Page 2 of 4
Re: Let's Build Troubadour11's Code
PostPosted: Thu Oct 02, 2014 1:31 pm
by troubadour11
Hi everyone,
So it's been awhile since I was last in here. I spent some time messing with the actual aquarium rather then the code stuff for the RA unit lately.
I did get the custom menu I was working on previously up and running. So I can easily test my storm function when I try to develop it further. Right now I have it working where it's firing the clouds and everything randomly. I had to step back a bit and remove the delay's and offsets. When I was trying to get that, one fixture wouldn't run the cloud sim at all. So I rolled back to having them both run correctly at the same time and will work on building in the offset more in the future.
Right now I do have a couple questions that maybe someone could help me solve.
The first place I could use a little help is just getting a couple relay's on the power strip turning on/off according to my time schedule. When I looked in the example code for switching relays, it looked like the command
ReefAngel.Relay.On( Port3 );
was what I needed to use. But I haven't been able to get Ports 3 and 4 to turn on/off via the code. I've been manually toggling them with the android app each day. I would love to get the code running it to remove a twice daily chore from my schedule.
Here is the beginning of my code from the void setup() and into the beginning of the void loop(). The Refugium and Phyto lights are on Ports 3 and 4 as noted in the set up section. And the if/else statement to toggle the ports on/off according to time is basically the first bit of code in my loop. There is more code beyond what I've pasted here, but that all has to do with dimming the LEDs and the storm function mostly.
    //This must be the first line.
    // Initialize the custom menu
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port7Bit;
    //Ports that are always on
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port7 );
      // Port1 = Heater
      // Port2 = Heater
      // Port3 = Refugium Light
      // Port4 = Phyto Light
      // Port5 = Return Pump
      // Port6 = Protein Skimmer
      // Port7 = UV Sterilizer
      // Port8 = Refugium Pump
    ////// Place additional initialization code below here //////
     //Sets values of ALL lighting channels to 0% on Start Up correctly, I think.
     ReefAngel.PWM.SetDaylight(0);
     ReefAngel.PWM.SetActinic(0);
     ReefAngel.PWM.SetChannel(LEDPWM0,0);
     ReefAngel.PWM.SetChannel(LEDPWM1,0);
     ReefAngel.PWM.SetChannel(LEDPWM2,0);
     ReefAngel.PWM.SetChannel(LEDPWM3,0);
     ReefAngel.PWM.SetChannel(LEDPWM4,0);
     ReefAngel.PWM.SetChannel(LEDPWM5,0);
     // I believe using this got rid of my bright flash to 100% when I uploaded new code. Specifically setting the Standard Daylight/Actinic
    // Adds the date and time menu to controller so I can change for Daylight Savings Time. **Takes up memory space**
    // - Can be removed after change or adding wifi. Time can be changed in portal or through phone app. eventually
    //ReefAngel.AddDateTimeMenu();
    ////// Place additional initialization code above here //////
    ReefAngel.StandardHeater(Port1);
    ReefAngel.StandardHeater(Port2);
    ////// Place your custom code below here //////
    //Set up for Refugium and Phytoplankton light cycle
 if ((NumMins(hour(now()),minute(now())) > NumMins(21,30)) && (NumMins(hour(now()),minute(now())) < NumMins(9,30)))
        ReefAngel.Relay.Off( Port3 );
        ReefAngel.Relay.Off( Port4 );
I currently have Ports 3 & 4 listed as "Always On" in the setup section in the above code and the lights show as always off on the android app. I can manually turn them on/off still with the phone as an override. I recently had the same above code with Ports 3 & 4 commented out in the set up "always on" section. This made no difference and the ports always stayed in the off position unless manually changed via the app.
I believe I previously tried reversing the time and the less-than/greater-than signs in the if/else statement. But that didn't seem to work and was awhile ago now. I've just been manually changing it since.
Any ideas why I'm failing to get this command to work?
The second thing I've been trying to figure out is why my moonlight drivers don't turn down to 0% when not in use. I have them coded in a similar way to my other lights which all show 0% at the appropriate times. However my 2 moonlight drivers turn to 2% and 3% whenever they are not running the lights.
