Help with old PDE converted to INO
PostPosted: Thu Jun 05, 2014 7:42 am
OK, started with commenting out the old moonphase code. Is there a variable set for the current phase that I can use to populate my custom menu?
I changed my lighting, but now my actinic turns on for a sec, then stays off. Here's where I'm at, any help would be greatly appreciated.
Is there a new cloud/storm library?
Sorry for the mess of comments in the code:(
// Autogenerated file by RAGen (v1.0.4.92), (10/15/2011 12:40)
// RA_101511_1240.pde
// MANY THANKS TO BOTH ROBERTO AND CURT FOR ALL THEIR HELP!*
#define DisplayLEDPWM
#define wifi
#define VersionMenu
#define CUSTOM_MAIN
#define NUMBERS_8x16
#define COLORS_PDE
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 6
#define RFEXPANSION
#include <avr/pgmspace.h>
#define Sump                1
#define DosingPump2         2
#define Refugium            3
#define Daylight            4
#define Actinic             5
#define Skimmer             6
#define Heater              7
#define DosingPump1         8
//Cloud & Lightning effect Global Variables
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
boolean ForceCloud=false;
// Echosmart Global Variable
byte vtechmode;
// Moon Global Variables - Thanks Deckoz2302!
byte DayAge;
byte ThisPhase;
int JulianDate(int,int,int);
double MoonAge(int,int,int);
byte MoonState();
// Create the menu entries
prog_char menu3_label[] PROGMEM = "Force Cloud";
prog_char menu4_label[] PROGMEM = "Reboot";
prog_char menu5_label[] PROGMEM = "Overheat Clear";
prog_char menu6_label[] PROGMEM = "PH Calibration";
prog_char menu7_label[] PROGMEM = "Version";
menu4_label, menu5_label, menu6_label, menu7_label
// Menu Item actions
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ForceCloud=true;
void MenuEntry4()
delay(1000);
void MenuEntry5()
ReefAngel.OverheatClear();
void MenuEntry6()
ReefAngel.SetupCalibratePH();
void MenuEntry7()
ReefAngel.DisplayVersion();
// Custom Main Screen
  ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 0, "                       "); //Top Banner
  ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 2, " BioCube 14 Nano Reef  "); //Top Banner
  ReefAngel.LCD.DrawDate(6, 123);
  // Display Temp Text
  ReefAngel.LCD.DrawText(0,255,12,12,"Temp");
  // Display the T1 temp value 10,22
  char text[7];
  ReefAngel.LCD.Clear(255, 0, 20, 50, 36);
  ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 10, 20, text, Num8x16);
  // Display pH Text
  ReefAngel.LCD.DrawText(0,255,100,12,"pH");
  // Display pH Value
  ReefAngel.LCD.Clear(255, 90, 20, 98, 36);
  ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 90, 20, text, Num8x16);
  // Display Actinic Percentage Text
  ReefAngel.LCD.DrawText(0,255,8,35,"Actinic %");
  // Display the Actinic PWM channel value at 90,40
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),COLOR_CORNFLOWERBLUE, 90, 35, 1);
  // Display Daylight Percentage Text
  ReefAngel.LCD.DrawText(0,255,8,45,"Daylight %");
  // Display the Daylight PWM channel value at 90,50
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),COLOR_CORNFLOWERBLUE, 90, 45, 1);
  // Display T2 Temp Text
  ReefAngel.LCD.DrawText(0,255,8,55,"Canopy Temp");
  // Display the T2 temperature value at 90,60
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_CORNFLOWERBLUE, 90, 55, 10);
  // Display T3 Temp Text
  ReefAngel.LCD.DrawText(0,255,8,65,"Ambient Temp");
  // Display the T3 temperature at 90,70
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_CORNFLOWERBLUE, 90, 65, 10);
  // Display Seperat0r
  ReefAngel.LCD.DrawText(0,255,5,73,"--------------------------");
  ReefAngel.LCD.DrawText(0,255,8,80,"EcoSmart");
  // Display EcoSmart Mode Value - Thanks Deckoz2302!
