TanksNStuff's 120G Upgrade Code
TanksNStuff
Re: TanksNStuff's 120G Upgrade Code
Post by TanksNStuff »
Gotcha Lee. I thought that Roberto was actually updating the firmware with the workaround found in the other post. If that's not the case, then no biggy. It will be nice to add the storm mode as another option to choose from though.
As to my bugs and your suggestion, I will do what you suggest and report back if it worked or not. I just got done dinner and went to feed the fish and even though it's not "Night Mode" the RF module light went out completely again when I ended Feeding Mode. Do I need to add a Feeding_Stop for that part too? I had to reboot my head unit to resolve the RF Module outage and luckily that's all it took to fix it. However, it wasn't in NTM, it reverted back to my default setting of Constant, 100%.
TanksNStuff
Feeding_Stop fixed the error with the RF module outage. I only added it once, right before the: ReefAngel.RF.UseMemory=true;
All seems to be working much better now. Thanks Lee!
Going to update my first post with the change(s).
