troylong45 ino
PostPosted: Wed Jan 27, 2016 10:59 pm
does this need to be in the loop(i guess its loop ) for cloud to work i dont see this in ur code lee but its in the old one u did for me months ago
CheckCloud(); // Apply cloud routine(SRY IS IN CODE)
ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue); // Override Channel 1 with the result from the Cloud operation
PostPosted: Wed Jan 27, 2016 11:21 pm
You should have the SetChannelRaw in updateLED and you most certainly do need CheckCloud in loop and I most certainly do have it in mine.
PostPosted: Wed Jan 27, 2016 11:23 pm
You have it in the code you posted...did you remove it?
PostPosted: Thu Jan 28, 2016 12:19 am
sry i over looked the check cloud i see it.
ok so those do not need added..
its beond me lol im differently able to under stand the writing a little more then my first day im guessing its something i screwed up the link between cloud/storm and dimming or something maybe if i swap the storm cloud from this one
    #include <SunLocation.h>
    SunLocation sun;
    int DaylightPWMValue=0;        // For cloud code
    int Latitude=-18;
    int Longitude=147;
        ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
        sun.Init(Latitude,Longitude);
        void CheckCloud()
        #define Clouds_Every_X_Days 1
        #define Min_Cloud_Duration 7
        #define Max_Cloud_Duration 7
        #define Min_Clouds_per_Day 1
        #define Max_Clouds_per_Day 2
        #define Start_Cloud_After NumMins(12,00)
          // Add Random Lightning modes
        #define Calm 0    // No lightning
        #define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
        #define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
        #define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
        #define Mega2 4   // Like Mega, but with more lightning
          // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
          // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
          byte LightningModes[] = {Mega2,Mega,Mega};
          static byte cloudchance=255;
          static byte cloudduration=0;
          static int cloudstart=0;
          static byte numclouds=0;
          static byte cloudindex=0;
          static int LastNumMins=0;
          static byte lightningMode=0;
          static time_t DelayCounter=millis();    // Variable for lightning timing.
          static int DelayTime=random(1000);      // Variable for lightning timimg.
        #ifdef forcecloudcalculation
          if (cloudchance==255)
        #else
        #endif
              randomSeed(millis());    // Seed the random number generator
              cloudchance=random(100);
              // If we have cloud today
              if (cloudchance)
                lightningchance=random(100);
          if (cloudchance)
            //is it time for cloud yet?
              if (chooseLightning)
                chooseLightning=false;
              switch (lightningMode)
              case Calm:
                break;
              case Mega:
                // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
                  // Send the trigger
                  Strike();
                  DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
                  DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
                break;
              case Mega2:
                // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
                  Strike();
                break;
              case Fast:
                  Strike();
                break;
              case Slow:
                // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
                  else lightningstatus=0;
                  if (lightningstatus)
                    DaylightPWMValue=4095;
                    DaylightPWMValue=0;
                  delay(1);
                break;
              default:
                break;
              cloudindex++;
              if (cloudindex < numclouds)
              int x=0;
              else x=17;
              else x=35;
            ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
            if (lightningchance)
              int x=0;
              else x=57;
              ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
              else x=75;
        void Strike()
          int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
          for (int i=0; i<a; i++)
            // Flash on
            int newdata=4095;
            Wire.beginTransmission(0x40);      // Address of the dimming expansion module
            Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
            Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
            Wire.write(newdata>>8);            // This sends the MSB
            Wire.endTransmission();
            int randy=random(20,80);    // Random number for a delay
            if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
            delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
            // Flash off.  Return to baseline.
            newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
            Wire.beginTransmission(0x40);    // Same as above
            delay(random(30,50));                // Wait from 30 to 49 ms
            wdt_reset();    // Reset watchdog timer to avoid re-boots
          cstart*=60;
          cend*=60;
        ReefAngel.DayLights( Port2 );
        ReefAngel.Relay.DelayedOn( Port4 );
        ReefAngel.Relay.Set(Port5, ReefAngel.HighATO.IsActive());
        ReefAngel.SingleATOLow( Port7 );
        ReefAngel.PWM.SetChannel(0,0); // Make sure we're at 0% at night
        ReefAngel.PWM.Channel0PWMParabola(); // Set Channel0 based on Parabola and Memory values
        ReefAngel.PWM.Channel1PWMParabola(); // Set Chanenl1 based on Parabola and Memory values
        sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
        DaylightPWMValue=ReefAngel.PWM.GetChannelValueRaw(1); // Get the current value of channel 1
        ReefAngel.Portal( "troylong45" );
        ReefAngel.DDNS( "209.18.47.61" ); // Your DDNS is troylong45-209.18.47.61.myreefangel.com
PostPosted: Fri Jan 29, 2016 6:07 pm
ok i put this code above and changed the cloud and effect channel to work and storm is working but what is the issue with the storm in the ino i copyed and edited from yous lee if maybe i can just add the effects switch to this code below to activate at will.
    #include <Tide.h>
    #include <WiFiAlert.h>
    // Won't compile without this...
    // ReefAngel.DCPump.UseMemory=true;
    // Custom menus
    #include <avr/pgmspace.h>
    prog_char menu1_label[] PROGMEM = "Feeding Mode";
    menu4_label, menu5_label, menu6_label
    // Define Custom Memory Locations
    #define Mem_I_Latitude        108
    #define Mem_I_Longitude       110
    #define Mem_B_AcclRiseOffset  112
    #define Mem_B_AcclSetOffset   113
    #define Mem_B_AcclDay         114
    #define Mem_B_LightMode       160
    #define Mem_B_LightOffset     161
    #define Mem_I_RiseOffset      162
    #define Mem_I_SetOffset       164
    #define Mem_B_AcclActinicOffset     166
    #define Mem_B_AcclDaylightOffset    167
    #define Mem_B_LightsOffPerc   171
    #define Mem_B_EnableStorm     178
    #define Mem_B_PrintDebug      198
    #define Mem_B_ResetMemory     199
    void init_memory() {
      // Initialize Custom Memory Locations
      InternalMemory.write_int(Mem_I_Latitude,21);
      InternalMemory.write_int(Mem_I_Longitude,-73);
      InternalMemory.write(Mem_B_AcclRiseOffset,4);
      InternalMemory.write(Mem_B_AcclSetOffset,2);
      InternalMemory.write(Mem_B_AcclDay,0);
      InternalMemory.write(Mem_B_LightOffset,20);
      InternalMemory.write(Mem_B_LightMode,1);
      InternalMemory.write_int(Mem_I_RiseOffset,-1);
      InternalMemory.write_int(Mem_I_SetOffset,-1);
      InternalMemory.write(Mem_B_AcclActinicOffset,100);
      InternalMemory.write(Mem_B_AcclDaylightOffset,100);
      InternalMemory.write(Mem_B_LightsOffPerc,1);
      InternalMemory.write(Mem_B_EnableStorm,true);
      InternalMemory.write(Mem_B_ResetMemory,false);
    #define NUMBERS_8x16
    // Define Relay Ports by Name
    #define Return             1
    #define Heater             2
    #define WhiteLeft          3
    #define BlueLeft           4
    #define WhiteRight         5
    #define BlueRight          6
    #define Autotopoff         7
    #define Skimmer            8
    // Custom classes
    SunLocation sun;
    Tide tide;
    // For Cloud and preset code
    int ActinicPWMValue=0;
    int DaylightPWMValue0=0;        // For cloud code, channel 0
    int DaylightPWMValue2=0;        // For cloud code, chennel 2
    int ActinicPWMValue1=0;        // For cloud code, channel 0
    int ActinicPWMValue3=0;        // For cloud code, chennel 2
    // Needs to be global for DrawCustomGraph()
    int ScreenID=1;
    // Setup on controller startup/reset
      ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize Menu
      ReefAngel.FeedingModePorts = Port1Bit | Port2Bit;
      ReefAngel.WaterChangePorts = Port1Bit | Port2Bit  | Port7Bit  | Port8Bit;
      ReefAngel.LightsOnPorts = Port3Bit | Port5Bit;
    ReefAngel.Relay.On( Port1 ); // Return Pump
      if (InternalMemory.read(Mem_B_ResetMemory))
        init_memory();
    ReefAngel.SingleATOLow( Port7 ); // Auto top off
    ReefAngel.Relay.Set(Port8, ReefAngel.HighATO.IsActive()); // Skimmer
    ReefAngel.DCPump.ExpansionChannel[4] = Sync; // Left Jebao RW4
    ReefAngel.DCPump.ExpansionChannel[5] = AntiSync; // Right Jebao RW4
      ReefAngel.StandardHeater(Heater);
      // Lighting and Flow
      SetSun();               // Setup Sun rise/set lighting
      AcclimateLED();         // Apply acclimation dimming
      LEDPresets();
      CheckCloud();           //  Check for cloud and lightning.