Here is the section of code in my loop that deals with the LED drivers:
                                   //// Calculate your regular sunrise/sunset PWM values ////
 //_____________________________________________________________________________________________________________
    // - Turns RDT - B/UV channel to 0% power between 8:30 p.m. and 11:00 a.m. to conserve energy
    // - Dimming Expansion - LEDPWM1 - RDT Blue/UV -
    // - Parabola dimming 11%-85%-11%
 if ((NumMins(hour(now()),minute(now())) > NumMins(11,00)) && (NumMins(hour(now()),minute(now())) < NumMins(20,30)))
         RDT_ActinicPWMValue=PWMParabola(11,00,20,30,11,85,RDT_ActinicPWMValue);
         RDT_ActinicPWMValue=0;
    // - Turns LDT - B/UV channel to 0% power between 9:00 p.m. and 11:15 p.m. to conserve energy
    // - RA Standard Power Unit - LDT Blue/UV -
     if ((NumMins(hour(now()),minute(now())) > NumMins(11,15)) && (NumMins(hour(now()),minute(now())) < NumMins(21,00)))
        LDT_ActinicPWMValue=PWMParabola(11,15,21,00,11,85,LDT_ActinicPWMValue);
        LDT_ActinicPWMValue=0;
    // - Turns RDT - W/C channel to 0% power between 8:30 p.m. and 11:25 a.m. to conserve energy
    // - Dimming Expansion - RDT White/Color -
    // - Parabola dimming 11%-60%-11%
     if ((NumMins(hour(now()),minute(now())) > NumMins(11,25)) && (NumMins(hour(now()),minute(now())) < NumMins(20,30)))
        RDT_DaylightPWMValue=PWMParabola(11,25,20,30,11,60,RDT_DaylightPWMValue);
        RDT_DaylightPWMValue=0;
    // - Turns LDT - W/C channel to 0% power between 9:00 p.m. and 11:40 a.m. to conserve energy
    // - RA Power Unit - LDT White/Color -
     if ((NumMins(hour(now()),minute(now())) > NumMins(11,40)) && (NumMins(hour(now()),minute(now())) < NumMins(21,00)))
        LDT_DaylightPWMValue=PWMParabola(11,40,21,00,11,60,LDT_DaylightPWMValue);
        LDT_DaylightPWMValue=0;
    CheckCloud();
    ReefAngel.PWM.SetDaylight(LDT_DaylightPWMValue);
    ReefAngel.PWM.SetActinic(LDT_ActinicPWMValue);
    ReefAngel.PWM.SetChannel(LEDPWM0,RDT_DaylightPWMValue);
    ReefAngel.PWM.SetChannel(LEDPWM1,RDT_ActinicPWMValue);
                                   //// Set MoonLights Cycles ////
//_________________________________________________________________________________________________________________________________________________
    // - Turns RDT Moonlights to 0% power between 11:15 p.m. and 9:15 p.m. to conserve energy.
    // - Slope dimming 10% up to 1/5 * MoonPhase +10 (to offest for 10% min driver start power). Fades up to current Moonphase over 30 minutes.
    // - Dimming Expansion - LEDPWM3 - RDT Moonlight - on @ 9:15 p.m. - off @ 11:15 p.m.
if ((NumMins(hour(now()),minute(now())) > NumMins(23,15)) && (NumMins(hour(now()),minute(now())) < NumMins(11,45)))
      else if ((NumMins(hour(now()),minute(now())) > NumMins(11,40)) && (NumMins(hour(now()),minute(now())) < NumMins(20,30)))
        ReefAngel.PWM.SetChannel(LEDPWM3,PWMParabola(11,40,20,30,10,30,LEDPWM3));
       ReefAngel.PWM.SetChannel(LEDPWM3,PWMSlope(21,15,23,15,10,MoonPhase()/5+10,30,LEDPWM3));
    // - Turns LDT Moonlights to 0% power between 11:30 p.m. and 9:30 p.m. to conserve energy
    // - Slope dimming - 10% up to 1/5 * MoonPhase +10 (to offest for 10% min driver start power). Fades up to current Moonphase over 30 minutes
    // - Dimming Expansion - LEDPWM2 - LDT Moonlight - on @ 9:30 p.m. - off @ 11:30 a.m.
if ((NumMins(hour(now()),minute(now())) > NumMins(23,30)) && (NumMins(hour(now()),minute(now())) < NumMins(21,35)))
       else if ((NumMins(hour(now()),minute(now())) > NumMins(11,55)) && (NumMins(hour(now()),minute(now())) < NumMins(21,00)))
        ReefAngel.PWM.SetChannel(LEDPWM2,PWMParabola(11,55,21,00,10,30,LEDPWM2));
       ReefAngel.PWM.SetChannel(LEDPWM2,PWMSlope(21,30,23,30,10,MoonPhase()/5+10,30,LEDPWM2));
    ////// Place your custom code above here //////
I recently added in the "else if" statements to run my moonlight channels as additional actinic supplements during the day time. So my noted headers are not completely accurate for the times that I have programmed right now. But the moonlight drivers have been running during the day and moonlight times correctly. It is just when they are supposed to be turned off, they don't turn all the way to 0% like my other drivers that I am trying to solve.
