00Warpig00's Code Works In Progress
PostPosted: Mon Jun 30, 2014 9:29 pm
Version 101
// Initialize Alert variables
byte AlertNonCritical=0;
byte AlertCritical=0;
byte overheatflag=0;
byte atoflag=0;
byte iochannel0flag=0;
byte iochannel1flag=0;
byte iochannel2flag=0;
byte iochannel3flag=0;
byte iochannel4flag=0;
byte iochannel5flag=0;
//*****Begin reporting of Maximum\Minimum Temperature on probe T1 Additions
int T1CurrentMinTemp=0;
int T1CurrentMaxTemp=0;
int T1MinTemp=0;
int T1MaxTemp=0;
//*****End reporting of Maximum\Minimum Temperature on probe T1 Additions
//*****Begin WaterChange Additions
// skimmer port
byte SkimmerPort = Port4;
// return port
byte ReturnPort = Port3;
// sump drain port
byte SumpDrainPort = Port8;
// SaltWater brute pump
byte SWBrutePort = Port7;
// Timer for countdowns
TimerClass tm;
//*****End WaterChange Additions
//*****Begin ATO By Salinity Additions
byte ATOBrutePort = Port2;
//*****End ATO By Salinity Additions
//*****Begin Custom Menu Additions
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Mask LED's On";
prog_char menu2_label[] PROGMEM = "Mask LED's Off";
prog_char menu3_label[] PROGMEM = "Mask LED's Clear";
prog_char menu4_label[] PROGMEM = "Water Change";
prog_char menu5_label[] PROGMEM = "Clear ATO Timeout";
prog_char menu6_label[] PROGMEM = "Overheat Clear";
prog_char menu7_label[] PROGMEM = "PH Calibration";
prog_char menu8_label[] PROGMEM = "Date / Time";
PROGMEM const char *menu_items[] =
    menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label,
//*****End Custom Menu Additions
    //_Running_Config_Revision_101
    InternalMemory.write(100, 101);
    //*****Begin Custom Menu Additions... Initialize Custom Menu
    InternalMemory.write(199, 0); //sets the controller to non masked LED mode upon boot.
    ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit;
    ReefAngel.OverheatShutoffPorts = Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.CustomVar[0]=0;
    ReefAngel.CustomVar[1]=0;
    ReefAngel.CustomVar[2]=0;
    ReefAngel.CustomVar[3]=0;
    ReefAngel.CustomVar[4]=0;
    ReefAngel.CustomVar[5]=0;
    ReefAngel.CustomVar[6]=0;
    ReefAngel.CustomVar[7]=0;
    T1CurrentMinTemp=1;
    T1CurrentMaxTemp=1;
    T1MinTemp=0;
    T1MaxTemp=0;
    ReefAngel.StandardFan( Port1,790,820 );
    ReefAngel.Relay.DelayedOn( Port4,1 );
    ReefAngel.WavemakerRandom( Port5,30,100 );
    ReefAngel.StandardHeater( Port6,750,760 );
    ReefAngel.StandardLights( Box1_Port1,13,0,23,0 );
    ReefAngel.StandardLights( Box1_Port2,13,0,23,0 );
    ReefAngel.StandardHeater( Box1_Port3,750,760 );
    ReefAngel.StandardHeater( Box1_Port4,750,760 );
  // Removes LED's from a "MASKED" State
  if ( InternalMemory.read(199) == 0 )
      ReefAngel.PWM.SetChannel( 0, PWMParabola(14,0,23,59,1,100,1) ); //Sets LED Drivers on Ch0 to Parabola math
      ReefAngel.PWM.SetChannel( 1, PWMParabola(14,0,23,59,1,100,1) ); //Sets LED Drivers on Ch1 to Parabola math
      ReefAngel.PWM.SetChannel( 3, PWMSlope(2,0,7,30,0,50,0,0) ); //Opens/closes 5V relay on Ch3 that shorts\opens dimmer leads on Ch0 LED driver to turn Driver on/off
      ReefAngel.PWM.SetChannel( 4, PWMSlope(0,0,14,0,0,50,0,0) ); //Opens/closes 5V relay on Ch4 that shorts\opens dimmer leads on Ch1 LED driver to turn Driver on/off
  // MASKS LED's Off
  if ( InternalMemory.read(199) == 1 )
      ReefAngel.PWM.SetChannel( 0, 0 ); //Sets LED Drivers on Ch0 to 0%
      ReefAngel.PWM.SetChannel( 1, 0 ); //Sets LED Drivers on Ch1 to 0%
      ReefAngel.PWM.SetChannel( 3, 50 ); //closes 5V relay on Ch3 that shorts dimmer leads on Ch0 LED driver to turn Driver off
      ReefAngel.PWM.SetChannel( 4, 50 ); //closes 5V relay on Ch4 that shorts dimmer leads on Ch1 LED driver to turn Driver off
  if ( InternalMemory.read(199) == 2 )
      ReefAngel.PWM.SetChannel( 0, 100 ); //Sets LED Drivers on Ch0 to 100%
      ReefAngel.PWM.SetChannel( 1, 100 ); //Sets LED Drivers on Ch1 to 100%
      ReefAngel.PWM.SetChannel( 3, 0 ); //Opens 5V relay on Ch3 that removes short on dimmer leads on Ch0 LED driver to turn Driver on
      ReefAngel.PWM.SetChannel( 4, 0 ); //Opens 5V relay on Ch4 that removes short on dimmer leads on Ch1 LED driver to turn Driver on
    T1CurrentMinTemp=ReefAngel.Params.Temp[T1_PROBE];
      if ( T1CurrentMinTemp < T1MinTemp )
          T1MinTemp = T1CurrentMinTemp;
          InternalMemory.write(101, T1MinTemp);
    T1CurrentMaxTemp=ReefAngel.Params.Temp[T1_PROBE];
      if ( T1CurrentMaxTemp > T1MaxTemp )
          T1MaxTemp = T1CurrentMaxTemp;
          InternalMemory.write(102, T1MaxTemp);
    overheatflag = InternalMemory.read( Overheat_Exceed_Flag );
    atoflag = InternalMemory.read( ATO_Exceed_Flag );
    iochannel0flag = ! ReefAngel.IO.GetChannel( 0 );
    iochannel1flag = ! ReefAngel.IO.GetChannel( 1 );
    iochannel2flag = ! ReefAngel.IO.GetChannel( 2 );
