Sabo's ino
PostPosted: Sun May 04, 2014 9:40 am
Saving it here pretty much as just a last resort backup. I seem to drown things since I gt my tank, so this is my last resort. :)
#define Return       1
#define Pwm_Exp      2
#define Unused       3
#define ATI          4
#define Jebao1_Rhs   5
#define Jebao2_Rhs   6
#define Jebao1_Lhs   7
#define Jebao2_Lhs   8
#define ATO         Box1_Port1
#define Fuge_Led    Box1_Port2
#define Heater1     Box1_Port3
#define Skimmer     Box1_Port4
#define Heater2     Box1_Port5
#define Kamoar      Box1_Port6
#define Swabby      Box1_Port7
#define Unused      Box1_Port8
    ReefAngel.SetTemperatureUnit( Celsius );  // set to Celsius Temperature
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.OverheatShutoffPorts = Port4Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port5Bit;
    ReefAngel.Relay.On( Pwm_Exp );
    ReefAngel.Relay.On( Return );
    ReefAngel.Relay.On( ATI );
    ReefAngel.Relay.On( Fuge_Led );
    ReefAngel.Relay.On( Skimmer );
    ReefAngel.Relay.On( Kamoar );
    ReefAngel.StandardHeater( Heater1 );
    ReefAngel.StandardHeater( Heater2 );
    ReefAngel.WaterLevelATO( ATO );
    if (ReefAngel.LowATO.IsActive() && ReefAngel.HighATO.IsActive())
        ReefAngel.Relay.On(Skimmer);
        ReefAngel.Relay.Off(Skimmer);
    ReefAngel.DosingPumpRepeat1(Swabby);
    if (hour()>=6 && hour()<12)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(60,20,true) ); // ReefCrest at 60% +/- 20% on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(60,20,true) ); // ReefCrest at 60% +/- 20% on anti-sync mode
  ReefAngel.Relay.Off( Jebao1_Lhs );
  ReefAngel.Relay.Off( Jebao2_Lhs );
  ReefAngel.Relay.On( Jebao1_Rhs );
  ReefAngel.Relay.On( Jebao2_Rhs );
else if (hour()>=12 && hour()<18)
  ReefAngel.PWM.SetChannel( 0, ReefCrestMode(60,20,true) ); // ReefCrest at 60% +/- 20% on sync mode
  ReefAngel.PWM.SetChannel( 1, ReefCrestMode(60,20,true) ); // ReefCrest at 60% +/- 20% on anti-sync mode
  ReefAngel.Relay.Off( Jebao1_Rhs );
  ReefAngel.Relay.Off( Jebao2_Rhs );
  ReefAngel.Relay.On( Jebao1_Lhs );
  ReefAngel.Relay.On( Jebao2_Lhs );
else if (hour()>=18 && hour()<24)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(50,20,true) ); // ReefCrest at 60% +/- 20% on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(50,20,true) ); // ReefCrest at 60% +/- 20% on anti-sync mode
  ReefAngel.PWM.SetChannel( 0, ReefCrestMode(50,20,true) ); // ReefCrest at 60% +/- 20% on sync mode
  ReefAngel.PWM.SetChannel( 1, ReefCrestMode(50,20,true) ); // ReefCrest at 60% +/- 20% on anti-sync mode
    ReefAngel.Portal( "sabo" );
Return to My PDE/INO file
