Alekos' Complete INO
PostPosted: Sun May 24, 2015 5:45 pm
Here is my Complete INO.
I am still updating things before plug it into my tank
Any suggestions/Comments/Improvements are welcome
Please post if you see any bugs.
Thank you
#include <WiFiAlert.h>
// TODO Alerts: High Water Level, Temp alerts, PH alerts, // it looks like the notifications can be created on the app.
// WifiAlert ... // sends email alert where is the email stored?
// Custom menus
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Feeding Mode";
prog_char menu3_label[] PROGMEM = "Calibrate PH";
prog_char menu4_label[] PROGMEM = "Setup Date Time";
prog_char menu5_label[] PROGMEM = "DC Pump Settings";
prog_char menu6_label[] PROGMEM = "Version";
   menu4_label, menu5_label, menu6_label
// Needs to be global for DrawCustomGraph()
int ScreenID=1;
boolean drawGraph=true;
boolean HighAlertActive=false;
boolean EmptyAlertActive=false;
WiFiAlert levelAlert, emptyAlert;
//Rename ports
#define MAINPUMP      Port1
#define REFPUMP         Port2
#define SKIMMER         Port3
#define REACTOR         Port4
#define POWERHEAD      Port5
#define REFLIGHTS      Port6
#define UNUSED         Port7
#define DRUMPUMP      Port8
   ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize Menu
   //ReefAngel.AddStandardMenu();  // Add Standard Menu
   //ReefAngel.Use2014Screen();  // Let's use 2014 Screen
   //ReefAngel.FeedingModePorts = Port5Bit; // its being handled on runDCPump()
   ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit;
   //ReefAngel.OverheatProbe = T1_PROBE;
   //Set the Overheat temperature setting
   // Jebao Pump
   ReefAngel.DCPump.ActinicChannel=Sync; // DC pump on PWM Actinic channel
   //ReefAngel.DCPump.DaylightChannel=AntiSync; // DC pump on PWM Daylight channel if I had one
   //ReefAngel.DCPump.AntiSyncOffset=85;
   //ReefAngel.Network.WifiAuthentication("alekos:xxxxxxxx"); // Not working
   //ports schedule
   ReefAngel.Relay.On(MAINPUMP);
   ReefAngel.Relay.On(REFPUMP);
   ReefAngel.StandardLights( SKIMMER,7,0,22,0 );
   ReefAngel.StandardLights( REACTOR,7,0,22,0 );
   ReefAngel.StandardLights( POWERHEAD,7,0,22,0 );
   ReefAngel.StandardLights( REFLIGHTS,8,0,22,0 );
   ReefAngel.Relay.On( UNUSED ); // this port is not used yet
   ReefAngel.StandardLights( DRUMPUMP,20,0,20,15 ); //Automatic Water change Time calculated for 2 Gal per day
   // using the High float switch to stop pumps to prevent overflow
   if (!ReefAngel.HighATO.IsActive()){
      levelAlert.Send("Display+Tank+water+level+high+PUMPS+OFF");
      HighAlertActive=true;
      ReefAngel.Relay.Off(MAINPUMP);
      ReefAngel.Relay.Off(REFPUMP);
      ReefAngel.Relay.Off(SKIMMER);
      ReefAngel.Relay.Off(REACTOR);
      ReefAngel.Relay.Off(POWERHEAD);
      ReefAngel.Relay.Off(DRUMPUMP);
   else{
   if (HighAlertActive && ReefAngel.HighATO.IsActive())
   levelAlert.Send("Display+Tank+water+level+normal+PUMPS+Ok");
   //Low sensor on the Water supply drum
   //this is to avoid running the pump dry
   if (ReefAngel.LowATO.IsActive()){
   else{
   runDCPump();// running the pump in custom mode
   ReefAngel.Portal("alekos");
// Menu Code
void MenuEntry1() {
   ReefAngel.FeedingModeStart();
   DrawRelaysBox(0,0);
void MenuEntry2() {
   DrawWaterChangeScreen();
void MenuEntry3() {
   ReefAngel.SetupCalibratePH();
void MenuEntry4() {
   //ReefAngel.DisplayMenuEntry("Relay Control");
   // I am Creating menu to turn on and off the Relay Box's ports
   ReefAngel.StartSetupDateTime(); //Just a place holder
void MenuEntry5()
   DCPumpSettingScreen();
void MenuEntry6() {
   ReefAngel.DisplayVersion(); // Just Because...
