what do you think??
wijigong
what do you think??
Post by wijigong »
is that everything seems ok
i have one meanwell on the daylight
and the actinic port is set to moonlight
thank you
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
byte DaylightPWMValue=0;
//custom dysplay temp+on and off relay
   byte x = 6;
   byte y = 2;
   byte t;
   ReefAngel.LCD.DrawDate(6, 2);
   x = 12;
   y += MENU_START_ROW+1;
   char text[7];
   ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
   y += MENU_START_ROW*2;
   x = 10;
   ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, x, y,text);
   x += (16*4) + 8;
   ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
   randomSeed(analogRead(0));
   ReefAngel.Timer[1].SetInterval(random(10,InternalMemory.WM1Timer_read()));
   ReefAngel.Timer[1].Start();
   ReefAngel.Relay.On(Port6);
   ReefAngel.FeedingModePorts = B00110000;
   ReefAngel.OverheatShutoffPorts = B00001110;
   ReefAngel.WaterChangePorts = B11110001;
   ReefAngel.Relay.On(Port8);
   ReefAngel.Relay.On(Port7);
  DaylightPWMValue=PWMSlope(12,30,20,00,10,100,40,DaylightPWMValue);
  CheckCloud();
  MoonPhase();
  ReefAngel.StandardLights(Port3, 10, 00, 22, 00);
  ReefAngel.StandardHeater(Port4);
  //ReefAngel.StandardATO(Port1);
  //wave maker fonction with night mode
   if ( (hour() >= 22) || (hour() <= 8) ) // from 10p - 8a
      ReefAngel.Relay.Off(Port6);
      ReefAngel.Relay.On(Port5);
      // during the day
         ReefAngel.Timer[1].SetInterval(random(25,50));
         ReefAngel.Relay.Toggle(Port6);
         ReefAngel.LCD.BacklightOn();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          DaylightPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
    if (lightningchance)
      int x=0;
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
Re: what do you think??
Looks good to me.
wijigong
Post by wijigong »
the last one i need is to have the DP on the display
i try couple of line butt nothing working
Try this:
   byte x = 6;
   byte y = 2;
   byte t;
   x = 12;
   char text[7];
   x = 10;
   ConvertNumToString(text, ReefAngel.PWM.GetDaylightValue(), 1);
   y += MENU_START_ROW*3;
   x = 10;
   ReefAngel.LCD.DrawHugeNumbers(DPColor, DefaultBGColor, x, y,text);
  CheckCloud();
  MoonPhase();
      // during the day
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
          DaylightPWMValue=0;
        delay(1);
      cloudindex++;
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