My next step beyond asking for help is to try to create some variables for the moonlights similar to the variables I use for the daylight drivers. Then set the values that way and see if it fixes the issue. But I've been stuck on this for a bit now and thought someone might have a quick answer for me that would let me move on to other sections of the code.
Oh, and here is the current version of my entire code all in one spot if you're interested in seeing that:
//Start of PWM Expansion Code Header
//This is just how we are going to reference the PWM expansion ports within the code.
//You can change the labels if you would like, just as long as they are changed all throughout the code too.
                  //Standard PowerRelay PWM Daylight = L-DT White/Color
                  //Standard PowerRelay PWM Actinic = L-DT Blue/UV
#define LEDPWM0 0 // R-DT = White/Color
#define LEDPWM1 1 // R-DT = Blue/UV
#define LEDPWM2 2 // L-DT = MoonLight
#define LEDPWM3 3 // R-DT = Moonlight
#define LEDPWM4 4 // - EMPTY -
#define LEDPWM5 5 // - EMPTY -
//Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={0,0,0,0,0,0};
//End of PWM Expansion Code Header
// - Creates a variable to control a "force cloud function" inside a menu.
boolean ForceCloud=false;
//added for custom menu set up
#include <avr/pgmspace.h>
// Create the menu entries
prog_char menu1_label[] PROGMEM = "Feeding";
prog_char menu3_label[] PROGMEM = "ATO Clear";
prog_char menu4_label[] PROGMEM = "Overheat Clear";
prog_char menu5_label[] PROGMEM = "PH Calibration";
prog_char menu6_label[] PROGMEM = "Date / Time";
prog_char menu7_label[] PROGMEM = "Version";
prog_char menu8_label[] PROGMEM = "Storm Effect";
PROGMEM const char *menu_items[] = {menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label};
// Creating the custom menu fucntions. menu2_label corresponds to MenuEntry2 funtion
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
// Trying to add a menu to the RA Head Unit so I can trigger a cloud effect on demand.
void MenuEntry8()
ForceCloud=true;
////// Place global variable code below here //////
byte LDT_DaylightPWMValue=0;
byte LDT_ActinicPWMValue=0;
byte RDT_DaylightPWMValue=0;
byte RDT_ActinicPWMValue=0;
////// Place global variable code above here //////
      // Port1 = Heater
      // Port2 = Heater
// ***PLEASE HELP HERE********************************************************************************************************************************************
    CheckCloud();
    //Connects Reef Angel Head Unit to the Portal through WiFi Unit.
    ReefAngel.Portal("troubadour11");
  // - My lighting is set up as:
  //      - LDT (Left Display Tank) fixture on the "Standard" 2 (PWM signal) slots on my power relay box.
  //      - RDT (Right Display Tank) fixture on channels 0=daylight and 1=actinic (PWM signal) of the Dimming Expansion.
  //      - Moonlights = channels 2 and 3 of the PWM expansion. These drivers are Analog and the jumper pins have been set for 0-10v Analog in Dimming Expansion.
 // - I'd like to calculate the cloud effect for the LDT lights using the "Weather Sim for Standard PWM" code which I think
 //   I got copied, set up, and working correctly for the 1 fixture on the Standard Ports.
 //                 - Then find a way to feed those values into the RDT lights with a "Random Sample" of + or - a small time offset for the cloud effect on the RDT
 //                                - This way I could randomly generate a weather sim, and randomly have the cloud move Right-to-Left or Left-to-Right each time a cloud occurs
//                  - Lightning effect could either be off set with a similar way with +/- value OR left sync'd to LDT lightning (would need to test what looks good).
//                  - Or possibly more or less lightning per fixture during cloud.
void CheckCloud()
  // I should create a random variable here to randomize the days it has clouds?
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 50
  // Minimum number of minutes for cloud duration.  Don't use min duration of less than 6.
