Temp 0.0 and timeout on first line of code
PostPosted: Sat Aug 23, 2014 5:38 am
Does anything look wrong here? I used this code for 2 days with no problems. I woke up today and temp says 0.0 so I tried to reload the code, but it times out on the first orange line of code uploading.
// Define Relay Ports by Name
#define Return_Pump 1
#define Skimmer 2
#define Kessil 3
#define Nick_WP10 4
#define unused 5
#define Steph_ATO 6
#define Refugium 7
#define Steph_WP10 8
//ReefAngel.CustomLabels[0]="ReturnPump";
//ReefAngel.CustomLabels[1]="Skimmer";
//ReefAngel.CustomLabels[2]="Kessil";
//ReefAngel.CustomLabels[3]="Nick WP10";
//ReefAngel.CustomLabels[4]="None";
//ReefAngel.CustomLabels[5]="Steph ATO";
//ReefAngel.CustomLabels[6]="Refugium";
//ReefAngel.CustomLabels[7]="Steph WP10";
#define NUMBERS_8x16
ReefAngel.LCD.DrawText(COLOR_ORANGERED, COLOR_DEEPSKYBLUE,14,8, "Fortney Money Pit");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
ReefAngel.FeedingModePorts = Port2Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port3Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit | Port8Bit | Port7Bit;
ReefAngel.Relay.On( Return_Pump );
ReefAngel.Relay.On( Nick_WP10 );
ReefAngel.Relay.On( Steph_WP10 );
ReefAngel.Relay.DelayedOn( Skimmer,60 );
ReefAngel.MHLights( Kessil,8,00,20,00,1 );
ReefAngel.Relay.Set( Refugium, !ReefAngel.Relay.Status( Kessil ) );
ReefAngel.StandardATO(6, 40);
if (hour()>=8 && hour()<20)
ReefAngel.PWM.SetDaylight( ElseMode(70,30,true) ); // Else Mode at 70% +/- 30% on sync mode
else if (hour()>=20 && hour()<23)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(40,80,200,true) ); // Nutrient Transport 40%minspeed - 80%maxspeed - 200ms
else if (hour()>=23 || hour()<8)
ReefAngel.PWM.SetDaylight( ElseMode(45,15,true) ); // Else Mode at 45% +/- 15% on sync mode
if (hour()>=11 && hour()<22)
ReefAngel.PWM.SetActinic( ElseMode(70,30,false) ); // Else Mode at 70% +/- 30% on anti-sync mode
else if (hour()>=22 || hour()<1)
ReefAngel.PWM.SetActinic( NutrientTransportMode(40,80,200,false) ); // Nutrient Transport 40%minspeed - 80%maxspeed - 200ms
else if (hour()>=1 && hour()<11)
ReefAngel.PWM.SetActinic( ElseMode(45,15,false) ); // Else Mode at 45% +/- 15% on anti-sync mode
ReefAngel.Portal( "imFortney" );
void DrawParamsa(int x, int y){
char buf[16];
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+40,y+10,"Steph:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+78, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+40,y+20,"Nick:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+78, y+20,1);
char buf[16];
ReefAngel.LCD.DrawText(COLOR_INDIGO,DefaultBGColor,x+5,y,"Temp:");
ReefAngel.LCD.DrawText(COLOR_INDIGO,DefaultBGColor,x+80, y, "PH:");
// Temp and PH
y+=10;
y+=5;
int t=x;
ReefAngel.LCD.DrawLargeText(COLOR_ORANGERED,DefaultBGColor,85,y,"Low",Font8x16);
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_INDIGO);
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_ORANGERED);
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_ORANGERED);
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_INDIGO);
if (WaveSync)
return NewSpeed;
return AntiSpeed;
Thanks guys
PostPosted: Sun Aug 24, 2014 3:15 am
Bad temp sensor? Try unplugging the temp sensor and see if it uploads.
PostPosted: Sun Aug 24, 2014 6:35 pm
unplugging the temp sensor was my first try. now i have unplugged everything and it is being powered by the usb cable. i got the error message that it set.
Watchdog Timer
Version Menu
Dimming Signal
Date/Time Setup Menu
Standard Menu
Binary sketch size: 41,188 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM4 -b115200 -D -V -Uflash:w:C:\Users\Owner\AppData\Local\Temp\build2718938394513701128.tmp\RA_Preloaded.cpp.hex:i
avrdude: Version 6.0, compiled on Apr  6 2012 at 19:29:19
         Copyright (c) 2000-2005 Brian Dean,
         Using Port                    : \\.\COM4
         Using Programmer              : stk500v2
         Overriding Baud Rate          : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude done.  Thank you.
now i am going to leave it unplugged overnight i guess. and try reprogramming in the am. Any suggestions?
thanks
PostPosted: Sun Aug 24, 2014 6:46 pm
Are you sure that the COM4 port is the one?