    iochannel3flag = ! ReefAngel.IO.GetChannel( 3 );
    iochannel4flag = ! ReefAngel.IO.GetChannel( 4 );
    iochannel5flag = ! ReefAngel.IO.GetChannel( 5 );
    AlertNonCritical = atoflag + iochannel2flag + iochannel3flag + iochannel4flag + iochannel5flag;
    AlertCritical = overheatflag + iochannel0flag + iochannel1flag;
    if ( AlertNonCritical >= 1 ) AlertNonCritical = 5;
    if ( AlertCritical >= 1 ) AlertCritical = 5;
    ReefAngel.PWM.SetActinic(millis()%60000<100?AlertNonCritical:0);
    ReefAngel.PWM.SetDaylight(millis()%60000<100?AlertNonCritical:0);
    if ( AlertCritical >= 1 ) ReefAngel.PWM.SetActinic(millis()%300<100?AlertCritical:0);
    if ( AlertCritical >= 1 ) ReefAngel.PWM.SetDaylight(millis()%300<100?AlertCritical:0);
    ReefAngel.CustomVar[0]=InternalMemory.read(ATO_Exceed_Flag);
    ReefAngel.CustomVar[1]=InternalMemory.read(Overheat_Exceed_Flag);
    ReefAngel.CustomVar[4]=InternalMemory.read(199);
    ReefAngel.CustomVar[5]=AlertNonCritical;
    ReefAngel.CustomVar[6]=AlertCritical;
    ReefAngel.CustomVar[7]=ATOBrutePort;
    if ( ReefAngel.CustomVar[0]== 1 )
        ReefAngel.Relay.RelayMaskOff=~(Port4Bit);
    //*****Begin WC Additions
    // If menu equals waterchange mode
    // then we start the automatic water change
    // Otherwise we ignore and proceed
    if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE)
        AutoWaterChange();
    //*****End WC Additions
    if (ReefAngel.Params.Salinity<300)
        ATOBrutePort=Port7;
        ATOBrutePort=Port2;
    ReefAngel.StandardATO(ATOBrutePort,40 );
    if (iochannel2flag == 1)
        ReefAngel.Relay.RelayMaskOff=~(Port7Bit);
    if (iochannel4flag == 1)
        ReefAngel.Relay.RelayMaskOff=~(Port2Bit);
    ReefAngel.Portal( "00Warpig00" );
//Mask LED's On. Forces LED's On Full Blast
void MenuEntry1()
    InternalMemory.write(199, 2);
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "                      ");
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Mask Lights On"); waitForTime(2);
//Mask LED's Off. Forces LED's Off
void MenuEntry2()
    InternalMemory.write(199, 1);
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Mask Lights Off"); waitForTime(2);
//Mask LED's Clear. Remove LED Masking Returns LED's To Normal Schedule
void MenuEntry3()
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Mask Lights Clear"); waitForTime(2);
//Start Waterchange Mode
void MenuEntry4()
//Clear ATO Timeout Flag
void MenuEntry5()
    ReefAngel.ATOClear();
//Clear Overheat Flag
void MenuEntry6()
    ReefAngel.OverheatClear();
//Calibrate PH Probe
void MenuEntry7()
    ReefAngel.SetupCalibratePH();
//Set clock Date & Time
void MenuEntry8()
    ReefAngel.SetupDateTime();
void AutoWaterChange()
    // auto water change mode
    // Display Starting Water Change"
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Starting Water Change"); waitForTime(3);
    // Check Saltwater BRUTE for sufficient saltwater on IO Module Port2
    if ( isSWBruteEmpty() )
        ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Not Enough Saltwater"); waitForTime(3);
        //Abort Water Change if insufficient saltwater
        // Handles the cleanup to return to the main screen
        ReefAngel.DisplayedMenu = DEFAULT_MENU;
        DrawCustomGraph();
        return;
    //Display Disabling ATO Pump
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Disabling ATO Pump"); waitForTime(3);
    // turn off ATO pump port to prevent ATO from trying to fill a sump being drained intentionally
    //Display Stopping Skimmer
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Stopping Skimmer"); waitForTime(3);
    // turn off the skimmer port
    ReefAngel.Relay.Off(SkimmerPort);
    ReefAngel.Relay.Write();
    //Display Skimmer Draining
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Skimmer Draining"); waitForTime(3);
    // wait for 1 minute
    waitForTime(60);
    //Display Skimmer Done Draining
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Skimmer Done Draining"); waitForTime(3);
    //display Stopping Return Pump
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Stopping Return Pump"); waitForTime(3);
    //Stop Return Pump
    ReefAngel.Relay.Off(ReturnPort);
    //Display Draining To Sump
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Draining To Sump"); waitForTime(3);
    //display Sump Filling
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Filling"); waitForTime(3);
    // wait for IO Mod Port 1 to be active
    waitForIOChannel(1);
    //display Sump Is Full
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Is Full"); waitForTime(3);
    //Display Sump Settling
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Settling"); waitForTime(3);
    // wait for sump to settle
    waitForTime(30);
