMax = 2150;
ReefAngel.TempProbe = T2_PROBE; // Set the 2nd plug to be DT Main temp
ReefAngel.OverheatProbe = T2_PROBE; // to monitor the overheat and temperatures
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit; // Items turned off when Overheat temperature exceeded
ReefAngel.OverheatShutoffPortsE[0] = Port7Bit | Port3Bit | Box1_Port4; // Items turned off on Box1 when Overheat temperature exceeded
ReefAngel.OverheatShutoffPortsE[1] = Port3Bit | Port7Bit; // Items turned off on Box2 when Overheat temperature exceeded
InternalMemory.OverheatTemp_write( 829 ); // Set the DT Overheat temperature setting
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit; // Toggle Lights
ReefAngel.LightsOnPortsE[0] = Port3Bit | Port4Bit; // Toggle Lights
// Ports that default on
ReefAngel.Relay.On(DT_Pump); // Turn on DT Pump
ReefAngel.Relay.On(GT_Pump); // Turn on GT Pump
ReefAngel.Relay.On(Skimmer); // Turn on Skimmer
// Ports that default off
ReefAngel.Relay.Off(Swabbie);
CheckPower(); // Monitor for power outages
CheckSwitches(); // Monitor for float switches
RunSwabbie(); // Skimmer neck cleaner
// RunDosingPumps(); // Dose by volume or time
// LogDosingPumps(); // Keep track of dosing
// CalibrateDPumps(); // Calibrate Dosing pumps
DelayedOnModes(Skimmer); // DelayedOn after mode change only
ReefAngel.StandardLights( DT_LightsOne,14,00,22,00 ); // DT Lights on at 2:00pm and off at 10:00pm
ReefAngel.StandardLights( DT_LightsTwo,22,00,01,00 ); // DT-Moon Lights on at 10:00am and off at 1:00am
ReefAngel.StandardLights( GT_LightsOne,14,00,21,45 ); //GT Lights Main 2:00pm - 9:45pm
ReefAngel.StandardLights( GT_LightsTwo,15,00,22,30 ); //GT Lights Actinic 3:00pm - 10:30pm
ReefAngel.WavemakerRandom( DT_LWM,60,100 );
ReefAngel.Relay.Set( DT_RWM, !ReefAngel.Relay.Status( DT_LWM ) ); //Randomize DT powerheads
ReefAngel.WavemakerRandom1( GT_LWM,60,100 );
ReefAngel.Relay.Set( GT_RWM, !ReefAngel.Relay.Status( GT_LWM ) ); //Randomize GT powerheads
StandardHeater1( DT_Heat,779,791 ); //DT-Heat
StandardHeater2( GT_Heat,779,791 ); //GT-Heat
ReefAngel.DosingPumpRepeat( DosePumpOne,0,720,5 );
// if the hour is 2p or 8p, minute is 55 and seconds is 0, start the feeding mode
if ( ((hour() == 14) || (hour() == 20)) &&
(minute() == 55) &&
(second() == 0) )
ReefAngel.FeedingModeStart();
// if the hour is between 1a and 6a, start the Reservoir Pump
if (hour()>=1 && hour()<6)
ReefAngel.Relay.On(RV_Pump);
ReefAngel.Relay.Off(RV_Pump);
// turn on RV_Heat when temp falls below 76.0 and turn off when temp gets above 80.0
if (ReefAngel.Params.Temp[T3_PROBE] <= 780 && ReefAngel.Params.Temp[T3_PROBE] > 0) ReefAngel.Relay.On(RV_Heat);
if (ReefAngel.Params.Temp[T3_PROBE] >= 791) ReefAngel.Relay.Off(RV_Heat);
//turn on GT Fill when switch is tripped
if (hour()>=19 && hour()<20) // Turn on GT_Fill if water is needed
ReefAngel.Relay.Set(GT_Fill,ReefAngel.IO.GetChannel(2));
ReefAngel.Portal("rossbryant1956");
// ReefAngel.Params.ORP=ReefAngel.PH.Read();
void CheckPower() {
static boolean powerOutage=false;
static WiFiAlert powerAlert;
// Power Outage - turn off everything
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY) && (!ReefAngel.Relay.IsRelayPresent(EXP2_RELAY))) // Expansion Relay NOT present
powerOutage=true;
ReefAngel.Relay.Off(DT_LightsOne);
ReefAngel.Relay.Off(DT_LightsTwo);
ReefAngel.Relay.Off(Port3);
ReefAngel.Relay.Off(Port4);
ReefAngel.Relay.Off(Port7);
ReefAngel.Relay.Off(Port8);
powerAlert.Send("Power+Outage!");
// Power Restored - Turn things back on
if (powerOutage && ReefAngel.Relay.IsRelayPresent(EXP1_RELAY) && ReefAngel.Relay.IsRelayPresent(EXP2_RELAY)) // Expansion Relay IS present
LastStart=now();
powerOutage=false;
