Let's Build Troubadour11's Code
PostPosted: Thu Jul 23, 2015 7:56 am
Thanks so much for the speedy help. :D I knew I had to be missing how to input the variables.
So I inserted this into my code between the heater ports and light cycle like in the example from the wizard:
    ReefAngel.StandardHeater(Port1);
    ReefAngel.StandardHeater(Port2);
    ////// Place your custom code below here //////
    //Sets Port 7 on the Power Unit to a dosing pump running for 5 seconds every 2 hours.
    ReefAngel.DosingPumpRepeat( Port7,0,120,5 );
    //Set up for Refugium and Phytoplankton light cycle
Was I also correct to exclude Port7 from the "always on" list then?
    //Ports that are always on
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    //ReefAngel.Relay.On( Port7 );
      // Port1 = Heater
      // Port2 = Heater
      // Port3 = Refugium Light
      // Port4 = Phyto Light
      // Port5 = Return Pump
      // Port6 = Protein Skimmer
      // Port7 = Dosing Pump
      // Port8 = Refugium Pump
    ////// Place additional initialization code below here //////
And I also removed Portbit7 from the water change function since I had a different pump on here.
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit;
All right. So the code verified and looks like it's good to go. It's time for me to head off to work this morning. So I'm going to upload my modified full code and set up the vinegar dripping into a measuring cup to test it out during the day while at work. Hopefully I come home to the proper amount and will have this all set up and ready to go for my tank sitter :)
I'll try to report back on the results before I head out of town :D
Current full code:
//Start of PWM Expansion Code Header
//This is just how we are going to reference the PWM expansion ports within the code.
//You can change the labels if you would like, just as long as they are changed all throughout the code too.
                  //Standard PowerRelay PWM Daylight = L-DT White/Color
                  //Standard PowerRelay PWM Actinic = L-DT Blue/UV
#define LEDPWM0 0 // R-DT = White/Color
#define LEDPWM1 1 // R-DT = Blue/UV
#define LEDPWM2 2 // L-DT = MoonLight
#define LEDPWM3 3 // R-DT = Moonlight
#define LEDPWM4 4 // - EMPTY -
#define LEDPWM5 5 // - EMPTY -
//Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={0,0,0,0,0,0};
//End of PWM Expansion Code Header
// - Creates a variable to control a "force cloud function" inside a menu.
boolean ForceCloud=false;
//added for custom menu set up
#include <avr/pgmspace.h>
// Create the menu entries
prog_char menu6_label[] PROGMEM = "Date / Time";
prog_char menu7_label[] PROGMEM = "Version";
prog_char menu8_label[] PROGMEM = "Storm Effect";
PROGMEM const char *menu_items[] = {menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label};
// Creating the custom menu fucntions. menu2_label corresponds to MenuEntry2 funtion
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
// Trying to add a menu to the RA Head Unit so I can trigger a cloud effect on demand.
void MenuEntry8()
ForceCloud=true;
////// Place global variable code below here //////
byte LDT_DaylightPWMValue=0;
byte LDT_ActinicPWMValue=0;
byte LDT_MoonLightANALOGValue=0;
byte RDT_DaylightPWMValue=0;
byte RDT_ActinicPWMValue=0;
byte RDT_MoonLightANALOGValue=0;
////// Place global variable code above here //////
    //This must be the first line.
    // Initialize the custom menu
    ReefAngel.AddStandardMenu();  // Add Standard Menu
      // Port1 = Heater
      // Port2 = Heater
// ***PLEASE HELP HERE********************************************************************************************************************************************
     //Sets values of ALL lighting channels to 0% on Start Up correctly, I think.
