hedrickms code
PostPosted: Fri Sep 19, 2014 3:35 am
Sweet! Very nice.
PostPosted: Fri Sep 19, 2014 8:13 am
yeah, what lee said....looks good. nice work. :)
PostPosted: Fri Sep 19, 2014 8:26 am
I like this! This should be a library, no ?
PostPosted: Sat Sep 20, 2014 7:33 am
Does anyone know why the random(7) function would always select #5 when the controller reboots? I am not sure if it is always doing this yet (cause I rebooted everyday) but my pumps are not switching modes during the day.
Ideas?
code below:
void JebaoMode()
     static boolean feedingalert = false;
     static boolean pumpstormalert = false;
    static unsigned long isfeeding;
    static int ranMode = random (9);
     static WiFiAlert pumpAlert;
    if (ReefAngel.DCPump.Mode == Custom)
          isfeeding = now();
          feedingalert = false; //reset feeding flag so alert can be sent if needed
       if (now()-isfeeding<5400) // Continue for the 90 minutes
         if (!feedingalert)
            pumpAlert.Send("Pump+Mode+NTM+Feeding!+Activated.");
           feedingalert = true;
           ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,70,140,true));
           ReefAngel.PWM.SetActinic( NutrientTransportMode(30,70,140,false));
       else if ((now()%SECS_PER_DAY >= 82800) || (now()%SECS_PER_DAY < 28800)) // night mode 11pm -> 8am
         if (now()%SECS_PER_DAY == 82800) pumpstormalert = false; //reset pump flag so alert can be sent if needed
         if (!pumpstormalert)
           pumpAlert.Send("Pump+Mode+Sine+NightMode!+Activated.");
           pumpstormalert = true;
         ReefAngel.PWM.SetDaylight(SineMode(30,50,20, true));
           ReefAngel.PWM.SetActinic(SineMode(30,50,20, false));
       }// end night mode 8am
       else   //  choose a random pump mode (ReefCrest, TidalSwell, ShortPulse, LongPulse, Else) between 0 and 8
        if (now()%SECS_PER_DAY == 28800)//at 8am set pump mode and determine if storm
          //set random pump mode at start of each day (midnight) and determine if storm will occur
          ranMode = random(30);
         if (ranMode!=29 || ranMode!=17) ranMode = random (9);//if not storm set normal random pump mode
        if (ranMode==29 || ranMode==17)//storm mode
              //enter storm mode for pumps (random)
              pumpAlert.Send("Pump+Mode+STORM!+Activated.");
              pumpstormalert = true; //reset pump flag so alert can be sent if needed
           StormMode();
              switch (ranMode)
            case 0:
               pumpAlert.Send("Pump+Mode+ShortPule+case0!+Activated.");
              ReefAngel.PWM.SetActinic( ShortPulseMode(0,60,400,true) );
              ReefAngel.PWM.SetDaylight( ShortPulseMode(0,60,400,false) );
              break;
             case 1:
               pumpAlert.Send("Pump+Mode+ReefCrest+case1!+Activated.");
              ReefAngel.PWM.SetDaylight( ReefCrestMode(50,20,true) );
              ReefAngel.PWM.SetActinic( ReefCrestMode(50,20,false) );
              break;
             case 2:
               pumpAlert.Send("Pump+Mode+TidalSwell+case2!+Activated.");
              ReefAngel.PWM.SetDaylight( TidalSwellMode(70,true) );
              ReefAngel.PWM.SetActinic( TidalSwellMode(70,false) );
              break;
             case 3:
               pumpAlert.Send("Pump+Mode+TidalSwell+case3!+Activated.");
              ReefAngel.PWM.SetDaylight( TidalSwellMode(50,true) );
              ReefAngel.PWM.SetActinic( TidalSwellMode(50,false) );
              break;
             case 4:
               pumpAlert.Send("Pump+Mode+TideMode+case4!+Activated.");
              ReefAngel.PWM.SetDaylight( TideMode(50,30,70) );
              ReefAngel.PWM.SetActinic( TideMode(50,30,70) );
              break;
             case 5:
               pumpAlert.Send("Pump+Mode+LongPulse+case5!+Activated.");
              ReefAngel.PWM.SetDaylight( LongPulseMode(20,60,10,true) );
              ReefAngel.PWM.SetActinic( LongPulseMode(20,60,10,false) );
              break;
             case 6:
               pumpAlert.Send("Pump+Mode+ElseMode+case6!+Activated.");
              ReefAngel.PWM.SetDaylight( ElseMode(50,30,true) );
              ReefAngel.PWM.SetActinic( ElseMode(50,30,false) );
              break;
             case 7:
               pumpAlert.Send("Pump+Mode+SineWave+case7!+Activated.");
              ReefAngel.PWM.SetDaylight(SineMode(40,70,20, true));
              ReefAngel.PWM.SetActinic(SineMode(40,70,20, false));
              break;
             case 8:
               pumpAlert.Send("Pump+Mode+ShortPule+case8!+Activated.");
              ReefAngel.PWM.SetActinic( ShortPulseMode(10,50,600,true) );
              ReefAngel.PWM.SetDaylight( ShortPulseMode(10,50,600,false) );
              break;
           }//end of random pump mode
       }//end else switch
       }//end else pump mode
    } //end of DCPump custom
} // End Void JebaoRandomMode()
PostPosted: Sat Sep 20, 2014 8:04 am
Because random() isn't seed'ed by default. So if you were troubleshooting something, you'd always have the same stream of random numbers. You will need to seed it with something that would also change, like the current time.
This is what I have:
randomSeed(now()/SECS_PER_DAY);
PostPosted: Sat Sep 20, 2014 9:16 am
Ahh... got it. Thanks a bunch. Do you seed under Setup ()?
PostPosted: Sat Sep 20, 2014 9:42 am
Yes. My INO is in my signature
PostPosted: Sat Sep 20, 2014 11:04 am
Awesome... Thanks again!
I should have checked there first (my apologies). Sometimes I get a little trigger happy :lol:
PostPosted: Sun Sep 21, 2014 12:55 pm
ok code updated on first post to include fixes to random mode (thanks Lee!). Everything seems to be working.
PostPosted: Sun Sep 21, 2014 1:17 pm
Awesome! Now comes the incessant tweaking and feature adding. :)
Return to My PDE/INO file