void DrawCustomMain() {
   const int NumScreens=3;
   switch (ScreenID) {
   case 0:
         //Parameters and Chart small relay box
         DrawScreen1();
         break;
   case 1:
         //Parameters and nice relay box
         DrawScreen2();
         break;
   case 2:
         //DC Pump settings
         DrawScreen3();
         break;
   //loop between screens
   if (ReefAngel.Joystick.IsLeft()) {
      ScreenID--;
      drawGraph=true;
   if (ReefAngel.Joystick.IsRight()) {
      ScreenID++;
      drawGraph=true;
void DrawScreen1(){
   // Main Header
   //ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 31, 2,"Alekos's Reef");
   ReefAngel.LCD.DrawDate(5,2);
   ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 128, 11);
   // Param Header
   DrawParams(5,14);
   DrawStatus(5,35);
   // Draw Relays
   DrawRelays(13,116);
   // Draw chart
   if (drawGraph) {
      ReefAngel.LCD.DrawGraph(5, 62);
      drawGraph=false;
void DrawScreen2(){
   // Main Header
   // Param Header
   DrawParams(5,14);
   DrawStatus(5,35);
   DrawRelaysBox(0,55);
   // The Below code was moved to its own screen a better one from Draw2014Main()
   //char jebaomsg[32];
   //String PUMP_MODES[] = {"Constant","Lagoon","ReefCrest","Short Pulse","Long Pulse","Nutrient Trans.","Tidal Swell","Feeding","FeedingAndNightStop","Night","Storm","Custom","Else","Sine","Gyre"};
   //char buf[16];
   //PUMP_MODES[ReefAngel.DCPump.Mode].toCharArray(buf,16);
   //sprintf(jebaomsg,"M:%s-%d s:%d d:%d ms",buf,pmode,InternalMemory.DCPumpSpeed_read(),InternalMemory.DCPumpDuration_read());
   //ReefAngel.LCD.DrawText(COLOR_INDIGO,DefaultBGColor,2,62,jebaomsg);
//Modified From Draw2014Main()
void DrawScreen3(){
   const unsigned PROGMEM char BAR_I_LEFT[] = {
      0xAB, 0xAB, 0xAF, 0xD3, 0xD7, 0xFB};
   const unsigned PROGMEM char BAR_CENTER[] = {
      0x92, 0x92, 0xFF, 0xFF, 0xFF, 0xFF, 0xDB, 0xDB, 0xB6, 0xB6, 0xB6, 0xB6};
   const unsigned PROGMEM char BAR_I_RIGHT[] = {
      0xB7, 0xB7, 0xB7, 0xDB, 0xDB, 0xDB};
   byte x,y,w;
   char text[7];
   char buf[16];
   String PUMP_MODES[] = {"Constant","Lagoon","ReefCrest","Short Pulse","Long Pulse","Nutrient Trans.","Tidal Swell","Feeding","Feeding Stop","Night","Storm","Custom","Else","Sine","Gyre"};
   x=5;
   y=5;
   ReefAngel.LCD.DrawLargeText(COLOR_BLACK,COLOR_WHITE,40,y,"DC Pump");
   y+=20;
   ReefAngel.LCD.DrawLargeText(COLOR_BLACK,COLOR_WHITE,x,y,"Mode");
   y+=25;
   ReefAngel.LCD.DrawLargeText(COLOR_BLACK,COLOR_WHITE,x,y,"Duration");
   y+=25;
   ReefAngel.LCD.DrawLargeText(COLOR_BLACK,COLOR_WHITE,x,y,"Speed");
   y+=25;
   ReefAngel.LCD.DrawLargeText(COLOR_BLACK,COLOR_WHITE,x,y,"Threshold");
   y=33;
   ReefAngel.LCD.DrawLargeText(COLOR_DARKGREEN,DefaultBGColor,x,y,buf);
   ReefAngel.LCD.Clear(DefaultBGColor,(PUMP_MODES[ReefAngel.DCPump.Mode].length()*8)+5,y,131,y+7);
   y+=25;
   ConvertNumToString(text, ReefAngel.DCPump.Duration, 1);
   ReefAngel.LCD.DrawLargeText(COLOR_DARKGREEN,DefaultBGColor,x,y,text);
   y+=25;
   w=ReefAngel.DCPump.Speed;
   ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor, 110,y,"   ");
   ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor, 110,y,w);
   for(int b=0; b<w; b++)
   ReefAngel.LCD.DrawImage(1,6,b+5,y+2,BAR_I_LEFT);
   ReefAngel.LCD.DrawImage(2,6,w+5,y+2,BAR_CENTER);
   for(int b=w; b<100; b++)
   ReefAngel.LCD.DrawImage(1,6,b+7,y+2,BAR_I_RIGHT);
   y+=25;
   ConvertNumToString(text, ReefAngel.DCPump.Threshold, 1);
void DrawWaterChangeScreen(){
   // Main Header
   ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,1,12,"Water Change Mode");
   // to display the relay box to ensre the right ports a off/on
   DrawRelaysBox(0,0);
void DrawCustomGraph() {
   if (ScreenID==0)
//Copied from lnevo, thanks
   char buf[16];
   // Temp and PH
   y+=2;
   y+=6;
   ReefAngel.LCD.DrawLargeText(T1TempColor, DefaultBGColor, x+6, y, buf, Num8x16);
   ConvertNumToString(buf, ReefAngel.Params/dot/PH, 100); // Replace /dot/ for a period the forum didn't allowed this thinking it is an url
   y+=5;
void DrawRelays(int x, int y) {
   // Draw Relays
   /* //Extendsion Boxes
y+=12;
y+=12;
TempRelay = ReefAngel.Relay.RelayDataE[1];
TempRelay &= ReefAngel.Relay.RelayMaskOffE[1];
TempRelay |= ReefAngel.Relay.RelayMaskOnE[1];
void DrawRelaysBox(int x, int y) {
   // Draw Relays
   ReefAngel.LCD.DrawCircleOutletBox(x+56,y+36,TempRelay);
   //pingSerial();
   ReefAngel.LCD.DrawLargeText(0,255,x+27,y+22,"RelayBox 1");
   ReefAngel.LCD.DrawText(0,255,x+3,y+32,"MainPump"); //1
   ReefAngel.LCD.DrawText(0,255,x+8,y+42,"Skimmer"); //3
   ReefAngel.LCD.DrawText(0,255,x+7,y+52,"PwrHead"); //5
   ReefAngel.LCD.DrawText(0,255,x+13,y+62,"Unused"); //7
   ReefAngel.LCD.DrawText(0,255,x+75,y+32,"Ref Pump");  //2
   ReefAngel.LCD.DrawText(0,255,x+75,y+42,"Reactor");  //4
   ReefAngel.LCD.DrawText(0,255,x+75,y+52,"Ref Light"); //6
   ReefAngel.LCD.DrawText(0,255,x+75,y+62,"Drum Pump");  //8
   ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,21,y,"High",Font8x16);
   ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,21,y+15,"Drum",Font8x16);
      ReefAngel.LCD.FillCircle(11,y+3,5,COLOR_GREEN);
      ReefAngel.LCD.DrawText(COLOR_GREEN,DefaultBGColor,53,y,"(Normal)    ");
   else {
      ReefAngel.LCD.FillCircle(11,y+3,5,COLOR_RED);
      ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,53,y,"(High level)");
      ReefAngel.LCD.FillCircle(11,y+17,5,COLOR_GREEN);
      ReefAngel.LCD.DrawText(COLOR_GREEN,DefaultBGColor,53,y+15,"(Normal)  ");
   else {
      ReefAngel.LCD.FillCircle(11,y+17,5,COLOR_RED);
      ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,53,y+15,"(Empty)   ");
//parts copied and modified from 89delta Thanks
void runDCPump()
   // Jebao Code
   //ReefAngel.DCPump.SetMode( MODE,%SPEED,DURATION ms );
   static int rmode;
   byte modes[] = { ReefCrest, Gyre, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else};
   if (now()%SECS_PER_DAY<=2) { // Change at midnight
   static unsigned long feeding;
   if (now()-feeding<900) {
      // Do Feeding mode for 15 minutes
      ReefAngel.DCPump.Mode=NutrientTransport; // Maybe Feeding_Start I think this is for RF Only (Vortex)