     ReefAngel.PWM.SetDaylight(0);
     ReefAngel.PWM.SetActinic(0);
     ReefAngel.PWM.SetChannel(LEDPWM0,0);
     ReefAngel.PWM.SetChannel(LEDPWM1,0);
     ReefAngel.PWM.SetChannel(LEDPWM2,0);
     ReefAngel.PWM.SetChannel(LEDPWM3,0);
     ReefAngel.PWM.SetChannel(LEDPWM4,0);
     ReefAngel.PWM.SetChannel(LEDPWM5,0);
     // I believe using this got rid of my bright flash to 100% when I uploaded new code. Specifically setting the Standard Daylight/Actinic
    // Adds the date and time menu to controller so I can change for Daylight Savings Time. **Takes up memory space**
    // - Can be removed after change or adding wifi. Time can be changed in portal or through phone app. eventually
    //ReefAngel.AddDateTimeMenu();
    ////// Place additional initialization code above here //////
    //USE THIS TO TOGGLE PORTS ON/OFF - ReefAngel.StandardLight(relay,onhour,onminute,offhour,offminute)
     //Turns Refugium Light plugged into port3 on at 9:30 pm and off at 9:30 am.
     ReefAngel.StandardLights(Port3,21,30,9,30);
     //Turns Phyto Light plugged into port4 on at 9:30 pm and off at 9:30 am.
     ReefAngel.StandardLights(Port4,21,30,9,30);
                                   //// Calculate your regular sunrise/sunset PWM values ////
 //_____________________________________________________________________________________________________________
    // - Turns RDT - B/UV channel to 0% power between 8:55 p.m. and 10:00 a.m. to conserve energy
    // - Dimming Expansion - LEDPWM1 - RDT Blue/UV -
    // - Parabola dimming 11%-100%-11%
 if ((NumMins(hour(now()),minute(now())) > NumMins(10,00)) && (NumMins(hour(now()),minute(now())) < NumMins(20,55)))
         RDT_ActinicPWMValue=PWMSlope(10,00,20,55,11,100,240,RDT_ActinicPWMValue);
    // - Turns LDT - B/UV channel to 0% power between 9:05 p.m. and 10:15 p.m. to conserve energy
    // - RA Standard Power Unit - LDT Blue/UV -
     if ((NumMins(hour(now()),minute(now())) > NumMins(10,15)) && (NumMins(hour(now()),minute(now())) < NumMins(21,05)))
        LDT_ActinicPWMValue=PWMSlope(10,15,21,05,11,100,240,LDT_ActinicPWMValue);
    // - Turns RDT - W/C channel to 0% power between 8:30 p.m. and 10:25 a.m. to conserve energy
    // - Dimming Expansion - RDT White/Color -
     if ((NumMins(hour(now()),minute(now())) > NumMins(10,25)) && (NumMins(hour(now()),minute(now())) < NumMins(20,30)))
        RDT_DaylightPWMValue=PWMSlope(10,25,20,30,11,100,240,RDT_DaylightPWMValue);
    // - Turns LDT - W/C channel to 0% power between 8:45 p.m. and 10:35 a.m. to conserve energy
    // - RA Power Unit - LDT White/Color -
    // - Parabola dimming 11%-%100-11%
     if ((NumMins(hour(now()),minute(now())) > NumMins(10,35)) && (NumMins(hour(now()),minute(now())) < NumMins(20,45)))
        LDT_DaylightPWMValue=PWMSlope(10,35,20,45,11,100,240,LDT_DaylightPWMValue);
                                   //// Set MoonLights Cycles ////
    LDT_MoonLightANALOGValue=PWMSlope(10,30,21,00,10,100,240,PWMSlope(21,20,23,15,20,MoonPhase()/5+10,30,LDT_MoonLightANALOGValue=0));
    RDT_MoonLightANALOGValue=PWMSlope(10,20,20,50,10,100,240,PWMSlope(21,15,23,15,20,MoonPhase()/5+10,30,RDT_MoonLightANALOGValue=0));
    CheckCloud();
    ReefAngel.PWM.SetDaylight(LDT_DaylightPWMValue);
    ReefAngel.PWM.SetActinic(LDT_ActinicPWMValue);
    ReefAngel.PWM.SetChannel(LEDPWM2,LDT_MoonLightANALOGValue);
    ReefAngel.PWM.SetChannel(LEDPWM0,RDT_DaylightPWMValue);
    ReefAngel.PWM.SetChannel(LEDPWM1,RDT_ActinicPWMValue);
    ReefAngel.PWM.SetChannel(LEDPWM3,RDT_MoonLightANALOGValue);
    ////// Place your custom code above here //////
    //Connects Reef Angel Head Unit to the Portal through WiFi Unit.
