My code with RANet
PostPosted: Sun Feb 01, 2015 7:02 am
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>U
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <ReefAngel.h>
#include <SoftwareSerial.h>
////// Place global variable code below here
////// Place global variable code above here
    ReefAngel.Use2014Screen();
    ReefAngel.AddRANet();
    // Ports toggled when relay looses communication
    ReefAngel.Relay.RANetFallBackE[0] = Port1Bit | Port5Bit | Port8Bit;
    ReefAngel.FeedingModePortsE[0] = Port5Bit;
    // Feeding Mode speeds
    ReefAngel.Relay.On( Port2 );
    ReefAngel.StandardLights( Port1, 13, 0, 23, 00);
    ReefAngel.StandardLights( Port3, 13, 0, 23, 05);
    ReefAngel.StandardLights( Port7, 23, 0, 7, 05);
    ReefAngel.StandardLights( Port8, 23, 0, 7, 05);
    ReefAngel.StandardLights( Box1_Port1, 7, 0, 1, 00);
    ReefAngel.StandardLights( Box1_Port2, 22, 0, 7, 00);
    ReefAngel.StandardLights( Box1_Port7, 19, 0, 23, 00);
    if (hour()>=7 && hour()<23) // Turn Moonlights on/off
    ReefAngel.PWM.SetChannel( 0, (0));
    ReefAngel.PWM.SetChannel( 0, MoonPhase()/4);
if (hour()>=4 && hour()<8)
  ReefAngel.PWM.SetDaylight(SineMode(32,40,30,true) ); //SineMode from 30% to 40% for 30 seconds on sync mode
  ReefAngel.PWM.SetActinic(SineMode(32,40,30,false) ); //SineMode from 30% to 40% for 30 seconds on anti-sync mode
else if (hour()>=8 && hour()<12)
  ReefAngel.PWM.SetDaylight( TidalSwellMode(55,true) ); // TidalSwell at 40% on sync mode
  ReefAngel.PWM.SetActinic( TidalSwellMode(55,false) ); // TidalSwell at 40% on sync mode
else if (hour()>=12 && hour()<16)
  ReefAngel.PWM.SetDaylight(millis()%1200>750?50:0);
  ReefAngel.PWM.SetActinic(millis()%1200<750?0:50);
else if (hour()>=16 && hour()<19)
  ReefAngel.PWM.SetDaylight( LongPulseMode(0,50,10,true) ); // Long pulse at 0% to 50% with 10s pulse on sync mode
  ReefAngel.PWM.SetActinic( LongPulseMode(0,50,10,false) ); // Long pulse at 0% to 50% with 10s pulse on on anti-sync mode
else if (hour()>=19 && hour()<23)
  ReefAngel.PWM.SetDaylight( ElseMode(42,10,true )); // ElseMode on sync mode, 40 +/- 10%
  ReefAngel.PWM.SetActinic( ElseMode(42,10,false )); // ElseMode on anti-sync mode, 40 +/- 10%
  ReefAngel.PWM.SetDaylight(GyreMode(32,50,10,true) ); //GyreMode from 30% to 50% for 10 minutes on sync mode
  ReefAngel.PWM.SetActinic(GyreMode(32,50,10,false) ); //GyreMode from 30% to 50% for 10 minutess on anti-sync mode
    ReefAngel.Portal( "davaraj" );
PostPosted: Mon Feb 02, 2015 10:23 pm
Used this code for feeding mode with ReefAngel battery backup for wavemakers.
This part of code does not work well. One wavemaker runs at full speed:
ReefAngel.DCPump.Mode =millis();
ReefAngel.DCPump.Speed = 1200, 750?50:0;
By the way is this how one codes for DCPump class?
#include <Wire.h>
#include <Time.h>
#include <RA_ATO.h>
#include <LED.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <DCPump.h>
  ReefAngel.DCPump.Mode = Sine;
  ReefAngel.DCPump.Speed = 30, 40;
  ReefAngel.DCPump.Mode = TidalSwell; // TidalSwell at 55% on sync mode
  ReefAngel.DCPump.Speed = 55;
  ReefAngel.DCPump.Mode=LongPulse; // Long pulse at 0% to 50% with 10s pulse on sync mode
  ReefAngel.DCPump.Speed =0,50,10;
  ReefAngel.DCPump.Mode=Else; // ElseMode on sync mode, 40 +/- 10%
  ReefAngel.DCPump.Speed =40, 10;
  ReefAngel.DCPump.Mode=Gyre; //GyreMode from 30% to 50% for 10 minutes on sync mode
  ReefAngel.DCPump.Speed = 32, 50, 10;
PostPosted: Tue Feb 03, 2015 5:09 am
davaraj wrote:Used this code for feeding mode with ReefAngel battery backup for wavemakers.
Close. For Mode, you need to pick a valid mode or. Using millis() is not going to work. This would also cause the mode to change every iteration of loop() which would never keep the mode constant for more than a few milliseconds.
ReefAngel.DCPump.Mode=5;
ReefAngel.DCPump.Speed=60;
Second for Speed, the number needs to be between 0-100. I'm not even sure how the above would compile. 750?50:0 is valid, but not the 1200, part. And that code would always return 50 fro the speed.
PostPosted: Tue Feb 03, 2015 6:45 am
This was my original code that worked well.
I changed it to this:
Will the 2nd set of codes work? i know that 'millis' will not work as you have mentioned above.
PostPosted: Tue Feb 03, 2015 7:02 am
No it won't work. When you use the DCPump class the Modes have built in parameters for duration and ranges. You can't pass multiple values to Speed.
You can only set one number.
PostPosted: Sun Feb 22, 2015 2:57 am
    ReefAngel.StandardFan( Box1_Port6, 262,273);
  ReefAngel.DCPump.SetMode(Sine,50,30,30) ;
  ReefAngel.DCPump.SetMode(TidalSwell,55,0); // TidalSwell at 55% on sync/antisync mode
  ReefAngel.DCPump.SetMode(Constant, millis()%1200>750?50:0,0);
  ReefAngel.DCPump.SetMode(LongPulse,50,10,0); // Long pulse at 0% to 50% with 10s pulse on sync/antisync mode
  ReefAngel.DCPump.SetMode(Else,40,20);           // ElseMode sync/antisync, 40 +/- 20%
  ReefAngel.DCPump.SetMode(Gyre,50,05,30); //GyreMode from 30% to 50% for 10 minutes on sync/antisync mode
Return to My PDE/INO file