#define Min_Cloud_Duration 6
#define Max_Cloud_Duration 12
#define Min_Clouds_per_Day 5
#define Max_Clouds_per_Day 15
     // In this example, start could happen after 11:30am
#define Start_Cloud_After NumMins(13,00)
     // In this example, end must be before 6:45pm
#define End_Cloud_Before NumMins(19,45)
  // Percentage chance of lightning happening for every cloud
#define Lightning_Change_per_Cloud 50
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen results could happen.
//____________________________________________________________________________________________________________________________________________________________
  //***Question***
  // Why do you have to double the amount of time from 250 to 500 in your example? - This is just a question to understand the programming better, I don't see why it needs to be doubled.
  // I see it in the code dividing by (numclouds*2), etc. What's the purpose of multiplying it up by 2? I'm just trying to learn on this question if you have time to explain. Thanks :-)
  //#define forcecloudcalculation // Uncomment this to force the cloud calculation to happen in the boot process.
  static byte cloudchance = 255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  //made individual lightningchance for each fixture
  static byte LDTlightningchance=0;
  //static byte RDTlightningchance=0;
  static byte cloudindex=0;
  //made separate lightning status for each fixture
  static byte LDTlightningstatus=0;
  //static byte RDTlightningstatus=0;
  static int LastNumMins=0;
  // - I created this value to use as +/- offset value to make clouds pass left-to-right or vice-versa.
  //static int RDTcloudstartOffset=0;
  // - I added this to use as a randomly chosen value between (-)x to y.
  // - This will be added to "cloudstart" in order to determine the start time of the RDT cloud effect.
  //static byte RDTcloudstart=0;
  // - I added this to create a random sample between 80% and 100% dimming power for "random" lightning intensity effect on each fixture.
  static byte LDT_LightningFlashPower=0;
  static byte RDT_LightningFlashPower=0;
  // - I added these to create a variable to randomize when and how long each lightning strike happens for each cloud.
  //LDTlightningRandomStart=0;
  //LDTlightningLength=0;
  //RDTlightningRandomStart=0;
  //RDTlightningLength=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        // pick a random number between these values to offset the RDT cloud by this many minutes
        //RDTcloudstartOffset=random(-1,1);
        // adds the random offset value to "cloudstart" and sets the cloudstart time for RDT light fixture
        //RDTcloudstart=cloudstart+RDTcloudstartOffset;
        LDTlightningchance=random(100);
        //RDTlightningchance=random(100);
        // if picked number is greater than Lightning_Change_per_Cloud, we will not have lightning on the next cloud.
        if (LDTlightningchance>Lightning_Change_per_Cloud) LDTlightningchance=0;
        //if (RDTlightningchance>Lightning_Change_per_Cloud) RDTlightningchance=0;
  // Now that we have all the parameters for the cloud, let's create the effect down below.
// Force Cloud from Menu Function jumps to here to start cloud effect immediately for a show!
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=8;
LDTlightningchance=1;
//RDTlightningchance=1;
cloudstart=NumMins(hour(),minute())+2;
//RDTcloudstart=NumMins(hour(),minute())+1;
  // - Controls Cloud and Lightning Effect timings for both fixtures
  if (cloudchance)
    //is it time for cloud yet over Left Display Tank?
      // - Dims LDT to create cloud and back up to Daylight Parabola. - maybe change to 11 in order to make minimum cloud power 11% so the lights don't click off.
      RDT_DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,RDT_DaylightPWMValue,10,180);
      LDT_DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,LDT_DaylightPWMValue,10,180);
      RDT_ActinicPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,RDT_DaylightPWMValue,50,180);
      LDT_ActinicPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,LDT_DaylightPWMValue,50,180);
      // To adjust possible length of time of lightning strike, Change the "second()< 5 " ... where 5 is the # of seconds of lightning during cloud.
      // and the "minute())=(cloudstart_(cloudduration/2)))" sets start time... dividing by 2 is exactly half way through cloud to trigger 5 seconds lightning.
      // if there is lightning and current time is 1/2 way through cloud, but less then 1/2 way through cloud + 5 seconds
     // if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/LDTlightningRandomStart))) && second()<LDTlightningLength)
      if (LDTlightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()<5)
        if (random(100)<20) LDTlightningstatus=1;
        else LDTlightningstatus=0;
        if (LDTlightningstatus)
               // - This will correctly flash lightning up to 100% power every lightning strike.
          //LDT_DaylightPWMValue=100;
          //LDT_ActinicPWMValue=100;
          // - Trying to make a random sample between, say 80% & 100% for the brightness of the lightning?