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Settled"); waitForTime(3);
    // display Draining Sump
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Start Draining Sump"); waitForTime(3);
    //turn on sump drain pump
    ReefAngel.Relay.On(SumpDrainPort);
    //display Sump Draining
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Draining"); waitForTime(3);
    // wait for sump empty port active, IO Mod Port 0
    waitForIOChannel(0);
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Sump Is Empty"); waitForTime(3);
    //display Stopping Sump Draining
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Stopping Sump Drain"); waitForTime(3);
    // turn off sump drain
    ReefAngel.Relay.Off(SumpDrainPort);
    waitForTime(30);
    //display Sump Settled
    //display Starting Saltwater Pump
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Start Saltwater Pump"); waitForTime(3);
    //turn on Saltwater Pump
    ReefAngel.Relay.On(SWBrutePort);
    //display Saltwater Pumping
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Saltwater Pumping"); waitForTime(3);
    // wait for sump full float switch active, IO Mod Port 1
    //display Stop Saltwater Pump
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Stop Saltwater Pump"); waitForTime(3);
    // turn off sw brute pump
    ReefAngel.Relay.Off(SWBrutePort);
    //diasplay Sump is Full
    waitForTime(30);
    //display Starting Return Pump
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Starting Return Pump"); waitForTime(3);
    // turn on return pump
    ReefAngel.Relay.On(ReturnPort);
    //display Return Pump Started
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Return Pump Started"); waitForTime(3);
    //display Normalizing Waterlevel
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Normalizing Waterlevel"); waitForTime(3);
    //waiting 2 minutes for waterlevel to normalize
    waitForTime(120);
    //display Starting Skimer
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Starting Skimmer"); waitForTime(3);
    //turn on skimmer
    ReefAngel.Relay.On(SkimmerPort);
    //display Normalizing Skimmer
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Normalizing Skimmer"); waitForTime(3);
    //wait for 2 minutes for skimmer to normalize
    waitForTime(120);
    //display Skimmer Normalized
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Skimmer Normalized"); waitForTime(3);
    //display Enabling ATO Pump
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Enabling ATO Pump"); waitForTime(3);
    //Enable ATO pump
    ReefAngel.Relay.RelayMaskOff = B11111111;
    //display Water Change Complete
    ReefAngel.LCD.DrawText(ModeScreenColor, DefaultBGColor, 2, 30, "Water Change Complete"); waitForTime(3);
    DrawCustomGraph();
bool isSWBruteEmpty()
  // check status of IO Mod Port 2
  if ( ! ReefAngel.IO.GetChannel(2) )
      return true;
  return false;
void waitForTime(int seconds)
    bool done = false;
    tm.SetInterval(seconds);
    tm.Start();
    int t = tm.Trigger - now();
    do
      // check the wifi interface
      // wait for specified seconds
      if ( (t >= 0) && ! tm.IsTriggered() )
          // TODO finish countdown on screen
          // show countdown on screen
          //LCD.Clear(DefaultBGColor,60+(intlength(t)*5),100,100,108);
          //LCD.DrawText(DefaultFGColor,DefaultBGColor,60,100,t);
          wdt_reset();
          delay(200);
          done = true;
    } while ( !done );
    return;
void waitForIOChannel(byte channel)
    // TODO complete this function
    do
      wdt_reset();
      // display something on screen
      delay(200);
      // TODO check the IO channel logic
    } while ( ReefAngel.IO.GetChannel(channel) );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,x,y,"Ch :   " );
      y += 10;
    // I/O Expansion
    byte bkcolor;
    x = 14;
    y = 34;
      if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE; else bkcolor=COLOR_GRAY;
    ReefAngel.LCD.DrawMonitor( 15, 44, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 44, ReefAngel.Params );
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,76, "SAL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,60,76, "L" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,90,76, "H" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,76, ReefAngel.Params.Salinity );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,69,76, T1MinTemp );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,98,76, T1MaxTemp );
    // Relay Expansion
    ReefAngel.LCD.DrawOutletBox( 12, 104, TempRelay );
180G FOWLR
20GH QT#1
29G QT#2
PostPosted: Mon Jun 30, 2014 9:31 pm
Version 102
byte atoflag=0;
int T1MinTemp=9999;
int T1MaxTemp=1;
int T1Temp=1;
// skimmer port
// return port
// sump drain port
TimerClass tm;
    //_Running_Config_Revision_102