ReefAngel.Relay.On(DT_LightsOne);
ReefAngel.Relay.On(DT_LightsTwo);
ReefAngel.Relay.On(DosePumpOne);
ReefAngel.Relay.On(DosePumpTwo);
powerAlert.Send("Power+restored.",true);
// I_O Expansion & Float Valves
void CheckSwitches() {
static boolean GT_OverFillOverride=true;
static WiFiAlert switchAlert, skimmerAlert, atoAlert;
skimmerAlert.SetDelay(3600);
switchAlert.SetDelay(3600);
if (ReefAngel.DisplayedMenu==FEEDING_MODE || ReefAngel.DisplayedMenu==WATERCHANGE_MODE)
// Turn off GT_OverFill if sump overflowing
if (!ReefAngel.IO.GetChannel(3)) {
if (!GT_OverFillOverride) {
switchAlert.Send("GT_Sump+level+alarm!+MixPump+disabled.");
ReefAngel.Relay.Override(GT_OverFill,0);
GT_OverFillOverride=false;
// Turn off DT_Pump if sump overflowing
static boolean DT_OverFillOverride=true;
if (!ReefAngel.IO.GetChannel(0)) {
if (!DT_OverFillOverride) {
switchAlert.Send("DT_Tank+level+alarm!");
ReefAngel.Relay.Override(DT_Pump,0);
DT_OverFillOverride=false;
ReefAngel.Relay.Override(DT_Pump,2);
// Turn off GT_Pump if sump overflowing
static boolean GT_PumpOverFillOverride=true;
if (!ReefAngel.IO.GetChannel(1)) {
if (!GT_PumpOverFillOverride) {
switchAlert.Send("GT_Tank+level+alarm!");
ReefAngel.Relay.Override(GT_Pump,0);
GT_PumpOverFillOverride=false;
ReefAngel.Relay.Override(GT_Pump,2);
// Turn off Skimmer if waste collector is full.
if (!ReefAngel.LowATO.IsActive()) { // switch is on by default
skimmerAlert.Send("Skimmate+container+full!+Skimmer+disabled.");
ReefAngel.Relay.Override(Skimmer,0);
//if (InternalMemory.read(Mem_B_MaintSkimmer) > 0) // Reset last Skimmer counter
//InternalMemory.write(Mem_B_MaintSkimmer,0);
// Turn off Skimmer if Return pump has been shutoff.
if (!ReefAngel.Relay.Status(DT_Pump)) {
// Alert if ATO timeout flag
if (bitRead(ReefAngel.Flags,ATOTimeOutFlag))
atoAlert.Send("ATO+timeout!+ATO+disabled.");
// Swabbie
void RunSwabbie() {
int repeat=InternalMemory.read(Mem_B_SwabbieRepeat)*60;
int runtime=InternalMemory.read(Mem_B_SwabbieTime)*60;
static time_t t;
// Manual mode
if (ReefAngel.Relay.isMaskOn(Swabbie)) {
ReefAngel.Relay.Override(Swabbie,2);
t=now();
if (now()-t < runtime) {
ReefAngel.Relay.On(Swabbie);
ReefAngel.DosingPumpRepeat(Swabbie,0,repeat,runtime);
void DelayedOnModes(byte relay) {
static unsigned long startTime=now();
if (startTime==LastStart && ReefAngel.HighATO.IsActive()) {
ReefAngel.Relay.On(relay);
ReefAngel.Relay.DelayedOn(relay);
// Definitions for dosing pumps
// #define numDPumps 2
// byte pump[numDPumps]={ DosePumpOne, DosePumpTwo };
// byte varReport[numDPumps]={ Var_DPump1, Var_DPump2 };
// byte memDPTime[numDPumps]={ Mem_B_DP1Timer, Mem_B_DP2Timer };
// int memDPVolume[numDPumps]={ Mem_I_DP1Volume, Mem_I_DP2Volume };
// int memDPRepeat[numDPumps]={ Mem_I_DP1RepeatInterval, Mem_I_DP2RepeatInterval };
// int memCalTime[numDPumps]={ Mem_I_CalDP1Time, Mem_I_CalDP2Time };
// int memCalVol[numDPumps]={ Mem_I_CalDP1Vol, Mem_I_CalDP2Vol };
// void RunDosingPumps() {
// float rate;
// byte dpTime;
// int dpRepeat, calcTime, totalVolume;
// static byte doseTime[numDPumps]={
// InternalMemory.read(memDPTime[0]),
// InternalMemory.read(memDPTime[1])
// for (int i=0;i < numDPumps; i++) {
// dpTime=InternalMemory.read(memDPTime[i]);
// dpRepeat=InternalMemory.read_int(memDPRepeat[i]);
// rate=(float)InternalMemory.read_int(memCalVol[i])/InternalMemory.read_int(memCalTime[i]);
// calcTime=(InternalMemory.read_int(memDPVolume[i])/rate)/(1440/dpRepeat);
// totalVolume=rate*(dpTime*(1440/dpRepeat));
// if (dpTime!=doseTime[i]) { // Memory has changed.
// InternalMemory.write_int(memDPVolume[i], totalVolume); // Update volume
// doseTime[i]=dpTime;
// } else if (dpTime!=calcTime) { // Calculated time has changed.
