Expansion Reboots
PostPosted: Mon Aug 08, 2016 12:44 pm
by projectx
When I put the system into feeding mode or water change mode my expansion relay reboots.
I recent installed the RA + board, but have never had 2 expansions on this unit.
Any thoughts?
here is my code
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePortsE[0] = Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit | Port6Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port7 );
ReefAngel.CustomLabels[0]="Return";
ReefAngel.CustomLabels[1]="Skimmer";
ReefAngel.CustomLabels[2]="";
ReefAngel.CustomLabels[3]="SumpHeater";
ReefAngel.CustomLabels[4]="LeftVortech";
ReefAngel.CustomLabels[5]="TankHeater";
ReefAngel.CustomLabels[6]="RightVortech";
ReefAngel.CustomLabels[7]="";
ReefAngel.CustomLabels[8]="Radion";
ReefAngel.CustomLabels[9]="StndLight";
ReefAngel.CustomLabels[10]="";
ReefAngel.CustomLabels[11]="FugeLight";
ReefAngel.CustomLabels[12]="";
ReefAngel.CustomLabels[13]="";
ReefAngel.CustomLabels[14]="Dosing1";
ReefAngel.CustomLabels[15]="Dosing2";
ReefAngel.MoonLights( Box1_Port4 );
ReefAngel.StandardHeater( Port4 );
ReefAngel.StandardHeater( Port6 );
ReefAngel.DosingPumpRepeat1( Box1_Port7 );
ReefAngel.DosingPumpRepeat2( Box1_Port8 );
ReefAngel.Portal( "XXXXXX" );
Re: Expansion Reboots
PostPosted: Thu Aug 11, 2016 4:11 pm
by projectx
On another note, when the system comes out of water change or feeding the expansion doesnt power cycle
PostPosted: Sun Aug 28, 2016 7:24 pm
by projectx
So something else that just showed up. If port 1 the return pump port is in the on state and not in auto. the expansion does not reboot.
Any ideas?
PostPosted: Sun Sep 18, 2016 7:53 pm
Can you try removing the custom labels to see if that is affecting anything?
PostPosted: Sun Sep 18, 2016 8:00 pm
by projectx
Ill give it a shot and see. I know I had an issue with a reboot loop with some of the labels
PostPosted: Sun Sep 25, 2016 7:09 am
by projectx2
I set all of the labels to blank just "" same thing happens
Sent from my SM-G935V using Tapatalk
PostPosted: Sun Sep 25, 2016 8:33 am
Remove the reference from the code.
Even if it is commented, it is still enabled.
When you are in water change mode, go to a browser within the same network and go to http://ipaddress:2000/r99
Send me the XML data you get back.