    InternalMemory.write(100, 102);
  // MASKS LED's Off
    T1Temp=ReefAngel.Params.Temp[T1_PROBE];
//T1MaxTemp = T1Temp;
//T1MinTemp = T1Temp;
      if ( T1Temp > T1MaxTemp ) T1MaxTemp = T1Temp;
      if ( T1Temp < T1MinTemp ) T1MinTemp = T1Temp;
        AutoWaterChange();
        ATOBrutePort=Port7;
        ATOBrutePort=Port2;
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
        DrawCustomGraph();
        return;
    waitForTime(60);
    //Stop Return Pump
    waitForTime(30);
    waitForTime(30);
    waitForTime(30);
    waitForTime(120);
    //turn on skimmer
    waitForTime(120);
    //Enable ATO pump
    DrawCustomGraph();
      return true;
  return false;
    bool done = false;
    tm.Start();
    do
          wdt_reset();
          delay(200);
          done = true;
    } while ( !done );
    return;
    do
      wdt_reset();
      delay(200);
    int x,y;
    x = 15;
    y = 2;
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
    // I/O Expansion
    byte bkcolor;
    x = 14;
    y = 34;
    // Salinity
    // Relay Expansion
180G FOWLR
20GH QT#1
29G QT#2
Version 103
byte atoflag=0;
int T1MinTemp=9999;
int T1MaxTemp=1;
int T1Temp=1;
// skimmer port
// return port
// sump drain port
TimerClass tm;
//*****Begin Custom IO Expander Additions
byte CustomIOExpanderData = 255;
//*****End Custom IO Expander Additions
    //_Running_Config_Revision_103
    InternalMemory.write(100, 103);
  // MASKS LED's Off
    ReefAngel.CustomVar[2]=CustomIOExpanderData;
        AutoWaterChange();
        ATOBrutePort=Port7;
        ATOBrutePort=Port2;
    Serial.println(expanderRead());
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
        DrawCustomGraph();
        return;
    waitForTime(60);
    //Stop Return Pump
    waitForTime(30);
    waitForTime(30);
    waitForTime(30);
    waitForTime(120);
    //turn on skimmer
    waitForTime(120);
    //Enable ATO pump
    DrawCustomGraph();
      return true;
  return false;
    bool done = false;
    tm.Start();
    do
          wdt_reset();
          delay(200);
          done = true;
    } while ( !done );
    return;
    do
      wdt_reset();
      delay(200);
    byte expanderRead()
      byte _data=0;
      Wire.requestFrom(0x27, 1);
      if(Wire.available())
        _data = Wire.read();
        CustomIOExpanderData = _data;
      delay(10);
      return _data;
    int x,y;
    x = 15;
    y = 2;
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
    // I/O Expansion
    byte bkcolor;
    x = 14;
    y = 34;
    // Salinity
    // Relay Expansion
180G FOWLR
20GH QT#1
29G QT#2
PostPosted: Mon Jun 30, 2014 9:32 pm
Version 104
    byte atoflag=0;
    int T1MinTemp=9999;
    int T1MaxTemp=1;
    int T1Temp=1;
    // skimmer port
    // return port
    // sump drain port
    TimerClass tm;
    byte CustomIOExpander = 255;
        //_Running_Config_Revision_104
        InternalMemory.write(100, 104);
      // MASKS LED's Off
        ReefAngel.CustomVar[2]=CustomIOExpander;
            AutoWaterChange();
            ATOBrutePort=Port7;
            ATOBrutePort=Port2;
    void MenuEntry1()
    void MenuEntry2()
    void MenuEntry3()
    void MenuEntry4()
    void MenuEntry5()
    void MenuEntry6()
    void MenuEntry7()
    void MenuEntry8()
            DrawCustomGraph();
            return;
        waitForTime(60);
        //Stop Return Pump
        waitForTime(30);
        waitForTime(30);
        waitForTime(30);
        waitForTime(120);
        //turn on skimmer
        waitForTime(120);
        //Enable ATO pump
        DrawCustomGraph();
          return true;
      return false;
        bool done = false;
        tm.Start();
        do
              wdt_reset();
              delay(200);
              done = true;
        } while ( !done );
        return;
        do
          wdt_reset();
          delay(200);
        byte expanderRead()
          byte _data=0;
            CustomIOExpander = _data;
          delay(10);
          return _data;
        boolean expanderReadGetChannel(byte channel)
          return bitRead(expanderRead(),channel);
        int x,y;
        x = 15;
        y = 2;
          if ( a>2 ) x = 75;
          if ( a==3 ) y = 2;
          y += 10;
        // I/O Expansion
        byte bkcolor;
        x = 14;
        y = 34;
        // Salinity
        // Relay Expansion
180G FOWLR
20GH QT#1
29G QT#2
PostPosted: Mon Jun 30, 2014 9:33 pm
Version 105
    byte atoflag=0;
    int T1LowTemp=999;
    int T1HighTemp=1;
    int T1Read=1;
    // skimmer port
    // return port
    // sump drain port
    TimerClass tm;
        //_Compiled_With_Libs_Version_1.1.0
        InternalMemory.write(100, 110);
        //_Running_Config_Revision_105
        InternalMemory.write(102, 105);
        InternalMemory.write(199, 0); //sets the controller to non masked LED mode upon reboot.
