Help with old PDE converted to INO
Posted: Wed Jun 04, 2014 1:50 pm
It's been quite a while since I've attempted to play with my controller, probably over 2 years. I've updated to Arduino 1.0.1, which I assume updated all my libraries. I opened my old sketch and got some errors right off the bat when trying to verify.
BioCube_14_Sketch.cpp: In function 'void DrawCustomMain()':
BioCube_14_Sketch:130: error: 'struct ParamsStruct' has no member named 'Temp1'
BioCube_14_Sketch:160: error: 'struct ParamsStruct' has no member named 'Temp2'
BioCube_14_Sketch:166: error: 'struct ParamsStruct' has no member named 'Temp3'
Here's a copy of my INO, any and all help with these errors and any depreciated code is greatly appreciated!
// Autogenerated file by RAGen (v1.0.4.92), (10/15/2011 12:40)
// RA_101511_1240.pde
// MANY THANKS TO BOTH ROBERTO AND CURT FOR ALL THEIR HELP!*
#define DisplayLEDPWM
#define wifi
#define VersionMenu
#define CUSTOM_MAIN
#define NUMBERS_8x16
#define COLORS_PDE
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 6
#define RFEXPANSION
#include <avr/pgmspace.h>
#define Sump 1
#define DosingPump2 2
#define Refugium 3
#define Daylight 4
#define Actinic 5
#define Skimmer 6
#define Heater 7
#define DosingPump1 8
//Cloud & Lightning effect Global Variables
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
boolean ForceCloud=false;
// Echosmart Global Variable
byte vtechmode;
// Moon Global Variables - Thanks Deckoz2302!
byte DayAge;
byte ThisPhase;
int JulianDate(int,int,int);
double MoonAge(int,int,int);
byte MoonState();
// Create the menu entries
prog_char menu1_label[] PROGMEM = "Feeding";
prog_char menu3_label[] PROGMEM = "Force Cloud";
prog_char menu4_label[] PROGMEM = "Reboot";
prog_char menu5_label[] PROGMEM = "Overheat Clear";
prog_char menu6_label[] PROGMEM = "PH Calibration";
prog_char menu7_label[] PROGMEM = "Version";
menu4_label, menu5_label, menu6_label, menu7_label
// Menu Item actions
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ForceCloud=true;
ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
void MenuEntry4()
delay(1000);
void MenuEntry5()
ReefAngel.OverheatClear();
void MenuEntry6()
ReefAngel.SetupCalibratePH();
void MenuEntry7()
ReefAngel.DisplayVersion();
// Custom Main Screen
ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 0, " "); //Top Banner
ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 2, " BioCube 14 Nano Reef "); //Top Banner
// Display Temp Text
ReefAngel.LCD.DrawText(0,255,12,12,"Temp");
// Display the T1 temp value 10,22
char text[7];
ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
ReefAngel.LCD.Clear(255, 0, 20, 50, 36);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 10, 20, text, Num8x16);
// Display pH Text
ReefAngel.LCD.DrawText(0,255,100,12,"pH");
// Display pH Value
ReefAngel.LCD.Clear(255, 90, 20, 98, 36);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 90, 20, text, Num8x16);
// Display Actinic Percentage Text
ReefAngel.LCD.DrawText(0,255,8,35,"Actinic %");
// Display the Actinic PWM channel value at 90,40
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),COLOR_CORNFLOWERBLUE, 90, 35, 1);
// Display Daylight Percentage Text
ReefAngel.LCD.DrawText(0,255,8,45,"Daylight %");
// Display the Daylight PWM channel value at 90,50
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),COLOR_CORNFLOWERBLUE, 90, 45, 1);
// Display T2 Temp Text
ReefAngel.LCD.DrawText(0,255,8,55,"Canopy Temp");
// Display the T2 temperature value at 90,60
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, COLOR_CORNFLOWERBLUE, 90, 55, 10);
// Display T3 Temp Text
ReefAngel.LCD.DrawText(0,255,8,65,"Ambient Temp");
// Display the T3 temperature at 90,70
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, COLOR_CORNFLOWERBLUE, 90, 65, 10);
// Display Seperat0r
ReefAngel.LCD.DrawText(0,255,5,73,"--------------------------");
ReefAngel.LCD.DrawText(0,255,8,80,"EcoSmart");
// Display EcoSmart Mode Value - Thanks Deckoz2302!
//ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,90,80,"Storm");
ReefAngel.LCD.Clear(255, 58, 80, 128, 90);
if (vtechmode == 0) ReefAngel.LCD.DrawText(COLOR_LIMEGREEN,255,58,80,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawText(COLOR_GOLD,255,58,80,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawText(COLOR_GOLD,255,58,80,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,58,80,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawText(COLOR_PINK,255,58,80,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,58,80,"Nut. Trans");
else if (vtechmode == 6) ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,58,80,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawText(COLOR_WHITE,0,58,80," Night ");
// Display Moon Phase & State Text
ReefAngel.LCD.DrawText(0,255,8,90,"Moon");
// Display Moon Phase & State at 35,90
DayAge = MoonAge(day(), month(), year());
MoonState(DayAge);
char* ThisPhaseLabel[]={
"New","Waxing Crescent","First Quarter","Waxing Gibbous","Full","Waning Gibbous","Last Quarter","Waning Crescent" };
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,90,ThisPhaseLabel[ThisPhase]);
// Display Outlet Box
ReefAngel.LCD.DrawOutletBox(13, 99, TempRelay);
// ReefAngel.LCD.DrawGraph(5,7);
ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); //For Custom Menu
ReefAngel.FeedingModePorts = B00100001; // Feeding mode: Ports 6 & 1 turn off
ReefAngel.WaterChangePorts = B00100001; // Water Change mode: Ports 6 & 1 turn off
ReefAngel.OverheatShutoffPorts = B00011000; // Overheat mode: Ports 4 & 5 turn off
ReefAngel.LightsOnPorts = B00011000; // Lights On mode: ports 4 & 5 turn on
ReefAngel.Relay.On(Port1); // Port 1 always on
// Delay Skimmer port 5 minutes whenever turned on
// From Curt - THANKS CURT!
ReefAngel.Relay.DelayedOn(Port6, 5);
//Heater
ReefAngel.StandardHeater(Heater,775,780); // Setup Heater to turn on at 77.5F and off at 78.0F
//Lighting schedule
ReefAngel.MHLights(Daylight,9,0,17,0,0); //Daylight schedule 9:00am - 5:00pm with 0min cool down
ReefAngel.StandardLights(Actinic,7,0,19,0); //Actinic schedule 7:00am - 7:00pm
ReefAngel.StandardLights(Refugium,19,0,7,0); //Refugium schedule 7:00pm - 7:00am
// Dosing pumps (OLD DOSING METHOD OF PUMP ONE ON THE HOUR, THEN PUMP2 5 MIN LATER - to use when tank is more mature
//From Roberto - THANKS ROBERTO!
/* if (ReefAngel.DisplayedMenu==255 && minute()==0 && second()<1) //Alk Doser - Only works if Main screen is showing
ReefAngel.Relay.On(DosingPump1); //Turn Alk Doser on
ReefAngel.Relay.Off(DosingPump1); //Turn Alk Doser off
if (ReefAngel.DisplayedMenu==255 && minute()==5 && second()<1) //CA Doser - Only works if Main screen is showing
ReefAngel.Relay.On(DosingPump2); //Turn CA Doser on
ReefAngel.Relay.Off(DosingPump2); //Turn CA Doser off
// Dosing pumps
// From Roberto - THANKS ROBERTO!
