So I don't have much time to go into details here. But after a bit of trouble shooting on the above code. I got things working better over last weekend.
The Refugium and Phyto lights turn on/off correctly. And the Moonlights are running on their correct time schedules with the new nested code.
Here's the latest version that I have loaded up to the head unit and running for the last few days.
//Start of PWM Expansion Code Header
//This is just how we are going to reference the PWM expansion ports within the code.
//You can change the labels if you would like, just as long as they are changed all throughout the code too.
//Standard PowerRelay PWM Daylight = L-DT White/Color
//Standard PowerRelay PWM Actinic = L-DT Blue/UV
#define LEDPWM0 0 // R-DT = White/Color
#define LEDPWM1 1 // R-DT = Blue/UV
#define LEDPWM2 2 // L-DT = MoonLight
#define LEDPWM3 3 // R-DT = Moonlight
#define LEDPWM4 4 // - EMPTY -
#define LEDPWM5 5 // - EMPTY -
//Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={0,0,0,0,0,0};
//End of PWM Expansion Code Header
// - Creates a variable to control a "force cloud function" inside a menu.
boolean ForceCloud=false;
//added for custom menu set up
#include <avr/pgmspace.h>
// Create the menu entries
prog_char menu6_label[] PROGMEM = "Date / Time";
prog_char menu7_label[] PROGMEM = "Version";
prog_char menu8_label[] PROGMEM = "Storm Effect";
PROGMEM const char *menu_items[] = {menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label};
// Creating the custom menu fucntions. menu2_label corresponds to MenuEntry2 funtion
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
// Trying to add a menu to the RA Head Unit so I can trigger a cloud effect on demand.
void MenuEntry8()
ForceCloud=true;
////// Place global variable code below here //////
byte LDT_DaylightPWMValue=0;
byte LDT_ActinicPWMValue=0;
byte LDT_MoonLightANALOGValue=0;
byte RDT_DaylightPWMValue=0;
byte RDT_ActinicPWMValue=0;
byte RDT_MoonLightANALOGValue=0;
////// Place global variable code above here //////
//This must be the first line.
// Initialize the custom menu
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port7Bit;
//Ports that are always on
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
// Port1 = Heater
// Port2 = Heater
// Port3 = Refugium Light
// Port4 = Phyto Light
// Port5 = Return Pump
// Port6 = Protein Skimmer
// Port7 = UV Sterilizer
// Port8 = Refugium Pump
////// Place additional initialization code below here //////
// ***PLEASE HELP HERE********************************************************************************************************************************************
//Sets values of ALL lighting channels to 0% on Start Up correctly, I think.
ReefAngel.PWM.SetDaylight(0);
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetChannel(LEDPWM0,0);
ReefAngel.PWM.SetChannel(LEDPWM1,0);
ReefAngel.PWM.SetChannel(LEDPWM2,0);
ReefAngel.PWM.SetChannel(LEDPWM3,0);
ReefAngel.PWM.SetChannel(LEDPWM4,0);
ReefAngel.PWM.SetChannel(LEDPWM5,0);
// I believe using this got rid of my bright flash to 100% when I uploaded new code. Specifically setting the Standard Daylight/Actinic
// Adds the date and time menu to controller so I can change for Daylight Savings Time. **Takes up memory space**
// - Can be removed after change or adding wifi. Time can be changed in portal or through phone app. eventually
//ReefAngel.AddDateTimeMenu();
////// Place additional initialization code above here //////
ReefAngel.StandardHeater(Port1);
ReefAngel.StandardHeater(Port2);
////// Place your custom code below here //////
//Set up for Refugium and Phytoplankton light cycle
//USE THIS TO TOGGLE PORTS ON/OFF - ReefAngel.StandardLight(relay,onhour,onminute,offhour,offminute)
//Turns Refugium Light plugged into port3 on at 9:30 pm and off at 9:30 am.
ReefAngel.StandardLights(Port3,21,30,9,30);
//Turns Phyto Light plugged into port4 on at 9:30 pm and off at 9:30 am.