      // MASKS LED's Off
      // MASKS LED's On
        T1Read = ReefAngel.Params.Temp[T1_PROBE];
          if (T1Read !=0)
              T1LowTemp = min(T1LowTemp, T1Read);
              T1HighTemp = max(T1HighTemp, T1Read);
            AutoWaterChange();
            ATOBrutePort=Port7;
            ATOBrutePort=Port2;
    void MenuEntry1()
    void MenuEntry2()
    void MenuEntry3()
    void MenuEntry4()
    void MenuEntry5()
    void MenuEntry6()
    void MenuEntry7()
    void MenuEntry8()
            DrawCustomGraph();
            return;
        waitForTime(60);
        //Stop Return Pump
        waitForTime(30);
        waitForTime(30);
        waitForTime(30);
        waitForTime(120);
        //display Starting Skimmer
        //turn on skimmer
        waitForTime(120);
        //Enable ATO pump
        DrawCustomGraph();
          return true;
      return false;
        bool done = false;
        tm.Start();
        do
              wdt_reset();
              delay(200);
              done = true;
        } while ( !done );
        return;
        do
          wdt_reset();
          delay(200);
        byte expanderRead()
          byte _data=0;
          delay(10);
          return _data;
        int x,y;
        x = 15;
        y = 2;
          if ( a>2 ) x = 75;
          if ( a==3 ) y = 2;
          y += 10;
        // I/O Expansion
        byte bkcolor;
        x = 14;
        y = 34;
        // Salinity
        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,69,76, T1LowTemp );
        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,98,76, T1HighTemp );
        // Relay Expansion
180G FOWLR
20GH QT#1
29G QT#2
PostPosted: Mon Jun 30, 2014 9:34 pm
Version 106
    byte atoflag=0;
    //*****Begin timing Light mask for auto mask release Additions
    long LightMaskTimerStart;
    long LightMaskTimerElapsed;
    long LightMaskTimerRelease;
    long LightMaskTimerPercentageDivider;
    //*****End timing Light mask for auto mask release
    int T1LowTemp=999;
    int T1HighTemp=1;
    int T1Read=1;
    // skimmer port
    // return port
    // sump drain port
    TimerClass tm;
        InternalMemory.write(110, 110);
        //_Running_Config_Revision_106
        InternalMemory.write(111, 106);
        LightMaskTimerStart=1; //milli value when the lights are masked on or off
        LightMaskTimerElapsed=1; //milli value elapsed since lights were masked on or off
        LightMaskTimerRelease=10800000; //if light mask is set and forgotten, clear the mask after 10,800,000 milli (3 Hours)
        LightMaskTimerPercentageDivider=LightMaskTimerRelease / 100 ;
        //*****End timing Light mask for auto mask release Additions
          ReefAngel.StandardLights( Box1_Port1,13,0,23,0 ); //turns QT Light schedule on if not masked off
          ReefAngel.StandardLights( Box1_Port2,13,0,23,0 ); //turns QT Light schedule on if not masked off
      // MASKS LED's Off
          LightMaskTimerElapsed=millis() - LightMaskTimerStart; //milli value time elapsed while lights are masked Off
          ReefAngel.Relay.Off( Box1_Port1 ); //turns QT Lights OFF if masked off
          ReefAngel.Relay.Off( Box1_Port2 ); //turns QT Lights OFF if masked off
            if (LightMaskTimerElapsed > LightMaskTimerRelease) InternalMemory.write(199, 0); //clears forgotten light mask due to timeout.
      // MASKS LED's On
          LightMaskTimerElapsed=millis() - LightMaskTimerStart; //milli value time elapsed while lights are masked On
          ReefAngel.Relay.On( Box1_Port1 ); //turns QT Lights ON if masked on
          ReefAngel.Relay.On( Box1_Port2 ); //turns QT Lights ON if masked on
          if (T1Read !=0)
            AutoWaterChange();
            ATOBrutePort=Port7;
            ATOBrutePort=Port2;
    void MenuEntry1()
        LightMaskTimerStart=millis(); //milli value when the lights are masked on
    void MenuEntry2()
        LightMaskTimerStart=millis(); //milli value when the lights are masked off
    void MenuEntry3()
        LightMaskTimerElapsed=0;
    void MenuEntry4()
    void MenuEntry5()
    void MenuEntry6()
    void MenuEntry7()
    void MenuEntry8()
            DrawCustomGraph();
            return;
        waitForTime(60);
        //Stop Return Pump
        waitForTime(30);
        waitForTime(30);
        waitForTime(30);
        waitForTime(120);
        //turn on skimmer
        waitForTime(120);
        //Enable ATO pump