PostPosted: Sun Aug 24, 2014 6:56 pm
yes, com3 says cannot communicate with device. com4 reboots the unit tries to start uploading code and fails.
PostPosted: Sun Aug 24, 2014 7:02 pm
i was excited for a second it started to go...
Watchdog Timer
Version Menu
Dimming Signal
Standard Menu
avrdude: Recv: . [1b]
avrdude: Recv: . [01]
avrdude: Recv: . [00]
avrdude: Recv: . [0b]
avrdude: Recv: . [0e]
avrdude: Recv: . [08]
avrdude: Recv: A [41]
avrdude: Recv: V [56]
avrdude: Recv: R [52]
avrdude: Recv: I [49]
avrdude: Recv: S [53]
avrdude: Recv: P [50]
avrdude: Recv: _ [5f]
avrdude: Recv: 2 [32]
avrdude: Recv: t [74]
avrdude: stk500v2_getsync(): found AVRISP programmer
         AVR Part                      : ATMEGA2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel STK500 Version 2.x firmware
         Programmer Model: AVRISP
avrdude: Send: . [1b] . [02] . [00] . [02] . [0e] . [03] . [90] . [86]
avrdude: Recv: . [02]
avrdude: Recv: . [03]
avrdude: Recv: . [0f]
avrdude: Recv: . [18]
avrdude: Send: . [1b] . [03] . [00] . [02] . [0e] . [03] . [91] . [86]
avrdude: Recv: . [14]
avrdude: Send: . [1b] . [04] . [00] . [02] . [0e] . [03] . [92] . [82]
avrdude: Recv: . [04]
avrdude: Recv: . [0a]
         Hardware Version: 15
         Firmware Version Master : 2.10
avrdude: Send: . [1b] . [05] . [00] . [02] . [0e] . [03] . [94] . [85]
avrdude: Recv: . [05]
avrdude: Recv: . [10]
         Vtarget         : 0.0 V
         SCK period      : 0.1 us
avrdude: Send: . [1b] . [06] . [00] . [0c] . [0e] . [10] . [c8] d [64] . [19]   [20] . [00] S [53] . [03] . [ac] S [53] . [00] . [00] 5 [35]
avrdude: Recv: . [06]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: . [1b] . [07] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] 0 [30] . [00] . [00] . [00] 7 [37]
avrdude: Recv: . [07]
avrdude: Recv: . [1d]
avrdude: Recv: 0 [30]
avrdude: Recv: . [1e]
avrdude: Recv: & [26]
avrdude: Send: . [1b] . [08] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] 0 [30] . [00] . [01] . [00] 9 [39]
avrdude: Recv: . [98]
avrdude: Recv: . [af]
################avrdude: Send: . [1b] . [09] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] 0 [30] . [00] . [02] . [00] ; [3b]
avrdude: Recv: . [09]
avrdude: Recv: 7 [37]
################################## | 100% 0.05s
avrdude: Device signature = 0x1e9801
avrdude: Send: . [1b] . [0a] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] . [a0] . [0f] . [fc] . [00] Y [59]
avrdude: Recv: . [a0]
avrdude: Recv: . [a5]
avrdude: Send: . [1b] . [0b] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] . [a0] . [0f] . [fd] . [00] Y [59]
avrdude: Recv: . [a4]
avrdude: Send: . [1b] . [0c] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] . [a0] . [0f] . [fe] . [00] ] [5d]
avrdude: Recv: . [0c]
avrdude: Recv: . [a3]
avrdude: Send: . [1b] . [0d] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] . [a0] . [0f] . [ff] . [00] ] [5d]
avrdude: Recv: . [0d]
avrdude: Recv: . [a2]
avrdude: reading input file "C:\Users\Owner\AppData\Local\Temp\build2718938394513701128.tmp\RA_Preloaded.cpp.hex"
avrdude: writing flash (41188 bytes):
Writing | avrdude: Send: . [1b] . [0e] . [00] . [05] . [0e] . [06] . [80] . [00] . [00] . [00] . [98]
avrdude: Recv: . [1f]
