Nutrient transport mode ?
PostPosted: Wed Oct 23, 2013 8:32 am
This is my graph of the dimming channel I am using for my tunzes.
Using the nutrient transport mode is the % supposed to drop down below the set min? I have it set for 30% minimum but as you can see its still dropping down to where the pump doesn't run. Also there are times where it will go to 0% for a few minutes.
My code reads like this
ReefAngel.PWM.SetDaylight( NutrientTransportMode (30,90,920,False) );
If I need to post the whole code I can but I can't do it from my phone right now.
PostPosted: Wed Oct 23, 2013 8:51 am
There is something else going on with your channel, because the NTM waveform is not like that.
I just simulated it on a controller using only the function you posted and this is what I got:
Can you post the entire code so we can see if there is something else using the same channel?
PostPosted: Wed Oct 23, 2013 12:00 pm
Yea I can post the whole code in a few hours. I am using 2 modes one for night and one for day but the NTM is the only mode where the pump drops below 30%. The other mode you are seeing on my graph is reef crest but the % is always >30 on that mode
PostPosted: Wed Oct 23, 2013 12:01 pm
But your graph answers my question because the line does fall below 30%
Return to My PDE/INO file
