Help Getting started again.
PostPosted: Thu Sep 08, 2016 7:13 pm
Roberto is there a permlink to the older version? I'd send him the one I have but I can't find the archive anywhere :(
PostPosted: Thu Sep 08, 2016 7:27 pm
The MAC version seems to be 1.0.1.
PostPosted: Fri Sep 09, 2016 12:21 pm
Yeah, the old version is the one in the download page of the website. It is the 1.0.1 IDE with 1.1.3 main branch of libraries.
It appears you got the correct IDE, just mismatched settings.
The sketchbook location should be /Users/Steves-iMac/Documents/Arduino in your case.
After you change it, you must quit Arduino and open it again though. If everything is correct, next time you open Arduino, when you click the open button, you should see the RA_Preloaded and the other codes in the drop down list.
PostPosted: Fri Sep 09, 2016 2:34 pm
Ok. That seems to be better.
I'm not getting the following error...
static time_t LastATO=millis();    // For de-bounced ATO
'time_t' does not name a type
I'm getting a very vague "Error Compiling".
There is no line # or anything else.
The last line in the verbose readout is...
/Users/Steves-iMac/Documents/Arduino/libraries/Globals/Globals.h:366: warning: 'RANetStatus' defined but not used
PostPosted: Fri Sep 09, 2016 5:23 pm
Warnings are safe to ignore. If you don't want to see them, just suppress them. For some reason, the Mac version shows suppressed but you actually need to force it to show and then suppress or it will never suppress. Bug in the IDE, I guess.
Go to File->Preferences and select All and click Ok. Then go back and select none again and click ok.
That will suppress the warnings.
If it is complaining about time_t, you can use unsigned long instead, which is actually better.
PostPosted: Sun Sep 11, 2016 1:40 pm
There is no preferences under file.
It's under Arduino and there is nothing like you are talking about in those preferences.
This is that pane...
The file section has the following options...
I don't care about the warning as long as it will compile and upload properly, but it won't' do that.
I'm still getting that very vague "Error Compiling".
and it just stops.
It doesn't upload at all.
It happens on the Bluetooth or USB-TTY port connections.
PostPosted: Fri Sep 16, 2016 6:00 am
Try downgrading the libraries to the last production version would be my suggestion.
PostPosted: Fri Sep 16, 2016 11:27 am
Where do I find those again?
PostPosted: Fri Sep 16, 2016 11:34 am
One thing I notice is that your sketchbook is pointing to the wrong folder.
Try deleting the code folder in the path.
Return to My PDE/INO file
