89delta's work-in-progress
Posted: Fri Jul 04, 2014 12:16 am
Working great.....weather simulation and moonphases on standard PWM Channels. Will keep this updated with the latest screen and sketch.
My 29BioCube
#include <SunLocation.h>
#define NUMBERS_8x16
SunLocation sl;
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
////// Memory Locations used by all formulas
#define Mem_B_AcclDay 100
// Note - 100 represents the hard coded Memory location used for this variable
// not the value for the variable.
// This variable represents the current day in Acclimation Cycle. Set this value to the same
// number of days as your AcclDuration to begin the acclimation cycle or set it to 0 to use
// your normal dimming end% values.
#define Mem_B_AcclDuration 101 // Set this value to how many days you want your acclimation cycle to take.
#define Mem_B_SlopeStart 102 // Set this to your desired starting acclimation end%.
/////// Memory Locations used by Blue Formula
#define Mem_B_AcclStartEndBlue 105 // Acclimation starting Slope end%
#define Mem_B_SlopeEndBlue 106 // slope End%
////// Memory Locations used by White Formula
#define Mem_B_AcclStartEndWhite 110 // Acclimation starting Slope end%
#define Mem_B_SlopeEndWhite 111 // Slope End%
void DrawCustomMain() { //5,14
char buf[16];
byte acclDay = InternalMemory.read(Mem_B_AcclDay);
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, COLOR_WHITE, 6, 4, " Martin's BC29");
// Temp and PH
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,10,14,"Temp:");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,85, 14, "PH:");
ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, 48, 16, buf);
ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawLargeText(T1TempColor, DefaultBGColor, 10, 22, buf, Num8x16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 85, 22, buf, Num8x16);
ConvertNumToString(buf, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, 48, 25, buf);
//ATO
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,40,"High",Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,40,"Low",Font8x16);
ReefAngel.LCD.FillCircle(55,43,5,COLOR_GREEN);
} else {
ReefAngel.LCD.FillCircle(55,43,5,COLOR_RED);
ReefAngel.LCD.FillCircle(70,43,5,COLOR_GREEN);
} else {
ReefAngel.LCD.FillCircle(70,43,5,COLOR_RED);
//Sunrise/Sunset Times
ReefAngel.LCD.DrawText(0,255,5,52,"Rise:");
ReefAngel.LCD.DrawText(0,255,38,52,(sl.GetRiseHour()));
ReefAngel.LCD.DrawText(0,255,43,52,":");
ReefAngel.LCD.DrawText(0,255,48,52,(sl.GetRiseMinute()));
ReefAngel.LCD.DrawText(0,255,65,52,"Set:");
ReefAngel.LCD.DrawText(0,255,88,52,(sl.GetSetHour()));
ReefAngel.LCD.DrawText(0,255,100,52,":");
ReefAngel.LCD.DrawText(0,255,105,52,(sl.GetSetMinute()));
//Cloud Start and Lightning Start
//ReefAngel.LCD.DrawText(0,255,5,62,"C");
//ReefAngel.LCD.DrawText(0,255,11,62,"00:00");
//ReefAngel.LCD.DrawText(0,255,45,62,"L");
//ReefAngel.LCD.DrawText(0,255,51,62,"00:00");
//Moon Phase
ReefAngel.LCD.DrawText(0,255,5,72,"Moon:");
ReefAngel.LCD.DrawText(0,255,35,72,MoonPhaseLabel());
// Display Acclimation timer
ReefAngel.LCD.DrawText(0,255,5,82,"Acclimation Day:");
ReefAngel.LCD.DrawText(0,255,105,82,acclDay);
// Display LED %
ReefAngel.LCD.DrawText(0,255,12,92, "CW:");
ReefAngel.LCD.DrawText(197,255,32,92, ReefAngel.PWM.GetDaylightValue());
ReefAngel.LCD.DrawText(0,255,72,92, "RB:");
ReefAngel.LCD.DrawText(3,255,92,92, ReefAngel.PWM.GetActinicValue());
// Display Relays
ReefAngel.LCD.DrawOutletBox(12, 102, TempRelay);
//ReefAngel.Use2014Screen(); // Let's use 2014 Screen
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