          // - If there will be lightning, pick a random number between 80 and 100 for the lightning power.
          LDT_LightningFlashPower=random(80,100);
          RDT_LightningFlashPower=random(80,100);
          RDT_DaylightPWMValue=RDT_LightningFlashPower;
          RDT_ActinicPWMValue=RDT_LightningFlashPower;
          LDT_DaylightPWMValue=LDT_LightningFlashPower;
          LDT_ActinicPWMValue=LDT_LightningFlashPower;
          // - Changed these values from 0 to 11 so at end of lightning cycle, the go to min. 11% power
          RDT_DaylightPWMValue=11;
          RDT_ActinicPWMValue=50;
          LDT_DaylightPWMValue=11;
          LDT_ActinicPWMValue=50;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
//// - I think this resets the random offset and cloudstart time for the RDT Fixture to match the new/next "cloudstart" time if there will be another cloud today ////
      int x=0;
      if ((cloudstart/60)>=10) x=11; else x=17;
      if ((cloudstart%60)>=10) x=29; else x=35;
    if (LDTlightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
      if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
      ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
  //End Cloud & Lighting
PostPosted: Thu Oct 02, 2014 2:02 pm
First off great job on getting so far.
The issue with your moonlights is that you don't need all that if/then/else. Your first if is broken. I'll get back to that in a second..
Since you have different schedules you can nest them. The last argument in the slope and parabola functions is the previous value. You are passing the channel number which is 2/3 respectively. Replace that value with the second slope/parabola function. Since they each have their own time schedule they will work in tandem. No if/then/else required.
Now the reason your if is broken is because your asking RA if the time is later than 23:39 AND earlier than 21:35. Thats an impossible time since it can never meet both requirements. You can change it to || which is an OR question. This is a common mistake.
Finally for your always on ports...it may not sound intuitive but you will use the ReefAngel.StandardLight() function which takes the relay,onhour,onminute,offhour,offminute arguments to know when you want them to go on and then off.
Let me know if any if that makes sense :)
PostPosted: Fri Oct 03, 2014 1:58 pm
by troubadour11
Thanks for the help lnevo!
I think I have an idea of what you're getting at for it all.
First off, to solve the problem with my always on ports for the Refugium and Phyto lights. Does this look correct for toggling them on/off by time?
    //USE THIS TO TOGGLE PORTS ON/OFF - ReefAngel.StandardLight(relay,onhour,onminute,offhour,offminute)
     //Turns Refugium Light plugged into port3 on at 9:30 PM and off at 9:30 AM.
     ReefAngel.StandardLight(Port3,21,30,9,30);
     //Turns Phyto Light plugged into port4 on at 9:30 PM and off at 9:30 AM.
     ReefAngel.StandardLight(Port4,21,30,9,30);
And if I am understanding correctly. To run my Moonlight channels during the day, then night, and turn off outside of those hours. Is this how you're recommending setting them up by nesting them? Does the nesting of the functions look like I have the concept down correctly?
*note, I created the LDT_MoonLightPWMValue variable yesterday and use whatever value stored there to set the channel. More on how that was implemented at the bottom. But basically the same as all my other channels.
LDT_MoonLightPWMValue=PWMParabola(11,40,20,30,10,30,PWMSlope(21,15,23,15,10,MoonPhase()/5+10,30,LDT_MoonLightPWMValue=0))));
The above code should run this channel from 11:40 AM until 8:30 PM from 10%-30%-10%. Then turn them on from 9:15 PM until 11:15 PM using the slope function. Then by inserting "LDT_MoonLightPWMValue=0" into the last value of the slope function, it will turn the driver to 0% outside of those times?
And out of curiosity. Is there an advantage to coding it this way by nesting them over using the if/then/else method? Does it reduce memory because it's less/smaller code or something? The timing of the MoonLights were running correctly with the if/then/else, it was just during the "off" hours I was passing the (2 and 3) on from the labels which I had in the last value. So now it makes sense why they were sitting at 2% and 3% at least!
Yesterday before I saw your post helping me out. I had used my lunch break to re-work the moonlight section of code to use a variable similar to how I did the daylight and actinics drivers. I haven't uploaded the code as I'm planning to implement the changes you've helped me with and try it out this weekend. But here is how I did re-work that section before your tip on nesting the functions.