ReefAngel.StandardLights(Port4,21,30,9,30);
//if ((NumMins(hour(now()),minute(now())) > NumMins(21,30)) && (NumMins(hour(now()),minute(now())) < NumMins(9,30)))
// ReefAngel.Relay.On( Port3 );
// ReefAngel.Relay.On( Port4 );
// else
// ReefAngel.Relay.Off( Port3 );
// ReefAngel.Relay.Off( Port4 );
//// Calculate your regular sunrise/sunset PWM values ////
//_____________________________________________________________________________________________________________
// - Turns RDT - B/UV channel to 0% power between 8:30 p.m. and 11:00 a.m. to conserve energy
// - Dimming Expansion - LEDPWM1 - RDT Blue/UV -
// - Parabola dimming 11%-85%-11%
if ((NumMins(hour(now()),minute(now())) > NumMins(11,00)) && (NumMins(hour(now()),minute(now())) < NumMins(20,30)))
RDT_ActinicPWMValue=PWMParabola(11,00,20,20,11,85,RDT_ActinicPWMValue);
// - Turns LDT - B/UV channel to 0% power between 9:00 p.m. and 11:15 p.m. to conserve energy
// - RA Standard Power Unit - LDT Blue/UV -
if ((NumMins(hour(now()),minute(now())) > NumMins(11,15)) && (NumMins(hour(now()),minute(now())) < NumMins(21,00)))
LDT_ActinicPWMValue=PWMParabola(11,15,20,50,11,85,LDT_ActinicPWMValue);
// - Turns RDT - W/C channel to 0% power between 8:30 p.m. and 11:25 a.m. to conserve energy
// - Dimming Expansion - RDT White/Color -
// - Parabola dimming 11%-60%-11%
if ((NumMins(hour(now()),minute(now())) > NumMins(11,25)) && (NumMins(hour(now()),minute(now())) < NumMins(20,30)))
RDT_DaylightPWMValue=PWMParabola(11,25,20,40,11,60,RDT_DaylightPWMValue);
// - Turns LDT - W/C channel to 0% power between 9:00 p.m. and 11:40 a.m. to conserve energy
// - RA Power Unit - LDT White/Color -
if ((NumMins(hour(now()),minute(now())) > NumMins(11,40)) && (NumMins(hour(now()),minute(now())) < NumMins(21,00)))
LDT_DaylightPWMValue=PWMParabola(11,40,21,10,11,60,LDT_DaylightPWMValue);
//// Set MoonLights Cycles ////
LDT_MoonLightANALOGValue=PWMParabola(11,40,21,00,10,30,PWMSlope(21,20,23,15,10,MoonPhase()/5+10,30,LDT_MoonLightANALOGValue=0));
RDT_MoonLightANALOGValue=PWMParabola(11,25,20,30,10,30,PWMSlope(21,15,23,15,10,MoonPhase()/5+10,30,RDT_MoonLightANALOGValue=0));
//_________________________________________________________________________________________________________________________________________________
// - Turns RDT Moonlights to 0% power between 11:15 p.m. and 9:15 p.m. to conserve energy.
// - Slope dimming 10% up to 1/5 * MoonPhase +10 (to offest for 10% min driver start power). Fades up to current Moonphase over 30 minutes.
// - Dimming Expansion - LEDPWM3 - RDT Moonlight - on @ 9:15 p.m. - off @ 11:15 p.m.
//if ((NumMins(hour(now()),minute(now())) > NumMins(23,15)) && (NumMins(hour(now()),minute(now())) < NumMins(11,45)))
// RDT_MoonLightANALOGValue=0;
// //ReefAngel.PWM.SetChannel(LEDPWM3,0);
// else if ((NumMins(hour(now()),minute(now())) > NumMins(11,40)) && (NumMins(hour(now()),minute(now())) < NumMins(20,30)))
// RDT_MoonLightANALOGValue=PWMParabola(11,40,20,30,10,30,RDT_MoonLightValue));
//ReefAngel.PWM.SetChannel(LEDPWM3,PWMParabola(11,40,20,30,10,30,LEDPWM3));
// else
// RDT_MoonLightANALOGValue=PWMSlope(21,15,23,15,10,MoonPhase()/5+10,30,RDT_MoonLightValue));
//ReefAngel.PWM.SetChannel(LEDPWM3,PWMSlope(21,15,23,15,10,MoonPhase()/5+10,30,LEDPWM3));
// - Turns LDT Moonlights to 0% power between 11:30 p.m. and 9:30 p.m. to conserve energy
// - Slope dimming - 10% up to 1/5 * MoonPhase +10 (to offest for 10% min driver start power). Fades up to current Moonphase over 30 minutes
// - Dimming Expansion - LEDPWM2 - LDT Moonlight - on @ 9:30 p.m. - off @ 11:30 a.m.
