Alekos' Complete INO
Posted: Sun May 24, 2015 5:45 pm
by alekos
Here is my Complete INO.
I am still updating things before plug it into my tank
Any suggestions/Comments/Improvements are welcome
Please post if you see any bugs.
Thank you
#include <WiFiAlert.h>
// TODO Alerts: High Water Level, Temp alerts, PH alerts, // it looks like the notifications can be created on the app.
// WifiAlert ... // sends email alert where is the email stored?
// Custom menus
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Feeding Mode";
prog_char menu3_label[] PROGMEM = "Calibrate PH";
prog_char menu4_label[] PROGMEM = "Setup Date Time";
prog_char menu5_label[] PROGMEM = "DC Pump Settings";
prog_char menu6_label[] PROGMEM = "Version";
	menu4_label, menu5_label, menu6_label
// Needs to be global for DrawCustomGraph()
int ScreenID=1;
boolean drawGraph=true;
boolean HighAlertActive=false;
boolean EmptyAlertActive=false;
WiFiAlert levelAlert, emptyAlert;
//Rename ports
#define MAINPUMP		Port1
#define REFPUMP			Port2
#define SKIMMER			Port3
#define REACTOR			Port4
#define POWERHEAD		Port5
#define REFLIGHTS		Port6
#define UNUSED			Port7
#define DRUMPUMP		Port8
	ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize Menu
	//ReefAngel.AddStandardMenu();  // Add Standard Menu
	//ReefAngel.Use2014Screen();  // Let's use 2014 Screen
	//ReefAngel.FeedingModePorts = Port5Bit; // its being handled on runDCPump()
	ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit;
	//ReefAngel.OverheatProbe = T1_PROBE;
	//Set the Overheat temperature setting
	// Jebao Pump
	ReefAngel.DCPump.ActinicChannel=Sync; // DC pump on PWM Actinic channel
	//ReefAngel.DCPump.DaylightChannel=AntiSync; // DC pump on PWM Daylight channel if I had one
	//ReefAngel.DCPump.AntiSyncOffset=85;
	//ReefAngel.Network.WifiAuthentication("alekos:xxxxxxxx"); // Not working
	//ports schedule
	ReefAngel.Relay.On(MAINPUMP);
	ReefAngel.Relay.On(REFPUMP);
	ReefAngel.StandardLights( SKIMMER,7,0,22,0 );
	ReefAngel.StandardLights( REACTOR,7,0,22,0 );
	ReefAngel.StandardLights( POWERHEAD,7,0,22,0 );
	ReefAngel.StandardLights( REFLIGHTS,8,0,22,0 );
	ReefAngel.Relay.On( UNUSED ); // this port is not used yet
	ReefAngel.StandardLights( DRUMPUMP,20,0,20,15 ); //Automatic Water change Time calculated for 2 Gal per day
	// using the High float switch to stop pumps to prevent overflow
	if (!ReefAngel.HighATO.IsActive()){
		levelAlert.Send("Display+Tank+water+level+high+PUMPS+OFF");
		HighAlertActive=true;
		ReefAngel.Relay.Off(MAINPUMP);
		ReefAngel.Relay.Off(REFPUMP);
		ReefAngel.Relay.Off(SKIMMER);
		ReefAngel.Relay.Off(REACTOR);
		ReefAngel.Relay.Off(POWERHEAD);
		ReefAngel.Relay.Off(DRUMPUMP);
	else{
	if (HighAlertActive && ReefAngel.HighATO.IsActive())
	levelAlert.Send("Display+Tank+water+level+normal+PUMPS+Ok");
	//Low sensor on the Water supply drum
	//this is to avoid running the pump dry
	if (ReefAngel.LowATO.IsActive()){
	else{
	runDCPump();// running the pump in custom mode
	ReefAngel.Portal("alekos");
// Menu Code
void MenuEntry1() {
	ReefAngel.FeedingModeStart();
	DrawRelaysBox(0,0);
void MenuEntry2() {
	DrawWaterChangeScreen();
void MenuEntry3() {
	ReefAngel.SetupCalibratePH();
void MenuEntry4() {
	//ReefAngel.DisplayMenuEntry("Relay Control");
	// I am Creating menu to turn on and off the Relay Box's ports
	ReefAngel.StartSetupDateTime(); //Just a place holder
void MenuEntry5()
	DCPumpSettingScreen();
void MenuEntry6() {
	ReefAngel.DisplayVersion(); // Just Because...
