Icecool2's PDE
PostPosted: Wed Aug 19, 2015 4:44 pm
I'm getting my tank up and running again and to my dismay, I'm having a heck of a time getting my code onto the RA.
First off, my old code no longer compiles with the current version of libraries. No big deal, I used the wizard to write new code. Really basic stuff. BUT it is too big. How is that possible? I can't have the RA do it's basic functions and have the code fit on the thing anymore? Maybe I'm missing something.
Here's my code:
//#include <Salinity.h>
// Port 1: Return Pump
// Port 2: Dead
// Port 3: Skimmer
// Port 4: Heater
// Port 5: Kessil
// Port 6: Wavemaker
// Port 7: Sump Light
// Port 8: Unused
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.FeedingModePorts = Port1Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port6Bit;
    //ReefAngel.OverheatShutoffPorts = 0;
   // ReefAngel.OverheatProbe = T1_PROBE;
    //InternalMemory.OverheatTemp_write( 869 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardHeater( Port4,751,761 );
    ReefAngel.StandardLights( Port5,9,0,19,0 );
    //ReefAngel.Wavemaker( Port6,60 );
    ReefAngel.PWM.SetDaylight( PWMParabola(11,0,18,0,13,50,13) );
    ReefAngel.PWM.SetActinic( PWMParabola(9,0,19,0,13,100,13) );
I commented out everything I could think of and I'm still too large.
PostPosted: Wed Aug 19, 2015 5:05 pm
Remove the standard menu.
PostPosted: Wed Aug 19, 2015 5:35 pm
Closer, but still too big.
Is there a more compact function for ramping the LEDs? This is for a Kessil, perhaps there's a library for that? Removing both gets me just under the limit.
PostPosted: Thu Aug 20, 2015 4:16 am
I see there's a "new" bootloader available "optiboot". That frees up 2k of space. I'd have to buy a ISP, but that's only $10.
My concern is that even with that extra 2k I get back, I still won't be able to use any additional modules. Like the Wifi module.
PostPosted: Thu Aug 20, 2015 8:33 am
It still needs ISP.
You can send it back and I can burn the new bootloader if you would like to.
You can also dowgrade to an earlier release libraries:
https://github.com/reefangel/Libraries/releases
PostPosted: Thu Aug 20, 2015 8:46 am
I ordered the ISP. Should be here Saturday.
Do the earlier libraries include the Wizard? How many versions back do you suggest I try to fit in the 32k?
PostPosted: Thu Aug 20, 2015 8:48 am
The libraries version should be independent of the wizard for the most part, unless you try to use a feature that wasn't added in the previous version of the libraries.
I think if you go to 1.0.8, you should be good.
PostPosted: Thu Aug 20, 2015 8:53 am
I dropped back to 1.0 and it is under 29k now with Wifi enabled. Looks like I don't need that ISP after all.
PostPosted: Thu Aug 20, 2015 9:02 am
Just tried 1.0.8 and still good. 28.2k with everything turned on.
Thanks for the help!
Return to My PDE/INO file