avrdude: Send: . [1b] . [0f] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] . [9d] . [c4] . [00] . [00] . [c8] . [c4] . [00] . [00] . [c6] . [c4] . [00] . [00] . [c4] . [c4] . [00] . [00] . [c2] . [c4] . [00] . [00] . [c0] . [c4] . [00] . [00] . [be] . [c4] . [00] . [00] . [bc] . [c4] . [00] . [00] . [ba] . [c4] . [00] . [00] . [0c] . [94] . [bc] + [2b] . [b6] . [c4] . [00] . [00] . [b4] . [c4] . [00] . [00] . [b2] . [c4] . [00] . [00] . [b0] . [c4] . [00] . [00] . [ae] . [c4] . [00] . [00] . [ac] . [c4] . [00] . [00] . [aa] . [c4] . [00] . [00] . [a8] . [c4] . [00] . [00] . [a6] . [c4] . [00] . [00] . [a4] . [c4] . [00] . [00] . [a2] . [c4] . [00] . [00] . [a0] . [c4] . [00] . [00] . [9e] . [c4] . [00] . [00] . [0c] . [94] . [c1] B [42] . [9a] . [c4] . [00] . [00] . [0c] . [94] . [03] F [46] . [0c] . [94] + [2b] G [47] . [94] . [c4] . [00] . [00] . [92] . [c4] . [00] . [00] . [90] . [c4] . [00] . [00] . [8e] . [c4] . [00] . [00] . [8c] . [c4] . [00] . [00] . [8a] . [c4] . [00] . [00] . [88] . [c4] . [00] . [00] . [86] . [c4] . [00] . [00] . [84] . [c4] . [00] . [00] . [0c] . [94] < [3c] F [46] . [0c] . [94] j [6a] G [47] ~ [7e] . [c4] . [00] . [00] . [0c] . [94] l [6c] . [13] z [7a] . [c4] . [00] . [00] x [78] . [c4] . [00] . [00] v [76] . [c4] . [00] . [00] t [74] . [c4] . [00] . [00] r [72] . [c4] . [00] . [00] p [70] . [c4] . [00] . [00] n [6e] . [c4] . [00] . [00] l [6c] . [c4] . [00] . [00] j [6a] . [c4] . [00] . [00] h [68] . [c4] . [00] . [00] f [66] . [c4] . [00] . [00] . [0c] . [94] u [75] F [46] . [0c] . [94] . [a9] G [47] ` [60] . [c4] . [00] . [00] . [0c] . [94] . [ae] F [46] . [0c] . [94] . [e8] G [47] Z [5a] . [c4] . [00] . [00] . [2e] . [0a] 7 [37] . [0a] A [41] . [0a] E [45] . [0b] E [45] . [0b] u [75] . [0f] r [72] . [0d] . [7f] . [0d] . [b1] . [0a] . [b1] . [0a] w [77] . [0e] . [7f] . [0e] . [8b] . [0e] u [75] . [0f] | [7c]
avrdude: Recv: . [13]
avrdude: Send: . [1b] . [10] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] . [a5] . [0e] . [aa] . [0e] . [f7] . [0c] . [af] . [0e] . [b4] . [0e] . [86] . [0e] f [66] . [0c] . [b9] . [0e] E [45] . [0b] . [be] . [0e] . [d3] . [0e] . [05] . [a8] L [4c] . [cd] . [b2] . [d4] N [4e] . [b9] 8 [38] 6 [36] . [a9] . [02] . [0c] P [50] . [b9] . [91] . [86] . [88] . [08] < [3c] . [a6] . [aa] . [aa] * [2a] . [be] . [00] . [00] . [00] . [80] ? [3f] G [47] E [45] T [54]   [20] / [2f] s [73] t [74] a [61] t [74] u [75] s [73] / [2f] s [73] u [75] b [62] m [6d] i [69] t [74] p [70] . [2e] a [61] s [73] p [70] x [78] ? [3f] t [74] 1 [31] = [3d] . [00] & [26] t [74] 2 [32] = [3d] . [00] & [26] t [74] 3 [33] = [3d] . [00] & [26] p [70] h [68] = [3d] . [00] & [26] i [69] d [64] = [3d] . [00] & [26] e [65] m [6d] = [3d] . [00] & [26] e [65] m [6d] 1 [31] = [3d] . [00] & [26] r [72] e [65] m [6d] = [3d] . [00] & [26] k [6b] e [65] y [79] = [3d] . [00] & [26] a [61] f [66] = [3d] . [00] & [26] s [73] f [66] = [3d] . [00] & [26] a [61] t [74] o [6f] h [68] i [69] g [67] h [68] = [3d] . [00] & [26] a [61] t [74] o [6f] l [6c] o [6f] w [77] = [3d] . [00] & [26] r [72] . [00] & [26] r [72] o [6f] n [6e] . [00] & [26] r [72] o [6f] f [66] f [66] . [00] & [26] p [70] w [77] m [6d] a [61] = [3d] . [00] & [26] p [70] w [77] m [6d] d [64] = [3d] . [00] & [26] p [70] w [77] m [6d] a [61] o [6f] = [3d] . [00] & [26] p [70] w [77] m [6d] d [64] o [6f] = [3d] . [00] { [7b] " [22] j [6a] s [73] o [6f] n [6e] " [22] : [3a] { [7b] . [00] I [49] D [44] . [00] T [54] 1 [31] . [00] T [54] 2 [32] . [00] T [54] 3 [33] . [00] P [50] H [48] . [00] R [52] . [00] R [52] O [4f] N [4e] . [00] R [52] O [4f] F [46] F [46] . [00] A [41] T [54] O [4f] L [4c] O [4f] W [57] . [00] A [41] T [54] O [4f] H [48] I [49] G [47] H [48] . [00] E [45] M [4d] . [00] E [45] M [4d] 1 [31] . [00] R [52] . [c0]
