Spotted's Code
PostPosted: Mon Feb 29, 2016 8:25 am
by Spotted
So here's my code. I have in here scheduled times for activating feed mode at 2 different times a day. It coincides with an automatic feeder that I've got. I haven't yet modified the auto feeder to be run by my Reef Angel, but that is in future plans. The timer on the auto feeder is not as accurate as the Reef Angel, so having my controller run it will be awesome!!
I have code in here to refill my ATO reservoir every 3 days for 2 hours (many thanks to lnevo for the help).
I really am just throwing this up here to help with BACKUP!! I lost a previous version of my code when a hard drive crashed on my back drive (ironic) :oops: .
I also want to thank everyone who has helped me develop this code. Not being a coder, this forum has greatly helped me in the care of my beloved fish. Thank you so very much!!
So here it is:
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.FeedingModePortsE[0] = Port3Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port3Bit;
    ReefAngel.LightsOnPortsE[0] = Port1Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.Relay.On( Port3 ); //Sump Powerhead. Main Relay Port 3
    ReefAngel.Relay.On( Port4 );//Display Lights
    ReefAngel.Relay.On( Port5 ); //Display Tank Power Heads MaiRelay Port 5
    ReefAngel.Relay.On( Port8 ); //Return Pump Relay 1 Port 8
    ReefAngel.Relay.On( Box1_Port1 ); //ATS Air Pump. Relay 2 Port 1
    ReefAngel.Relay.On( Box1_Port2 ); //Media Reactor. Relay 2 Port 2
    ReefAngel.Relay.On( Box1_Port3 ); //Aqualifter. Relay 2 Port 3
    ReefAngel.Relay.Off( Box2_Port8 );//Referencing Relay 3
    ReefAngel.SingleATOLow( Port1 );
    ReefAngel.Relay.DelayedOn( Port7 ); //Skimmer Relay 1 Port 7
    ReefAngel.MHLights( Box1_Port4 ); //ATS Light Relay 2 Port 4
    ReefAngel.DCPump.UseMemory = true; //ignore programming and use memory locations
    if ((now()%SECS_PER_DAY==31320)) //if it is 8:42 AM
    {ReefAngel.FeedingModeStart();} //START FEEDING MODE
    if ((now()%SECS_PER_DAY==67320)) //if it is 6:42 PM
    if (hour()>=22 || hour()<9)
    { // Sleep mode - slow things down
    ReefAngel.DCPump.SetMode( ReefCrest,25,10 );
    // Normal power
    ReefAngel.DCPump.SetMode( ReefCrest,50,10 );
    RefillATO();
    ReefAngel.Portal( "spotted" );
    ReefAngel.DDNS( "7730.homeip.net:2000" ); // Your DDNS is spotted-7730.homeip.net:2000.myreefangel.com
// Set this to the port your solenoid is on.
#define ROSolenoid Box2_Port1
void RefillATO() {
  static boolean refillActive=false; // Flag to determine if we've initiated the refill.
  static time_t startedAt=0;
  byte startAt=23;
  byte runFor=2;
  byte runEvery=3;
  if ( now()+(startAt*SECS_PER_HOUR) % (runEvery*SECS_PER_DAY)==0 ) {
    ReefAngel.Relay.Override(ROSolenoid,1); // We turn on the solenoid port.
    startedAt=now();
    refillActive=true;
  if ( now()-startedAt == runFor*SECS_PER_HOUR && refillActive) {
    ReefAngel.Relay.Override(ROSolenoid,0); // Back to automatic mode
    refillActive=true;
    startedAt=0;