    ReefAngel.Portal("troubadour11");
  // - My lighting is set up as:
  //      - LDT (Left Display Tank) fixture on the "Standard" 2 (PWM signal) slots on my power relay box.
  //      - RDT (Right Display Tank) fixture on channels 0=daylight and 1=actinic (PWM signal) of the Dimming Expansion.
  //      - Moonlights = channels 2 and 3 of the PWM expansion. These drivers are Analog and the jumper pins have been set for 0-10v Analog in Dimming Expansion.
 // - I'd like to calculate the cloud effect for the LDT lights using the "Weather Sim for Standard PWM" code which I think
 //   I got copied, set up, and working correctly for the 1 fixture on the Standard Ports.
 //                 - Then find a way to feed those values into the RDT lights with a "Random Sample" of + or - a small time offset for the cloud effect on the RDT
 //                                - This way I could randomly generate a weather sim, and randomly have the cloud move Right-to-Left or Left-to-Right each time a cloud occurs
//                  - Lightning effect could either be off set with a similar way with +/- value OR left sync'd to LDT lightning (would need to test what looks good).
//                  - Or possibly more or less lightning per fixture during cloud.
void CheckCloud()
  // I should create a random variable here to randomize the days it has clouds?
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 50
  // Minimum number of minutes for cloud duration.  Don't use min duration of less than 6.
#define Min_Cloud_Duration 6
#define Max_Cloud_Duration 12
#define Min_Clouds_per_Day 5
#define Max_Clouds_per_Day 15
     // In this example, start could happen after 11:30am
#define Start_Cloud_After NumMins(13,00)
     // In this example, end must be before 6:45pm
#define End_Cloud_Before NumMins(19,45)
  // Percentage chance of lightning happening for every cloud
#define Lightning_Change_per_Cloud 50
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen results could happen.
//____________________________________________________________________________________________________________________________________________________________
  //***Question***
  // Why do you have to double the amount of time from 250 to 500 in your example? - This is just a question to understand the programming better, I don't see why it needs to be doubled.
  // I see it in the code dividing by (numclouds*2), etc. What's the purpose of multiplying it up by 2? I'm just trying to learn on this question if you have time to explain. Thanks :-)
  //#define forcecloudcalculation // Uncomment this to force the cloud calculation to happen in the boot process.
  static byte cloudchance = 255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  //made individual lightningchance for each fixture
  static byte LDTlightningchance=0;
  //static byte RDTlightningchance=0;
  static byte cloudindex=0;
  //made separate lightning status for each fixture
  static byte LDTlightningstatus=0;
  //static byte RDTlightningstatus=0;
  static int LastNumMins=0;
  // - I created this value to use as +/- offset value to make clouds pass left-to-right or vice-versa.
  //static int RDTcloudstartOffset=0;
  // - I added this to use as a randomly chosen value between (-)x to y.
  // - This will be added to "cloudstart" in order to determine the start time of the RDT cloud effect.
  //static byte RDTcloudstart=0;
  // - I added this to create a random sample between 80% and 100% dimming power for "random" lightning intensity effect on each fixture.
  static byte LDT_LightningFlashPower=0;
  static byte RDT_LightningFlashPower=0;
  // - I added these to create a variable to randomize when and how long each lightning strike happens for each cloud.
  //LDTlightningRandomStart=0;
  //LDTlightningLength=0;
  //RDTlightningRandomStart=0;
  //RDTlightningLength=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        // pick a random number between these values to offset the RDT cloud by this many minutes
        //RDTcloudstartOffset=random(-1,1);
        // adds the random offset value to "cloudstart" and sets the cloudstart time for RDT light fixture
        //RDTcloudstart=cloudstart+RDTcloudstartOffset;
        LDTlightningchance=random(100);
        //RDTlightningchance=random(100);
        // if picked number is greater than Lightning_Change_per_Cloud, we will not have lightning on the next cloud.
        if (LDTlightningchance>Lightning_Change_per_Cloud) LDTlightningchance=0;
        //if (RDTlightningchance>Lightning_Change_per_Cloud) RDTlightningchance=0;
  // Now that we have all the parameters for the cloud, let's create the effect down below.