  //ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,90,80,"Storm");
  ReefAngel.LCD.Clear(255, 58, 80, 128, 90);
  if (vtechmode == 0) ReefAngel.LCD.DrawText(COLOR_LIMEGREEN,255,58,80,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawText(COLOR_GOLD,255,58,80,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawText(COLOR_GOLD,255,58,80,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,58,80,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawText(COLOR_PINK,255,58,80,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,58,80,"Nut. Trans");
  else if (vtechmode == 6) ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,58,80,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawText(COLOR_WHITE,0,58,80," Night ");
  // Display Moon Phase & State Text
  ReefAngel.LCD.DrawText(0,255,8,90,"Moon");
  // Display Moon Phase & State at 35,90
 /* DayAge = MoonAge(day(), month(), year());
  MoonState(DayAge);
  char* ThisPhaseLabel[]={
    "New","Waxing Crescent","First Quarter","Waxing Gibbous","Full","Waning Gibbous","Last Quarter","Waning Crescent"                        };*/
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,90,"Moon phase here");
  // Display Outlet Box
  ReefAngel.LCD.DrawOutletBox(13, 99, TempRelay);
 // ReefAngel.LCD.DrawGraph(5,7);
  InternalMemory.IMCheck_write(0xCF06A31E); //Fix "No Internal Memory Found" LCD Display Error after upload
  ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); //For Custom Menu
  ReefAngel.FeedingModePorts = B00100001; // Feeding mode: Ports 6 & 1 turn off
  ReefAngel.WaterChangePorts = B00100001; // Water Change mode: Ports 6 & 1 turn off
  ReefAngel.OverheatShutoffPorts = B00011000; // Overheat mode: Ports 4 & 5 turn off
  ReefAngel.LightsOnPorts = B00011000; // Lights On mode: ports 4 & 5 turn on
  ReefAngel.Relay.On(Port1); // Port 1 always on
  // Delay Skimmer port 5 minutes whenever turned on
  // From Curt - THANKS CURT!
  ReefAngel.Relay.DelayedOn(Port6, 5);
  //Heater
  ReefAngel.StandardHeater(Heater,775,780);  // Setup Heater to turn on at 77.5F and off at 78.0F
  //Lighting schedule
  ReefAngel.StandardLights(Daylight,9,0,17,0);  //Daylight schedule 9:00am - 5:00pm with 0min cool down
  ReefAngel.StandardLights(Actinic,7,0,19,0);  //Actinic schedule 7:00am - 7:00pm
  ReefAngel.StandardLights(Refugium,19,0,7,0);  //Refugium schedule 7:00pm - 7:00am
  // Dosing pumps (OLD DOSING METHOD OF PUMP ONE ON THE HOUR, THEN PUMP2 5 MIN LATER - to use when tank is more mature
  //From Roberto - THANKS ROBERTO!
   /* if (ReefAngel.DisplayedMenu==255 && minute()==0 && second()<1)  //Alk Doser - Only works if Main screen is showing
      ReefAngel.Relay.On(DosingPump1);  //Turn Alk Doser on
      ReefAngel.Relay.Off(DosingPump1);  //Turn Alk Doser off
    if (ReefAngel.DisplayedMenu==255 && minute()==5 && second()<1)  //CA Doser - Only works if Main screen is showing
      ReefAngel.Relay.On(DosingPump2);  //Turn CA Doser on
      ReefAngel.Relay.Off(DosingPump2);  //Turn CA Doser off
  // Dosing pumps
  // From Roberto - THANKS ROBERTO!
