My PDE/INO File - question/debug
Posted: Thu Sep 03, 2015 8:58 am
by saf1
Hi everyone.
Wondering if anyone can spot anything obvious without spending too much time with regards to my current code base. I have a 40 gallon breeder with two RW4's on either side, about middle height in tank. Anyway as the day wore on I noticed that it got a bit turbulent and/or violent with regards to water movement with the last if statement that is doing the nutrient export showing pwm A and pwm D at 184% (not sure how) and causing a 2 to 4 inch wave in my little tank. While it looked super cool that wave was really huge and almost made it out of the tank before I caught it...
I was adding in the weather/storm lighting routine and then did the various flow patterns but don't see how I can get so much movement unless I somehow have the pwm for lights mixed in with DCPumps. I overrode the pwm a and b last night and manually set to 25 or 27 to stop it. I just canceled and the two both shot up to 184% again :(
So I have something goofy going on and the flow is way too much for the tank. Anyway if it is obvious let me know. Otherwise I'll try and swap around the flow patterns after each upload and see if I can find out the cause.
#include <Moon.h>
#include <Tide.h>  // testing for tide control
Tide tide;  // testing for tide control
byte  PWMChannel[6];
    ReefAngel.Use2014Screen();
    ReefAngel.AddPHExpansion(); // pH Expansion Module
 ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
 ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
 ReefAngel.OverheatShutoffPorts = Port2Bit;
 ReefAngel.Relay.On( Port1 );  // skimmer
 // ReefAngel.Relay.On( Port4 );  // LED Fans
 ReefAngel.Relay.On( Port5 );  // RW 4 left side facing tank
 ReefAngel.Relay.On( Port6 );  // RW 4 right side facing tank
    ReefAngel.CustomLabels[0]="Heater";
    ReefAngel.CustomLabels[1]="SumpFan";
    ReefAngel.CustomLabels[2]="Alk";
    ReefAngel.CustomLabels[3]="Calcium";
    ReefAngel.CustomLabels[4]="FugeLight";
    ReefAngel.CustomLabels[5]="Swabbie";
    ReefAngel.CustomLabels[6]="FanLight";
    ReefAngel.CustomLabels[7]="FanLight2";
    ReefAngel.StandardLights( Port2,9,0,21,0 ); // power to LED power supply
    ReefAngel.StandardLights( Port4,9,0,21,0 ); // LED fans
 // Testing tidal function
if (tide.isIncoming()) {
 ReefAngel.DCPump.DaylightChannel = AntiSync;
else {
//    ReefAngel.StandardHeater( Port1,760,780 );
//    ReefAngel.StandardFan( Port2,810,820 );
//    ReefAngel.DosingPumpRepeat( Port3,0,120,60 );
//    ReefAngel.DosingPumpRepeat( Port4,1,120,60 );
//    ReefAngel.StandardLights( Port5,23,0,15,0 );
//    ReefAngel.DosingPumpRepeat( Port6,0,240,120 );
//    ReefAngel.StandardLights( Port7,12,0,23,30 );
//    ReefAngel.StandardLights( Port8,12,0,23,30 );
    // Channel 0 (1000mA max) - 5 Neutral White
    PWMChannel[0]=PWMParabola(8,0,21,0,0,75,0);
    // Channel 1 (1000mA max) - 6 Royal Blue + 5 Blue
    PWMChannel[1]=PWMParabola(8,0,21,0,0,100,0);
    // Channel 2 (700mA max) - 12 Lime
    PWMChannel[2]=PWMParabola(8,0,21,0,0,65,0);
    // Channel 3 (700mA max) - 5 Violet UV + 4 Deep Red (660nm)
    PWMChannel[3]=PWMParabola(8,0,21,0,0,75,0);
    CheckCloud();
    ReefAngel.PWM.SetChannel(0,PWMChannel[0]);
    ReefAngel.PWM.SetChannel(1,PWMChannel[1]);
    ReefAngel.PWM.SetChannel(2,PWMChannel[2]);
    ReefAngel.PWM.SetChannel(3,PWMChannel[3]);
  if (hour()>=21 || hour()<=9)
// Sleep mode - slow things down
 ReefAngel.DCPump.SetMode( ReefCrest,25,10 );
if (hour()>=9 && hour()<11) {