// Force Cloud from Menu Function jumps to here to start cloud effect immediately for a show!
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=8;
LDTlightningchance=1;
//RDTlightningchance=1;
cloudstart=NumMins(hour(),minute())+2;
//RDTcloudstart=NumMins(hour(),minute())+1;
  // - Controls Cloud and Lightning Effect timings for both fixtures
  if (cloudchance)
    //is it time for cloud yet over Left Display Tank?
      // - Dims LDT to create cloud and back up to Daylight Parabola. - maybe change to 11 in order to make minimum cloud power 11% so the lights don't click off.
      RDT_DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,RDT_DaylightPWMValue,10,180);
      LDT_DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,LDT_DaylightPWMValue,10,180);
      RDT_ActinicPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,RDT_DaylightPWMValue,20,180);
      LDT_ActinicPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,LDT_DaylightPWMValue,20,180);
      RDT_MoonLightANALOGValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,RDT_MoonLightANALOGValue,11,180);
      LDT_MoonLightANALOGValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,LDT_MoonLightANALOGValue,11,180);
      // To adjust possible length of time of lightning strike, Change the "second()< 5 " ... where 5 is the # of seconds of lightning during cloud.
      // and the "minute())=(cloudstart_(cloudduration/2)))" sets start time... dividing by 2 is exactly half way through cloud to trigger 5 seconds lightning.
      // if there is lightning and current time is 1/2 way through cloud, but less then 1/2 way through cloud + 5 seconds
     // if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/LDTlightningRandomStart))) && second()<LDTlightningLength)
      if (LDTlightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()<5)
        if (random(100)<20) LDTlightningstatus=1;
        else LDTlightningstatus=0;
        if (LDTlightningstatus)
               // - This will correctly flash lightning up to 100% power every lightning strike.
          //LDT_DaylightPWMValue=100;
          //LDT_ActinicPWMValue=100;
          // - Trying to make a random sample between, say 80% & 100% for the brightness of the lightning?
          // - If there will be lightning, pick a random number between 80 and 100 for the lightning power.
          LDT_LightningFlashPower=random(80,100);
          RDT_LightningFlashPower=random(80,100);
          RDT_DaylightPWMValue=RDT_LightningFlashPower;
          RDT_ActinicPWMValue=RDT_LightningFlashPower;
          RDT_MoonLightANALOGValue=RDT_LightningFlashPower;
          LDT_DaylightPWMValue=LDT_LightningFlashPower;
          LDT_ActinicPWMValue=LDT_LightningFlashPower;
          LDT_MoonLightANALOGValue=LDT_LightningFlashPower;
          // - Changed these values from 0 to 11 so at end of lightning cycle, the go to min. 11% power
          RDT_DaylightPWMValue=11;
          RDT_ActinicPWMValue=20;
          RDT_MoonLightANALOGValue=11;
          LDT_DaylightPWMValue=11;
          LDT_ActinicPWMValue=20;
          LDT_MoonLightANALOGValue=11;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
//// - I think this resets the random offset and cloudstart time for the RDT Fixture to match the new/next "cloudstart" time if there will be another cloud today ////
      int x=0;
    if (LDTlightningchance)
      int x=0;
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
  //End Cloud & Lighting
PostPosted: Thu Jul 23, 2015 8:12 am
Oh, I forgot to ask.
In the new code:
What does the 0 represent?
I get that you're telling the controller to do a repeating dosing pump cycle on Port 7. Every 120 minutes, for 5 seconds. Are those numbers always in minutes and seconds no matter what? Using the .DosingPump code tells it those will be minutes and seconds?
I just want to fully understand all the variables in case I ever need to modify it further. Thanks! :)
PostPosted: Thu Jul 23, 2015 8:36 am
Correct, minutes for repeat and seconds to run.
The 0 is for offset.
If you were to dose alk and Ca, you would want to offset both of them.