      ReefAngel.DCPump.Speed=5; // adjust for really low speed
   else if (now()%SECS_PER_DAY>=75600 || now()%SECS_PER_DAY<32400) { // Between 9 pm and 9 am
      // Night mode (go to 30% or lower)
      ReefAngel.DCPump.Speed=30; // lower depends how loud or fast this is.
   else if (InternalMemory.DCPumpMode_read()==11) {
      //ReefAngel.DCPump.Threshold=InternalMemory.DCPumpThreshold_read();// Set Threshold from portal
   else {
//Menu screen to change DCPump settings
void DCPumpSettingScreen(){
   // Drawing the screen
   ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,3,3,"DC Pump Settings");
   ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 4, 25, "Mode:");
   ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 4, 45, "Duration:");
   ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 4, 65, "Speed:");
   ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 4, 85, "Threshold:");
   //initializing Some variables
   byte setup_dcpump_option;
   char buf[16];
   char *dcpump_mode[15] = { "Constant       ","Lagoon         ","Reef Crest     ","Short Pulse    ","Long Pulse     ","Nutrient Trans.","Tidal Swell    ","Feeding        ","Feeding Stop   ","Night          ","Storm          ","Custom         ","Else           ","Sine           ","Gyre           "};
   bool done = false;
   bool page_refresh = true;
   enum{
      SETUP_DCPUMP_MODE,
      SETUP_DCPUMP_DURATION,
      SETUP_DCPUMP_SPEED,
      SETUP_DCPUMP_THRESHOLD,
      SETUP_DCPUMP_CANCEL,
      SETUP_DCPUMP_OK
   setup_dcpump_option=SETUP_DCPUMP_MODE;
   //Pulling DCPump settings from memory
   int pmodeindex = InternalMemory.DCPumpMode_read();
   int pduration = InternalMemory.DCPumpDuration_read();
   int pspeed = InternalMemory.DCPumpSpeed_read();
   int pthreshold = InternalMemory.DCPumpThreshold_read();
   do{
      if(page_refresh)
         ReefAngel.LCD.DrawSelect(dcpump_mode[pmodeindex], setup_dcpump_option==SETUP_DCPUMP_MODE?1:0, 37, 25, 1);
         ReefAngel.LCD.DrawOption(pduration, setup_dcpump_option==SETUP_DCPUMP_DURATION?1:0, 60, 45, "", "", 2);
         ReefAngel.LCD.DrawOption(pspeed, setup_dcpump_option==SETUP_DCPUMP_SPEED?1:0, 42, 65, "", "", 2);
         ReefAngel.LCD.DrawOption(pthreshold, setup_dcpump_option==SETUP_DCPUMP_THRESHOLD?1:0, 65, 85, "", "", 2);
         ReefAngel.LCD.DrawOK(setup_dcpump_option==SETUP_DCPUMP_OK?1:0);
         ReefAngel.LCD.DrawCancel(setup_dcpump_option==SETUP_DCPUMP_CANCEL?1:0);
         //ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 4, 95, "       ");
         //ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 4, 95, pmodeindex);
         page_refresh = !page_refresh;
      }else{
         ReefAngel.Refresh();// not really refreshing the page is to avoid a blank screen
      if(ReefAngel.Joystick.IsUp())
         switch(setup_dcpump_option)
         case SETUP_DCPUMP_MODE:
               pmodeindex--;
               if(pmodeindex<0){
                  pmodeindex=14;
            break;
         case SETUP_DCPUMP_DURATION:
               pduration++;
               if(pduration>99){