void DrawCustomMain() {
	const int NumScreens=3;
	switch (ScreenID) {
	case 0:
			//Parameters and Chart small relay box
			DrawScreen1();
			break;
	case 1:
			//Parameters and nice relay box
			DrawScreen2();
			break;
	case 2:
			//DC Pump settings
			DrawScreen3();
			break;
	//loop between screens
	if (ReefAngel.Joystick.IsLeft()) {
		ScreenID--;
		drawGraph=true;
	if (ReefAngel.Joystick.IsRight()) {
		ScreenID++;
		drawGraph=true;
	if (ScreenID<0) ScreenID=NumScreens-1;
void DrawScreen1(){
	// Main Header
	//ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 31, 2,"Alekos's Reef");
	ReefAngel.LCD.DrawDate(5,2);
	ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 128, 11);
	// Param Header
	DrawParams(5,14);
	DrawStatus(5,35);
	// Draw Relays
	DrawRelays(13,116);
	// Draw chart
	if (drawGraph) {
		ReefAngel.LCD.DrawGraph(5, 62);
		drawGraph=false;
void DrawScreen2(){
	// Main Header
	// Param Header
	DrawParams(5,14);
	DrawStatus(5,35);
	DrawRelaysBox(0,55);
	// The Below code was moved to its own screen a better one from Draw2014Main()
	//char jebaomsg[32];
	//String PUMP_MODES[] = {"Constant","Lagoon","ReefCrest","Short Pulse","Long Pulse","Nutrient Trans.","Tidal Swell","Feeding","FeedingAndNightStop","Night","Storm","Custom","Else","Sine","Gyre"};
	//char buf[16];
	//PUMP_MODES[ReefAngel.DCPump.Mode].toCharArray(buf,16);
	//sprintf(jebaomsg,"M:%s-%d s:%d d:%d ms",buf,pmode,InternalMemory.DCPumpSpeed_read(),InternalMemory.DCPumpDuration_read());
	//ReefAngel.LCD.DrawText(COLOR_INDIGO,DefaultBGColor,2,62,jebaomsg);
//Modified From Draw2014Main()
void DrawScreen3(){
	const unsigned PROGMEM char BAR_I_LEFT[] = {
		0xAB, 0xAB, 0xAF, 0xD3, 0xD7, 0xFB};
	const unsigned PROGMEM char BAR_CENTER[] = {
		0x92, 0x92, 0xFF, 0xFF, 0xFF, 0xFF, 0xDB, 0xDB, 0xB6, 0xB6, 0xB6, 0xB6};
	const unsigned PROGMEM char BAR_I_RIGHT[] = {
		0xB7, 0xB7, 0xB7, 0xDB, 0xDB, 0xDB};
	byte x,y,w;
	char text[7];
	char buf[16];
	String PUMP_MODES[] = {"Constant","Lagoon","ReefCrest","Short Pulse","Long Pulse","Nutrient Trans.","Tidal Swell","Feeding","Feeding Stop","Night","Storm","Custom","Else","Sine","Gyre"};
	x=5;
	y=5;
	ReefAngel.LCD.DrawLargeText(COLOR_BLACK,COLOR_WHITE,40,y,"DC Pump");
	y+=20;
	ReefAngel.LCD.DrawLargeText(COLOR_BLACK,COLOR_WHITE,x,y,"Mode");
	y+=25;
	ReefAngel.LCD.DrawLargeText(COLOR_BLACK,COLOR_WHITE,x,y,"Duration");
	y+=25;
	ReefAngel.LCD.DrawLargeText(COLOR_BLACK,COLOR_WHITE,x,y,"Speed");
	y+=25;
	ReefAngel.LCD.DrawLargeText(COLOR_BLACK,COLOR_WHITE,x,y,"Threshold");
	y=33;
	ReefAngel.LCD.DrawLargeText(COLOR_DARKGREEN,DefaultBGColor,x,y,buf);
	ReefAngel.LCD.Clear(DefaultBGColor,(PUMP_MODES[ReefAngel.DCPump.Mode].length()*8)+5,y,131,y+7);
	y+=25;
	ConvertNumToString(text, ReefAngel.DCPump.Duration, 1);
	ReefAngel.LCD.DrawLargeText(COLOR_DARKGREEN,DefaultBGColor,x,y,text);
	y+=25;
	w=ReefAngel.DCPump.Speed;
	ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor, 110,y,"   ");
	ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor, 110,y,w);
	for(int b=0; b<w; b++)
	ReefAngel.LCD.DrawImage(1,6,b+5,y+2,BAR_I_LEFT);
	ReefAngel.LCD.DrawImage(2,6,w+5,y+2,BAR_CENTER);
	for(int b=w; b<100; b++)
	ReefAngel.LCD.DrawImage(1,6,b+7,y+2,BAR_I_RIGHT);
	y+=25;
	ConvertNumToString(text, ReefAngel.DCPump.Threshold, 1);
void DrawWaterChangeScreen(){
	// Main Header
	ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,1,12,"Water Change Mode");
	// to display the relay box to ensre the right ports a off/on
	DrawRelaysBox(0,0);
void DrawCustomGraph() {
	if (ScreenID==0)
//Copied from lnevo, thanks
void DrawParams(int x, int y) {
	char buf[16];
	// Temp and PH
	y+=2;
	ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
	ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, x+45, y, buf);
	y+=6;
	ReefAngel.LCD.DrawLargeText(T1TempColor, DefaultBGColor, x+6, y, buf, Num8x16);
	ConvertNumToString(buf, ReefAngel.Params/dot/PH, 100); // Replace /dot/ for a period the forum didn't allowed this thinking it is an url
	y+=5;
	ConvertNumToString(buf, ReefAngel.Params.Temp[T3_PROBE], 10);
	ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, x+45, y, buf);
void DrawRelays(int x, int y) {
	// Draw Relays
	/* //Extendsion Boxes
y+=12;
y+=12;
TempRelay = ReefAngel.Relay.RelayDataE[1];
TempRelay &= ReefAngel.Relay.RelayMaskOffE[1];
TempRelay |= ReefAngel.Relay.RelayMaskOnE[1];
void DrawRelaysBox(int x, int y) {
	// Draw Relays
	ReefAngel.LCD.DrawCircleOutletBox(x+56,y+36,TempRelay);
	//pingSerial();
	ReefAngel.LCD.DrawLargeText(0,255,x+27,y+22,"RelayBox 1");
	ReefAngel.LCD.DrawText(0,255,x+3,y+32,"MainPump"); //1
	ReefAngel.LCD.DrawText(0,255,x+8,y+42,"Skimmer"); //3
	ReefAngel.LCD.DrawText(0,255,x+7,y+52,"PwrHead"); //5
	ReefAngel.LCD.DrawText(0,255,x+13,y+62,"Unused"); //7
	ReefAngel.LCD.DrawText(0,255,x+75,y+32,"Ref Pump");  //2
	ReefAngel.LCD.DrawText(0,255,x+75,y+42,"Reactor");  //4
	ReefAngel.LCD.DrawText(0,255,x+75,y+52,"Ref Light"); //6
	ReefAngel.LCD.DrawText(0,255,x+75,y+62,"Drum Pump");  //8
void DrawStatus(int x, int y) {
	ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,21,y,"High",Font8x16);
	ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,21,y+15,"Drum",Font8x16);
		ReefAngel.LCD.FillCircle(11,y+3,5,COLOR_GREEN);
		ReefAngel.LCD.DrawText(COLOR_GREEN,DefaultBGColor,53,y,"(Normal)    ");
	else {
		ReefAngel.LCD.FillCircle(11,y+3,5,COLOR_RED);
		ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,53,y,"(High level)");
		ReefAngel.LCD.FillCircle(11,y+17,5,COLOR_GREEN);
		ReefAngel.LCD.DrawText(COLOR_GREEN,DefaultBGColor,53,y+15,"(Normal)  ");
	else {
		ReefAngel.LCD.FillCircle(11,y+17,5,COLOR_RED);
		ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,53,y+15,"(Empty)   ");
//parts copied and modified from 89delta Thanks
