controlling Jebao from portal
PostPosted: Thu Nov 27, 2014 3:20 pm
I am trying to set up controlling my jebao wp25 from the portal and it is not working. I want to be able to change the pump setting from the portal during the day and then have it be steady sine mode during the night. when I upload this, I can't change anything during the day from the portal, when I try and change modes, else mode stays on.
Any ideas? Thanks and Happy Thanksgiving...
    ReefAngel.WaterChangePorts = Port5Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit;
    ReefAngel.CustomLabels[0]="Frag Pump";
    ReefAngel.CustomLabels[1]="Actinics";
    ReefAngel.CustomLabels[2]="Daylights";
    ReefAngel.CustomLabels[3]="Frag LED";
    ReefAngel.CustomLabels[4]="ATO Pump";
    ReefAngel.CustomLabels[5]="Reactor";
    ReefAngel.CustomLabels[6]="Heater";
    ReefAngel.CustomLabels[7]="Fan";
    ReefAngel.ActinicLights( Port2 );
    ReefAngel.DayLights( Port3 );
    ReefAngel.ActinicLights( Port4 );
    ReefAngel.SingleATOLow( Port5 );
    ReefAngel.StandardFan( Port8 );
       if (hour()>=8 && hour()<21)
             ReefAngel.PWM.SetDaylight(0);
        if (ReefAngel.DCPump.Mode==Custom)
         ReefAngel.PWM.SetActinic(ElseMode(65, 20, true));
         ReefAngel.PWM.SetActinic(SineMode(75,35, 15, true));
    ReefAngel.Portal( "psyrob" );
  static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
  static int Delay = random( 500, 1500);           // Set the initial delay
  static int NewSpeed = MidPoint;                  // Set the initial speed
  static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
  if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
    Delay=random(500,5000);                        // If so, come up with a new delay
    int ChangeUp = random(Offset);                 // Amount to go up or down
    if (random(100)<50)                            // 50/50 chance of speed going up or going down
    LastChange=millis();                           // Reset the time of the last change
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
PostPosted: Thu Nov 27, 2014 6:08 pm
OK, so you want Portal control from 8 AM to 8 PM, with "Custom" being Else mode, and then Sine after 8 PM?
PostPosted: Thu Nov 27, 2014 6:21 pm
Try this:
  ReefAngel.PWM.SetActinic(SineMode(75,35,15,true));    // This will run unless something changes it
  if (hour()>=8 && hour()<21)    //runs from 8 am to 2000 (8 PM)
    if (ReefAngel.DCPump.Mode == Custom)
      ReefAngel.PWM.SetActinic(ElseMode(65,20,true));
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
PostPosted: Fri Nov 28, 2014 3:42 pm
Thanks: I uploaded this new code, but still can't change the pump from the portal. I switch to long pulse, for example, and it stays in custom, running else mode...
PostPosted: Fri Nov 28, 2014 4:05 pm
correction:
when I upload the code, it is in sine mode. I go to the portal or my ipad app, and if I change it to custom (which is else), I can't change it back to anything else...
PostPosted: Fri Nov 28, 2014 4:23 pm
Huh.
Try this.
    else ReefAngel.DCPump.UseMemory = true;
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Edit: Made a minor fix.
PostPosted: Sun Nov 30, 2014 1:19 pm
Still cant control jebao pump from portal or ipad app. It stays on custom (else) no matter what I change it to...
I appreciate your help, tho...
PostPosted: Sun Nov 30, 2014 3:45 pm
psyrob wrote:Still cant control jebao pump from portal or ipad app. It stays on custom (else) no matter what I change it to...
OK, this works (kind of). We forgot to set the sync channel to Actinic for the DC pumps.
The main problem is that when we use ReefAngel.SetActinic to set our pumps, it doesn't reflect on the pump section of the portal. It would be much better if you were using the dev libraries which has Else built in and selectable from the Portal.
  if (InternalMemory.DCPumpMode_read()==11)   // Custom mode on Portal
      ReefAngel.PWM.SetActinic(ElseMode2(65,20,true));
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
PostPosted: Sun Nov 30, 2014 3:52 pm
With the new libraries it would be this:
  ReefAngel.DCPump.SetMode(Sine,75,35,15);    // This will run unless something changes it
      ReefAngel.DCPump.SetMode(Else,65,20);
PostPosted: Sun Nov 30, 2014 7:55 pm
Ok, didn't realize else mode had been added to the libraries. I can update the libraries and change my code like you have here. So is custom mode not needed in my coding to do what I want? I want it to run else all day unless I change from the portal...
And thanks again :)
Next
Return to My PDE/INO file