avrdude: Recv:
avrdude: Send: . [1b] . [10] . [00] . [01] . [0e] . [01] . [05]
avrdude: Recv:
avrdude: stk500v2_command(): failed miserably to execute command 0x13
avrdude: stk500v2_paged_write: write command failed
avrdude: Send: . [1b] . [10] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] @ [40] . [00] . [00] . [9d] . [cd]
avrdude: Recv:
avrdude: Recv:
avrdude: stk500v2_command(): failed miserably to execute command 0x1d
avrdude: stk500v2_cmd(): failed to send command
avrdude: Send: . [1b] . [10] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] H [48] . [00] . [00] . [c4] . [9c]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [10] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] @ [40] . [00] . [01] . [00] Q [51]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [10] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] H [48] . [00] . [01] . [00] Y [59]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [10] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] @ [40] . [00] . [02] . [c8] . [9a]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [10] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] H [48] . [00] . [02] . [c4] . [9e]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [10] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] @ [40] . [00] . [03] . [00] S [53]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [10] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] H [48] . [00] . [03] . [00] [ [5b]
PostPosted: Sun Aug 24, 2014 7:14 pm
its still trying and timing out. should i disconect?
PostPosted: Sun Aug 24, 2014 7:36 pm
Does it fail like that if you try to upload another code?
Try something simple like the Template code in the Example Codes.
PostPosted: Sun Aug 24, 2014 7:42 pm
yes i tried the template...
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 34,110 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM4 -b115200 -D -V -Uflash:w:C:\Users\Owner\AppData\Local\Temp\build2718938394513701128.tmp\Template.cpp.hex:i
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Vtarget         : 0.0 V
         SCK period      : 0.1 us
avrdude: reading input file "C:\Users\Owner\AppData\Local\Temp\build2718938394513701128.tmp\Template.cpp.hex"
avrdude: writing flash (34110 bytes):
avrdude: Send: . [1b] . [0f] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] - [2d] . [c4] . [00] . [00] X [58] . [c4] . [00] . [00] V [56] . [c4] . [00] . [00] T [54] . [c4] . [00] . [00] R [52] . [c4] . [00] . [00] P [50] . [c4] . [00] . [00] N [4e] . [c4] . [00] . [00] L [4c] . [c4] . [00] . [00] J [4a] . [c4] . [00] . [00] . [0c] . [94] . [93] ' [27] F [46] . [c4] . [00] . [00] D [44] . [c4] . [00] . [00] B [42] . [c4] . [00] . [00] @ [40] . [c4] . [00] . [00] > [3e] . [c4] . [00] . [00] < [3c] . [c4] . [00] . [00] : [3a] . [c4] . [00] . [00] 8 [38] . [c4] . [00] . [00] 6 [36] . [c4] . [00] . [00] 4 [34] . [c4] . [00] . [00] 2 [32] . [c4] . [00] . [00] 0 [30] . [c4] . [00] . [00] . [2e] . [c4] . [00] . [00] . [0c] . [94] . [d2] 5 [35] * [2a] . [c4] . [00] . [00] . [0c] . [94] . [14] 9 [39] . [0c] . [94] < [3c] : [3a] $ [24] . [c4] . [00] . [00] " [22] . [c4] . [00] . [00]   [20] . [c4] . [00] . [00] . [1e] . [c4] . [00] . [00] . [1c] . [c4] . [00] . [00] . [1a] . [c4] . [00] . [00] . [18] . [c4] . [00] . [00] . [16] . [c4] . [00] . [00] . [14] . [c4] . [00] . [00] . [0c] . [94] M [4d] 9 [39] . [0c] . [94] { [7b] : [3a] . [0e] . [c4] . [00] . [00] . [0c] . [94] . [91] . [11] . [0a] . [c4] . [00] . [00] . [08] . [c4] . [00] . [00] . [06] . [c4] . [00] . [00] . [04] . [c4] . [00] . [00] . [02] . [c4] . [00] . [00] . [00] . [c4] . [00] . [00] . [fe] . [c3] . [00] . [00] . [fc] . [c3] . [00] . [00] . [fa] . [c3] . [00] . [00] . [f8] . [c3] . [00] . [00] . [f6] . [c3] . [00] . [00] . [0c] . [94] . [86] 9 [39] . [0c] . [94] . [ba] : [3a] . [f0] . [c3] . [00] . [00] . [0c] . [94] . [bf] 9 [39] . [0c] . [94] . [f9] : [3a] . [ea] . [c3] . [00] . [00] S [53] . [08] \ [5c] . [08] f [66] . [08] j [6a] . [09] j [6a] . [09] . [9a] . [0d] . [97] . [0b] . [a4] . [0b] . [d6] . [08] . [d6] . [08] . [9c] . [0c] . [a4] . [0c] . [b0] . [0c] . [9a] . [0d] . [e7]
avrdude: Send: . [1b] . [10] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] . [ca] . [0c] . [cf] . [0c] . [1c] . [0b] . [d4] . [0c] . [d9] . [0c] . [ab] . [0c] . [8b] . [0a] . [de] . [0c] j [6a] . [09] . [e3] . [0c] . [f8] . [0c] G [47] E [45] T [54]   [20] / [2f] s [73] t [74] a [61] t [74] u [75] s [73] / [2f] s [73] u [75] b [62] m [6d] i [69] t [74] p [70] . [2e] a [61] s [73] p [70] x [78] ? [3f] t [74] 1 [31] = [3d] . [00] & [26] t [74] 2 [32] = [3d] . [00] & [26] t [74] 3 [33] = [3d] . [00] & [26] p [70] h [68] = [3d] . [00] & [26] i [69] d [64] = [3d] . [00] & [26] e [65] m [6d] = [3d] . [00] & [26] e [65] m [6d] 1 [31] = [3d] . [00] & [26] r [72] e [65] m [6d] = [3d] . [00] & [26] k [6b] e [65] y [79] = [3d] . [00] & [26] a [61] f [66] = [3d] . [00] & [26] s [73] f [66] = [3d] . [00] & [26] a [61] t [74] o [6f] h [68] i [69] g [67] h [68] = [3d] . [00] & [26] a [61] t [74] o [6f] l [6c] o [6f] w [77] = [3d] . [00] & [26] r [72] . [00] & [26] r [72] o [6f] n [6e] . [00] & [26] r [72] o [6f] f [66] f [66] . [00] & [26] p [70] w [77] m [6d] a [61] = [3d] . [00] & [26] p [70] w [77] m [6d] d [64] = [3d] . [00] & [26] p [70] w [77] m [6d] a [61] o [6f] = [3d] . [00] & [26] p [70] w [77] m [6d] d [64] o [6f] = [3d] . [00] { [7b] " [22] j [6a] s [73] o [6f] n [6e] " [22] : [3a] { [7b] . [00] I [49] D [44] . [00] T [54] 1 [31] . [00] T [54] 2 [32] . [00] T [54] 3 [33] . [00] P [50] H [48] . [00] R [52] . [00] R [52] O [4f] N [4e] . [00] R [52] O [4f] F [46] F [46] . [00] A [41] T [54] O [4f] L [4c] O [4f] W [57] . [00] A [41] T [54] O [4f] H [48] I [49] G [47] H [48] . [00] E [45] M [4d] . [00] E [45] M [4d] 1 [31] . [00] R [52] E [45] M [4d] . [00] A [41] F [46] . [00] S [53] F [46] . [00] P [50] W [57] M [4d] A [41] . [00] P [50] W [57] M [4d] D [44] . [00] } [7d] } [7d] . [00] < [3c] R [52] A [41] > [3e] < [3c] I [49] D [44] > [3e] . [10]