void runDCPump()
	// Jebao Code
	//ReefAngel.DCPump.SetMode( MODE,%SPEED,DURATION ms );
	static int rmode;
	byte modes[] = { ReefCrest, Gyre, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else};
	if (now()%SECS_PER_DAY<=2) { // Change at midnight
	static unsigned long feeding;
	if (now()-feeding<900) {
		// Do Feeding mode for 15 minutes
		ReefAngel.DCPump.Mode=NutrientTransport; // Maybe Feeding_Start I think this is for RF Only (Vortex)
		ReefAngel.DCPump.Speed=5; // adjust for really low speed
	else if (now()%SECS_PER_DAY>=75600 || now()%SECS_PER_DAY<32400) { // Between 9 pm and 9 am
		// Night mode (go to 30% or lower)
		ReefAngel.DCPump.Speed=30; // lower depends how loud or fast this is.
	else if (InternalMemory.DCPumpMode_read()==11) {
		ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
		//ReefAngel.DCPump.Threshold=InternalMemory.DCPumpThreshold_read();// Set Threshold from portal
	else {
//Menu screen to change DCPump settings
void DCPumpSettingScreen(){
	// Drawing the screen
	ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,3,3,"DC Pump Settings");
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 4, 25, "Mode:");
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 4, 45, "Duration:");
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 4, 65, "Speed:");
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 4, 85, "Threshold:");
	//initializing Some variables
	byte setup_dcpump_option;
	char buf[16];
	char *dcpump_mode[15] = { "Constant       ","Lagoon         ","Reef Crest     ","Short Pulse    ","Long Pulse     ","Nutrient Trans.","Tidal Swell    ","Feeding        ","Feeding Stop   ","Night          ","Storm          ","Custom         ","Else           ","Sine           ","Gyre           "};
	bool done = false;
	bool page_refresh = true;
	enum{
		SETUP_DCPUMP_MODE,
		SETUP_DCPUMP_DURATION,
		SETUP_DCPUMP_SPEED,
		SETUP_DCPUMP_THRESHOLD,
		SETUP_DCPUMP_CANCEL,
		SETUP_DCPUMP_OK
	setup_dcpump_option=SETUP_DCPUMP_MODE;
	//Pulling DCPump settings from memory
	int pmodeindex = InternalMemory.DCPumpMode_read();
	int pduration = InternalMemory.DCPumpDuration_read();
	int pspeed = InternalMemory.DCPumpSpeed_read();
	int pthreshold = InternalMemory.DCPumpThreshold_read();
	do{
		if(page_refresh)
			ReefAngel.LCD.DrawSelect(dcpump_mode[pmodeindex], setup_dcpump_option==SETUP_DCPUMP_MODE?1:0, 37, 25, 1);
			ReefAngel.LCD.DrawOption(pduration, setup_dcpump_option==SETUP_DCPUMP_DURATION?1:0, 60, 45, "", "", 2);
			ReefAngel.LCD.DrawOption(pspeed, setup_dcpump_option==SETUP_DCPUMP_SPEED?1:0, 42, 65, "", "", 2);
			ReefAngel.LCD.DrawOption(pthreshold, setup_dcpump_option==SETUP_DCPUMP_THRESHOLD?1:0, 65, 85, "", "", 2);
			ReefAngel.LCD.DrawOK(setup_dcpump_option==SETUP_DCPUMP_OK?1:0);
			ReefAngel.LCD.DrawCancel(setup_dcpump_option==SETUP_DCPUMP_CANCEL?1:0);