//if ((NumMins(hour(now()),minute(now())) > NumMins(23,30)) && (NumMins(hour(now()),minute(now())) < NumMins(21,35)))
// LDT_MoonLightANALOGValue=0;
//ReefAngel.PWM.SetChannel(LEDPWM2,0);
// else if ((NumMins(hour(now()),minute(now())) > NumMins(11,55)) && (NumMins(hour(now()),minute(now())) < NumMins(21,00)))
// LDT_MoonLightANALOGValue=PWMParabola(11,40,20,30,10,30,LDT_MoonLightValue));
//ReefAngel.PWM.SetChannel(LEDPWM2,PWMParabola(11,55,21,00,10,30,LEDPWM2));
// else
// LDT_MoonLightANALOGValue=PWMSlope(21,15,23,15,10,MoonPhase()/5+10,30,LDT_MoonLightValue));
//ReefAngel.PWM.SetChannel(LEDPWM2,PWMSlope(21,30,23,30,10,MoonPhase()/5+10,30,LEDPWM2));
CheckCloud();
ReefAngel.PWM.SetDaylight(LDT_DaylightPWMValue);
ReefAngel.PWM.SetActinic(LDT_ActinicPWMValue);
ReefAngel.PWM.SetChannel(LEDPWM2,LDT_MoonLightANALOGValue);
ReefAngel.PWM.SetChannel(LEDPWM0,RDT_DaylightPWMValue);
ReefAngel.PWM.SetChannel(LEDPWM1,RDT_ActinicPWMValue);
ReefAngel.PWM.SetChannel(LEDPWM3,RDT_MoonLightANALOGValue);
////// Place your custom code above here //////
//Connects Reef Angel Head Unit to the Portal through WiFi Unit.
ReefAngel.Portal("troubadour11");
// - My lighting is set up as:
// - LDT (Left Display Tank) fixture on the "Standard" 2 (PWM signal) slots on my power relay box.
// - RDT (Right Display Tank) fixture on channels 0=daylight and 1=actinic (PWM signal) of the Dimming Expansion.
// - Moonlights = channels 2 and 3 of the PWM expansion. These drivers are Analog and the jumper pins have been set for 0-10v Analog in Dimming Expansion.
// - I'd like to calculate the cloud effect for the LDT lights using the "Weather Sim for Standard PWM" code which I think
// I got copied, set up, and working correctly for the 1 fixture on the Standard Ports.
// - Then find a way to feed those values into the RDT lights with a "Random Sample" of + or - a small time offset for the cloud effect on the RDT
// - This way I could randomly generate a weather sim, and randomly have the cloud move Right-to-Left or Left-to-Right each time a cloud occurs
// - Lightning effect could either be off set with a similar way with +/- value OR left sync'd to LDT lightning (would need to test what looks good).
// - Or possibly more or less lightning per fixture during cloud.
void CheckCloud()
// I should create a random variable here to randomize the days it has clouds?
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 50
// Minimum number of minutes for cloud duration. Don't use min duration of less than 6.
#define Min_Cloud_Duration 6
#define Max_Cloud_Duration 12
#define Min_Clouds_per_Day 5
#define Max_Clouds_per_Day 15
// In this example, start could happen after 11:30am
#define Start_Cloud_After NumMins(13,00)
// In this example, end must be before 6:45pm
#define End_Cloud_Before NumMins(19,45)
// Percentage chance of lightning happening for every cloud
#define Lightning_Change_per_Cloud 50
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen results could happen.
//____________________________________________________________________________________________________________________________________________________________
//***Question***
// Why do you have to double the amount of time from 250 to 500 in your example? - This is just a question to understand the programming better, I don't see why it needs to be doubled.
// I see it in the code dividing by (numclouds*2), etc. What's the purpose of multiplying it up by 2? I'm just trying to learn on this question if you have time to explain. Thanks :-)
//#define forcecloudcalculation // Uncomment this to force the cloud calculation to happen in the boot process.
static byte cloudchance = 255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
//made individual lightningchance for each fixture
static byte LDTlightningchance=0;
//static byte RDTlightningchance=0;
static byte cloudindex=0;
//made separate lightning status for each fixture
static byte LDTlightningstatus=0;
//static byte RDTlightningstatus=0;
static int LastNumMins=0;
// - I created this value to use as +/- offset value to make clouds pass left-to-right or vice-versa.
//static int RDTcloudstartOffset=0;
// - I added this to use as a randomly chosen value between (-)x to y.