avrdude: Send: . [1b] . [11] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] . [00] < [3c] / [2f] I [49] D [44] > [3e] < [3c] T [54] 1 [31] > [3e] . [00] < [3c] / [2f] T [54] 1 [31] > [3e] < [3c] T [54] 2 [32] > [3e] . [00] < [3c] / [2f] T [54] 2 [32] > [3e] < [3c] T [54] 3 [33] > [3e] . [00] < [3c] / [2f] T [54] 3 [33] > [3e] < [3c] P [50] H [48] > [3e] . [00] < [3c] / [2f] P [50] H [48] > [3e] < [3c] R [52] > [3e] . [00] < [3c] / [2f] R [52] > [3e] < [3c] R [52] O [4f] N [4e] > [3e] . [00] < [3c] / [2f] R [52] O [4f] N [4e] > [3e] < [3c] R [52] O [4f] F [46] F [46] > [3e] . [00] < [3c] / [2f] R [52] . [00] O [4f] F [46] F [46] . [00] > [3e] . [00] < [3c] A [41] T [54] O [4f] L [4c] O [4f] W [57] > [3e] . [00] < [3c] / [2f] A [41] T [54] O [4f] L [4c] O [4f] W [57] > [3e] < [3c] A [41] T [54] O [4f] H [48] I [49] G [47] H [48] > [3e] . [00] < [3c] / [2f] A [41] T [54] O [4f] H [48] I [49] G [47] H [48] > [3e] < [3c] E [45] M [4d] > [3e] . [00] < [3c] / [2f] E [45] M [4d] > [3e] < [3c] E [45] M [4d] 1 [31] > [3e] . [00] < [3c] / [2f] E [45] M [4d] 1 [31] > [3e] < [3c] R [52] E [45] M [4d] > [3e] . [00] < [3c] / [2f] R [52] E [45] M [4d] > [3e] < [3c] A [41] F [46] > [3e] . [00] < [3c] / [2f] A [41] F [46] > [3e] < [3c] S [53] F [46] > [3e] . [00] < [3c] / [2f] S [53] F [46] > [3e] . [00] < [3c] P [50] W [57] M [4d] A [41] > [3e] . [00] < [3c] / [2f] P [50] W [57] M [4d] A [41] > [3e] < [3c] P [50] W [57] M [4d] D [44] > [3e] . [00] < [3c] / [2f] P [50] W [57] M [4d] D [44] > [3e] < [3c] P [50] W [57] M [4d] A [41] O [4f] > [3e] . [00] < [3c] / [2f] P [50] W [57] M [4d] A [41] O [4f] > [3e] < [3c] P [50] W [57] M [4d] D [44] O [4f] > [3e] . [00] < [3c] / [2f] P [50] W [57] M [4d] D [44] O [4f] > [3e] . [00] < [3c] / [2f] R [52] A [41] > [3e] . [00] A [41] B [42] C [43] D [44] E [45] F [46] G [47] H [48] I [49] J [4a] K [4b] L [4c] M [4d] . [a5]
avrdude: Recv: . [11]
avrdude: Recv: . [15]
#avrdude: Send: . [1b] . [12] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] N [4e] O [4f] P [50] Q [51] R [52] S [53] T [54] U [55] V [56] W [57] X [58] Y [59] Z [5a] a [61] b [62] c [63] d [64] e [65] f [66] g [67] h [68] i [69] j [6a] k [6b] l [6c] m [6d] n [6e] o [6f] p [70] q [71] r [72] s [73] t [74] u [75] v [76] w [77] x [78] y [79] z [7a] 0 [30] 1 [31] 2 [32] 3 [33] 4 [34] 5 [35] 6 [36] 7 [37] 8 [38] 9 [39] + [2b] / [2f] . [00] H [48] T [54] T [54] P [50] / [2f] 1 [31] . [2e] 1 [31]   [20] 2 [32] 0 [30] 0 [30]   [20] O [4f] K [4b] . [0d] . [0a] S [53] e [65] r [72] v [76] e [65] r [72] : [3a]   [20] R [52] e [65] e [65] f [66] A [41] n [6e] g [67] e [65] l [6c] . [0d] . [0a] C [43] a [61] c [63] h [68] e [65] - [2d] C [43] o [6f] n [6e] t [74] r [72] o [6f] l [6c] : [3a]   [20] n [6e] o [6f] - [2d] s [73] t [74] o [6f] r [72] e [65] , [2c]   [20] n [6e] o [6f] - [2d] c [63] a [61] c [63] h [68] e [65] , [2c]   [20] m [6d] u [75] s [73] t [74] - [2d] r [72] e [65] v [76] a [61] l [6c] i [69] d [64] a [61] t [74] e [65] . [0d] . [0a] P [50] r [72] a [61] g [67] m [6d] a [61] : [3a]   [20] n [6e] o [6f] - [2d] c [63] a [61] c [63] h [68] e [65] . [0d] . [0a] C [43] o [6f] n [6e] n [6e] e [65] c [63] t [74] i [69] o [6f] n [6e] : [3a]   [20] c [63] l [6c] o [6f] s [73] e [65] . [0d] . [0a] C [43] o [6f] n [6e] t [74] e [65] n [6e] t [74] - [2d] T [54] y [79] p [70] e [65] : [3a]   [20] t [74] e [65] x [78] t [74] / [2f] . [00] . [0d] . [0a] C [43] o [6f] n [6e] t [74] e [65] n [6e] t [74] - [2d] L [4c] e [65] n [6e] g [67] t [74] h [68] : [3a]   [20] . [00] < [3c] h [68] 1 [31] > [3e] R [52] e [65] e [65] f [66]   [20] A [41] n [6e] g [67] e [65] l [6c]   [20] C [43] o [6f] n [6e] t [74] r [72] o [6f] l [6c] l [6c] e [65] r [72]   [20] W [57] e [65] b [62]   [20] S [53] e [65] r [72] v [76] e [65] r [72] < [3c] / [2f] h [68] 1 [31] . [e7]
