moon lights always on and jebao portal problem
PostPosted: Sun Jun 01, 2014 5:38 pm
I've got two problems:
My moonlights stay on 24/7, I want them to go off when the moon isn't up. I am using moonphase from the wizard set up.
Also, I can't control my jebao from the portal, meaning I can't change wave settings from the portal. What I want to do is either set the portal to "custom" and have it run my code (else mode during the day, sine at night) or take the portal off custom and be able to change it to some other wave pattern.
Here is the code...any ideas are appreciated...
Rob
    ReefAngel.WaterChangePorts = Port5Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit;
    ReefAngel.CustomLabels[0]="Frag Pump";
    ReefAngel.CustomLabels[1]="Actinics";
    ReefAngel.CustomLabels[2]="Daylights";
    ReefAngel.CustomLabels[3]="Frag LED";
    ReefAngel.CustomLabels[4]="ATO Pump";
    ReefAngel.CustomLabels[5]="Reactor";
    ReefAngel.CustomLabels[6]="Heater";
    ReefAngel.CustomLabels[7]="Fan";
    ReefAngel.ActinicLights( Port2 );
    ReefAngel.DayLights( Port3 );
    ReefAngel.ActinicLights( Port4 );
    ReefAngel.SingleATOLow( Port5 );
    ReefAngel.StandardFan( Port8 );
       if (hour()>=8 && hour()<21)
        if (ReefAngel.DCPump.Mode==Custom)
         ReefAngel.PWM.SetActinic(ElseMode(65, 20, true));
         ReefAngel.PWM.SetActinic(SineMode(75,35, 15, true));
    ReefAngel.Portal( "psyrob" );
  static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
  static int Delay = random( 500, 1500);           // Set the initial delay
  static int NewSpeed = MidPoint;                  // Set the initial speed
  static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
  if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
    Delay=random(500,5000);                        // If so, come up with a new delay
    int ChangeUp = random(Offset);                 // Amount to go up or down
    if (random(100)<50)                            // 50/50 chance of speed going up or going down
    LastChange=millis();                           // Reset the time of the last change
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
PostPosted: Mon Jun 02, 2014 8:06 am
I think this is what you want:
  ReefAngel.PWM.SetDaylight(0);
PostPosted: Tue Jun 03, 2014 9:27 pm
Thanks, I tried it, but it's just running sine mode no matter what I do on the portal...changing to other wave patterns or to custom, doesn't change how the pump is running...
PostPosted: Wed Jun 04, 2014 4:03 am
Is the mode set to custom? Nvm reread.. Not sure, code looks fine.
PostPosted: Wed Jun 04, 2014 6:01 am
I think this:
Needs to be after this:
This is my code for reference. It does very similar to yours:
                  if ( (now()%SECS_PER_DAY >= 77400) || (now()%SECS_PER_DAY<= 34200) )
                    ReefAngel.PWM.SetActinic(30); // Constant at 30% on sync mode
                  else if ( (now()%SECS_PER_DAY >= 34200) && (now()%SECS_PER_DAY<= 48600) )
                    ReefAngel.PWM.SetActinic(33); // Constant at 33% on sync mode
                  else if ( (now()%SECS_PER_DAY >= 48600) && (now()%SECS_PER_DAY<= 77400) )
                    ReefAngel.PWM.SetActinic( ElseMode(37,7,true));   // Else on sync mode, 37 +/- 7%
Look at my thread here:
viewtopic.php?f=12&t=4475&start=20
Return to My PDE/INO file