       RDT_MoonLightPWMValue=0;
       //ReefAngel.PWM.SetChannel(LEDPWM3,0);
        RDT_MoonLightPWMValue=PWMParabola(11,40,20,30,10,30,RDT_MoonLightValue));
        //ReefAngel.PWM.SetChannel(LEDPWM3,PWMParabola(11,40,20,30,10,30,LEDPWM3));
       RDT_MoonLightPWMValue=PWMSlope(21,15,23,15,10,MoonPhase()/5+10,30,RDT_MoonLightValue));
       //ReefAngel.PWM.SetChannel(LEDPWM3,PWMSlope(21,15,23,15,10,MoonPhase()/5+10,30,LEDPWM3));
       LDT_MoonLightPWMValue=0;
       //ReefAngel.PWM.SetChannel(LEDPWM2,0);
        LDT_MoonLightPWMValue=PWMParabola(11,40,20,30,10,30,LDT_MoonLightValue));
        //ReefAngel.PWM.SetChannel(LEDPWM2,PWMParabola(11,55,21,00,10,30,LEDPWM2));
       LDT_MoonLightPWMValue=PWMSlope(21,15,23,15,10,MoonPhase()/5+10,30,LDT_MoonLightValue));
       //ReefAngel.PWM.SetChannel(LEDPWM2,PWMSlope(21,30,23,30,10,MoonPhase()/5+10,30,LEDPWM2));
    CheckCloud();
    ReefAngel.PWM.SetChannel(LEDPWM2,LDT_MoonLightPWMValue);
    ReefAngel.PWM.SetChannel(LEDPWM3,RDT_MoonLightPWMValue);
This was my thought on how to fix it before I got the feed back. I created the new variables for LDT_MoonLightPWMValue and RDT_MoonLightPWMValue and then used the if/then/else statement to set the values of the new variable and then applied those values to their channels like I had with the RDT_daylight/actinics that are hooked up to the first 2 ports of the dimming expansion.
Anyway, that was just me trying to problem solve it over lunch. If the first two sections of new code look correct, then hopefully I should be good to go for now if I implemented your recommendations correctly. I would appreciate it if you have a moment to call me out if I did something completely wrong or misunderstood.
Thanks again for the help! It is very much appreciated!
PostPosted: Thu Oct 09, 2014 2:15 pm
by troubadour11
So I don't have much time to go into details here. But after a bit of trouble shooting on the above code. I got things working better over last weekend.
The Refugium and Phyto lights turn on/off correctly. And the Moonlights are running on their correct time schedules with the new nested code.
Here's the latest version that I have loaded up to the head unit and running for the last few days.
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
ForceCloud=true;
byte LDT_MoonLightANALOGValue=0;
byte RDT_MoonLightANALOGValue=0;
      // Port1 = Heater
      // Port2 = Heater
     //Turns Refugium Light plugged into port3 on at 9:30 pm and off at 9:30 am.
     ReefAngel.StandardLights(Port3,21,30,9,30);
     //Turns Phyto Light plugged into port4 on at 9:30 pm and off at 9:30 am.
     ReefAngel.StandardLights(Port4,21,30,9,30);
//if ((NumMins(hour(now()),minute(now())) > NumMins(21,30)) && (NumMins(hour(now()),minute(now())) < NumMins(9,30)))
//        ReefAngel.Relay.On( Port3 );
//        ReefAngel.Relay.On( Port4 );
//      else
//        ReefAngel.Relay.Off( Port3 );
//        ReefAngel.Relay.Off( Port4 );
         RDT_ActinicPWMValue=PWMParabola(11,00,20,20,11,85,RDT_ActinicPWMValue);
        LDT_ActinicPWMValue=PWMParabola(11,15,20,50,11,85,LDT_ActinicPWMValue);
        RDT_DaylightPWMValue=PWMParabola(11,25,20,40,11,60,RDT_DaylightPWMValue);
        LDT_DaylightPWMValue=PWMParabola(11,40,21,10,11,60,LDT_DaylightPWMValue);
    LDT_MoonLightANALOGValue=PWMParabola(11,40,21,00,10,30,PWMSlope(21,20,23,15,10,MoonPhase()/5+10,30,LDT_MoonLightANALOGValue=0));
    RDT_MoonLightANALOGValue=PWMParabola(11,25,20,30,10,30,PWMSlope(21,15,23,15,10,MoonPhase()/5+10,30,RDT_MoonLightANALOGValue=0));
//if ((NumMins(hour(now()),minute(now())) > NumMins(23,15)) && (NumMins(hour(now()),minute(now())) < NumMins(11,45)))
//       RDT_MoonLightANALOGValue=0;
//       //ReefAngel.PWM.SetChannel(LEDPWM3,0);
//      else if ((NumMins(hour(now()),minute(now())) > NumMins(11,40)) && (NumMins(hour(now()),minute(now())) < NumMins(20,30)))
//        RDT_MoonLightANALOGValue=PWMParabola(11,40,20,30,10,30,RDT_MoonLightValue));