avrdude: Recv: . [12]
avrdude: Recv: . [16]
avrdude: Send: . [1b] . [13] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] > [3e] . [00] < [3c] ! [21] D [44] O [4f] C [43] T [54] Y [59] P [50] E [45]   [20] h [68] t [74] m [6d] l [6c] > [3e] < [3c] s [73] c [63] r [72] i [69] p [70] t [74]   [20] s [73] r [72] c [63] = [3d] ' [27] h [68] t [74] t [74] p [70] : [3a] / [2f] / [2f] w [77] w [77] w [77] . [2e] r [72] e [65] e [65] f [66] a [61] n [6e] g [67] e [65] l [6c] . [2e] c [63] o [6f] m [6d] / [2f] w [77] i [69] f [66] i [69] / [2f] r [72] a [61] 2 [32] . [2e] j [6a] s [73] ' [27] > [3e] < [3c] / [2f] s [73] c [63] r [72] i [69] p [70] t [74] > [3e] . [00] < [3c] M [4d] . [00] O [4f] K [4b] . [00] < [3c] / [2f] M [4d] . [00] E [45] R [52] R [52] . [00] < [3c] P [50] . [00] < [3c] / [2f] P [50] . [00] < [3c] M [4d] E [45] M [4d] > [3e] . [00] < [3c] / [2f] M [4d] E [45] M [4d] > [3e] . [00] < [3c] D [44] > [3e] . [00] < [3c] / [2f] D [44] > [3e] . [00] < [3c] M [4d] O [4f] D [44] E [45] > [3e] . [00] < [3c] / [2f] M [4d] O [4f] D [44] E [45] > [3e] . [00] . [00] . [00] . [00] . [00] . [00] . [00] . [06] _ [5f] . [06] . [00] . [07] . [03] . [00] . [07] . [03] $ [24] ~ [7e] $ [24] ~ [7e] $ [24] $ [24] + [2b] j [6a] . [12] . [00] c [63] . [13] . [08] d [64] c [63] 6 [36] I [49] V [56]   [20] P [50] . [00] . [07] . [03] . [00] . [00] . [00] > [3e] A [41] . [00] . [00] . [00] A [41] > [3e] . [00] . [00] . [08] > [3e] . [1c] > [3e] . [08] . [08] . [08] > [3e] . [08] . [08] . [00] . [e0] ` [60] . [00] . [00] . [08] . [08] . [08] . [08] . [08] . [00] ` [60] ` [60] . [00] . [00]   [20] . [10] . [08] . [04] . [02] > [3e] Q [51] I [49] E [45] > [3e] . [00] B [42] . [7f] @ [40] . [00] b [62] Q [51] I [49] I [49] F [46] " [22] I [49] I [49] I [49] 6 [36] . [18] . [14] . [12] . [7f] . [10] / [2f] I [49] I [49] I [49] 1 [31] < [3c] J [4a] I [49] I [49] 0 [30] . [01] q [71] . [09] . [05] . [03] ] [5d]
avrdude: Recv: . [17]
avrdude: Send: . [1b] . [14] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] 6 [36] I [49] I [49] I [49] 6 [36] . [06] I [49] I [49] ) [29] . [1e] . [00] l [6c] l [6c] . [00] . [00] . [00] . [ec] l [6c] . [00] . [00] . [08] . [14] " [22] A [41] . [00] $ [24] $ [24] $ [24] $ [24] $ [24] . [00] A [41] " [22] . [14] . [08] . [02] . [01] Y [59] . [09] . [06] > [3e] A [41] ] [5d] U [55] . [1e] ~ [7e] . [09] . [09] . [09] ~ [7e] . [7f] I [49] I [49] I [49] 6 [36] > [3e] A [41] A [41] A [41] " [22] . [7f] A [41] A [41] A [41] > [3e] . [7f] I [49] I [49] I [49] A [41] . [7f] . [09] . [09] . [09] . [01] > [3e] A [41] I [49] I [49] z [7a] . [7f] . [08] . [08] . [08] . [7f] . [00] A [41] . [7f] A [41] . [00] 0 [30] @ [40] @ [40] @ [40] ? [3f] . [7f] . [08] . [14] " [22] A [41] . [7f] @ [40] @ [40] @ [40] @ [40] . [7f] . [02] . [04] . [02] . [7f] . [7f] . [02] . [04] . [08] . [7f] > [3e] A [41] A [41] A [41] > [3e] . [7f] . [09] . [09] . [09] . [06] > [3e] A [41] Q [51] ! [21] ^ [5e] . [7f] . [09] . [09] . [19] f [66] & [26] I [49] I [49] I [49] 2 [32] . [01] . [01] . [7f] . [01] . [01] ? [3f] @ [40] @ [40] @ [40] ? [3f] . [1f]   [20] @ [40]   [20] . [1f] ? [3f] @ [40] < [3c] @ [40] ? [3f] c [63] . [14] . [08] . [14] c [63] . [07] . [08] p [70] . [08] . [07] q [71] I [49] E [45] C [43] . [00] . [00] . [7f] A [41] A [41] . [00] . [02] . [04] . [08] . [10]   [20] . [00] A [41] A [41] . [7f] . [00] . [04] . [02] . [01] . [02] . [04] . [80] . [80] . [80] . [80] . [80]   [20] @ [40] . [80] @ [40]   [20]   [20] T [54] T [54] T [54] x [78] . [7f] D [44] D [44] D [44] 8 [38] 8 [38] D [44] D [44] D [44] ( [28] 8 [38] D [44] D [44] D [44] . [7f] 8 [38] T [54] T [54] T [54] . [18] . [08] ~ [7e] . [09] . [09] . [00] . [18] . [a4] . [a4] . [a4] | [7c] . [7f] . [04] . [04] x [78] . [00] . [00] . [00] } [7d] . [00] . [00] @ [40] . [80] . [84] } [7d] . [00] . [7f] . [a2]