  if (ReefAngel.DisplayedMenu==255 && hour()%2==0 && minute()==0 && second()<1) // 1 sec dosing on even hours
    ReefAngel.Relay.On(DosingPump1);  //Turn DosingPump1 Doser on
    ReefAngel.Relay.Off(DosingPump1);  //Turn DosingPump1 Doser off
  if (ReefAngel.DisplayedMenu==255 && hour()%2==1 && minute()==0 && second()<1) // 1 sec dosing on odd hours
    ReefAngel.Relay.On(DosingPump2);  //Turn DosingPump2 Doser on
    ReefAngel.Relay.Off(DosingPump2);  //Turn DosingPump2 Doser off
  // Cloud & Lightning effects - Calculate your regular sunrise/sunset PWM value
  // byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
  if (hour()>=19 || hour()<7)
      ReefAngel.PWM.SetActinic(MoonPhase());  //Moon phase schedule between 7:00pm - 7:00am
      ReefAngel.RF.UseMemory=false;
      vtechmode = 9;
      ReefAngel.PWM.SetActinic( PWMParabola(7,0,19,0,15,50,0) ); //Actinic turn on at 7am, off at 7pm, and parabola 15% to 50% PWM
      //ActinicPWMValue=PWMSlope(16,00,19,0,0,50,60,ActinicPWMValue); //Actinic turn on at 4pm, off at 7pm, and ramp up 0% to 50% PWM in 60 minutes
      ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
      ReefAngel.RF.UseMemory=true;
      vtechmode = InternalMemory.RFMode_read();
  ReefAngel.PWM.SetDaylight( PWMParabola(9,0,17,0,15,50,0) ); //Daylight turn on at 9am, off at 5pm, and parabola 15% to 50% PWM
  CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 6
  // In this example, end could before 4:30pm
#define End_Cloud_Before NumMins(16,30)
#define Lightning_Change_per_Cloud 25
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen result could happen.
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  //When custom menu Force cloud is selected
  if (ForceCloud)
    ForceCloud=false;
    cloudchance=1;
    cloudduration=10;
    lightningchance=1;
    cloudstart=NumMins(hour(),minute())+1;
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
    ReefAngel.LCD.Clear(255,0,113,132,121);
    ReefAngel.LCD.DrawText(0,255,12,113,"C");
    ReefAngel.LCD.DrawText(0,255,18,113,"00:00");
    ReefAngel.LCD.DrawText(0,255,52,113,"L");
    ReefAngel.LCD.DrawText(0,255,58,113,"00:00");
    ReefAngel.LCD.DrawText(0,255,93,113,"DUR");
      int x=0;
      if ((cloudstart/60)>=10) x=18;
      else x=24;
      ReefAngel.LCD.DrawText(0,255,x,113,(cloudstart/60));
      if ((cloudstart%60)>=10) x=36;
      else x=42;
      ReefAngel.LCD.DrawText(0,255,x,113,(cloudstart%60));
    ReefAngel.LCD.DrawText(0,255,114,113,cloudduration);
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=88;
      else x=94;
      ReefAngel.LCD.DrawText(0,255,x,113,((cloudstart+(cloudduration/2))/60));
      if (((cloudstart+(cloudduration/2))%60)>=10) x=109;
      else x=112;
      ReefAngel.LCD.DrawText(0,255,x,113,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
  //End Cloud & Lighting
// Moon Calculators - Thanks Deckoz2302!
int JulianDate(int d, int m, int y)
  int mm, yy;
  int k1, k2, k3;
  int j;
  yy = y - (int)((12 - m) / 10);
  mm = m + 9;
  if (mm >= 12)
    mm = mm - 12;
  k1 = (int)(365.25 * (yy + 4712));
  k2 = (int)(30.6001 * mm + 0.5);
  k3 = (int)((int)((yy / 100) + 49) * 0.75) - 38;
  // 'j' for dates in Julian calendar:
  j = k1 + k2 + d + 59;
  if (j > 2299160)
    // For Gregorian calendar:
    j = j - k3; // 'j' is the Julian date at 12h UT (Universal Time)
  return j;
double MoonAge(int d, int m, int y)
  int j = JulianDate(d, m, y);
  //Calculate the approximate phase of the moon
  int ip = (j + 4.867) / 29.53059;
  ip = ip - abs(ip);
  //After several trials I've seen to add the following lines,
  //which gave the result was not bad
  if(ip < 0.5)
    int ag = ip * 29.53059 + 29.53059 / 2;
    int ag = ip * 29.53059 - 29.53059 / 2;
  // Moon's age in days
  byte ag = abs(ag) + 1;
  return ag;
byte MoonState(byte D)
  switch(D){
  case 1:
    0, 29;
    ThisPhase = 0;
  case 2:
    1, 2, 3, 4, 5, 6;
    ThisPhase = 1;
  case 3:
    7;
    ThisPhase = 2;
  case 4:
    8, 9, 10, 11, 12, 13;
    ThisPhase = 3;
  case 5:
    14;
    ThisPhase = 4;
  case 6:
    15, 16, 17, 18, 19, 20, 21;
    ThisPhase = 5;
  case 7:
    22;
    ThisPhase = 6;
  case 8:
    23, 24, 25, 26, 27, 28;
    ThisPhase = 7;
  default:
    return 0;
PostPosted: Thu Jun 05, 2014 8:07 am
MoonPhase() is the function to get the current phase (in 0-100%) and MoonPhaseLabel() to get the name of the current phase.