sl.Init(-21.285833, 150.999722); // In decimal numbers (i.e. -18.285833, 147.699722)
sl.SetOffset(11,0,11,0); // rise_hour, rise_seconds, set_hour, set_seconds
randomSeed(now()/SECS_PER_DAY);
//if (InternalMemory.read(Mem_B_ResetMemory))
//init_memory();
ReefAngel.DosingPumpRepeat1( Port4 );
ReefAngel.DosingPumpRepeat2( Port5 );
ReefAngel.StandardATO( Port6 );
////////// Variables used for all channels
// What day in the acclimation cycle it is
byte acclDuration = InternalMemory.read(Mem_B_AcclDuration);
// Acclimation Duration in days
byte startPercent = InternalMemory.read(Mem_B_SlopeStart);
// Normal start% being used by all 3 channels
////////// Blue Channel Variables
byte acclStartEndBlue = InternalMemory.read(Mem_B_AcclStartEndBlue);
// Starting End% for Acclimation cycle
float acclendPercentBlue = InternalMemory.read(Mem_B_SlopeEndBlue);
// Your target Blue end% once acclimation is complete
////////// Blue Channel Formula
float acclPercentPerDayBlue = (acclendPercentBlue - acclStartEndBlue) / acclDuration;
// How much your Blue end% rises per acclimation day
float acclFactorBlue = acclDay * acclPercentPerDayBlue;
// endPercentBlue will be offset by this much. If acclDay = 0 then this value will be 0
byte endPercentBlue = acclendPercentBlue - acclFactorBlue;
// Your final Blue end% for the day
////////// White Channel Variables
byte acclStartEndWhite = InternalMemory.read(Mem_B_AcclStartEndWhite);
float acclEndPercentWhite = InternalMemory.read(Mem_B_SlopeEndWhite);
// Your target White end% once acclimation is complete
////////// White Channel Formula
float acclPercentPerDayWhite= (acclEndPercentWhite - acclStartEndWhite) / acclDuration;
// How much your White end% rises per acclimation day
float acclFactorWhite = acclDay * acclPercentPerDayWhite;
// endPercentWhite will be offset by this much. If acclDay = 0 then this value will be 0
byte endPercentWhite = acclEndPercentWhite - acclFactorWhite;
// At the end of the day, we need to decrement the acclimation counter.
static boolean acclCounterReady=false; // We need a boolean so we only do this once per day
if (now()%SECS_PER_DAY!=0) acclCounterReady=true; // If it's not midnight we'll get the boolean ready
if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) { // It's midnight, our bool is true and acclDay is more than 0
acclDay--; // Reduce the counter
acclCounterReady=false; // Reset the boolean flag
InternalMemory.write(Mem_B_AcclDay,acclDay); // Update memory
// handle updating sunrise and sunset values
sl.CheckAndUpdate();
//sl.SetOffset(10,0,10,0); // rise_hour, rise_seconds, set_hour, set_seconds
ReefAngel.Portal( "89delta" );
ActinicPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),startPercent,endPercentBlue,120,(MoonPhase()/3));
DaylightPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),startPercent,endPercentWhite,120,DaylightPWMValue);
//ActinicPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),0,90,120,(MoonPhase()/3));
//DaylightPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),0,90,120,DaylightPWMValue);
CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 6
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 10
#define Start_Cloud_After NumMins(8,30)
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.Clear(255,0,62,132,132);
int x=0;
ReefAngel.LCD.DrawText(0,255,x,62,(cloudstart/60));
ReefAngel.LCD.DrawText(0,255,x,62,(cloudstart%60));
ReefAngel.LCD.DrawText(0,255,90,62,cloudduration);
if (lightningchance)
int x=0;
ReefAngel.LCD.DrawText(0,255,x,62,((cloudstart+(cloudduration/2))/60));
ReefAngel.LCD.DrawText(0,255,x,62,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