    ReefAngel.DCPump.SetMode( TidalSwell,55,0 ); // Tidal Swell at 40% on sync mode
  else if (hour()>=11 && hour()<12) {
    ReefAngel.DCPump.SetMode( ReefCrest,40,10 ); // ReefCrest at 50% + - 20 on sync mode
  else if (hour()>=12 && hour()<13) {
    ReefAngel.DCPump.SetMode(Sine,40,10,30); // WaveMode on sync mode
  else if (hour()>=13 && hour()<14) {
    ReefAngel.DCPump.SetMode( ReefCrest,50,10 ); // ReefCrest at 50% + - 20 on sync mode
  else if (hour()>=15 && hour()<18) {
    ReefAngel.DCPump.SetMode(Else,40,10 ); // Else on sync mode
  else if (hour()>=18 && hour()<21) {
    ReefAngel.DCPump.SetMode( NutrientTransport,40,20,3000 ); // Nutrient Transport on sync mode
 ReefAngel.Portal( "saf1" );
 ReefAngel.DDNS( "saf1-dns.myreefangel.com" ); // Your DDNS is saf1-saf1-dns.myreefangel.com.myreefangel.com
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 45
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 4
#define Start_Cloud_After NumMins(11,30)
#define End_Cloud_Before NumMins(21,30)
#define Lightning_Change_per_Cloud 65
 // Channels used by the actinic LEDs on the PWM Expansion module
 // These channels will not be dimmed when the cloud effect is triggered
 // Number is a binary form. B001100 means channel 2 and 3 are used for actinics
#define Actinic_Channels B000001
 // Channels used by the daylight LEDs on the PWM Expansion module
 // These channels will be used for the spike when lightning effect is triggered
 // Number is a binary form. B000011 means channel 0 and 1 are used for daylights
#define Daylight_Channels B000010
 static byte cloudchance=255;
 static byte cloudduration=0;
 static int cloudstart=0;
 static byte numclouds=0;
 static byte cloudindex=0;
 static int LastNumMins=0;
#ifdef forcecloudcalculation
 if (cloudchance==255)
#else
#endif
 cloudchance=random(100);
 // If we have cloud today
 if (cloudchance)
 lightningchance=random(100);
 if (cloudchance)
 //is it time for cloud yet?
 // let's go through all channels to pick which ones will be dimmed
 for (int a=0;a<6;a++)
 if (bitRead(Actinic_Channels,a)==0)
 // this will slope down the channel from the current PWM to 0 within 3minutes.
 // then it will stay at 0 for the duration of the cycle
 // and finally slope up from 0 to PWM value within 3 minutes
 // it is basically an inversed slope
 PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
 for (int b=0;b<6;b++)
 if (bitRead(Daylight_Channels,b)==1)
 else lightningstatus=0;
 if (lightningstatus) PWMChannel[b]=100;
 else PWMChannel[b]=0;
 //delay(10);
 PWMChannel[b]=20;
 cloudindex++;
 if (cloudindex < numclouds)
 int x=0;
 if ((cloudstart/60)>=10) x=11; else x=17;
 if ((cloudstart%60)>=10) x=29; else x=35;
 if (lightningchance)
 int x=0;
 if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
 if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
 ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
 cstart*=60;
 cend*=60;
 if (n>cend) return PWMStart;
Re: My PDE/INO File - question/debug
Posted: Mon Sep 07, 2015 8:05 am
by saf1
Maybe found the culprit.
I changed:
"ReefAngel.DCPump.SetMode( NutrientTransport,40,20,3000 );"
to:
"ReefAngel.DCPump.SetMode( NutrientTransport,40,20 );
And things seem to run a lot better and the RW's not spooling or reporting 184% on the portal or client. I don't recall what 3000 did as the last parameter with the NutrientTransport mode but once I removed it everything settled in. Only other change was at the beginning whereas I originally had:
if (hour() >=21 || hour()<=9
I've since changed it to "if (hour()>=21 || hour()<8)"
