Xender
PostPosted: Thu May 11, 2017 5:52 am
by Xender
Hello,
working on my ReefAngel RA Star prototype only me and Lee have (no touch screen) :
Can you help me plz?
I have Dimming module(not wired), and RANet relais (I don't have the basic relais).
Dimming module is for Meanwell Drivers eln60-48p pwm 0-10V
In the wizard what do I have to select? Can I do it for my model on the wizard? Or sould I use webwizard better?
For now I have selected :
ReefAngel Plus
Dimming PWN
Rope Leak Detector
RANet Add-On
I Would like :
Standard Light On port 1 and 2 from 8:00 AM to 11:00 PM
CO2 on port 3
Auto Top Off Port 4
Leak detect --> make OFF port 4
Heater Port 5
Always ON : Port 6 -> 8
Dimming parabola on Dimming module all channels from 8:00 AM to 11:00 PM
Radom Cloud mode on Dimming module when activated
Over Heat 29°C --> OFF Port 5
Buzzer --> Leak detected and ATO time out
Temperature : Celcius
Email notifications :
when over heat
when leak detected
when Auto Top Off ON and when stop
View on U-app + Portal
Thanks for your help !
Re: Xender
PostPosted: Thu May 11, 2017 6:34 am
by Xender
Generated by the webwizard
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
    ReefAngel.Star();
    ReefAngel.AddRANet();  // RANet Add-On Module
    ReefAngel.SetTemperatureUnit( Celsius );  // set to Celsius Temperature
    // Ports turned off when Leak is detected
    ReefAngel.LeakShutoffPorts = Port4Bit;
    InternalMemory.OverheatTemp_write( 290 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardLights( Port1,8,0,23,0 );
    ReefAngel.StandardLights( Port2,8,0,23,0 );
    ReefAngel.CO2Control( Port3,720,710 );
    ReefAngel.StandardATO( Port4,60 );
    ReefAngel.StandardHeater( T1_PROBE,Port5,750,770 );
    ReefAngel.PWM.SetChannel( 0,PWMParabola( 9,0,23,0,15,100,0 ) );
    ReefAngel.PWM.SetChannel( 1,PWMParabola( 9,0,23,0,15,100,0 ) );
    ReefAngel.PWM.SetChannel( 2,PWMParabola( 9,0,23,0,15,100,0 ) );
    ReefAngel.PWM.SetChannel( 3,PWMParabola( 9,0,23,0,15,100,0 ) );
    ReefAngel.PWM.SetChannel( 4,PWMParabola( 9,0,23,0,15,100,0 ) );
    boolean buzzer=false;
    if ( ReefAngel.isATOTimeOut() ) buzzer=true;
    ReefAngel.Network.Cloud();
// RA_STRING1=**********************
// RA_STRING2=null
// RA_STRING3=null
Re: Xender
PostPosted: Thu May 11, 2017 9:37 am
I would start with just the very basic and see if you can get Uapp to connect, because you don't have a screen to see what is going on.
Re: Xender
PostPosted: Thu May 11, 2017 11:06 am
by Xender
Hi !
thx for your help
I tried this code
RA_STRING1 is made by the web wizard, is it normal that each time it change with the same password?
Uapp is not working
IP : empty
port : empty
Username : Xender
Password : my password not encrypted
Can I try with local IP too?
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
    ReefAngel.Star();
// RA_STRING1=$$$$$$$$
// RA_STRING2=null
// RA_STRING3=null
Re: Xender
PostPosted: Thu May 11, 2017 11:16 am
Open Arduino IDE and use serial monitor to check the log.
What does it say?
Re: Xender
PostPosted: Thu May 11, 2017 11:24 am
by Xender
Ardruino won't start on mac. It's says that the file is corrupt even if trying with ctrl open
Re: Xender
PostPosted: Thu May 11, 2017 11:35 am
Use coolterm instead then.
Open serial port at 57600 baud
Re: Xender
PostPosted: Thu May 11, 2017 12:11 pm
by Xender
Made working again ardruino :
Serial :
RA Init
SPI Init
LCD Init
Network Init
Unknown Touch controller
Touch Init
SD Found: 0
192.168.1.39
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT failed
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
    ReefAngel.Star();
    //ReefAngel.AddStandardMenu();  // Add Standard Menu
    //ReefAngel.Use2014Screen();  // Let's use 2014 Screen
    ReefAngel.AddPHExpansion();  // pH Expansion Module
    ReefAngel.LeakShutoffPorts = 0;
    InternalMemory.OverheatTemp_write( 300 );
// RA_STRING2=null
// RA_STRING3=null
Re: Xender
PostPosted: Thu May 11, 2017 12:23 pm
by Xender
Don't know if there is a difference but I tryed the same PDE with WebWizard
Serie :
RA Init
SPI Init
LCD Init
Network Init
Touch Init
SD Found: 0
192.168.1.38
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT succeeded
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
    ReefAngel.Star();
// RA_STRING1=$$$$$
// RA_STRING2=null
// RA_STRING3=null
Re: Xender
PostPosted: Thu May 11, 2017 4:11 pm
The second one shows it connected to the cloud server
