My PDE w/ Custom Main
StuGotz
Post by StuGotz »
Here's my 1st attempt at a custom main screen. There's definitely some tweaking I still have to do. The Cloud/Thunderstorm effects line was a real pain, so I'm procrastinating on fixing that. I probably shouldn't have started there! The EcoSmart line is a placeholder until I get my RF Module :D
And if anyone is interested in my current PDE...
// Autogenerated file by RAGen (v1.0.4.92), (10/15/2011 12:40)
// RA_101511_1240.pde
#define SIMPLE_MENU
#define DisplayLEDPWM
#define wifi
#define VersionMenu
#define CUSTOM_MAIN
#define NUMBERS_8x16
#define COLORS_PDE
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_Colors.h>
#define Sump                1
#define DosingPump2         2
#define Refugium            3
#define Daylight            4
#define Actinic             5
#define Skimmer             6
#define Heater              7
#define DosingPump1         8
//Cloud & Lightning effects
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
boolean ForceCloud=false;
  ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 0, "                       "); //Top Banner
  ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 2, " BioCube 14 Nano Reef  "); //Top Banner
  // Display Temp Text
  ReefAngel.LCD.DrawText(0,255,12,12,"Temp");
  // Display the T1 temp value 10,22
  char text[7];
  ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
  ReefAngel.LCD.Clear(255, 0, 22, 50, 36);
  ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 10, 22, text, Num8x16);
  // Display pH Text
  ReefAngel.LCD.DrawText(0,255,100,12,"pH");
  // Display pH Value
  ReefAngel.LCD.Clear(255, 90, 22, 98, 36);
  ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 90, 22, text, Num8x16);
  // Display Actinic Percentage Text
  ReefAngel.LCD.DrawText(0,255,8,40,"Actinic %");
  // Display the Actinic PWM channel value at 90,40
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),COLOR_CORNFLOWERBLUE, 90, 40, 1);
  // Display Daylight Percentage Text
  ReefAngel.LCD.DrawText(0,255,8,50,"Daylight %");
  // Display the Daylight PWM channel value at 90,50
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),COLOR_CORNFLOWERBLUE, 90, 50, 1);
  // Display T2 Temp Text
  ReefAngel.LCD.DrawText(0,255,8,60,"Canopy Temp");
  // Display the T2 temperature value at 90,60
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, COLOR_CORNFLOWERBLUE, 90, 60, 10);
  // Display T3 Temp Text
  ReefAngel.LCD.DrawText(0,255,8,70,"Ambient Temp");
  // Display the T3 temperature at 90,70
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, COLOR_CORNFLOWERBLUE, 90, 70, 10);
  // Display Vortech MP10ew Mode Text at 90, 80
  ReefAngel.LCD.DrawText(0,255,8,80,"EcoSmart Mode");
  // Display EcoSmart Mode Value
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,90,80,"Storm");
  //#if defined DisplayLEDPWM && ! defined RemoveAllLights
    //ReefAngel.LCD.DrawMonitor(11, 60, ReefAngel.Params,
    //ReefAngel.PWM.GetDaylightValue(), ReefAngel.PWM.GetActinicValue());
  //#else // defined DisplayLEDPWM && ! defined RemoveAllLights
    //ReefAngel.LCD.DrawMonitor(11, 60, ReefAngel.Params);
  //#endif // defined DisplayLEDPWM && ! defined RemoveAllLights
 // ReefAngel.LCD.DrawGraph(5,7);
  ReefAngel.FeedingModePorts = B00100001; //Ports 6 & 1 turn off
  ReefAngel.WaterChangePorts = B00100001; //Ports 6 & 1 turn off
  ReefAngel.OverheatShutoffPorts = B00011000; //Ports 4 & 5 turn off
  ReefAngel.LightsOnPorts = B00011000; //Ports 4 & 5 turn on
  ReefAngel.Relay.On(Port1);
  // Delay Skimmer port 5 minutes whenever turned on
  // From Curt - THANKS CURT!
  ReefAngel.Relay.DelayedOn(Port6, 5);
  //Heater
  ReefAngel.StandardHeater(Heater,775,780);  // Setup Heater to turn on at 77.5F and off at 78.0F
  //Lighting schedule
  ReefAngel.MHLights(Daylight,9,0,17,0,0);  //Daylight schedule 9:00am - 5:00pm with 0min cool down
  ReefAngel.StandardLights(Actinic,7,0,19,0);  //Actinic schedule 7:00am - 7:00pm
  ReefAngel.StandardLights(Refugium,19,0,7,0);  //Refugium schedule 7:00pm - 7:00am
  // Dosing pumps (OLD DOSING METHOD OF PUMP ONE ON THE HOUR, THEN PUMP2 5 MIN LATER - to use when tank is more mature
  //From Roberto - THANKS ROBERTO!