//      else
//       RDT_MoonLightANALOGValue=PWMSlope(21,15,23,15,10,MoonPhase()/5+10,30,RDT_MoonLightValue));
//if ((NumMins(hour(now()),minute(now())) > NumMins(23,30)) && (NumMins(hour(now()),minute(now())) < NumMins(21,35)))
//       LDT_MoonLightANALOGValue=0;
//       else if ((NumMins(hour(now()),minute(now())) > NumMins(11,55)) && (NumMins(hour(now()),minute(now())) < NumMins(21,00)))
//        LDT_MoonLightANALOGValue=PWMParabola(11,40,20,30,10,30,LDT_MoonLightValue));
//      else
//       LDT_MoonLightANALOGValue=PWMSlope(21,15,23,15,10,MoonPhase()/5+10,30,LDT_MoonLightValue));
    CheckCloud();
    ReefAngel.PWM.SetChannel(LEDPWM2,LDT_MoonLightANALOGValue);
    ReefAngel.PWM.SetChannel(LEDPWM3,RDT_MoonLightANALOGValue);
void CheckCloud()
  //***Question***
#else
#endif
      if (cloudchance)
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=8;
  if (cloudchance)
      RDT_ActinicPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,RDT_DaylightPWMValue,20,180);
      LDT_ActinicPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,LDT_DaylightPWMValue,20,180);
      RDT_MoonLightANALOGValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,RDT_MoonLightANALOGValue,11,180);
      LDT_MoonLightANALOGValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,LDT_MoonLightANALOGValue,11,180);
          RDT_MoonLightANALOGValue=RDT_LightningFlashPower;
          LDT_MoonLightANALOGValue=LDT_LightningFlashPower;
          RDT_ActinicPWMValue=20;
          RDT_MoonLightANALOGValue=11;
          LDT_ActinicPWMValue=20;
          LDT_MoonLightANALOGValue=11;
        delay(1);
      cloudindex++;
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
Next up... getting my PH probe to read something more accurate then a constant value of 1. I've failed twice at getting it to calibrate correctly.
PostPosted: Thu Oct 09, 2014 3:33 pm
Thats an odd issue. What happens when you try to calibrate? You should be seeing numbers register on the screen when in the 7 and 10 fluids.
PostPosted: Fri Oct 10, 2014 3:54 pm
by troubadour11
I'm not sure what I'm doing wrong on the PH calibration. I followed all directions I could find and haven't been successful yet.
I do see numbers when I place the probe in the 7 and 10 fluid packets. But it NEVER stops changing numbers and never really settles close to an average. It just keeps bouncing around constantly no matter how long I leave it in the calibration fluid and then gives inaccurate readings on whatever numbers I eventually select as it ping-pongs around.
The first time, I tried it gave drastically low readings following the calibration when the numbers were jumping around and never stopped. And I had just tested the PH, so it was not super low.
Because I was expecting to screw up at least once, I had ordered extra calibration packets. The second time I tried leaving it in the fluid even longer hoping it would settle close to an average and give an appropriate reading. Again, it never did and know reads a constant value of 1 in the sump all the time.
I still have 1 more set of calibration packets. So I'm hoping I can get it right on the 3rd try. I had jotted down there is code I can use to hard-code the calibration values. I'm wondering if I need to calibrate it with the fluid and write down what looks like the average number it should settle on. Then hard-code those calibration numbers.?.?
PostPosted: Fri Oct 10, 2014 4:19 pm
You can try that or you could hardcode the default valued again and see what happens...before wasting your last packets..
PostPosted: Fri Oct 10, 2014 4:21 pm
Sorry i hit send instead of enter.
What does the calibration number look like if you put it in a plastic cup with the probe and tank water? Does it settle? It should not be eratic..like +1/-1 when watching it. Sounds like either a bad probe or stray voltage.
PostPosted: Wed Jul 22, 2015 9:49 pm
by troubadour11
Some last minute help requested :?
