Almost complete feature hog :P
PostPosted: Mon Mar 26, 2012 9:18 am
I can and will soon - tank has been on cruise control for a few months lol. Now I need to update libraries and all the other fun stuff that's been going on
PostPosted: Sun May 06, 2012 2:01 pm
Hi Deckoz2302.
I have 5 Led channels , Channel 1 , 2 , 3 , 4 being white and blue, and channel 5 being colours.
I am using your pwm code - how would I set it up to switch on channel 1 , then 2 then 3, then 4&5 with 30 min delay on each? that would give a sunrise effect, and the same with sunset, channel 1, then delay channel 2 with 30 min, then channel 3 with 30 min then channel 4&5 with 30 minutes.
PostPosted: Sun May 13, 2012 9:32 pm
Hi,
i am planning to use your pwm code for 2 led channels only.
what modification should i do to make it work for.
PostPosted: Sat Aug 11, 2012 6:16 pm
Deckoz, looks like you've got the code I need in here for calculating Sunrise and Sunset... I'm not going to be using dimming at the moment, so just wondering if you have any pointers on what to pull / ignore, etc. from your PDE. I'll be analyzing it later when I have some more time, but this looks like the place to start...
PostPosted: Sun Aug 19, 2012 4:21 pm
FYI...I just got bitten by this code since Timer[4] is used for the portal timer...
    ReefAngel.Timer[4].SetInterval(10); // Timer for 30min
    ReefAngel.Timer[4].Start();
Might want to modify your example so other people don't get bitten too :)
PostPosted: Mon Oct 13, 2014 2:44 pm
Tagging along so I can do this in the future.
Previous
Return to My PDE/INO file
