And if anyone is interested in my current PDE...
// Autogenerated file by RAGen (v1.0.4.92), (10/15/2011 12:40)
// RA_101511_1240.pde
#define SIMPLE_MENU
#define DisplayLEDPWM
#define wifi
#define VersionMenu
#define CUSTOM_MAIN
#define NUMBERS_8x16
#define COLORS_PDE
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_Colors.h>
#define Sump 1
#define DosingPump2 2
#define Refugium 3
#define Daylight 4
#define Actinic 5
#define Skimmer 6
#define Heater 7
#define DosingPump1 8
//Cloud & Lightning effects
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
boolean ForceCloud=false;
ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 0, " "); //Top Banner
ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 2, " BioCube 14 Nano Reef "); //Top Banner
ReefAngel.LCD.DrawDate(6, 123);
// Display Temp Text
ReefAngel.LCD.DrawText(0,255,12,12,"Temp");
// Display the T1 temp value 10,22
char text[7];
ReefAngel.LCD.Clear(255, 0, 22, 50, 36);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 10, 22, text, Num8x16);
// Display pH Text
ReefAngel.LCD.DrawText(0,255,100,12,"pH");
// Display pH Value
ReefAngel.LCD.Clear(255, 90, 22, 98, 36);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 90, 22, text, Num8x16);
// Display Actinic Percentage Text
ReefAngel.LCD.DrawText(0,255,8,40,"Actinic %");
// Display the Actinic PWM channel value at 90,40
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),COLOR_CORNFLOWERBLUE, 90, 40, 1);
// Display Daylight Percentage Text
ReefAngel.LCD.DrawText(0,255,8,50,"Daylight %");
// Display the Daylight PWM channel value at 90,50
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),COLOR_CORNFLOWERBLUE, 90, 50, 1);
// Display T2 Temp Text
ReefAngel.LCD.DrawText(0,255,8,60,"Canopy Temp");
// Display the T2 temperature value at 90,60
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, COLOR_CORNFLOWERBLUE, 90, 60, 10);
// Display T3 Temp Text
ReefAngel.LCD.DrawText(0,255,8,70,"Ambient Temp");
// Display the T3 temperature at 90,70
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, COLOR_CORNFLOWERBLUE, 90, 70, 10);
// Display Vortech MP10ew Mode Text at 90, 80
ReefAngel.LCD.DrawText(0,255,8,80,"EcoSmart Mode");
// Display EcoSmart Mode Value
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,90,80,"Storm");
//#if defined DisplayLEDPWM && ! defined RemoveAllLights
//ReefAngel.LCD.DrawMonitor(11, 60, ReefAngel.Params,
//ReefAngel.PWM.GetDaylightValue(), ReefAngel.PWM.GetActinicValue());
//#else // defined DisplayLEDPWM && ! defined RemoveAllLights
//ReefAngel.LCD.DrawMonitor(11, 60, ReefAngel.Params);
//#endif // defined DisplayLEDPWM && ! defined RemoveAllLights
ReefAngel.LCD.DrawOutletBox(13, 97, TempRelay);
// ReefAngel.LCD.DrawGraph(5,7);
ReefAngel.FeedingModePorts = B00100001; //Ports 6 & 1 turn off
ReefAngel.WaterChangePorts = B00100001; //Ports 6 & 1 turn off
ReefAngel.OverheatShutoffPorts = B00011000; //Ports 4 & 5 turn off
ReefAngel.LightsOnPorts = B00011000; //Ports 4 & 5 turn on
ReefAngel.Relay.On(Port1);
// Delay Skimmer port 5 minutes whenever turned on
// From Curt - THANKS CURT!
