I just got the controller today and I've managed to modify one of the custom main screens here, get the moonlight working right, and it appears all the timers working correctly.
The one issue I'm having is that when I start feeding mode, it enters the mode then immediately exits. Don't know what's going on there.
#define SIMPLE_MENU
#define DisplayLEDPWM
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#define AutoTopOff 1
#define Daylight 2
#define Relay3 3
#define Heater 4
#define Skimmer 5
#define MetalHalide 6
#define Actinic 7
#define Return 8
#include <avr/pgmspace.h>
//Create the menu entries
prog_char menu1_label[] PROGMEM= "Chow Time";
prog_char menu2_label[] PROGMEM= "h2o Change";
prog_char menu3_label[] PROGMEM= "ph Calibration";
prog_char menu4_label[] PROGMEM= "Set Date Time";
//Group menu entries together
menu4_label
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.SetupCalibratePH();
void MenuEntry4()
ReefAngel.SetupDateTime();
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 6, 2, "Dave's 40g Reef");
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 17, 132, 17);
//pingSerial();
x = 12;
y += MENU_START_ROW+1;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Temp: ph");
char text[7];
ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text);
//pingSerial();
y += MENU_START_ROW*2;
x = 10;
//pingSerial();
//pingSerial();
x += (16*4) + 8;
ReefAngel.Relay.On(Return); //Turn Return on at startup
ReefAngel.Relay.On(Skimmer); //Turn Skimmer on at startup
ReefAngel.StandardATO(AutoTopOff,30); //Setup AutoTopOff as Auto Top-Off function with 30s timeout
ReefAngel.MHLights(Daylight,10,0,22,30,15); //Daylight schedule 10:00am - 10:30pm with 15min cool down
ReefAngel.StandardHeater(Heater,788,792); // Setup Heater to turn on at 78.8F and off at 79.2F
if (hour()>=22 || hour()<=9)
ReefAngel.PWM.SetActinic(0);
ReefAngel.ShowInterface(); //Draw the Standard Interface