#avrdude: Send: . [1b] . [15] . [01] . [0a] . [0e] . [13] . [01] . [00] . [c1] . [0a] @ [40] L [4c]   [20] . [00] . [00] . [10] ( [28] D [44] . [00] . [00] . [00] . [7f] @ [40] . [00] | [7c] . [04] . [18] . [04] x [78] | [7c] . [04] . [04] x [78] . [00] 8 [38] D [44] D [44] D [44] 8 [38] . [fc] D [44] D [44] D [44] 8 [38] 8 [38] D [44] D [44] D [44] . [fc] D [44] x [78] D [44] . [04] . [08] . [08] T [54] T [54] T [54]   [20] . [04] > [3e] D [44] $ [24] . [00] < [3c] @ [40]   [20] | [7c] . [00] . [1c]   [20] @ [40]   [20] . [1c] < [3c] ` [60] 0 [30] ` [60] < [3c] l [6c] . [10] . [10] l [6c] . [00] . [9c] . [a0] ` [60] < [3c] . [00] d [64] T [54] T [54] L [4c] . [00] 3 [33] f [66] . [cc] f [66] 3 [33] . [00] . [00] . [7f] . [00] . [00] . [cc] f [66] 3 [33] f [66] . [cc] . [02] . [01] . [02] . [01] . [00] , [2c] . [02] . [01]   [20] . [0f] & [26] . [0f] ( [28] . [01] . [2e] E [45] . [00] S [53] . [00] . [10] . [03] $ [24] " [22] 0 [30] = [3d] 2 [32] . [0e] @ [40] . [80] B [42] . [00] . [83] C [43] . [00] . [83] 4 [34] . [8d] * [2a] E [45] + [2b] i [69] " [22] . [11] U [55] . [00] V [56] . [00] W [57] . [9f] Y [59] . [00] . [00] . [9f] . [00] Q [51] . [11] . [03] ) [29] . [13] ! [21] N [4e] o [6f]   [20] I [49] n [6e] t [74] e [65] r [72] n [6e] a [61] l [6c]   [20] M [4d] e [65] m [6d] o [6f] r [72] y [79] . [00] F [46] o [6f] u [75] n [6e] d [64] . [00] . [c7] . [06] . [cf] . [06] . [dc] . [06] . [e6] . [06] . [f5] . [06] . [04] . [07] . [10] . [07] . [18] . [07] . [1e] . [07] + [2b] . [07] F [46] e [65] e [65] d [64] i [69] n [6e] g [67] . [00] W [57] a [61] t [74] e [65] r [72]   [20] C [43] h [68] a [61] n [6e] g [67] e [65] . [00] A [41] T [54] O [4f]   [20] C [43] l [6c] e [65] a [61] r [72] . [00] O [4f] v [76] e [65] r [72] h [68] e [65] a [61] t [74]   [20] C [43] l [6c] e [65] a [61] r [72] . [00] P [50] H [48]   [20] C [43] a [61] l [6c] i [69] b [62] r [72] a [61] t [74] . [ed]
avrdude: Recv:
avrdude: Send: . [1b] . [15] . [00] . [01] . [0e] . [01] . [00]
avrdude: Recv:
avrdude: Send: . [1b] . [15] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] @ [40] . [00] . [00] - [2d] x [78]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [15] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] H [48] . [00] . [00] . [c4] . [99]
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [15] . [00] . [08] . [0e] . [1d] . [04] . [04] . [00] @ [40] . [00] . [01] . [00] T [54]
avrdude: Recv:
PostPosted: Sun Aug 24, 2014 7:58 pm
i tried the new cable that i bought from RA and the old cable. with the new cable i got this message:
Watchdog Timer
Version Menu
Simple Menu
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM5 -b115200 -D -V -Uflash:w:C:\Users\Owner\AppData\Local\Temp\build7422261211813710313.tmp\Template.cpp.hex:i
         Using Port                    : \\.\COM5
avrdude: Recv:
Next
Return to My PDE/INO file
