clouds and lightning
Posted: Sat Dec 03, 2011 8:18 am
Hello, I have this in my controller PDE but I dont see the effects of clouds or lightning.
Is there something wrong?. I do not see why clouds or lightning?
please I need you if you look you see faulty.
// Autogenerated file by RAGen (v1.1.0.126), (12/03/2011 12:18)
// RA_120311_1218.pde
#define DisplayImages
#define DosingPumpSetup
#define DateTimeSetup
#define ATOSetup
#define MetalHalideSetup
#define SingleATOSetup
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
//Cloud & Lightning effects
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
byte ATOPWMValue=0;
ReefAngel.PHMin=217;
ReefAngel.PHMax=885;
ReefAngel.SetTemperatureUnit(1); // set to Celsius Temperature
ReefAngel.FeedingModePorts = B00111000;
ReefAngel.WaterChangePorts = B00111000;
ReefAngel.OverheatShutoffPorts = B00000000;
ReefAngel.LightsOnPorts = B00000000;
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
byte ATOPWMValue=0;
// Specific functions
ReefAngel.SingleATOHigh(Port1);
ReefAngel.MHLights(Port3);
ReefAngel.DosingPump1(Port7);
ReefAngel.DosingPump2(Port8);
// Cloud & Lightning effects - Calculate your regular sunrise/sunset PWM value
// byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
ActinicPWMValue=PWMSlope(12,45,21,45,0,100,100,ActinicPWMValue); //Actinic turn on at 7am, off at 7pm, and ramp up 0% to 50% PWM in 60 minutes
DaylightPWMValue=PWMSlope(12,05,21,45,0,100,100,DaylightPWMValue); //Daylight turn on at 9am, off at 5pm, and ramp up 0% to 50% PWM in 60 minutes
ATOPWMValue=PWMSlope(12,00,16,55,0,100,5,ATOPWMValue);
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,ATOPWMValue);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(14,30)
// In this example, end could before 4:30pm
#define End_Cloud_Before NumMins(20,30)
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen result could happen.
#define forcecloudcalculation
// Uncomment this to force the cloud calculation to happen in the boot process.
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
else x=17;
else x=35;
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
else x=57;
if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
//End Cloud & Lighting