if (ReefAngel.DisplayedMenu==255 && hour()%2==0 && minute()==0 && second()<1) // 1 sec dosing on even hours
ReefAngel.Relay.On(DosingPump1); //Turn DosingPump1 Doser on
ReefAngel.Relay.Off(DosingPump1); //Turn DosingPump1 Doser off
if (ReefAngel.DisplayedMenu==255 && hour()%2==1 && minute()==0 && second()<1) // 1 sec dosing on odd hours
ReefAngel.Relay.On(DosingPump2); //Turn DosingPump2 Doser on
ReefAngel.Relay.Off(DosingPump2); //Turn DosingPump2 Doser off
// Cloud & Lightning effects - Calculate your regular sunrise/sunset PWM value
// byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
if (hour()>=19 || hour()<7)
ReefAngel.PWM.SetActinic(MoonPhase()); //Moon phase schedule between 7:00pm - 7:00am
ReefAngel.RF.UseMemory=false;
vtechmode = 9;
ActinicPWMValue=PWMSlope(7,00,19,0,0,35,60,ActinicPWMValue); //Actinic turn on at 7am, off at 10am, and ramp up 0% to 50% PWM in 60 minutes
//ActinicPWMValue=PWMSlope(16,00,19,0,0,50,60,ActinicPWMValue); //Actinic turn on at 4pm, off at 7pm, and ramp up 0% to 50% PWM in 60 minutes
ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
ReefAngel.RF.UseMemory=true;
vtechmode = InternalMemory.RFMode_read();
DaylightPWMValue=PWMSlope(9,00,17,0,0,75,60,DaylightPWMValue); //Daylight turn on at 9am, off at 5pm, and ramp up 0% to 50% PWM in 60 minutes
CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 6
#define Start_Cloud_After NumMins(11,30)
// In this example, end could before 4:30pm
#define End_Cloud_Before NumMins(16,30)
#define Lightning_Change_per_Cloud 25
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen result could happen.
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
//When custom menu Force cloud is selected
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
lightningchance=1;
cloudstart=NumMins(hour(),minute())+1;
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.Clear(255,0,113,132,121);
ReefAngel.LCD.DrawText(0,255,12,113,"C");
ReefAngel.LCD.DrawText(0,255,18,113,"00:00");
ReefAngel.LCD.DrawText(0,255,52,113,"L");
ReefAngel.LCD.DrawText(0,255,58,113,"00:00");
ReefAngel.LCD.DrawText(0,255,93,113,"DUR");
int x=0;
if ((cloudstart/60)>=10) x=18;
else x=24;
ReefAngel.LCD.DrawText(0,255,x,113,(cloudstart/60));
if ((cloudstart%60)>=10) x=36;
else x=42;
ReefAngel.LCD.DrawText(0,255,x,113,(cloudstart%60));
ReefAngel.LCD.DrawText(0,255,114,113,cloudduration);
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=88;
else x=94;
ReefAngel.LCD.DrawText(0,255,x,113,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=109;
else x=112;
ReefAngel.LCD.DrawText(0,255,x,113,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
//End Cloud & Lighting
// Moon Calculators - Thanks Deckoz2302!
int JulianDate(int d, int m, int y)
int mm, yy;
int k1, k2, k3;
int j;
yy = y - (int)((12 - m) / 10);
mm = m + 9;
if (mm >= 12)
mm = mm - 12;
k1 = (int)(365.25 * (yy + 4712));
k2 = (int)(30.6001 * mm + 0.5);
k3 = (int)((int)((yy / 100) + 49) * 0.75) - 38;
// 'j' for dates in Julian calendar:
j = k1 + k2 + d + 59;
if (j > 2299160)
// For Gregorian calendar:
j = j - k3; // 'j' is the Julian date at 12h UT (Universal Time)
return j;
double MoonAge(int d, int m, int y)
int j = JulianDate(d, m, y);
//Calculate the approximate phase of the moon
int ip = (j + 4.867) / 29.53059;
ip = ip - abs(ip);
//After several trials I've seen to add the following lines,
//which gave the result was not bad
if(ip < 0.5)
int ag = ip * 29.53059 + 29.53059 / 2;
int ag = ip * 29.53059 - 29.53059 / 2;
// Moon's age in days
byte ag = abs(ag) + 1;
return ag;
byte MoonState(byte D)
switch(D){
case 1:
0, 29;
ThisPhase = 0;
case 2:
1, 2, 3, 4, 5, 6;
ThisPhase = 1;
case 3:
7;
ThisPhase = 2;
case 4:
8, 9, 10, 11, 12, 13;
ThisPhase = 3;
case 5:
14;
ThisPhase = 4;
case 6:
15, 16, 17, 18, 19, 20, 21;
ThisPhase = 5;
case 7:
22;
ThisPhase = 6;
case 8:
23, 24, 25, 26, 27, 28;
ThisPhase = 7;
default:
return 0;