The cloud lightning library has not really been updated.
Can you narrow down the code for your lights to make it easier to review? :)
PostPosted: Thu Jun 05, 2014 9:36 am
let's see, I think this covers it.
  //Lighting schedule
      vtechmode = 9;
  CheckCloud();
PostPosted: Thu Jun 05, 2014 12:06 pm
I uploaded my previous sketch before I made any changes and my lights come on for a second, then go off still. Could there be some internal memory settings that were wiped somehow affecting it? The last time this happened my canopy temp probe wasn't reporting a temp, but it's working fine right now.
Looks like my RF module for ecotech mp10 isn't doing anything either. I think that was based on an initial memory setting.
PostPosted: Thu Jun 05, 2014 1:29 pm
If think this:
  CheckCloud();
Needs to be changed to this:
  DaylightPWMValue=PWMParabola(9,0,17,0,15,50,0); //Daylight turn on at 9am, off at 5pm, and parabola 15% to 50% PWM
  CheckCloud();
PostPosted: Thu Jun 05, 2014 4:32 pm
Now both actinic and daylight turn on for a second, and then completely off. I pushed the daylight to stay on until 7pm to during testing.
The only other thing that has ever affected my lights was my canopy temp, and that's 78.4F. Like I mentioned ealier, my RF Module isn't working anymore either. Could this have something to do with my memory settings?
#define wifi
#define VersionMenu
#define CUSTOM_MAIN
#define COLORS_PDE
#define CUSTOM_MENU
#define RFEXPANSION
#define Sump                1
#define Refugium            3
#define Daylight            4
#define Actinic             5
#define Skimmer             6
#define Heater              7
byte vtechmode;
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
ForceCloud=true;
void MenuEntry4()
delay(1000);
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
  char text[7];
  // Display pH Text
  // Display pH Value
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,90,MoonPhaseLabel());
  //Heater
  //Lighting schedule
  ReefAngel.MHLights(Daylight,9,0,19,0,0);  //Daylight schedule 9:00am - 5:00pm with 0min cool down
  // Dosing pumps
      vtechmode = 9;
      ActinicPWMValue=PWMParabola(9,0,19,0,15,50,0);  //Actinic turn on at 7am, off at 7pm, and parabola 15% to 50% PWM
  DaylightPWMValue=PWMParabola(9,0,19,0,15,50,0); //Daylight turn on at 9am, off at 5pm, and parabola 15% to 50% PWM
  CheckCloud();
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (ForceCloud)
    ForceCloud=false;
    cloudchance=1;
    cloudduration=10;
    lightningchance=1;
  if (cloudchance)
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      int x=0;
      else x=24;
      else x=42;
      int x=0;
      else x=94;
      else x=112;
  cstart*=60;
  cend*=60;
PostPosted: Thu Jun 05, 2014 4:52 pm
I tried running "Overheat Clear" on my menu... it did nothing. So I commented out the following code and the lights stay on now.
Any idea why it's tripping an overheat?
PostPosted: Thu Jun 05, 2014 4:55 pm
I uncommented the first line and added the second line and all is well.
InternalMemory.OverheatTemp_write( 869 ); // Set the Overheat temperature setting
Any idea why the following selection on my menu didn't clear the overheat?
void MenuEntry5()
PostPosted: Thu Jun 05, 2014 6:57 pm
You probably had the overheat temp set wrong and the minute you clear it, it goes into overheat again in a split of a second.
PostPosted: Fri Jun 06, 2014 6:56 am
rimai wrote:You probably had the overheat temp set wrong and the minute you clear it, it goes into overheat again in a split of a second.
Thanks. I never changed it from before I updated my libraries, so not sure how that happened.
Is there a way to change the default feeding timeout? I'm sorry for all these questions. I tried to find a manual with all the commands, but can't find one.
Return to My PDE/INO file