So it's been awhile since my last update. I've still been working away a little bit. I never solved my PH probe issue. I haven't had time to get back to it. Most of the work has been additional fixes and adjustments to my lighting section.
But I have a new dosing pump that I could use a little bit of help with. I've been carbon dosing my system (50 mL per day) and need to leave town Friday morning. I have a friend that will feed my aquarium and keep an eye on things, but I picked up the dosing pump and would love to get it integrated to help my house sitter out.
Here is the current code I have loaded up on my controller:
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
ForceCloud=true;
      // Port1 = Heater
      // Port2 = Heater
      // Port7 = Dosing Pump
    // - Turns RDT - B/UV channel to 0% power between 8:55 p.m. and 10:00 a.m. to conserve energy
    // - Parabola dimming 11%-100%-11%
 if ((NumMins(hour(now()),minute(now())) > NumMins(10,00)) && (NumMins(hour(now()),minute(now())) < NumMins(20,55)))
         RDT_ActinicPWMValue=PWMSlope(10,00,20,55,11,100,240,RDT_ActinicPWMValue);
    // - Turns LDT - B/UV channel to 0% power between 9:05 p.m. and 10:15 p.m. to conserve energy
     if ((NumMins(hour(now()),minute(now())) > NumMins(10,15)) && (NumMins(hour(now()),minute(now())) < NumMins(21,05)))
        LDT_ActinicPWMValue=PWMSlope(10,15,21,05,11,100,240,LDT_ActinicPWMValue);
    // - Turns RDT - W/C channel to 0% power between 8:30 p.m. and 10:25 a.m. to conserve energy
     if ((NumMins(hour(now()),minute(now())) > NumMins(10,25)) && (NumMins(hour(now()),minute(now())) < NumMins(20,30)))
        RDT_DaylightPWMValue=PWMSlope(10,25,20,30,11,100,240,RDT_DaylightPWMValue);
    // - Turns LDT - W/C channel to 0% power between 8:45 p.m. and 10:35 a.m. to conserve energy
    // - Parabola dimming 11%-%100-11%
     if ((NumMins(hour(now()),minute(now())) > NumMins(10,35)) && (NumMins(hour(now()),minute(now())) < NumMins(20,45)))
        LDT_DaylightPWMValue=PWMSlope(10,35,20,45,11,100,240,LDT_DaylightPWMValue);
    LDT_MoonLightANALOGValue=PWMSlope(10,30,21,00,10,100,240,PWMSlope(21,20,23,15,20,MoonPhase()/5+10,30,LDT_MoonLightANALOGValue=0));
    RDT_MoonLightANALOGValue=PWMSlope(10,20,20,50,10,100,240,PWMSlope(21,15,23,15,20,MoonPhase()/5+10,30,RDT_MoonLightANALOGValue=0));
    CheckCloud();
void CheckCloud()
  //***Question***
#else
#endif
      if (cloudchance)
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=8;
  if (cloudchance)
        delay(1);
      cloudindex++;
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
I popped open the Wizard to try and generate the code I needed. But I think I'm missing something. I pretty much skipped over most options and tried to set up a dosing pump. Here is the code it gave me:
    ReefAngel.StandardHeater( Port5 );
    ReefAngel.StandardHeater( Port6 );
    ReefAngel.DosingPumpRepeat1( Port7 );
    ReefAngel.AddWifi();
From that, it seems like all I need to add into my code is this to connect my pump to port 7:
But as I mentioned, it seems like I'm missing some info I can input to control the timing of the port for the pump.
I did a few tests of the new pump. (tests done by hand and stop watch)
- I was getting about 14.15 seconds for 10 mL of tank water.
- 13.8 seconds for 10 mL of vinegar.
- Then 1:01.75 seconds for 50 mL of vinegar. (50 mL is the daily amount I have been dosing)
Based off that information. I figured I could run my pump (on Port7) for 5 seconds every 2 hours. If I could do a shorter time, more often; that would be preferred. But those were nice even numbers that I figured out first.
If anyone could help me out, point me in the right direction, or let me know whether or not I am missing something to get this integrated it would be very much appreciated. :) It would definitely put my mind at ease knowing I've got this covered and automated during this last minute / unexpected trip.
Thanks :D
PostPosted: Wed Jul 22, 2015 11:21 pm
Try using hard coded settings.
They are missing because you chose internal memory.
But I think you need this:
ReefAngel.DosingPumpRepeat( Port7,0,120,5 );