PostPosted: Sat Aug 08, 2015 10:33 am
So I didn't make it back to report the results before leaving town. But I was right at the amount expected after running a 12 hour test from 8am to 8pm. So I set it up into my sump and let it go. So far it seems to be working just fine!
Thanks so much for the timely help and for the follow up on the offset. Definitely good to know. If my system ever out-paces kalk dosing through my ATO, I'll be looking to use that to keep up.
Thanks again! :D
PostPosted: Sat Sep 10, 2016 12:39 pm
I've been wanting to figure out how to set up my light cycles on variables using custom memory locations. That way I should be able to access the variables and adjust them as I desire without having to break out my laptop and upload a new hard coded version every time, correct? Either through the portal or the RA android app?
I spent some time attempting to get it going. I'm sure I am missing some things since I wasn't getting the results I expected.
Here is a copy of my full code that is currently running (without the custom memory locations):
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
ForceCloud=true;
      // Port1 = Heater
      // Port2 = Heater
     //Turns Refugium Light plugged into port3 on at 10:30 pm and off at 5:30 am.
     ReefAngel.StandardLights(Port3,22,30,8,30);
     //Turns Phyto Light plugged into port4 on at 10:30 pm and off at 5:30 am.
     ReefAngel.StandardLights(Port4,22,30,8,30);
         //RDT_ActinicPWMValue=PWMSlope(10,00,20,55,11,100,240,RDT_ActinicPWMValue);
         RDT_MoonLightANALOGValue=PWMSlope(10,00,20,55,11,100,240,RDT_MoonLightANALOGValue);
         //RDT_ActinicPWMValue=0;
        //LDT_ActinicPWMValue=PWMSlope(10,15,21,05,11,100,240,LDT_ActinicPWMValue);
        LDT_MoonLightANALOGValue=PWMSlope(10,15,21,05,11,100,240,LDT_MoonLightANALOGValue);
        //LDT_ActinicPWMValue=0;
    // - Parabola dimming 11%-50%-11%
        RDT_DaylightPWMValue=PWMSlope(10,25,20,30,11,50,240,RDT_DaylightPWMValue);
        LDT_DaylightPWMValue=PWMSlope(10,35,20,45,11,50,240,LDT_DaylightPWMValue);
    //LDT_MoonLightANALOGValue=PWMSlope(10,30,21,00,10,100,240,PWMSlope(21,20,23,15,20,MoonPhase()/5+10,30,LDT_MoonLightANALOGValue=0));
    LDT_ActinicPWMValue=PWMSlope(10,30,21,00,10,100,240,PWMSlope(21,20,23,15,20,MoonPhase()/5+10,30,LDT_ActinicPWMValue=0));
    //RDT_MoonLightANALOGValue=PWMSlope(10,20,20,50,10,100,240,PWMSlope(21,15,23,15,20,MoonPhase()/5+10,30,RDT_MoonLightANALOGValue=0));
    RDT_ActinicPWMValue=PWMSlope(10,20,20,50,10,100,240,PWMSlope(21,15,23,15,20,MoonPhase()/5+10,30,RDT_ActinicPWMValue=0));
    CheckCloud();
void CheckCloud()
  //***Question***
#else
#endif
      if (cloudchance)
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=8;
  if (cloudchance)
        delay(1);
      cloudindex++;
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
To start out my attempt at setting this up, I used my refugium lights which are just 2 spots on a timer running on Port3 and Port4 of my power strip.
Here is how I modified the code... it resulted in my refugium lights being set to on at noon when I was testing it.