                  pduration=0;
            break;
         case SETUP_DCPUMP_SPEED:
               pspeed++;
               if(pspeed>99){
                  pspeed=0;
            break;
         case SETUP_DCPUMP_THRESHOLD:
               pthreshold++;
               if(pthreshold>99){
                  pthreshold=0;
            break;
      if(ReefAngel.Joystick.IsDown())
               pmodeindex++;
               if(pmodeindex>14){
                  pmodeindex=0;
            break;
               pduration--;
               if(pduration<0){
                  pduration=99;
            break;
               pspeed--;
               if(pspeed<0){
                  pspeed=99;
            break;
               pthreshold--;
               if(pthreshold<0){
                  pthreshold=99;
            break;
      if(ReefAngel.Joystick.IsLeft())
         setup_dcpump_option--;
         if (setup_dcpump_option>SETUP_DCPUMP_OK)
            setup_dcpump_option=SETUP_DCPUMP_OK;
      if(ReefAngel.Joystick.IsRight())
         setup_dcpump_option++;
            setup_dcpump_option=SETUP_DCPUMP_MODE; //The first option. since im testing Cancel is the first option
      if(ReefAngel.Joystick.IsButtonPressed())
         if(setup_dcpump_option==SETUP_DCPUMP_OK||setup_dcpump_option==SETUP_DCPUMP_CANCEL)
            if(setup_dcpump_option==SETUP_DCPUMP_OK)
               // COMMIT THE CHANGES HERE
               //ReefAngel.DCPump.UseMemory=true;
               InternalMemory.DCPumpMode_write(pmodeindex);
               //ReefAngel.DCPump.Mode=pmodeindex;
               InternalMemory.DCPumpSpeed_write(pspeed);
               //ReefAngel.DCPump.Speed=pspeed;
               InternalMemory.DCPumpDuration_write(pduration);
               //ReefAngel.DCPump.Duration=pduration;
               InternalMemory.DCPumpThreshold_write(pthreshold);
               //ReefAngel.DCPump.Threshold=pthreshold;
               ReefAngel.DisplayedMenu = ALT_SCREEN_MODE; //Go Back to Menu
               //ReefAngel.DisplayedMenu=DEFAULT_MENU;// Go Back to Main Screen
            }else{
            done=true;
   }while(!done);
// Not using code below at the moment
void WaterFill(bool stat)
   if(stat = 0){
   else{
void saving_stuff(){
   int pmode;
   switch (ReefAngel.DCPump.Mode)
   case Constant:
         pmode=0;
         break;
   case Lagoon:
         pmode=1;
         break;
   case ReefCrest:
         pmode=2;
         break;
   case ShortPulse:
         pmode=3;
         break;
   case LongPulse:
         pmode=4;
         break;
   case NutrientTransport:
         pmode=5;
         break;
   case TidalSwell:
         pmode=6;
         break;
   case Feeding_Start:
         pmode=7;
         break;
   case Feeding_Stop:
         pmode=8;
         break;
   case Night:
         pmode=9;
         break;
   case Storm:
         pmode=10;
         break;
   case Custom:
         pmode=11;
         break;
   case Else:
         pmode=12;
         break;
   case Sine:
         pmode=13;
         break;
   case Gyre:
         pmode=14;
         break;
Return to My PDE/INO file
