Kirkwood's Code - Dosing/ATO Pump Timers, Icecap Backup Batt
Posted: Sun Mar 19, 2017 5:30 pm
Wanted to share my code with the community. The highlights are the dosing and ATO pump timers. I use the dosing pump timers to ensure the pumps always run correctly. The ATO timer is especially helpful. I know when the pump has run over 100 minutes that it is time to change the 5 gallon top-off reservoir. When I'm out of town for a couple weeks I use this timer to notify the neighbor to swap reservoir jugs.
I recently installed the Icecap backup battery for the Jebao PH and added code to put the PH to 0 speed instead of turning off during feeding mode and water change mode.
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port6Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port5 );
ReefAngel.DosingPumpRepeat( Port3,0,120,224 ); // dose ALK 224 seconds 12x/day
ReefAngel.DosingPumpRepeat( Port4,60,120,300 ); // dose CAL 300 seconds 12x/day
ReefAngel.StandardHeater( Port6,770,773 );
ReefAngel.StandardATO( Port7,900 );
//Start Feeding Mode at 20:30 - NONE
if ( (now()%86400==73800) ) {
ReefAngel.FeedingModeStart();
//Track ALK, CAL, and ATO dosing pumps
const byte numPumps=3;
byte pump[numPumps] = { Port3, Port4, Port7 };
byte portalMinutes[numPumps] = { 0, 2, 4 };
byte portalSeconds[numPumps] = { 1, 3, 5 };
static time_t pumpTimer[numPumps];
static boolean pumpStatus[numPumps];
static boolean atoDisabled;
for (int i=0;i< numPumps;i++) {
if (ReefAngel.Relay.Status(pump[i])) {
if (!pumpStatus[i]) {
pumpStatus[i]=true;
} else {
if (pumpStatus[i]) {
pumpStatus[i]=false;
// Normalize and assign to CustomVar for reporting on the portal
ReefAngel.CustomVar[portalMinutes[i]]=pumpTimer[i]/60; // Number of Minutes
// ReefAngel.CustomVar[portalSeconds[i]]=pumpTimer[i]%60; // Number of Seconds
static boolean clearTimer;
if (now()%SECS_PER_DAY!=SECS_PER_DAY-1) clearTimer=true;
if ( (now()%SECS_PER_DAY==SECS_PER_DAY-1) && clearTimer==true) {
// Backup timers to portal variable
ReefAngel.CustomVar[portalSeconds[0]] = pumpTimer[0]/60;
ReefAngel.CustomVar[portalSeconds[1]] = pumpTimer[1]/60;
ReefAngel.CustomVar[portalSeconds[2]] = pumpTimer[2]/60;
pumpTimer[0]=0; // Clear timer for Port3
pumpTimer[1]=0; // Clear timer for Port4
clearTimer=false;
if (bitRead(ReefAngel.Relay.RelayMaskOn, 6)==1) { // ATO relay was forced on
atoDisabled=true; // don't want to change the variable names yet.. but you may want to to make it clearer..
if (atoDisabled && (bitRead(ReefAngel.Relay.RelayMaskOn, 6)==0)) { // ATO override has been cleared
pumpTimer[2]=0; // Clear timer for ATOPort
atoDisabled=false;
ReefAngel.Relay.Set(Port5,now()%19800!=0);
//Jebao speed 0 on feeding/water change modes to prevent Icecap battery from turning on
if (ReefAngel.DisplayedMenu==FEEDING_MODE || ReefAngel.DisplayedMenu==WATERCHANGE_MODE)
ReefAngel.PWM.SetDaylight( 0 );
ReefAngel.PWM.SetActinic( 0);
else if (hour()>=7 && hour()<8)
ReefAngel.PWM.SetDaylight( LongPulseMode(40,55,10,true) ); // Long pulse hi/low 60%40% 10s pulse on sync mode
ReefAngel.PWM.SetActinic( LongPulseMode(40,55,10,false) ); // Long pulse hi/low 60%40% 10s pulse on anti-sync mode
else if (hour()>=8 && hour()<11)
ReefAngel.PWM.SetDaylight( SineMode(30,70,300,true) ); // Sine mode low/hi 40%95% on 5 minute cycle on sync mode
ReefAngel.PWM.SetActinic( SineMode(30,70,300,false) ); // Sine mode low/hi 40%95% on 5 minute cycle on anti-sync mode
else if (hour()>=11 && hour()<14)
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,80,500,true) ); // Short pulse at 60% with 200ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,80,500,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
else if (hour()>=14 && hour()<16)
ReefAngel.PWM.SetDaylight( ReefCrestMode(60,25,true) ); // ReefCrest on 50% with +/-10% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(60,25,false) ); // ReefCrest on 50% with +/-10% on sync mode
else if (hour()>=16 && hour()<18)
else if (hour()>=18 && hour()<20)
ReefAngel.PWM.SetDaylight( TidalSwellMode(70,true) ); // TidalSwell at 70% on sync mode
ReefAngel.PWM.SetActinic( TidalSwellMode(70,false) ); // TidalSwell at 70% on anti-sync mode
else if (hour()>=20 && hour()<21)
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,80,500,true) ); // TidalSwell at 70% on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,80,500,false) ); // TidalSwell at 70% on anti-sync mode
else if (hour()>=21 && hour()<23)
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,50,300,true) ); // Short pulse at 60% with 200ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,50,300,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
ReefAngel.Portal( "kirkwood" );
