DmnYnkee's Code
Posted: Tue Oct 20, 2015 7:28 pm
by DmnYnkee
My current code tweaked after move to Florida. Went from standard Oceanic 90 gallon before move, to SCA150 gallon, custom built into wall.
#include <SunLocation.h>
#include <Tide.h>
#include <Moon.h>
#include <WiFiAlert.h>
  SunLocation sl;
  int avgph[10];
    unsigned long totalavgph=0;
    byte avgindex=0;
      byte x;
      byte y = 2;
      char text[7];
      // *********** CHANGE TEMP READOUT COLOR DEPENDENT ON FAN AND HEATER STATUS ***********
      int TempColor;                                    // Color for drawing temperature
      boolean HeatOn = ReefAngel.Relay.Status(Port6);   // Get the status of the heater relay
      if (HeatOn)
        TempColor = COLOR_NAVY;                         // Blue text, too cold, heater is on
      if (!HeatOn)
          TempColor = COLOR_GREEN;                      // Green text, no fan or heater on
           int pHColor;                                 // Color for drawing pH
      boolean LowpH = (ReefAngel.Params.PH < 780) ;     // Check for Low pH Value
      boolean HighpH = (ReefAngel.Params.PH > 850);     // Check for High pH Value
      if (LowpH)
        pHColor = COLOR_NAVY;                          // Blue text, Low pH value
      if (HighpH)
        pHColor = COLOR_RED;                           // Red text, High pH value
      if (!LowpH && !HighpH)
        pHColor = COLOR_GREEN;                         // Green text, pH acceptable
      ReefAngel.LCD.DrawLargeText(COLOR_DARKSLATEBLUE,DefaultBGColor, 6, 3, " Thunder Reef",Font8x8);   // Put a banner at the top
      ReefAngel.LCD.DrawDate(6, 119);        // Put the date and time at the bottom
      ReefAngel.LCD.Clear(COLOR_BLACK, 1, 12, 132, 12);                                                 // Draw a cyan line under the banner
      x = 6;
      y += MENU_START_ROW*1.4;        // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
      ReefAngel.LCD.DrawLargeText(COLOR_BLUE, COLOR_WHITE, x, y+1, " Temp      pH");
      ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10);                                    // Get T1 temp and convert
      x = 2;
      y += MENU_START_ROW*1.6;
      ReefAngel.LCD.DrawHugeNumbers(COLOR_BLACK, TempColor, x, y, text);                                // Draw the temperature, white numbers on a colored background
      ConvertNumToString(text, ReefAngel.Params.PH, 100);                                               // Get pH reading and convert
      x = 2;
      y = MENU_START_ROW*2.6;
      ReefAngel.LCD.DrawHugeNumbers(COLOR_YELLOW, pHColor, x+65, y+6, text);                            // Put pH on the screen
      x += 6;
      y += MENU_START_ROW*3.3;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"Sump Level",Font8x8);      // Draw the Sump Float switch status
    ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_RED);
  } else {
    ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_GREEN);
  x += 6;
  y += MENU_START_ROW*2.0;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"Skimmer Cup",Font8x8);     // Draw the Skimmer Cup Float switch status
  if (ReefAngel.LowATO.IsActive()) {
  } else {
      byte TempRelay = ReefAngel.Relay.RelayData;                                          // Code for drawing the relay box
      ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
    ReefAngel.Init();        //Initialize controller
    ReefAngel.Use2014Screen();                                                               // Let's use 2014 Screen
    ReefAngel.FeedingModePorts = Port5Bit | Port7Bit;                                        // Ports toggled in Feeding Mode
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port7Bit | Port8Bit;                  // Ports toggled in Water Change Mode
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;                                // Ports toggled when Lights On / Off menu entry selected
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit;   // Ports turned off when Overheat temperature exceeded
    ReefAngel.TempProbe = T1_PROBE;                                                          // Use T1 probe as temperature and overheat functions
    InternalMemory.OverheatTemp_write( 830 );                                                // Set the Overheat temperature setting
    ReefAngel.Relay.On( Port7 );
    sl.Init(28.5708, -81.6995);    // Lat/long for Clermont, FL
    sl.SetOffset(-3,0,-3,0);       // rise_hour, rise_seconds, set_hour, set_seconds (set 1 hr later for better viewing time)
    randomSeed(now()%SECS_PER_DAY);
      //Custom Variable [0] =  Month/Season
    ReefAngel.CustomLabels[0]="Return";
    ReefAngel.CustomLabels[1]="Daylights";
    ReefAngel.CustomLabels[2]="Actinics";
    ReefAngel.CustomLabels[3]="Fuge Light";
    ReefAngel.CustomLabels[4]="Reactor";
    ReefAngel.CustomLabels[5]="Heater";
    ReefAngel.CustomLabels[6]="Skimmer";
    ReefAngel.CustomLabels[7]="ATO";
    ReefAngel.ReverseATOHigh();
    // seasonal temperatures
    SeasonalTemps();
    ReefAngel.DayLights( Port2 );             // ATI DayLights (White+Purple)  On 120 min after sunrise, off 120 min before sunset.
    ReefAngel.ActinicLights( Port3 );         // ATI Actinic+ Lights (Blues).   On at sunrise, off at sunset.
    ReefAngel.MoonLights( Port4 );            // Refugium light.  On 120 min before sunset, off 150 min after sunrise.
if (hour()>=8 && hour()<10)
 ReefAngel.PWM.SetDaylight( LongPulseMode(0,60,5,true) ); // Long pulse at 60% with 5s pulse on sync mode
 ReefAngel.PWM.SetActinic( LongPulseMode(0,60,5,false) ); // Long pulse at 60% with 5s pulse on Anti-sync mode
else if (hour()>=10 && hour()<11)
 ReefAngel.PWM.SetDaylight( LongPulseMode(0,63,2,true) ); // Long pulse at 63% with 2s pulse on sync mode
 ReefAngel.PWM.SetActinic( LongPulseMode(0,63,2,false) ); // Long pulse at 63% with 2s pulse on Anti-sync mode
else if (hour()>=11 && hour()<12)
 ReefAngel.PWM.SetDaylight( ShortPulseMode(0,68,408,true) ); // Short pulse at 68% with 408ms pulse on sync mode (3/4" surface wave)
 ReefAngel.PWM.SetActinic( ShortPulseMode(0,68,408,false) ); // Short pulse at 68% with 408ms pulse on Anti-sync mode (3/4" surface wave)
else if (hour()>=12 && hour()<14)
 ReefAngel.PWM.SetDaylight( GyreMode(35,80,25,true) ); // Gyre 35% ramping up to 80% for 25 minutes on sync mode
 ReefAngel.PWM.SetActinic( GyreMode(35,80,25,false) ); // Gyre 35% ramping up to 80% for 25 minutes on Anti-sync mode
else if (hour()>=14 && hour()<15)
 ReefAngel.PWM.SetDaylight( ShortPulseMode(0,72,408,true) ); // Short pulse at 72% with 408ms pulse on sync mode (1" surface wave)
 ReefAngel.PWM.SetActinic( ShortPulseMode(0,72,408,false) ); // Short pulse at 72% with 408ms pulse on Anti-sync mode (1" surface wave)
else if (hour()>=15 && hour()<17)
else if (hour()>=17 && hour()<18)
 ReefAngel.PWM.SetDaylight( LongPulseMode(38,75,3,true) ); // Long pulse at 38%/75% with 3s pulse on sync mode (Nutrient transport mode)
 ReefAngel.PWM.SetActinic( LongPulseMode(38,75,3,false) ); // Long pulse at 38%/75% with 3s pulse on Anti-sync mode (Nutrient transport mode)
else if (hour()>=18 && hour()<19)
 ReefAngel.PWM.SetDaylight( LongPulseMode(0,63,5,true) ); // Long pulse at 63% with 5s pulse on sync mode
 ReefAngel.PWM.SetActinic( LongPulseMode(0,63,5,false) ); // Long pulse at 63% with 5s pulse on Anti-sync mode
else if (hour()>=19 && hour()<20)
 ReefAngel.PWM.SetDaylight( LongPulseMode(0,60,10,true) ); // Long pulse at 60% with 10s pulse on sync mode
 ReefAngel.PWM.SetActinic( LongPulseMode(0,60,10,false) ); // Long pulse at 60% with 10s pulse on Anti-sync mode
 ReefAngel.PWM.SetDaylight( ReefCrestMode(46,10,true) ); // reefcrest at 46% +/- 10% on sync mode  (night Mode)
 ReefAngel.PWM.SetActinic( ReefCrestMode(46,10,true) ); // reefcrest at 46% +/- 10% on sync mode  (night mode)
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
 ReefAngel.PWM.SetActinic(0);
 ReefAngel.PWM.SetDaylight(0);
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE )
 ReefAngel.PWM.SetActinic(35);
 ReefAngel.PWM.SetDaylight(35);
//    if(ReefAngel.LowATO.IsActive())           //  Float switch in Skimmer Cup
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.Off(Port7);               //  Turn off Skimmer when Cup full.
    ReefAngel.SingleATO(false,Port8,180,1);   //  Sump switch.  If ATO runs for 180 seconds, then shut off and send alert. Max times on is 1 per hour for bounce purposes.
    sl.CheckAndUpdate();  // handle updating sunrise and sunset values
    ReefAngel.Portal( "DmnYnkee" );
 void SeasonalTemps ()
  static int heatArray[][2] = { {792,796},// default in case of error in month=0 (June)
                    {770,774},//January (winter)
                    {774,778},//February (winter)
                    {775,779},//March (early spring)
                    {779,783},//April (spring)
                    {785,789},//May (spring)
                    {792,796},//June (early summer)
                    {799,803},//July (summer)
                    {806,810},//August (summer)
                    {796,800},//September (early fall)
                    {787,791},//October (fall)
                    {780,784},//November (fall)
                    {775,779} };//December (early winter)
  ReefAngel.StandardHeater( Port6,heatArray[month()][0],heatArray[month()][1]);
 }//end seasonalTemps
Re: DmnYnkee's Code
Posted: Wed Oct 21, 2015 1:25 pm
Pics or it didn't happen!
Re: DmnYnkee's Code
Posted: Wed Oct 21, 2015 4:17 pm
by DmnYnkee
It most definitely happened, haha! Still trying to figure out how to add pics to the forum. Looking like I can only add 3 at a time??
Re: DmnYnkee's Code
Posted: Wed Oct 21, 2015 4:25 pm
by DmnYnkee
These pics are all from the build. New tank has been up and running for about 3 months now. Have made many changes to sump and tank since I took these. Will take more pics later.
You can see my current stock list on Pinterest. https://www.pinterest.com/dmnynkee01/cu ... ium-stock/
Re: DmnYnkee's Code
Posted: Wed Oct 21, 2015 9:38 pm
Wow that looks awesome! Congrats on the new build. I really like the scape and the in-wall view.
Re: DmnYnkee's Code
Posted: Thu Oct 22, 2015 5:40 am
by DmnYnkee
The scape has grown a bit. That pic was taken early in the cycling process.
The main thing I am needing to do, is a lighting upgrade. I am still using the 4 bulb t5 fixture from the 90 gallon. There are so many options, that I can't commit to one enough to pull the trigger. I over think to a fault, lol.
The tank is only 24" in depth, with a 5' x 2' footprint, euro braced. I like the idea of Radions, but with the shallower depth, I would most likely only run them around 40% max, so why pay for 60% that I will not use.... I want controllability, and compatibility with the RA unit.
Re: DmnYnkee's Code
Posted: Thu Oct 22, 2015 2:33 pm
Buy chinese black boxes. If you want good ones check out the chinese blackbox led proof group on facebook. We can modify them for dimming control and you might be able to buy pre modified (not sure yet) as well. The group buy lights have a great spectrum and the admin's premium boxes are even better for like 20-30 more. They start at 99 and will grow everything. Dont waste tons of money for radions.
Re: DmnYnkee's Code
Posted: Thu Oct 22, 2015 3:10 pm
by DmnYnkee
Here are some scape pics as it is today.
Full
Full
Left side
Left side
Right side
Right side
Re: DmnYnkee's Code
Posted: Fri Oct 30, 2015 10:43 am
by DmnYnkee
Latest code.
Changes:
Updated from single ATO system to dual ATO system. ATO 1 (port 5) with RoDi/Kalk running from 8pm-8am, but only if pH is below 8.3 (failsafe), otherwise just RoDi on ATO 2 (port 8). Moved BRS dual reactor from port 5 to return pump port 1(always on).
Prior to implementing this change, pH was fluctuating from ~8.05 low at night, to ~8.35 daytime peak. Goal is to reduce .3 pH daily swing to <.2, with ideal results being <.15 (and still keep Alk/Ca/Mag within limits).
#include <Tide.h>
#include <Moon.h>
  SunLocation sl;
  int avgph[10];
    byte avgindex=0;
      byte x;
      byte y = 2;
      char text[7];
      if (HeatOn)
      if (!HeatOn)
      if (LowpH)
      if (HighpH)
      ReefAngel.LCD.Clear(COLOR_BLACK, 1, 12, 132, 12);                                                 // Draw a black line under the banner
      x = 6;
      x = 2;
      x = 2;
      x += 6;
  } else {
  x += 6;
  } else {
    ReefAngel.FeedingModePorts = Port7Bit;                                                   // Ports toggled in Feeding Mode
    ReefAngel.CustomLabels[4]="ATO Kalk";
    ReefAngel.CustomLabels[7]="ATO RoDi";
    SeasonalTemps();
    ReefAngel.MoonLights( Port4 );            // Refugium light.  On 120 min before sunset, off 120 min after sunrise.
 ReefAngel.PWM.SetDaylight( LongPulseMode(0,65,2,true) ); // Long pulse at 65% with 2s pulse on sync mode
 ReefAngel.PWM.SetActinic( LongPulseMode(0,65,2,false) ); // Long pulse at 65% with 2s pulse on Anti-sync mode
 ReefAngel.PWM.SetDaylight( ShortPulseMode(0,75,408,true) ); // Short pulse at 75% with 408ms pulse on sync mode (1" surface wave)
 ReefAngel.PWM.SetActinic( ShortPulseMode(0,75,408,false) ); // Short pulse at 75% with 408ms pulse on Anti-sync mode (1" surface wave)
 ReefAngel.PWM.SetDaylight( LongPulseMode(0,65,5,true) ); // Long pulse at 65% with 5s pulse on sync mode
 ReefAngel.PWM.SetActinic( LongPulseMode(0,65,5,false) ); // Long pulse at 65% with 5s pulse on Anti-sync mode
if(ReefAngel.LowATO.IsActive())           //  Float switch in Skimmer Locker
 ReefAngel.Relay.Off(Port7);               //  Turn off Skimmer when locker full.
if ((hour()>=20 || hour()<=8) && (ReefAngel.Params.PH < 830))
 ReefAngel.SingleATO(false,Port5,180,0);   //  Sump switch. Kalk schedule 8pm - 8am if pH < 8.3  If ATO/Kalk runs for 180 seconds, then shut off and send alert.
 ReefAngel.SingleATO(false,Port8,180,0);   //  Sump switch.  If ATO/RoDi runs for 180 seconds, then shut off and send alert.
Re: DmnYnkee's Code
Posted: Tue Dec 08, 2015 9:01 pm
by slm222
how is that ato code with the ph set level working for you? im interested in doing the same thing with a ato pump to kalk stirrer and a straight ato pump.
Re: DmnYnkee's Code
Posted: Fri Jan 01, 2016 3:03 pm
by DmnYnkee
It is working out well. I did have to modify the coding just a bit. Every couple of days, 1 or the other would turn on at switchover time, and would not shut off. By adding the Relay.Off coding, this issue has been eliminated. Thankfully, it did not cause a disaster.
 ReefAngel.Relay.Off(Port8);
 ReefAngel.Relay.Off(Port5);
Re: DmnYnkee's Code
Posted: Fri Jan 01, 2016 3:25 pm
by DmnYnkee
Current full code as of 1/1/16.
Recent changes:
Adjusted monthly temperatures
Adjusted Flow speeds
Added auto feeding
#include <Tide.h>
#include <Moon.h>
  SunLocation sl;
  int avgph[10];
    byte avgindex=0;
      byte x;
      byte y = 2;
      char text[7];
      if (HeatOn)
      if (!HeatOn)
      if (LowpH)
      if (HighpH)
      x = 6;
      x = 2;
      x = 2;
      x += 6;
  {ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_RED);
  x += 6;
  if (ReefAngel.LowATO.IsActive()) {ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_GREEN);
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;       // Ports toggled in Feeding Mode
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;       // Ports toggled in Water Change Mode
    // Delayed start for skimmer to allow sump level to return to normal after water change or feed mode
    ReefAngel.Relay.DelayedOn( Port7,4 );
    SeasonalTemps();
 ReefAngel.PWM.SetDaylight( LongPulseMode(0,70,4,true) ); // Long pulse at 70% with 4s pulse on sync mode
 ReefAngel.PWM.SetActinic( LongPulseMode(0,70,4,false) ); // Long pulse at 70% with 4s pulse on Anti-sync mode
 ReefAngel.PWM.SetDaylight( LongPulseMode(0,73,2,true) ); // Long pulse at 73% with 2s pulse on sync mode
 ReefAngel.PWM.SetActinic( LongPulseMode(0,73,2,false) ); // Long pulse at 73% with 2s pulse on Anti-sync mode
 ReefAngel.PWM.SetDaylight( ShortPulseMode(0,78,408,true) ); // Short pulse at 78% with 408ms pulse on sync mode (3/4" surface wave)
 ReefAngel.PWM.SetActinic( ShortPulseMode(0,78,408,false) ); // Short pulse at 78% with 408ms pulse on Anti-sync mode (3/4" surface wave)
else if (hour()>=12 && hour()<13)
 ReefAngel.PWM.SetDaylight( ShortPulseMode(0,85,408,true) ); // Short pulse at 85% with 408ms pulse on sync mode (1" surface wave)
 ReefAngel.PWM.SetActinic( ShortPulseMode(0,85,408,false) ); // Short pulse at 85% with 408ms pulse on Anti-sync mode (1" surface wave)
else if (hour()>=13 && hour()<14)
 ReefAngel.PWM.SetDaylight( ShortPulseMode(30,90,408,true) ); // Short pulse at 30%/90% with 408ms pulse on sync mode (1" surface wave)
 ReefAngel.PWM.SetActinic( ShortPulseMode(30,90,408,false) ); // Short pulse at 30%/90% with 408ms pulse on Anti-sync mode (1" surface wave)
 ReefAngel.PWM.SetDaylight( ShortPulseMode(0,80,408,true) ); // Short pulse at 80% with 408ms pulse on sync mode (3/4" surface wave)