   /* if (ReefAngel.DisplayedMenu==255 && minute()==0 && second()<1)  //Alk Doser - Only works if Main screen is showing
      ReefAngel.Relay.On(DosingPump1);  //Turn Alk Doser on
      ReefAngel.Relay.Off(DosingPump1);  //Turn Alk Doser off
    if (ReefAngel.DisplayedMenu==255 && minute()==5 && second()<1)  //CA Doser - Only works if Main screen is showing
      ReefAngel.Relay.On(DosingPump2);  //Turn CA Doser on
      ReefAngel.Relay.Off(DosingPump2);  //Turn CA Doser off
  // Dosing pumps
  // From Roberto - THANKS ROBERTO!
  if (ReefAngel.DisplayedMenu==255 && hour()%2==0 && minute()==0 && second()<1) // 1 sec dosing on even hours
    ReefAngel.Relay.On(DosingPump1);  //Turn DosingPump1 Doser on
    ReefAngel.Relay.Off(DosingPump1);  //Turn DosingPump1 Doser off
  if (ReefAngel.DisplayedMenu==255 && hour()%2==1 && minute()==0 && second()<1) // 1 sec dosing on odd hours
    ReefAngel.Relay.On(DosingPump2);  //Turn DosingPump2 Doser on
    ReefAngel.Relay.Off(DosingPump2);  //Turn DosingPump2 Doser off
  // Cloud & Lightning effects - Calculate your regular sunrise/sunset PWM value
  // byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
  if (hour()>=19 || hour()<7)
      ReefAngel.PWM.SetActinic(MoonPhase());  //Moon phase schedule between 7:00pm - 7:00am
      ActinicPWMValue=PWMSlope(7,00,19,0,0,35,60,ActinicPWMValue); //Actinic turn on at 7am, off at 10am, and ramp up 0% to 50% PWM in 60 minutes
      //ActinicPWMValue=PWMSlope(16,00,19,0,0,50,60,ActinicPWMValue); //Actinic turn on at 4pm, off at 7pm, and ramp up 0% to 50% PWM in 60 minutes
  DaylightPWMValue=PWMSlope(9,00,17,0,0,75,60,DaylightPWMValue); //Daylight turn on at 9am, off at 5pm, and ramp up 0% to 50% PWM in 60 minutes
  CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 6
#define Start_Cloud_After NumMins(11,30)
  // In this example, end could before 4:30pm
#define End_Cloud_Before NumMins(16,30)
#define Lightning_Change_per_Cloud 25
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen result could happen.
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  //When cusotm menu Force cloud is selected
  if (ForceCloud)
    ForceCloud=false;
    cloudchance=1;
    cloudduration=10;
    lightningchance=1;
    cloudstart=NumMins(hour(),minute())+1;
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
    ReefAngel.LCD.Clear(255,0,113,132,121);
    ReefAngel.LCD.DrawText(0,255,12,113,"C");
    ReefAngel.LCD.DrawText(0,255,18,113,"00:00");
    ReefAngel.LCD.DrawText(0,255,52,113,"L");
    ReefAngel.LCD.DrawText(0,255,58,113,"00:00");
    ReefAngel.LCD.DrawText(0,255,93,113,"DUR");
      int x=0;
      if ((cloudstart/60)>=10) x=18;
      else x=24;
      ReefAngel.LCD.DrawText(0,255,x,113,(cloudstart/60));
      if ((cloudstart%60)>=10) x=36;
      else x=42;
      ReefAngel.LCD.DrawText(0,255,x,113,(cloudstart%60));
    ReefAngel.LCD.DrawText(0,255,114,113,cloudduration);
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=88;
      else x=94;
      ReefAngel.LCD.DrawText(0,255,x,113,((cloudstart+(cloudduration/2))/60));
      if (((cloudstart+(cloudduration/2))%60)>=10) x=109;
      else x=112;
      ReefAngel.LCD.DrawText(0,255,x,113,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
  //End Cloud & Lighting
I welcome any and all suggestions!
Re: My PDE w/ Custom Main
Nice :)
StuGotz
Post by StuGotz »
Thanks Roberto! It didn't look like the DrawDate Function supported font colors. Can I just use ConvertNumToString to convert the value to a string and use ReefAngel.LCD.DrawText to make it the color I want?
Yeah, you can.
Looks pretty sweet.
The DrawDate function does not support font colors, but there is a way to change the font with it. This way includes the ability to change a lot of the default colors.
http://forum.reefangel.com/viewtopic.ph ... olors#p653
Halfway down in the original post, there is an example about using the ReefAngel_CustomColors.h file. This file will allow you to alter the "default" colors to whatever you want without altering the libraries and preserving your changes through code (library) updates. The line you will want to focus on is this one:
#define DateTextColor       COLOR_RED  // color of the date on home screen
Then, when you alter that line, you will be able to use the DrawDate function and not have to "re-invent" the wheel to get a different color date & time.
Let me know if you have more questions about it.
StuGotz
Post by StuGotz »
Sweet, that did the trick. So when I update my libraries, ReefAngel_CustomColors.h will not be overwritten, like how the ReefAngel_Features.h is no longer overwritten?
StuGotz wrote:Sweet, that did the trick. So when I update my libraries, ReefAngel_CustomColors.h will not be overwritten, like how the ReefAngel_Features.h is no longer overwritten?
It "shouldn't" be overwritten. I do not know what the updater does when it updates the libraries. Roberto may have to update his utility to not overwrite that file too. I would suggest making a copy of it to be on the safe side at least.
I just updated the utility to check for this file too. :)