      UpdateLED();
    ReefAngel.DDNS( "1" ); // Your DDNS is troylong45-1.myreefangel.com
    void SetSun() {
      // Start acclimation routine
      int acclRiseOffset=InternalMemory.read(Mem_B_AcclRiseOffset)*60;
      int acclSetOffset=InternalMemory.read(Mem_B_AcclSetOffset)*60;
      byte acclDay=InternalMemory.read(Mem_B_AcclDay);
      // See if we are acclimating corals and decrease the countdown each day
      static boolean acclCounterReady=false;
      if (now()%SECS_PER_DAY!=0) acclCounterReady=true;
      if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) {
        acclDay--;
        InternalMemory.write(Mem_B_AcclDay,acclDay);
      // End acclimation
      // Add some customizable offsets
      sun.Init(InternalMemory.read_int(Mem_I_Latitude), InternalMemory.read_int(Mem_I_Longitude));
      int riseOffset=InternalMemory.read_int(Mem_I_RiseOffset);
      int setOffset=InternalMemory.read_int(Mem_I_SetOffset);
      sun.SetOffset(riseOffset,(acclDay*acclRiseOffset),setOffset,(-acclDay*acclSetOffset)); // Bahamas
      byte lightOffset=InternalMemory.read(Mem_B_LightOffset); // left right separation
      byte actinicOffset=InternalMemory.ActinicOffset_read();
      // Make sure light resets to zero at night.
      for(int i=0;i<4;i++) { ReefAngel.PWM.SetChannel(i,0); }
      switch(InternalMemory.read(Mem_B_LightMode)) {
        case 0: {
          // Daylights
          ReefAngel.PWM.Channel0PWMSlope(lightOffset,0);
          ReefAngel.PWM.Channel2PWMSlope(0,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMSlope(actinicOffset+lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMSlope(actinicOffset,actinicOffset+lightOffset);
          break;
        case 1: {
          // Daylights
          ReefAngel.PWM.Channel0PWMParabola(lightOffset,0);
          ReefAngel.PWM.Channel2PWMParabola(0,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMParabola(actinicOffset+lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMParabola(actinicOffset,actinicOffset+lightOffset);
          break;
      case 2: {
          // Daylights
          ReefAngel.PWM.Channel0PWMSmoothRamp(lightOffset,0);
          ReefAngel.PWM.Channel2PWMSmoothRamp(0,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMSmoothRamp(actinicOffset+lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMSmoothRamp(actinicOffset,actinicOffset+lightOffset);
          break;
      case 3: {
          // Daylights
          ReefAngel.PWM.Channel0PWMSigmoid(lightOffset,0);
          ReefAngel.PWM.Channel2PWMSigmoid(0,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMSigmoid(actinicOffset+lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMSigmoid(actinicOffset,actinicOffset+lightOffset);
          break;
      case 4: { // Reverse the actinics in the morning
          // Daylights
          ReefAngel.PWM.Channel0PWMParabola(lightOffset+actinicOffset,0);
          ReefAngel.PWM.Channel2PWMParabola(actinicOffset,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMParabola(lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMParabola(0,actinicOffset+lightOffset);
          break;
    void AcclimateLED() {
      if (acclDay > 0) {
        float acclActinicOffset=acclDay*(40.95*(((float)InternalMemory.read(Mem_B_AcclActinicOffset)/100)));
        float acclDaylightOffset=acclDay*(40.95*((float)InternalMemory.read(Mem_B_AcclDaylightOffset)/100));
        float endPerc;
        endPerc=40.95*InternalMemory.PWMSlopeEnd1_read();
        ReefAngel.PWM.SetChannelRaw(1,map(ReefAngel.PWM.GetChannelValueRaw(1),0,endPerc,0,endPerc-acclActinicOffset));
        endPerc=40.95*InternalMemory.PWMSlopeEnd3_read();
        ReefAngel.PWM.SetChannelRaw(3,map(ReefAngel.PWM.GetChannelValueRaw(3),0,endPerc,0,endPerc-acclActinicOffset));
        endPerc=40.95*InternalMemory.PWMSlopeEnd0_read();
        ReefAngel.PWM.SetChannelRaw(0,map(ReefAngel.PWM.GetChannelValueRaw(0),0,endPerc,0,endPerc-acclDaylightOffset));
        endPerc=40.95*InternalMemory.PWMSlopeEnd2_read();
        ReefAngel.PWM.SetChannelRaw(2,map(ReefAngel.PWM.GetChannelValueRaw(2),0,endPerc,0,endPerc-acclDaylightOffset));
    #define LED_1to1  Box1_Port1
    #define LED_4to1  Box1_Port2
    #define LED_3to1  Box1_Port3
    #define LED_2to1  Box1_Port4
    #define LED_BLUE  Box1_Port5
    #define LED_WHITE Box1_Port6
    #define LED_STORM Box1_Port8
    void resetRelayBox(byte ID) {
      // toggle all relays except for the one selected
      for (int i=Box1_Port1;i<=Box1_Port4;i++) {
        if (i!=ID) ReefAngel.Relay.Auto(i);
    void LEDPresets() {
      static byte lastPreset=0;
      DaylightPWMValue0=ReefAngel.PWM.GetChannelValueRaw(0);
      ActinicPWMValue1=ReefAngel.PWM.GetChannelValueRaw(1);
      DaylightPWMValue2=ReefAngel.PWM.GetChannelValueRaw(2);
      ActinicPWMValue3=ReefAngel.PWM.GetChannelValueRaw(3);
      DaylightPWMValue=ReefAngel.PWM.GetDaylightValueRaw();
      ActinicPWMValue=ReefAngel.PWM.GetActinicValueRaw();
      if (ReefAngel.Relay.isMaskOn(LED_1to1)) {
        if (lastPreset!=1) resetRelayBox(LED_1to1);
        DaylightPWMValue0=90*40.95;
        ActinicPWMValue1=10*40.95;
        DaylightPWMValue2=90*40.95;
        ActinicPWMValue3=10*40.95;
        lastPreset=1;
      if (ReefAngel.Relay.isMaskOff(LED_1to1)) {
        if (lastPreset!=2) resetRelayBox(LED_1to1);
        DaylightPWMValue0=10*40.95;
        ActinicPWMValue1=90*40.95;
        DaylightPWMValue2=10*40.95;
        ActinicPWMValue3=90*40.95;
        lastPreset=2;
      if (ReefAngel.Relay.isMaskOn(LED_2to1)) {
        if (lastPreset!=3) resetRelayBox(LED_2to1);
        DaylightPWMValue0=60*40.95;
        ActinicPWMValue1=40*40.95;
        DaylightPWMValue2=60*40.95;
        ActinicPWMValue3=40*40.95;
        lastPreset=3;
      if (ReefAngel.Relay.isMaskOff(LED_2to1)) {
        if (lastPreset!=4) resetRelayBox(LED_2to1);
        DaylightPWMValue0=40*40.95;
        ActinicPWMValue1=60*40.95;
        DaylightPWMValue2=40*40.95;
        ActinicPWMValue3=60*40.95;
        lastPreset=4;
      if (ReefAngel.Relay.isMaskOn(LED_3to1)) {
        if (lastPreset!=5) resetRelayBox(LED_3to1);
        DaylightPWMValue0=75*40.95;
        ActinicPWMValue1=25*40.95;
        DaylightPWMValue2=75*40.95;
        ActinicPWMValue3=25*40.95;
        lastPreset=5;
      if (ReefAngel.Relay.isMaskOff(LED_3to1)) {
        if (lastPreset!=6) resetRelayBox(LED_3to1);
        DaylightPWMValue0=25*40.95;
        ActinicPWMValue1=75*40.95;
        DaylightPWMValue2=25*40.95;
        ActinicPWMValue3=75*40.95;
        lastPreset=6;
      if (ReefAngel.Relay.isMaskOn(LED_4to1)) {
        if (lastPreset!=7) resetRelayBox(LED_4to1);
        DaylightPWMValue0=80*40.95;
        ActinicPWMValue1=20*40.95;
        DaylightPWMValue2=80*40.95;
        ActinicPWMValue3=20*40.95;
        lastPreset=7;
      if (ReefAngel.Relay.isMaskOff(LED_4to1)) {
        if (lastPreset!=8) resetRelayBox(LED_4to1);
        DaylightPWMValue0=20*40.95;
        ActinicPWMValue1=80*40.95;
        DaylightPWMValue2=20*40.95;
        ActinicPWMValue3=80*40.95;
        lastPreset=8;
      if (ReefAngel.Relay.isMaskOn(LED_BLUE)) {
        if (lastPreset!=9) resetRelayBox(LED_BLUE);
        lastPreset=9;
      if (ReefAngel.Relay.isMaskOff(LED_BLUE)) {
        if (lastPreset!=10) resetRelayBox(LED_BLUE);
        ActinicPWMValue1=0;
        ActinicPWMValue3=0;
        lastPreset=10;
      if (ReefAngel.Relay.isMaskOn(LED_WHITE)) {
        if (lastPreset!=11) resetRelayBox(LED_WHITE);
        ActinicPWMValue1=0;
        ActinicPWMValue3=0;
        lastPreset=11;
      if (ReefAngel.Relay.isMaskOff(LED_WHITE)) {
        if (lastPreset!=12) resetRelayBox(LED_WHITE);
        lastPreset=12;
    // Write updated values to the channels
    void UpdateLED() {
      ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue0);
      ReefAngel.PWM.SetChannelRaw(1,ActinicPWMValue1);
      ReefAngel.PWM.SetChannelRaw(2,DaylightPWMValue2);
      ReefAngel.PWM.SetChannelRaw(3,ActinicPWMValue3);
      ReefAngel.PWM.SetDaylightRaw(DaylightPWMValue);
      ReefAngel.PWM.SetActinicRaw(ActinicPWMValue);
      byte LightsOffPerc=40.95*InternalMemory.read(Mem_B_LightsOffPerc);
      if (ReefAngel.PWM.GetChannelValueRaw(0)>=LightsOffPerc) ReefAngel.Relay.On(WhiteLeft); else ReefAngel.Relay.Off(WhiteLeft);
      if (ReefAngel.PWM.GetChannelValueRaw(1)>=LightsOffPerc) ReefAngel.Relay.On(BlueLeft); else ReefAngel.Relay.Off(BlueLeft);
      if (ReefAngel.PWM.GetChannelValueRaw(2)>=LightsOffPerc) ReefAngel.Relay.On(WhiteRight); else ReefAngel.Relay.Off(WhiteRight);
      if (ReefAngel.PWM.GetChannelValueRaw(3)>=LightsOffPerc) ReefAngel.Relay.On(BlueRight); else ReefAngel.Relay.Off(BlueRight);
    // Menu Code
    void MenuEntry1() {
      ReefAngel.FeedingModeStart();
    void MenuEntry2() {
    void MenuEntry3() {
      ReefAngel.ATOClear();
    void MenuEntry4() {
      ReefAngel.OverheatClear();
    void MenuEntry5() {
      ReefAngel.SetupCalibratePH();
    void MenuEntry6() {
      ReefAngel.SetupDateTime();
    // Custom Main Screen
    void DrawCustomMain() {
      const int NumScreens=4;
      static boolean drawGraph=true;
      // Main Header
      // ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 35, 2,"Troy's Reef");
      ReefAngel.LCD.DrawDate(5,2);
      ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 128, 11);
      // Param Header
      DrawParams(5,14);
      switch (ScreenID) {
        case 0:
          if (drawGraph) { ReefAngel.LCD.DrawGraph(5,40); drawGraph=false; }
          break;
        case 1: { DrawStatus(5,40); break; }
        case 2: { DrawSunMoon(5,40); break; }
      // Draw Relays
      DrawRelays(12,94);
      // Date+Time
      // ReefAngel.LCD.DrawDate(5,122);
      if (ReefAngel.Joystick.IsLeft()) {
        ScreenID--; drawGraph=true;
      if (ReefAngel.Joystick.IsRight()) {
        ScreenID++; drawGraph=true;
    void DrawCustomGraph() {
      if (ScreenID==0)
        ReefAngel.LCD.DrawGraph(5, 40);
      char buf[16];
      // Temp and PH
      y+=2;
      y+=6;
      y+=5;
      int t=x;
      y+=12;
      // Display Acclimation timer
      if (acclDay > 0) {
        ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Acclimation Day:"); x+=100;
        ReefAngel.LCD.DrawSingleMonitor(acclDay,DefaultFGColor,x,y,1);
        ReefAngel.LCD.Clear(DefaultBGColor,x,y,128,y+8);
    void DrawSunMoon(int x, int y) {
      char buf[16];
      int t=x;
      y+=2;
      /// Display Sunrise / Sunset
      sprintf(buf, "%02d:%02d", sun.GetRiseHour(), sun.GetRiseMinute());
      ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Rise:"); x+=31;
      ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf);
      sprintf(buf, "%02d:%02d", sun.GetSetHour(), sun.GetSetMinute()); x+=36;
      ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Set:"); x+=25;
      y+=15; x=t;
    void DrawRelays(int x, int y) {
      // Draw Relays
    void DelayedOnModes(byte relay) {
      static unsigned long startTime=now();
      if ( (startTime==LastStart) && ReefAngel.HighATO.IsActive()) {
        ReefAngel.Relay.On(relay);
        ReefAngel.Relay.DelayedOn(relay);
     void CheckCloud()
        #else
        #endif
              if (cloudchance)
          if (cloudchance)
              case Calm:
                break;
              case Mega:
                  // Send the trigger
                  Strike();
                break;
              case Mega2:
                  Strike();
                break;
              case Fast:
                  Strike();
                break;
              case Slow:
                    DaylightPWMValue=0;
                  delay(1);
                break;
              default:
                break;
              cloudindex++;
              int x=0;
              else x=17;
              else x=35;
              int x=0;
              else x=57;
              else x=75;
        void Strike()
            // Flash on
            int newdata=4095;
            Wire.write(0x8+(4*0));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
            Wire.write(0x8+(4*2));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
            newdata=ReefAngel.PWM.GetChannelValueRaw(0);   // Use the channel number you're flashing here
          cstart*=60;
          cend*=60;
PostPosted: Fri Apr 08, 2016 11:23 am
hey lee some reason im not seeing storm on my lights i need to edit the storm i guess see anything wrong with it?
PostPosted: Fri Apr 08, 2016 11:37 am
wait i think i found the problem its says in storm code dont use less then 6 mins minimum for cloud and i was using 1min
PostPosted: Tue Aug 30, 2016 3:30 pm
If i want to set a max dc pump speed in this code how do i do that
PostPosted: Fri Sep 09, 2016 9:49 pm
Lnevo if i want water change mode to overide a relay marked Refugium to on then then water change is reset to off to return to it's auto state i tried this but I'm missing something it was a cut from ur ino.
void RefugiumLight() {if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) {
        ReefAngel.Relay.On(Refugium);} }
And would like relay Refugium Auto to be on opposit from relay WhiteLeft plus and minis X hours (which i will add into memory) to overlap ph
as well the Refugium menu option on the head unit is not cycling it
And i was looking at your code and seen "delayedmode" on skimmer and says "delayed on" after mode change I tried fiddling with it but didn't get it to work or compile . I want Return to delay on after feed mode only right now it is doing it after reboot,after wc, and after feed.
PostPosted: Sat Sep 10, 2016 1:35 pm
ReefAngel.Relay.Set(Refugium,!ReefAngel.Relay.Status(WhiteLeft));
Return to My PDE/INO file