ReefAngel.Relay.DelayedOn(Port6, 5);
//Heater
ReefAngel.StandardHeater(Heater,775,780); // Setup Heater to turn on at 77.5F and off at 78.0F
//Lighting schedule
ReefAngel.MHLights(Daylight,9,0,17,0,0); //Daylight schedule 9:00am - 5:00pm with 0min cool down
ReefAngel.StandardLights(Actinic,7,0,19,0); //Actinic schedule 7:00am - 7:00pm
ReefAngel.StandardLights(Refugium,19,0,7,0); //Refugium schedule 7:00pm - 7:00am
// Dosing pumps (OLD DOSING METHOD OF PUMP ONE ON THE HOUR, THEN PUMP2 5 MIN LATER - to use when tank is more mature
//From Roberto - THANKS ROBERTO!
/* if (ReefAngel.DisplayedMenu==255 && minute()==0 && second()<1) //Alk Doser - Only works if Main screen is showing
ReefAngel.Relay.On(DosingPump1); //Turn Alk Doser on
ReefAngel.Relay.Off(DosingPump1); //Turn Alk Doser off
if (ReefAngel.DisplayedMenu==255 && minute()==5 && second()<1) //CA Doser - Only works if Main screen is showing
ReefAngel.Relay.On(DosingPump2); //Turn CA Doser on
ReefAngel.Relay.Off(DosingPump2); //Turn CA Doser off
// Dosing pumps
// From Roberto - THANKS ROBERTO!
if (ReefAngel.DisplayedMenu==255 && hour()%2==0 && minute()==0 && second()<1) // 1 sec dosing on even hours
ReefAngel.Relay.On(DosingPump1); //Turn DosingPump1 Doser on
ReefAngel.Relay.Off(DosingPump1); //Turn DosingPump1 Doser off
if (ReefAngel.DisplayedMenu==255 && hour()%2==1 && minute()==0 && second()<1) // 1 sec dosing on odd hours
ReefAngel.Relay.On(DosingPump2); //Turn DosingPump2 Doser on
ReefAngel.Relay.Off(DosingPump2); //Turn DosingPump2 Doser off
// Cloud & Lightning effects - Calculate your regular sunrise/sunset PWM value
// byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
if (hour()>=19 || hour()<7)
ReefAngel.PWM.SetActinic(MoonPhase()); //Moon phase schedule between 7:00pm - 7:00am
ActinicPWMValue=PWMSlope(7,00,19,0,0,35,60,ActinicPWMValue); //Actinic turn on at 7am, off at 10am, and ramp up 0% to 50% PWM in 60 minutes
//ActinicPWMValue=PWMSlope(16,00,19,0,0,50,60,ActinicPWMValue); //Actinic turn on at 4pm, off at 7pm, and ramp up 0% to 50% PWM in 60 minutes
DaylightPWMValue=PWMSlope(9,00,17,0,0,75,60,DaylightPWMValue); //Daylight turn on at 9am, off at 5pm, and ramp up 0% to 50% PWM in 60 minutes
CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 6
// In this example, end could before 4:30pm
#define End_Cloud_Before NumMins(16,30)
#define Lightning_Change_per_Cloud 25
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen result could happen.
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
//When cusotm menu Force cloud is selected
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
lightningchance=1;
cloudstart=NumMins(hour(),minute())+1;
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.Clear(255,0,113,132,121);
ReefAngel.LCD.DrawText(0,255,12,113,"C");
ReefAngel.LCD.DrawText(0,255,18,113,"00:00");
ReefAngel.LCD.DrawText(0,255,52,113,"L");
ReefAngel.LCD.DrawText(0,255,58,113,"00:00");
ReefAngel.LCD.DrawText(0,255,93,113,"DUR");
int x=0;
if ((cloudstart/60)>=10) x=18;
else x=24;
ReefAngel.LCD.DrawText(0,255,x,113,(cloudstart/60));
if ((cloudstart%60)>=10) x=36;
else x=42;
ReefAngel.LCD.DrawText(0,255,x,113,(cloudstart%60));
ReefAngel.LCD.DrawText(0,255,114,113,cloudduration);
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=88;
else x=94;
ReefAngel.LCD.DrawText(0,255,x,113,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=109;
else x=112;
ReefAngel.LCD.DrawText(0,255,x,113,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
//End Cloud & Lighting