I added this section into the top, I copied the lines above and below what I added to clip out the changes;
void MenuEntry8()
ForceCloud=true;
//Define Custom Memory Locations
#define Mem_B_Refugium03_onHour    100
#define Mem_B_Refugium03_onMins    101
#define Mem_B_Refugium03_offHour   102
#define Mem_B_Refugium03_offMins   103
#define Mem_B_Refugium04_onHour    104
#define Mem_B_Refugium04_onMins    105
#define Mem_B_Refugium04_offHour   106
#define Mem_B_Refugium04_offMins   107
void init_memory() {
  InternalMemory.write(Mem_B_Refugium03_onHour,22);
  InternalMemory.write(Mem_B_Refugium03_onMins,30);
  InternalMemory.write(Mem_B_Refugium03_offHour,8);
  InternalMemory.write(Mem_B_Refugium03_offMins,30);
  InternalMemory.write(Mem_B_Refugium04_onHour,22);
  InternalMemory.write(Mem_B_Refugium04_onMins,30);
  InternalMemory.write(Mem_B_Refugium04_offHour,8);
  InternalMemory.write(Mem_B_Refugium04_offMins,30);
and then adjusted my refugium light schedule section like this:
     //Turns Refugium Light plugged into port3 on/off at times specified by internal memory via web or app
         InternalMemory.read(Mem_B_Refugium03_onHour),
         InternalMemory.read(Mem_B_Refugium03_onMins),
         InternalMemory.read(Mem_B_Refugium03_offHour),
         InternalMemory.read(Mem_B_Refugium03_offMins));
     //Turns Refugium Light plugged into port3 on at 10:30 pm and off at 5:30 am. - older code
     //ReefAngel.StandardLights(Port3,22,30,5,30); - old code
     //Turns Refugium Light plugged into port4 on/off at times specified by internal memory via web or app
         InternalMemory.read(Mem_B_Refugium04_onHour),
         InternalMemory.read(Mem_B_Refugium04_onMins),
         InternalMemory.read(Mem_B_Refugium04_offHour),
         InternalMemory.read(Mem_B_Refugium04_offMins));
     //Turns Phyto Light plugged into port4 on at 10:30 pm and off at 5:30 am. - old code
     //ReefAngel.StandardLights(Port4,22,30,5,30); - old code
My only guess right now is that I need to create custom global variables and set them to the InternalMemory.read?
So create the variables for each custom memory location and set them like this?
byte Refugium03_onHour=InternalMemory.read(Mem_B_Refugium03_onHour);
And then insert each custom variable into the light schedule code similar to this?
     ReefAngel.StandardLights(Port3,Refugium03_onHour,Refugium03_onMins,Refugium03_offHour,Refugium03_offMins);
I appreciate any help I can get on setting this up. I'd love to be able to adjust my light schedule quickly and easily at times. This can open the door to controlling a lot more things eventually without having to hard code the values.
Then once I get it coded right, I need to find them via the app or portal. This previous attempt didn't yield many results as I couldn't find any Mem_B_Refugium03_onHour , etc. labels anywhere. But first, I need to make sure it's coded to work right and then I can go about finding them to be able to adjust them.
PostPosted: Sun Sep 11, 2016 10:21 am
Now I have another question and need some help with the DelayedOn command for my skimmer. I really do not understand why this is not working.
Here is a copy of my working code without the custom memory stuff I'm also working on where I tried to add in a simple delayed start for my skimmer so it doesn't over flow at times. It seemed like this would be easy to implement. I commented out Port6 from the always on list in the start up and added the delayed on command at the beginning of my main loop.
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
ForceCloud=true;
    //ReefAngel.Relay.On( Port6 ); // removed to add delayed start feature to skimmer in main loop
      // Port1 = Heater
      // Port2 = Heater
    // Always on ports that have a delay. These ports will delay turning on for the specified MINUTE_DELAY during the following modes:
      // Controller Power Up
      // Feeding Mode (if toggled during mode)
      // Water Change Mode (if toggled during mode)
    // This function needs to be placed inside loop() and not inside setup()
    // Usage is DelayedOn(PORT, MINUTE DELAY)
    ReefAngel.DelayedOn(Port6, 5);
    CheckCloud();
void CheckCloud()
  //***Question***
#else
#endif
      if (cloudchance)
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=8;
  if (cloudchance)
        delay(1);
      cloudindex++;
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
I looked up both the example files and code examples here in the forum and I can't find anything that I'm doing incorrectly.
When I try to verify the code, I get the following error:
Watchdog Timer
Version Menu
Dimming Expansion Module
Dimming Signal
Wifi Attachment
Date/Time Setup Menu
Custom Menu
2014 Main Screen
Number of Menu Options: 8
sketch_sept_11a_delayedOn.cpp: In function 'void setup()':
sketch_sept_11a_delayedOn:148: error: 'class ReefAngelClass' has no member named 'DelayedOn'
I was previously already running libraries 1.1.3 but had upgraded them from an old installer. Since it was not finding the class, I backed up my sketches, uninstalled the controller, deleted my documents/arduino and programs/arduino folders, restarted the computer, and re-installed from the ReefAngelInstaller_1.1.3 installer.