// InternalMemory.write(memDPTime[i], calcTime); // Update time
// doseTime[i]=calcTime;
// Make sure we're not calibrating
//if (!ReefAngel.Relay.Status(VO_Calibrate))
//ReefAngel.DosingPumpRepeat(pump[i], i*5, dpRepeat, doseTime[i]);
// ReefAngel.CustomVar[7]=1;
void StandardHeater1(byte HeaterRelay, int LowTemp, int HighTemp)
if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
void StandardHeater2(byte HeaterRelay, int LowTemp, int HighTemp) //Heater for Grow Tank
if (ReefAngel.Params.Temp[T1_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T1_PROBE] <= LowTemp && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T1_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor temperature >= HighTemp - turn off heater
// Globals for Params on Custom Main
byte x,y;
void MenuEntry1()
ReefAngel.DisplayMenuEntry("Item 1");ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif // RelayExp
ReefAngel.Relay.Write();
void MenuEntry2()
ReefAngel.DisplayMenuEntry("Item 2");ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif // RelayExp
void MenuEntry3()
ReefAngel.DisplayMenuEntry("Item 3");ReefAngel.FeedingModeStart();
void MenuEntry4()
ReefAngel.DisplayMenuEntry("Item 4");ReefAngel.WaterChangeModeStart();
void MenuEntry5()
ReefAngel.DisplayMenuEntry("Item 5");ReefAngel.OverheatClear();
void MenuEntry6()
ReefAngel.DisplayMenuEntry("Item 6");ReefAngel.SetupCalibratePH();
void MenuEntry7()
ReefAngel.DisplayMenuEntry("Item 7");ReefAngel.SetupCalibrateSalinity();
// End Custom Menu Globals
int x,y;
char text[7];
ReefAngel.LCD.DrawDate( 6, 122 ); //6 pixels left, 122 lines down
// I/O Expansion
byte bkcolor;
x = 14;
y = 11;
for ( int a=0;a<6;a++ )
if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE; else bkcolor=COLOR_GRAY;
ReefAngel.LCD.DrawText(0,255,18,26,"GT"); //18 left, 10 down
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 37, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,57,26,"DT"); //57 left, 10 down
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 50, 37, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,94,26,"Res"); //94 left, 10 down
ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 90, 37, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,16,52,"DT pH"); //18 left, 39 down
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 15, 65, text, Num8x8);
ReefAngel.LCD.DrawText( 0,255,57,52, "GT pH"); //57 left, 39 down
ConvertNumToString(text, ReefAngel.Params.PHExp, 100);
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 55, 65, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,100,52,"Sal"); //100 left, 39 down
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 98, 65, text, Num8x8);
ReefAngel.LCD.DrawOutletBox( 12, 80, TempRelay );
// Relay Expansion
// Relay Expansion
TempRelay = ReefAngel.Relay.RelayDataE[1];
TempRelay &= ReefAngel.Relay.RelayMaskOffE[1];
TempRelay |= ReefAngel.Relay.RelayMaskOnE[1];
// ReefAngel.LCD.DrawGraph( 5, 5 );
broken feeding mode
• Page 1 of 2 • 1, 2
Joined: Sat Jan 14, 2012 2:08 pm Location: Montgomery Village, MD |
Please help me fix my feeding mode. I have three relay boxes. on box 1, ReefAngel.FeedingModePortsE[0], does not turn off. On box 2, ReefAngel.FeedingModePortsE[1], port7bit turns off, but port8bit does not. Thx in advance
Building new 29g Nano after landlord went berserk over my 4 75 gallon tanks, Multiple RA's, Water mixing stations, etc. Your help welcomed in remembering all I've forgotten. |
What are you considering box1?
Sounds like you need to set ReefAngel.FeedingModePorts=Port7Bit; and ReefAngel.FeedingModePortsE[0]=Port7Bit|Port8Bit; |
i have my first relay box, hereafter called box0, with nothing on it that needs switching off. I have what I call box1, addressed as Box1_portX, and Box2_portX. There is one port on box1 that needs switching off, port 8, and two ports on box2, ports 7 & 8
still no change, plus something I noticed two nites ago and it played out again last night, my swabbie comes on at 1:00 AM and stays on until 4:00 AM. Has to be something with my new code. Please take a look.
The code for the swabbie looks good but you have to check what the memory locations hold...as that could change it drastically
how do I do that? Would that be affecting the feeding mode\water change as well? Thx
Dont think so...
For reading/writing memory http://reefangelwifi:2000/mbX,Y Where X is the location and Y is the value. If you want to read leave off the ,Y |
is there a post that tells where everything sits in memory? Thx
ok, so following your advice I tested memory locations 115 and 116 and both had the value of 255 in them. Going from there, I used the utility to reset 115 to 6 and 116 to 1 as stated in my code.
I would have thought the memory calls in the code should have set them, but obviously no. Should I check all my locations as stated in the code and set them to the proper values? Roscoe's Reefs - Starting Over Again:
lee is this why my mem locations are not being updated:
InternalMemory.write(Mem_B_ResetMemory,false); Roscoe's Reefs - Starting Over Again:
