#define SIMPLE_MENU
#define DisplayLEDPWM
#define RelayExp
#define wifi
#define VersionMenu
#define PWMEXPANSION
#define CUSTOM_MAIN
#define NUMBERS_8x16
#define COLORS_PDE
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_Wifi.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_Salinity.h>
#include <ReefAngel_Colors.h>
byte PWMChannel[]={
0,0,0,0,0,0};
//Top Banner
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_SKYBLUE, 9, 2, " Harry's 120H Reef ");
ReefAngel.LCD.DrawDate(6, 123);
// Display Temp Text
ReefAngel.LCD.DrawText(0,255,8,12,"Temp");
// Display the T1 temp value
char text[7];
ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
ReefAngel.LCD.Clear(255, 4, 22, 37, 38);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 4, 22, text, Num8x16);
// Display Salt Text
ReefAngel.LCD.DrawText(0,255,54,12,"Salt");
// Display Salt Value
ReefAngel.LCD.Clear(255, 52, 22, 75, 38);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 52, 22, text, Num8x16);
// Display pH Text
ReefAngel.LCD.DrawText(0,255,112,12,"pH");
// Display pH Value
ReefAngel.LCD.Clear(255, 94, 22, 106, 38);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 94, 22, text, Num8x16);
// Display Actinic Percentage Text
ReefAngel.LCD.DrawText(0,255,8,40,"Blue LED %");
// Display Actinic Percentage Value
ConvertNumToString(text, PWMChannel[1], 1);
strcat(text," ");
ReefAngel.LCD.DrawText(0, 255, 80, 40, text);
// Display Daylight Percentage Text
ReefAngel.LCD.DrawText(0,255,8,50,"White LED %");
// Display Daylight Percentage Value
ConvertNumToString(text, PWMChannel[0], 1);
strcat(text," ");
ReefAngel.LCD.DrawText(0, 255, 80, 50, text);
// Display Moonlight Phase Text
ReefAngel.LCD.DrawText(0,255,8,60,"Moonlight ");
// Display Moonlight Phase Value
ConvertNumToString(text, PWMChannel[2], 1);
strcat(text," ");
ReefAngel.LCD.DrawText(0, 255, 80, 60, text);
ReefAngel.LCD.DrawOutletBox(13, 97, TempRelay);
ReefAngel.LCD.DrawOutletBox(13, 109, TempRelay);
ReefAngel.FeedingModePorts = B00110000;
ReefAngel.FeedingModePortsE[0] = B00110000;
ReefAngel.WaterChangePorts = B00111100;
ReefAngel.WaterChangePortsE[0] = B00110011;
ReefAngel.OverheatShutoffPorts = B00000011;
ReefAngel.LightsOnPorts = B00011110;
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port4);
// Wavemaker timer
ReefAngel.Timer[1].SetInterval(random(15,90));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port6);
// Specific functions
// T5 White
ReefAngel.StandardLights(Port1,10,30,20,0);
//T5 Blue
ReefAngel.StandardLights(Port2,9,30,20,45);
//LED Blue
ReefAngel.StandardLights(Port7,9,0,21,15);
//LED White
ReefAngel.StandardLights(Port8,10,0,20,30);
//Heater
ReefAngel.StandardHeater(Box1_Port3,773,783);
//Refugium
ReefAngel.StandardLights(Box1_Port4,21,0,7,0);
//Fan
ReefAngel.StandardLights(Box1_Port7,8,30,21,0);
//LED Moonlight
ReefAngel.StandardLights(Box1_Port8,20,45,7,30);
// Channel 0 = White
PWMChannel[0]=PWMSlope(10,0,20,30,0,100,30,PWMChannel[0]); // calculate slope %
// Channel 1 = Blue
PWMChannel[1]=PWMSlope(9,0,21,15,0,100,30,PWMChannel[1]); // calculate slope %
// Channel 2= Moonlights
PWMChannel[2]=MoonPhase(); // calculate moon phase %
// this section sends the data to the PWM expansion module
for (int a=0;a<4;a++)
ReefAngel.PWM.Expansion(a,int(2.55*PWMChannel[a]));
// Wavemaker
ReefAngel.Relay.Toggle(Box1_Port5);
ReefAngel.Relay.Toggle(Box1_Port6);