        DrawCustomGraph();
          return true;
      return false;
        bool done = false;
        tm.Start();
        do
              wdt_reset();
              delay(200);
              done = true;
        } while ( !done );
        return;
        do
          wdt_reset();
          delay(200);
        byte expanderRead()
          byte _data=0;
          delay(10);
          return _data;
        int x,y;
        x = 15;
        y = 2;
          if ( a>2 ) x = 75;
          if ( a==3 ) y = 2;
          y += 10;
        // I/O Expansion
        byte bkcolor;
        x = 14;
        y = 34;
        // Salinity
        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,73, "SAL:" );
        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,60,73, "L" );
        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,90,73, "H" );
        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,82, "LMT%:" );
        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,73, ReefAngel.Params.Salinity );
        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,69,73, T1LowTemp );
        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,98,73, T1HighTemp );
        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,45,82, "    " );
        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,45,82, 100 - (LightMaskTimerElapsed / LightMaskTimerPercentageDivider));
        // Relay Expansion
180G FOWLR
20GH QT#1
29G QT#2
PostPosted: Mon Jun 30, 2014 9:35 pm
Version 107
    byte atoflag=0;
    //*****Begin Light Mask Timer Additions
    byte LightMaskRemaining=0;
    byte CurrentLightMask=0;
    byte PreviousLightMask=255;
    byte IgnoreMaskDuration; //manual switch to disable automatic Light Mask timeout (0=normal, != 0 = Ignore Light Mask timeout)
    byte MaskDuration; //Mask timer length in minutes 0 - 255
    long TargetMillis; //End of Timer in Millis
    long CurrentMillis; //Current Time in Millis
    long InitialMillis; //Start Time in Millis
    //*****End Light Mask Timer Additions
    int T1LowTemp=999;
    int T1HighTemp=1;
    int T1Read=1;
    // skimmer port
    // return port
    // sump drain port
    TimerClass tm;
        //_Running_Config_Revision_107
        InternalMemory.write(111, 107);
        if (InternalMemory.read(199) !=0) (InternalMemory.write(199, 0)); //sets the controller to non masked LED mode upon reboot.
      //LightMaskRemaining = ( TargetMillis - CurrentMillis ) / 3600000;//Display Light Mask Time Remaining in Hours
      LightMaskRemaining = ( TargetMillis - CurrentMillis ) / 60000;//Display Light Mask Time Remaining in Minutes
      //LightMaskRemaining = ( TargetMillis - CurrentMillis ) / 1000;//Display Light Mask Time Remaining in seconds
      CurrentLightMask = InternalMemory.read(199);//reads current light mask setting
      MaskDuration = InternalMemory.read (198);  //Mask timer length in minutes 0 - 255 (0:00 - 4:15)
      IgnoreMaskDuration = InternalMemory.read (197); //manual switch to disable automatic Light Mask timeout (0=normal, != 0 = Ignore Light Mask timeout)
      CurrentMillis = millis();//update the timer to the current count
      if ( CurrentLightMask == 0 )
      if ( PreviousLightMask != CurrentLightMask )//Checks if the light mask setting has been changed
          //Checks if light mask value has been set to an invalid value by direct memory access and clears (sets to 0) mask if not valid
        if ( CurrentLightMask > 2 )
            InternalMemory.write(199, 0); //clears light mask if value is not valid.
        // MASKS LED's Off
        if ( CurrentLightMask == 1 )
            TargetMillis = CurrentMillis + ( MaskDuration * 60000 ); //Set the duration of the mask timer in minutes ( 1 - 255 )
        // MASKS LED's On
        if ( CurrentLightMask == 2 )
        PreviousLightMask = CurrentLightMask;
        if ( CurrentLightMask != 0 )// Checks if lights are masked on or off
            if ( IgnoreMaskDuration == 0 )//Checks if Light mask timer ignore byte is active
                if ( CurrentMillis > TargetMillis )//checks if Light mask timeout has expired.
                    CurrentMillis = 0;//sets back to 0 when not being used to prevent display from counting negative time when Light mask is cleared.
                    TargetMillis = 0;//sets back to 0 when not being used to prevent display from counting negative time when Light mask is cleared.
