Howaboutme's Code
PostPosted: Sun Jun 08, 2014 4:44 am
For the record and so I can link to this on threads.
            ReefAngel.FeedingModePorts = Port1Bit | Port5Bit;
            ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port8Bit;
            ReefAngel.OverheatShutoffPorts = Port8Bit;
            ReefAngel.Relay.On( Port2 );
        ReefAngel.CustomLabels[0]="ATO Pump";
        ReefAngel.CustomLabels[1]="Skimmer";
        ReefAngel.CustomLabels[2]="LEDWhite";
        ReefAngel.CustomLabels[3]="LEDBlue";
        ReefAngel.CustomLabels[4]="WP25";
        ReefAngel.CustomLabels[5]="DoserAlk";
        ReefAngel.CustomLabels[6]="Unused";
        ReefAngel.CustomLabels[7]="Heater";
            ReefAngel.DayLights( Port3 );
            ReefAngel.ActinicLights( Port4 );
            ReefAngel.Relay.DelayedOn( Port5 );
            ReefAngel.DosingPumpRepeat1( Port6 );
            ReefAngel.StandardHeater( Port8 );
            if (ReefAngel.DCPump.Mode==Custom)
              if ( (now()%SECS_PER_DAY >= 77400) || (now()%SECS_PER_DAY<= 34200) )
                ReefAngel.PWM.SetActinic(32); // Constant at 32% on sync mode
              else if ( (now()%SECS_PER_DAY >= 34200) && (now()%SECS_PER_DAY<= 48600) )
                ReefAngel.PWM.SetActinic(36); // Constant at 36% on sync mode
              else if ( (now()%SECS_PER_DAY >= 48600) && (now()%SECS_PER_DAY<= 77400) )
                ReefAngel.PWM.SetActinic( ElseMode(41,8,true));   // Else on sync mode, 41 +/- 8%
            ////DoserAlk Schedule
              if ((hour() > 10) && (hour() < 22)) { // Between 10am and 10pm we will disable Port 6
              ReefAngel.Relay.Off(Port6);
            ////Water change delay for Port 1
          static time_t wcTimer;
          if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) wcTimer=now();
          if (now()-wcTimer > 0 && now()-wcTimer < 600) {
          ReefAngel.Relay.Off(Port1);
          else {ReefAngel.SingleATOLow (Port1 );
            ReefAngel.Portal( "howaboutme" );
          static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
          static int Delay = random( 500, 3000);           // Set the initial delay
          static int NewSpeed = MidPoint;                  // Set the initial speed
          static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
          if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
            Delay=random(500,5000);                        // If so, come up with a new delay
            int ChangeUp = random(Offset);                 // Amount to go up or down
            if (random(100)<50)                            // 50/50 chance of speed going up or going down
            LastChange=millis();                           // Reset the time of the last change
          if (WaveSync)
            return NewSpeed;
            return AntiSpeed;
Key Attributes
- Able to control pump settings via portal
- When in "custom mode": WP-25 is in else mode between 1:30pm and 9:30pm, constant mode at 32% between 9:30pm and 9:30am and 36% between 9:30am and 1:30pm.
- Doses Alk 12 times a day, once per hour between 10:00pm and 10:00am, controlled via portal
- Added ATO Low code to support my Avast ATO.
PostPosted: Thu Sep 11, 2014 5:00 am
howaboutme wrote:For the record and so I can link to this on threads.
            ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit | Port8Bit;
        ReefAngel.CustomLabels[0]="Unused";
          if (WaveSync)
            return NewSpeed;
            return AntiSpeed;
Key Attributes
WOW, thanks
Ive got it now...
Return to My PDE/INO file