When I opened it back up, I'm still getting the same error. Based off the reference material I found, I'm not sure how else I'm supposed to use it in order to get it to function.
PostPosted: Sun May 05, 2019 11:04 am
Hi,
I was wondering if anyone could help me set up a variable that change be changed via the app rather then hard-coded and requiring me to hook up a computer to the head-unit in order to change a function.
I am currently running a dosing pump off of one of my outlets and would like to be able to adjust the primary variables for it (how often it runs, and for how long).
Currently my code has this in there driving the pump.
So I'm assuming somewhere within the outer loop I'll need to create and declare 2 primary variables like "Dos7_HRinterval" and "Dos7_SECrun" for the interval hours and run-time seconds. Then drop that into above code similar to:
    ReefAngel.DosingPumpRepeat( Port7,0,Dos7_HRinterval,Dos7_SECrun );
Beyond that, how do I access and connect those custom variables to the Reef Angel app on my phone so I can adjust values such as these without uploading new hard-coded values to the head-unit every time?
I see the "Memory" section in the app with the ability to see some variables that look to be there by default inside the code builder. But I'd like to get a clear example set up the connection between my dosing pump, the code, and the app all the way through. The memory page in the app I believe is where I would be able to access and change those custom variables in my above example? If I could get this example working, I could then extrapolate it out to other potential variables as well for things such as lighting schedules (pmw & analog slope curves ), etc?
Thanks in advance for anyone willing to help out. Very much appreciated :)
Here is the current full version of my code running on the head unit:
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
ForceCloud=true;
      // Port1 = Heater
      // Port2 = Heater
    CheckCloud();
void CheckCloud()
  //***Question***
#else
#endif
      if (cloudchance)
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=8;
  if (cloudchance)
        delay(1);
      cloudindex++;
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
PostPosted: Sun May 05, 2019 3:26 pm
Are you already using DosingPump built-in variables for Pump1,2, and 3?
For the DelayedOn issue, the post was old, so if you haven't figured it out, it should have been ReefAngel.Relay.DelayedOn(...); but you didn't include your code to confirm.
PostPosted: Sun May 05, 2019 5:27 pm
Hello, hello :-)
No, I never did get the delayed on set up. That was the last time I was trying to update my code. But now I'm hitting a point I need to adjust the dosing pump and I'd love to be able to do it through the app if it's possible instead of having to upload new hard code.
I'm sorry, I thought I included my currently running code at the end of the last post.
I'll try it again here. I believe this is what I currently have loaded into my head unit:
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
ForceCloud=true;
      // Port1 = Heater
      // Port2 = Heater
    CheckCloud();
void CheckCloud()
  //***Question***
#else
#endif
      if (cloudchance)
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=8;
  if (cloudchance)
        delay(1);
      cloudindex++;
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
PostPosted: Sun May 05, 2019 5:40 pm
lnevo wrote:Are you already using DosingPump built-in variables for Pump1,2, and 3?
I believe the only thing that I know of driving my dosing pump is this code right after the heater declaration just inside the void loop start.
other then that line of code, I have the "always on" port commented out for the dosing pump on port 7 so that it's off unless driven by the above code. Or at least I thought that is what was happening.
// Port1 = Heater
// Port2 = Heater
Other then that I haven't set up or used anything to drive it. The built-in dosing pump variables for Pump 1,2,3 you mentioned. I can see in the Memory Location inside the app spots for Dosing Pump 1 & 2 with options for "On Hour" & On Minute, Repeat Interval, & Timer. Are these the correct pump variables you're referring to?
If yes, does that mean I can use those built-in options just dropped into the code running the dosing pump on port7 and easily change them via the app?
Basically drop built-in variables into this?:
Thanks again for looking at things for me.
PreviousNext
Return to My PDE/INO file