 ReefAngel.PWM.SetActinic( ShortPulseMode(0,80,408,false) ); // Short pulse at 80% with 408ms pulse on Anti-sync mode (3/4" surface wave)
 ReefAngel.PWM.SetDaylight( ShortPulseMode(0,75,408,true) ); // Short pulse at 75% with 408ms pulse on sync mode (1/2" surface wave
 ReefAngel.PWM.SetActinic( ShortPulseMode(0,75,408,false) ); // Short pulse at 75% with 408ms pulse on Anti-sync mode (1/2" surface wave)
 ReefAngel.PWM.SetDaylight( LongPulseMode(38,89,3,true) ); // Long pulse at 38%/89% with 3s pulse on sync mode (Nutrient transport mode)
 ReefAngel.PWM.SetActinic( LongPulseMode(38,89,3,false) ); // Long pulse at 38%/89% with 3s pulse on Anti-sync mode (Nutrient transport mode)
 ReefAngel.PWM.SetDaylight( LongPulseMode(0,75,2,true) ); // Long pulse at 75% with 2s pulse on sync mode
 ReefAngel.PWM.SetActinic( LongPulseMode(0,75,2,false) ); // Long pulse at 75% with 2s pulse on Anti-sync mode
 ReefAngel.PWM.SetDaylight( ReefCrestMode(60,15,true) ); // reefcrest at 60% +/- 15% on sync mode       (night Mode)
 ReefAngel.PWM.SetActinic( ReefCrestMode(60,15,false) ); // reefcrest at 60% +/- 15% on Anti-sync mode  (night mode)
 ReefAngel.PWM.SetActinic( LongPulseMode(0,60,1,false) );
 ReefAngel.PWM.SetDaylight( LongPulseMode(0,60,1,true) );
// enter feeding mode at 11:30am & 5pm
 if ( (hour()==11 && minute()==30 && second()==0) || (hour()==17 && minute()==0 && second()==0))
 ReefAngel.FeedingModeStart(); // turn on feeding mode
 ReefAngel.SingleATO(false,Port5,210,0);   //  Sump switch. Kalk schedule 8pm - 8am if pH < 8.3  If ATO/Kalk runs for 210 seconds, then shut off and send alert.
 ReefAngel.SingleATO(false,Port8,210,0);   //  Sump switch.  If ATO/RoDi runs for 210 seconds, then shut off and send alert.
  static int heatArray[][2] = { {802,806},// default in case of error in month=0 (June)
                    {783,787},//January (winter)
                    {786,790},//February (winter)
                    {789,793},//March (early spring)
                    {794,798},//April (spring)
                    {798,802},//May (spring)
                    {802,806},//June (early summer)
                    {806,810},//July (summer)
                    {810,814},//August (summer)
                    {806,810},//September (early fall)
                    {799,803},//October (fall)
                    {794,798},//November (fall)
                    {788,792} };//December (early winter)
Re: DmnYnkee's Code
Posted: Thu Jan 21, 2016 4:09 pm
by slm222
Great. I am trying it tonight with my reactor!
Re: DmnYnkee's Code
Posted: Thu Jan 21, 2016 9:12 pm
by slm222
I don't understand how this is working for you.. I put it in my code and now neither pump is working. did you include anything else than
if ((hour()>=20 && hour()<=8) && (ReefAngel.Params.PH < 825))
ReefAngel.SingleATO( true,Port7,480,0 ); // Sump switch. Kalk schedule 8pm - 8am if pH < 8.3 If ATO/Kalk runs for 210 seconds, then shut off and send alert.
ReefAngel.SingleATO( true,Port8,480,0 ); // Sump switch. If ATO/RoDi runs for 210 seconds, then shut off and send alert.
Re: DmnYnkee's Code
Posted: Fri Jan 22, 2016 6:14 am
See my comment on your other thread
Re: DmnYnkee's Code
Posted: Fri Feb 12, 2016 11:21 am
by DmnYnkee
you need the ||.