          if (T1Read !=0)//Debounce for Low Temperature reading 0 at startup
              T1LowTemp = min(T1LowTemp, T1Read);//Tracks Low Temperature
              T1HighTemp = max(T1HighTemp, T1Read);//Tracks High Temperature
        ReefAngel.CustomVar[4]=LightMaskRemaining;
            AutoWaterChange();
            ATOBrutePort=Port7;
            ATOBrutePort=Port2;
    //Mask Lights On. Forces Lights's On Full Blast
    void MenuEntry1()
    //Mask Lights Off. Forces Lights Off
    void MenuEntry2()
    //Mask Lights Clear. Remove Light Masking Returns Lights to normal schedule
    void MenuEntry3()
    void MenuEntry4()
    void MenuEntry5()
    void MenuEntry6()
    void MenuEntry7()
    void MenuEntry8()
    //*****Begin Water Change Additions
            DrawCustomGraph();
            return;
        waitForTime(60);
        //Stop Return Pump
        waitForTime(30);
        waitForTime(30);
        waitForTime(30);
        waitForTime(120);
        //turn on skimmer
        waitForTime(120);
        //Enable ATO pump
        DrawCustomGraph();
          return true;
      return false;
        bool done = false;
        tm.Start();
        do
              wdt_reset();
              delay(200);
              done = true;
        } while ( !done );
        return;
        do
          wdt_reset();
          delay(200);
    //*****End Water Change Additions
        byte expanderRead()
          byte _data=0;
          delay(10);
          return _data;
        int x,y;
        x = 15;
        y = 2;
          if ( a>2 ) x = 75;
          if ( a==3 ) y = 2;
          y += 10;
        // I/O Expansion
        byte bkcolor;
        x = 14;
        y = 34;
        // Salinity
          ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,73, "SAL:" );//Display Salinity
          ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,82, "LMTR:" );//Display Light Mask Time Remaining
//        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,45,82, "  Hours." );//Clear screen video from data location before new data draw
          ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,45,82, "    Min." );//Clear screen video from data location before new data draw
//        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,45,82, "      Sec." );//Clear screen video from data location before new data draw
//        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,45,82, ( TargetMillis - CurrentMillis ) / 3600000 );//Display Light Mask Time Remaining in Hours
          ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,45,82, ( TargetMillis - CurrentMillis ) / 60000 );//Display Light Mask Time Remaining in Minutes
//        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,45,82, ( TargetMillis - CurrentMillis ) / 1000 );//Display Light Mask Time Remaining in seconds
          ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,60,73, "L:" );//Display Low Temperature
          ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,96,73, "H:" );//Display High Temperature
          ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,73, ReefAngel.Params.Salinity );//Display Salinity
          ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,72,73, T1LowTemp );//Display Low Temperature
          ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,108,73, T1HighTemp );//Display High Temperature
        // Relay Expansion
180G FOWLR
20GH QT#1
29G QT#2
PostPosted: Mon Jun 30, 2014 9:36 pm
Version 108
    byte AlertATOPump=0;
    byte atoflag=0;
    int T1LowTemp=999;
    int T1HighTemp=1;
    int T1Read=1;
    // skimmer port
    // return port
    // sump drain port
    TimerClass tm;
    byte ATOBrutePort = Port7;
    char ATOBruteText[ ] = "ATOSW";
        //_Running_Config_Revision_108 06/29/2014
        InternalMemory.write(111, 108);
        // Ports that should always be on/off at startup
        ReefAngel.Relay.On( Port3 );//Turns 180G Return Pump ON if controller reboots
        ReefAngel.Relay.Off( Port2 );//Turns 180G RO/DI Topoff OFF if controller reboots
        ReefAngel.Relay.Off( Port7 );//Turns 180G SW Topoff OFF if controller reboots
        ReefAngel.Relay.Off( Port8 );//Turns 180G Sump Drain OFF if controller reboots
        ReefAngel.Relay.On( Box1_Port5 );//Turns 20GH QT Return Pump ON if controller reboots
        ReefAngel.Relay.On( Box1_Port6 );//Turns 29G QT Return Pump ON if controller reboots
        ReefAngel.Relay.On( Box1_Port7 );//Turns 20GH QT MaxiJet Pump ON if controller reboots
        ReefAngel.Relay.On( Box1_Port8 );//Turns 29G QT MaxiJet Pump ON if controller reboots
        // MASKS LED's Off
        // MASKS LED's On
        AlertATOPump = ReefAngel.Relay.Status(Port2);
        AlertCritical = AlertATOPump + overheatflag + iochannel0flag + iochannel1flag;
        if ( AlertNonCritical >= 1 ) AlertNonCritical = 25;
        if ( AlertCritical >= 1 ) AlertCritical = 25;
        if ( AlertNonCritical >= 1 ) ReefAngel.PWM.SetActinic(millis()%60000<100?AlertNonCritical:0);
        if ( AlertNonCritical >= 1 ) ReefAngel.PWM.SetDaylight(millis()%60000<100?AlertNonCritical:0);
        ReefAngel.CustomVar[0]=LightMaskRemaining;
        ReefAngel.CustomVar[1]=AlertCritical;
        ReefAngel.CustomVar[2]=AlertNonCritical;
        ReefAngel.CustomVar[3]=ATOBrutePort;
//        ReefAngel.CustomVar[4]=
//        ReefAngel.CustomVar[5]=
//        ReefAngel.CustomVar[6]=
//        ReefAngel.CustomVar[7]=
        if ( InternalMemory.read(ATO_Exceed_Flag)== 1 )
            AutoWaterChange();
        if (ReefAngel.Params.Salinity<300)//if salinity is low switch to Saltwater ATO
            ReefAngel.StandardATO(Port7,40 );//ATO Port is now Saltwater Port7
            ReefAngel.Relay.Off(Port2);//Turn off RO/DI Port2
            ATOBrutePort=Port7;