			//ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 4, 95, "       ");
			//ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 4, 95, pmodeindex);
			page_refresh = !page_refresh;
		}else{
			ReefAngel.Refresh();// not really refreshing the page is to avoid a blank screen
		if(ReefAngel.Joystick.IsUp())
			switch(setup_dcpump_option)
			case SETUP_DCPUMP_MODE:
					pmodeindex--;
					if(pmodeindex<0){
						pmodeindex=14;
				break;
			case SETUP_DCPUMP_DURATION:
					pduration++;
					if(pduration>99){
						pduration=0;
				break;
			case SETUP_DCPUMP_SPEED:
					pspeed++;
					if(pspeed>99){
						pspeed=0;
				break;
			case SETUP_DCPUMP_THRESHOLD:
					pthreshold++;
					if(pthreshold>99){
						pthreshold=0;
				break;
		if(ReefAngel.Joystick.IsDown())
					pmodeindex++;
					if(pmodeindex>14){
						pmodeindex=0;
				break;
					pduration--;
					if(pduration<0){
						pduration=99;
				break;
					pspeed--;
					if(pspeed<0){
						pspeed=99;
				break;
					pthreshold--;
					if(pthreshold<0){
						pthreshold=99;
				break;
		if(ReefAngel.Joystick.IsLeft())
			setup_dcpump_option--;
			if (setup_dcpump_option>SETUP_DCPUMP_OK)
				setup_dcpump_option=SETUP_DCPUMP_OK;
		if(ReefAngel.Joystick.IsRight())
			setup_dcpump_option++;
				setup_dcpump_option=SETUP_DCPUMP_MODE; //The first option. since im testing Cancel is the first option
		if(ReefAngel.Joystick.IsButtonPressed())
			if(setup_dcpump_option==SETUP_DCPUMP_OK||setup_dcpump_option==SETUP_DCPUMP_CANCEL)
				if(setup_dcpump_option==SETUP_DCPUMP_OK)
					// COMMIT THE CHANGES HERE
					//ReefAngel.DCPump.UseMemory=true;
					InternalMemory.DCPumpMode_write(pmodeindex);
					//ReefAngel.DCPump.Mode=pmodeindex;
					InternalMemory.DCPumpSpeed_write(pspeed);
					//ReefAngel.DCPump.Speed=pspeed;
					InternalMemory.DCPumpDuration_write(pduration);
					//ReefAngel.DCPump.Duration=pduration;
					InternalMemory.DCPumpThreshold_write(pthreshold);
					//ReefAngel.DCPump.Threshold=pthreshold;
					ReefAngel.DisplayedMenu = ALT_SCREEN_MODE; //Go Back to Menu
					//ReefAngel.DisplayedMenu=DEFAULT_MENU;// Go Back to Main Screen
				}else{
				done=true;
	}while(!done);
// Not using code below at the moment
void WaterFill(bool stat)
	if(stat = 0){
	else{
void saving_stuff(){
	int pmode;
	switch (ReefAngel.DCPump.Mode)
	case Constant:
			pmode=0;
			break;
	case Lagoon:
			pmode=1;
			break;
	case ReefCrest:
			pmode=2;
			break;
	case ShortPulse:
			pmode=3;
			break;
	case LongPulse:
			pmode=4;
			break;
	case NutrientTransport:
			pmode=5;
			break;
	case TidalSwell:
			pmode=6;
			break;
	case Feeding_Start:
			pmode=7;
			break;
	case Feeding_Stop:
			pmode=8;
			break;
	case Night:
			pmode=9;
			break;
	case Storm:
			pmode=10;
			break;
	case Custom:
			pmode=11;
			break;
	case Else:
			pmode=12;
			break;
	case Sine:
			pmode=13;
			break;
	case Gyre:
			pmode=14;
			break;