// - This will be added to "cloudstart" in order to determine the start time of the RDT cloud effect.
//static byte RDTcloudstart=0;
// - I added this to create a random sample between 80% and 100% dimming power for "random" lightning intensity effect on each fixture.
static byte LDT_LightningFlashPower=0;
static byte RDT_LightningFlashPower=0;
// - I added these to create a variable to randomize when and how long each lightning strike happens for each cloud.
//LDTlightningRandomStart=0;
//LDTlightningLength=0;
//RDTlightningRandomStart=0;
//RDTlightningLength=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
// pick a random number between these values to offset the RDT cloud by this many minutes
//RDTcloudstartOffset=random(-1,1);
// adds the random offset value to "cloudstart" and sets the cloudstart time for RDT light fixture
//RDTcloudstart=cloudstart+RDTcloudstartOffset;
LDTlightningchance=random(100);
//RDTlightningchance=random(100);
// if picked number is greater than Lightning_Change_per_Cloud, we will not have lightning on the next cloud.
if (LDTlightningchance>Lightning_Change_per_Cloud) LDTlightningchance=0;
//if (RDTlightningchance>Lightning_Change_per_Cloud) RDTlightningchance=0;
// Now that we have all the parameters for the cloud, let's create the effect down below.
// Force Cloud from Menu Function jumps to here to start cloud effect immediately for a show!
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=8;
LDTlightningchance=1;
//RDTlightningchance=1;
cloudstart=NumMins(hour(),minute())+2;
//RDTcloudstart=NumMins(hour(),minute())+1;
// - Controls Cloud and Lightning Effect timings for both fixtures
if (cloudchance)
//is it time for cloud yet over Left Display Tank?
// - Dims LDT to create cloud and back up to Daylight Parabola. - maybe change to 11 in order to make minimum cloud power 11% so the lights don't click off.
RDT_DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,RDT_DaylightPWMValue,10,180);
LDT_DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,LDT_DaylightPWMValue,10,180);
RDT_ActinicPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,RDT_DaylightPWMValue,20,180);
LDT_ActinicPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,LDT_DaylightPWMValue,20,180);
RDT_MoonLightANALOGValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,RDT_MoonLightANALOGValue,11,180);
LDT_MoonLightANALOGValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,LDT_MoonLightANALOGValue,11,180);
// To adjust possible length of time of lightning strike, Change the "second()< 5 " ... where 5 is the # of seconds of lightning during cloud.
// and the "minute())=(cloudstart_(cloudduration/2)))" sets start time... dividing by 2 is exactly half way through cloud to trigger 5 seconds lightning.
// if there is lightning and current time is 1/2 way through cloud, but less then 1/2 way through cloud + 5 seconds
// if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/LDTlightningRandomStart))) && second()<LDTlightningLength)
if (LDTlightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()<5)
if (random(100)<20) LDTlightningstatus=1;
else LDTlightningstatus=0;
if (LDTlightningstatus)
// - This will correctly flash lightning up to 100% power every lightning strike.
//LDT_DaylightPWMValue=100;
//LDT_ActinicPWMValue=100;
// - Trying to make a random sample between, say 80% & 100% for the brightness of the lightning?
// - If there will be lightning, pick a random number between 80 and 100 for the lightning power.
LDT_LightningFlashPower=random(80,100);
RDT_LightningFlashPower=random(80,100);
RDT_DaylightPWMValue=RDT_LightningFlashPower;
RDT_ActinicPWMValue=RDT_LightningFlashPower;
RDT_MoonLightANALOGValue=RDT_LightningFlashPower;
LDT_DaylightPWMValue=LDT_LightningFlashPower;
LDT_ActinicPWMValue=LDT_LightningFlashPower;
LDT_MoonLightANALOGValue=LDT_LightningFlashPower;
// - Changed these values from 0 to 11 so at end of lightning cycle, the go to min. 11% power
RDT_DaylightPWMValue=11;
RDT_ActinicPWMValue=20;
RDT_MoonLightANALOGValue=11;
LDT_DaylightPWMValue=11;
LDT_ActinicPWMValue=20;
LDT_MoonLightANALOGValue=11;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
//// - I think this resets the random offset and cloudstart time for the RDT Fixture to match the new/next "cloudstart" time if there will be another cloud today ////
int x=0;
if (LDTlightningchance)
int x=0;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
//End Cloud & Lighting
Next up... getting my PH probe to read something more accurate then a constant value of 1. I've failed twice at getting it to calibrate correctly.