        else//if Salinity is high switch to RO/DI Topoff
            ReefAngel.StandardATO(Port2,40 );//ATO Port is now RO/DI Port2
            ReefAngel.Relay.Off(Port7);//Turn off Saltwater Port7
            ATOBrutePort=Port2;
            char ATOBruteText[ ] = "ATORO";
        if (iochannel2flag == 1)//IF ATO Brute is empty do not pump
            ReefAngel.Relay.RelayMaskOff=~(Port7Bit);//Mask Off Saltwater Brute Pump
        if (iochannel4flag == 1)//IF ATO Brute is empty do not pump
            ReefAngel.Relay.RelayMaskOff=~(Port2Bit);//Mask Off RO/DI Brute Pump
    void MenuEntry1()
    void MenuEntry2()
    void MenuEntry3()
    void MenuEntry4()
    void MenuEntry5()
    void MenuEntry6()
    void MenuEntry7()
    void MenuEntry8()
            DrawCustomGraph();
            return;
        waitForTime(60);
        //Stop Return Pump
        waitForTime(30);
        waitForTime(30);
        waitForTime(30);
        waitForTime(120);
        //turn on skimmer
        waitForTime(120);
        //Enable ATO pump
        DrawCustomGraph();
          return true;
      return false;
        bool done = false;
        tm.Start();
        do
              wdt_reset();
              delay(200);
              done = true;
        } while ( !done );
        return;
        do
          wdt_reset();
          delay(200);
        byte expanderRead()
          byte _data=0;
          delay(10);
          return _data;
        int x,y;
        x = 15;
        y = 2;
          if ( a>2 ) x = 75;
          if ( a==3 ) y = 2;
          y += 10;
        // I/O Expansion
        byte bkcolor;
        x = 14;
        y = 34;
        // Salinity
          ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,96,82, ATOBruteText );
        // Relay Expansion
180G FOWLR
20GH QT#1
29G QT#2
PostPosted: Mon Jun 30, 2014 9:37 pm
Version 109
    byte atoflag=0;
    byte CurrentMaskDuration; //Mask timer length in minutes 0 - 255
    byte PreviousMaskDuration; //Mask timer variable to check for CurrentMaskDuration changes via direct write to memory location 198
    int T1LowTemp=999;
    int T1HighTemp=1;
    int T1Read=1;
    // skimmer port
    // return port
    // sump drain port
    TimerClass tm;
        //_Running_Config_Revision_109 06/30/2014
        InternalMemory.write(111, 109);
      CurrentMaskDuration = InternalMemory.read (198);  //Mask timer length in minutes 0 - 255 (0:00 - 4:15)
      if ( ( PreviousLightMask != CurrentLightMask ) || ( PreviousMaskDuration != CurrentMaskDuration ) )//Checks if the light mask setting or duration has been manually changed
        // MASKS LED's Off
            TargetMillis = CurrentMillis + ( CurrentMaskDuration * 60000 ); //Set the duration of the mask timer in minutes ( 1 - 255 )
        // MASKS LED's On
        PreviousMaskDuration = CurrentMaskDuration;
            AutoWaterChange();
            ATOBrutePort=Port7;
            ATOBrutePort=Port2;
    void MenuEntry1()
    void MenuEntry2()
    void MenuEntry3()
    void MenuEntry4()
    void MenuEntry5()
    void MenuEntry6()
    void MenuEntry7()
    void MenuEntry8()
            DrawCustomGraph();
            return;
        waitForTime(60);
        //Stop Return Pump
        waitForTime(30);
        waitForTime(30);
        waitForTime(30);
        waitForTime(120);
        //turn on skimmer
        waitForTime(120);
        //Enable ATO pump
        DrawCustomGraph();
          return true;
      return false;
        bool done = false;
        tm.Start();
        do
              wdt_reset();
              delay(200);
              done = true;
        } while ( !done );
        return;
        do
          wdt_reset();
          delay(200);
        byte expanderRead()
          byte _data=0;
          delay(10);
          return _data;
        int x,y;
        x = 15;
        y = 2;
          if ( a>2 ) x = 75;
          if ( a==3 ) y = 2;
          y += 10;
        // I/O Expansion
        byte bkcolor;
        x = 14;
        y = 34;
        // Salinity
        // Relay Expansion
180G FOWLR
20GH QT#1
29G QT#2
PostPosted: Sun Jul 13, 2014 7:20 pm
Version 110
    byte atoflag=0;
    int T1LowTemp=999;
    int T1HighTemp=1;
    int T1Read=1;
    // skimmer port
    // return port
    // sump drain port
    TimerClass tm;
        //_Running_Config_Revision_110 07/10/2014
        // MASKS LED's Off
        // MASKS LED's On
        else { ReefAngel.PWM.SetActinic(0); }
        else { ReefAngel.PWM.SetDaylight(0); }
            AutoWaterChange();
            ATOBrutePort=Port7;
            ATOBrutePort=Port2;
    void MenuEntry1()
    void MenuEntry2()
    void MenuEntry3()
    void MenuEntry4()
    void MenuEntry5()
    void MenuEntry6()
    void MenuEntry7()
    void MenuEntry8()
            DrawCustomGraph();
            return;
        waitForTime(60);
        //Stop Return Pump
        waitForTime(30);
        waitForTime(30);
        waitForTime(30);
        waitForTime(120);
        //turn on skimmer
        waitForTime(120);
        //Enable ATO pump
        DrawCustomGraph();
          return true;
      return false;
        bool done = false;
        tm.Start();
        do
              wdt_reset();
              delay(200);
              done = true;
        } while ( !done );
        return;
        do
          wdt_reset();
          delay(200);
        byte expanderRead()
          byte _data=0;
          delay(10);
          return _data;
        int x,y;
        x = 15;
        y = 2;
          if ( a>2 ) x = 75;
          if ( a==3 ) y = 2;
          y += 10;
        // I/O Expansion
        byte bkcolor;
        x = 14;
        y = 34;
        // Salinity
        // Relay Expansion
180G FOWLR
20GH QT#1
29G QT#2
Return to My PDE/INO file
Users browsing this forum: Bing [Bot] and 1 guest
