controlling Jebao from portal
Posted: Thu Nov 27, 2014 3:20 pm
I am trying to set up controlling my jebao wp25 from the portal and it is not working. I want to be able to change the pump setting from the portal during the day and then have it be steady sine mode during the night. when I upload this, I can't change anything during the day from the portal, when I try and change modes, else mode stays on.
Any ideas? Thanks and Happy Thanksgiving...
ReefAngel.WaterChangePorts = Port5Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.CustomLabels[0]="Frag Pump";
ReefAngel.CustomLabels[1]="Actinics";
ReefAngel.CustomLabels[2]="Daylights";
ReefAngel.CustomLabels[3]="Frag LED";
ReefAngel.CustomLabels[4]="ATO Pump";
ReefAngel.CustomLabels[5]="Reactor";
ReefAngel.CustomLabels[6]="Heater";
ReefAngel.CustomLabels[7]="Fan";
ReefAngel.ActinicLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.ActinicLights( Port4 );
ReefAngel.SingleATOLow( Port5 );
ReefAngel.StandardFan( Port8 );
if (hour()>=8 && hour()<21)
ReefAngel.PWM.SetDaylight(0);
if (ReefAngel.DCPump.Mode==Custom)
ReefAngel.PWM.SetActinic(ElseMode(65, 20, true));
ReefAngel.PWM.SetActinic(SineMode(75,35, 15, true));
ReefAngel.Portal( "psyrob" );
static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
static int Delay = random( 500, 1500); // Set the initial delay
static int NewSpeed = MidPoint; // Set the initial speed
static int AntiSpeed = MidPoint; // Set the initial anti sync speed
if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
Delay=random(500,5000); // If so, come up with a new delay
int ChangeUp = random(Offset); // Amount to go up or down
if (random(100)<50) // 50/50 chance of speed going up or going down
LastChange=millis(); // Reset the time of the last change
if (WaveSync)
return NewSpeed;
return AntiSpeed;
