Last weekend I was able to get some of the programing done with your help and have many of the functions working that I wanted. I think I am going to just try one thing at a time each weekend until I have it all together. Thank you for all the help so far.
Now I want to get the ATO and some dosing setup. Here is what I would like to end up with:
(1) float switch in the sump
(1) float switch in the ATO reservoir
(1) dosing pump
If Sump switch is not showing a high reading dose every hour for 30 sec.
If sump switch is showing high do not dose.
If reservoir switch is showing low then don't dose
If reservoir switch is showing low then show low status somewhere (Iphone app).
Is all of this possible? Will a float switch survive in a lime water mixture or will I have problems? Will be researching to try and figure it out, any help would be appreciated. I am also very open to suggestions on how to accomplish the basic idea of what I am proposing in another way if it makes more since.
Here is my current PDE file;
// Autogenerated file by RAGen (v1.1.0.127), (01/22/2012 09:53)
// RA_012212_0953.pde
#define DisplayImages
#define DateTimeSetup
#define DirectTempSensor
#define wifi
#define SIMPLE_MENU
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
// Labels for the web banner
#include <avr/pgmspace.h>
prog_char id_label[] PROGMEM = "Cruzer";
prog_char probe1_label[] PROGMEM = "Water";
prog_char probe2_label[] PROGMEM = "N/A";
prog_char probe3_label[] PROGMEM = "N/A";
prog_char relay1_label[] PROGMEM = "ATO";
prog_char relay2_label[] PROGMEM = "Light 1";
prog_char relay3_label[] PROGMEM = "Light 2";
prog_char relay4_label[] PROGMEM = "Power Head";
prog_char relay5_label[] PROGMEM = "WM2";
prog_char relay6_label[] PROGMEM = "Pump";
prog_char relay7_label[] PROGMEM = "Heater";
prog_char relay8_label[] PROGMEM = "Skimmer";
ReefAngel.FeedingModePorts = B10111001;
ReefAngel.WaterChangePorts = B10111001;
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port8);
ReefAngel.Timer[4].Start();
ReefAngel.WebBanner();
// Specific functions
ReefAngel.StandardATO(Port1);
ReefAngel.MHLights(Port3);
ReefAngel.Wavemaker1(Port4);
ReefAngel.Wavemaker2(Port5);
